Honda Odyssey: Problems & Solutions:(1995-2004 Models)
I did not understand "tpalm's" post # 1903. Did it cost $500.00 to fix the doors correctly? Can the power doors be converted to regular manual doors, in the future if an owner wants to do so to save on the repair bill??
Now I've read some posts here saying Honda USA does not honor warranties on Odysseys built in Canada. My dealer doesn't believe this to be true (he's presently double checking it) and I plan to get it in writing if this is indeed the car I get. He has said that there are some Odysseys which were made "for" the Canada then sold in the US. These are not covered by Honda USA. Those made for US delivery are covered. Could someone please comment on this.
Second when I asked about an extended warranty the dealer showed me an aftermarket warranty by a company called API, $1500 for 6 years or 100K miles. To be honest I don't trust aftermarket warranties but would still like the added coverage, I almost always own a car longer than 3 yrs or 36K. I've seen posts here regarding getting a Honda Care warranty for $895 (which I consider a much better and acceptable option) but there are close to 2000 messages here on this board alone and haven't seen one regarding how I can get this particular warranty. I guess I could push the dealer for it but want to have some recourse with regard to telling the dealer where I could actually get this warranty if he isn't willing to give it to me. Again could someone please comment.
If anyone has any other things to watch for those would also be appreciated.
Thanks for any help just trying to get all my ducks in order before signing on the dotted line
I've purchased 4 foam pads that the canoe sits on as well as 2 v-straps. One strap for the front of the canoe and one for the rear. The straps are meant to attach to the canoe and then they split off to the front left and front right and similarily to the rear left and rear right of the van.
The problem is there is no where to attach the straps to the underside of the van. The is a tow ring in the center of the van about 2 feet back from the bumper. There appears to be no attachment points on the front or rear on the left and right sides.
Does anyone have any suggestions or anyone have any experience carrying a canoe on their Ody.
Thanks in advance and sorry for the long post.
Sean
Few of the newer vans make it easy to tie off the canoe painters front or rear. I wound up putting a loop of perlon rope around a hefty bracket in the front of my engine compartment that tucks away when not in use. I do have a tie down hook in the rear of my van.
I think I'd lose the V straps and just tie off to the center tow hook in front and find something in the rear to do likewise - maybe there's a "spring shackle" in the rear suspension you can reach.
Steve
I'm sure this has been addressed but I can't find anything specific. I'm going to change out the speakers on my 2001 Odyssey EX. Can someone give me the color code key for the polarity of the wires (i.e. + and -) for the front door and rear speakers. Also, does anyone have a better method other than just cutting the wires to splice in the new speakers? Thanks!
Jim d.
speaker wire adapters from Circuit City or
Best Buy. I purchased these from Best Buy
for $5.00 a pair the name escapes me but the name was Metro........something or other. They simply plug into the factory speaker wire plug and allow you to plug the other end into any aftermarket speaker. A real time saver.
I'm in the process of replacing the speakers in our 2001 Ody EX. Had the front speakers out yesterday. During the day it rained pretty hard a few times. I noticed after work that there was water in the driver's side door cavity. Looked as if it had been sprayed with a hose. Lots of droplets all around! The passenger side was bone dry! Has anyone seen or heard of this previously? Any thoughts? Thanks!
Jim d.
1. Dumping the Van. (its brand new!)
2. Getting a new keyless entry system
3. Just dumping the entry system and use the key for the rest of its life cycle
Should I visit my dealer that sold me the car? I'm still under warranty with only 7600 miles on the odometer. The gas gauge is fine and is working. The automatic Climate control is fine and we have used the fold away seat many times. If the Dodge Grand caravan had the fold flat 3rd row seat, We would have a Dodge Grand Caravan ES in tan.
Steve
One dealer asks for $304 for service + $89 for air conditioner filter(part+labor)
Other asks for $351 for service + $51 for air conditioner filter(part+labor).
I will go to the first one and only get service done and thinking of changing the filter myself. Has anybody done it and how easy it is? Also, is there a place I can see the instruction diagram to change the filter before I buy it? Please help.
P.S. Don't you think $300+ is TOO much for service?
All of a sudden, I have noticed the transmission in our 99 Odyssey has started slipping when driving in reverse, especially on an incline. Have not noticed the famous clunking behavior, but I expect that the transmission will need to be replaced?
Any suggestions?
Thanks very much!
Car pulls left and dealer can't fix it.
Offer to realiged after 3k, at 2k now.
Other problems comes and goes.
All the doors light comes on dash battery, brake and goes off while driving.
Looks like the tranny issue is a real one.
I have a 2001 Ody with 21,000 miles. I have followed the suggested maintenance service. Just recently the van's brakes have begun to squeek on occasion. They appear to work fine and don't grab. Plus that the squeek seems only to happen after I've driven for quite a while, after an hour or so of driving.
Is this normal? Or do I have a problem I need to check out? Bulletins on this problem? Thanks.
I'll post later on build date and location.
The dealer said the aligment is within spec.
BS, I said. I can't let go the steering wheel for more than 3 seconds on the highway.
Dealer fix first time with increase tire pressure and said it was aligned.
My arm hurts from holding the van straight.
Take van back for service next week and ask for refund on extended warranty. Not keeping this van
after Wty expires
Very unhappy with Van so far for all problems.
I had starting problems also. Started on the 7 th time crank it.
Lots of minor stuff makes me mad and wish I still had trouble free 1987 Toyota Celica.( which I give away last week):(
Good things about the Van.
I had 2 babies(in car seats)and 6 adult in van with room to spare, filled with pinic stuff, BBQ, chairs Etc.
BLV (Best Looking Van)
MTTHD (Many Trips To Home Depot) with Van full for friend and family.
LOP (Lots of Power)
Skubes,
I assumed that the dealer turned your rotors because they claimed it was warped. Never let them turn the rotors unless it is really warped, it will just make the problem worse, since there's fewer rotor material (reduced stiffness) left. I figured out that over tightening of the lug nuts is the common cause of warped rotors. Do not let them use an impact wrench but insist on the use of a torque wrench (80 ft-lbs, fyi). None of our cars have had warped rotors since 1990. Good luck!
I bought my van in feb '02 and right off the parking lot it was pulling to right. I thought this is not under warranty but after week talking to sales person she told me to bring it in to get it fix.
First they told me to drive for 3500 miles to let tire even out some time new tire causes. I did that and still pulls to right. So I took it back to get it fix and dealer took hole 2 days to fix it (That what they said it!). Dealer told me that they have done alignment, rotate tire and did major work to adjust suspension subfram to get it fix. After 2 days of work car still pull to right and made problem worst then before.
I am schedule for 4th trip to dealer to get problem fix.
Any suggation or any one has this problem?
Service Manager told me to come back after 3K, SM Said
"Spring needs to adjust by themselves".
They tried to fix the first time playing with tire pressure and said it was aligned to spec.
Told service manager about subframe fix, he said he never heard of it.
Dumb [non-permissible content removed] said no such thing.
Found the TSB # 00-067. If any one needs it.
I hope it is the right one. Found it from previous list.
Good Luck!
I have an 02 EX with an April build date. No pull, no problem.
On my 2000 lx I had a shimmy at 70mph that was solved by alloy rims and michelins after the dealer put 4 new FIrestones on and it didn't make a difference.
My 2001 w/15k has the same problem of squeaky brakes when I am in reverse - very anoying. Have you heard - can the dealer fix this problem? I am ready to take it in, but won't unless they can fix the problem. The bakes don't squeak going forward.
BTW, do you have squeaky rear vent motors? Mine squeaks when you close them. Honda has not made a fix for it, which is really aggravating.
