Visitor Agreement.
"Change the transmission fluid every 15,000 miles screw the owner's manual"
Did he mean change 3 qts of transmission fluid or completely flush the transmission fluid which is about 8 qts?
bjk
I hope it works out for those with tranny problems. Isn't there a lemon law that says the manufacturer has to buy the car back after so many chances to fix a recurring problem?
The 1st failure (banging while backing-up) occured at 3200 miles and was repaired. It was almost 2 years later that I had the 2nd and 3rd failures (4 hours apart) while out of town on vacation - this is the reason I haven't been back to the dealer about it until this 3rd failure.
Have the tranny problems associated with '99 and '00 models been resolved with the '01, '02 and/or '03 models? If anyone has insight into the current status of Honda transmission, please post it. Thanx
Have the tranny problems associated with '99 and '00 models been resolved with the '01, '02 and/or '03 models? If anyone has insight into the current status of Honda transmissions, please post it. Thanx
I have a 99 with over 60K miles that still runs like new. The only thing I have replaced are front brakes and tires. I get about 20.5 MPG with about equal city and Interstate driving on my daily commute. I get about 24 MPG on all Interstate at 80- 85.
I have been looking at the lemon laws here in TN. They seem to pertain to problems only within the first 1 year. Although I only have 20k miles on the car, I have owned it 2 years 8 months. Most driving prior to my June vacation had been relatively short trips within the city, approx 6k miles/year.
Thanks for responding.
Several days before that there had been a barely noticeable whine/hum coming from the engine area, only at highway speeds and only with the transmission in D4(not in neutral). After conferring long distance with my home town dealer, they said the van should make it home OK and they'd look at it when I got back. As a precaution, I had a dealership in SLC look at it. They confirmed the noise and agreed it should make it back home (another 2000 miles).
Sometimes my shifter is hard to get out of park. As I try, it feels like it's sorta stuck and it squeaks as I'm moving it. Other times the shifter will slide very easily out of park. I also hear a pop in the steering colmn as I take out the key sometimes. I think it's related to this. The hard shift seems to happen about every other trip. I always put the van in neutral then apply the parking brake then take my foot off the brake before I shut down. My dealer service once lubed something in the steering column, but now they refuse to even recognize the problem still exists. Any one have/had anything similar or have any ideas what it could be? Thanks.
Anybody?
I am seriously thinking about looking into trading in for a 2002 EX with the entertainment system.
I've found that with my Affinity's even though there is plenty of tread left the wet traction is almost non exisitent, so long tread life may not be as important as wet traction if it rains a lot where you live.
Check out Honda Odussey Thread (Van Board), I posted Michelin Tire comparison from Michelin Website. X-one is best.
gess:
X-one has better wet traction than Rainforce MX4
regards,
Bjk
Steve
Any thoughts?
Dave
Sorry to hear about your cracked molding, I didn't have any problem to put mudguards on my 01 EX. It was my first time ever done it.
Why don't you call your local dealer to see if they will honor the part warranty? Or eles try the out of state dealer you ordered it from.
Good luck,
Bjk
This doesn't sound like a defective part, it unfortunately sounds like something you accidently broke.
If the dealer agrees to replace something you broke and cover it under warranty, consider it a gift.
I believe this is an indication that the electronic pads are poorly designed and Honda is aware of the problem.
I have a theory and would appreciate any feedback. I believe rain water is causing damage to the electronic pads. Each time I have had problems with my doors it was during a heavy rain. I opened the door to get my child out, which took about a minute, and when I closed the door it went part way and stopped. I believe if enough moisture gets on these pads they short out or something. Am I way off in left field on this?
Honda said they would pay for the parts. The labor to put the parts in will cost me $300. I am not happy. I think they should do a complete recall on these pads.
I told this to the service manager, he pulled up my records and sure enough there it was. He then tells me that because they couldn't duplicate the problem at the time it wasn't technically broken.
I quess as far as Honda is concerned the sliding doors not working properly is ok. They don't have to work all the time. Just most of the time. The only way for the doors to be fixed under warranty is if they completely fail.
What a joke.
Of course they have a service bulletin out on the electronic pads.
Come on Honda. You know there is a problem with these electronic pads. Honda you really should consider a recall on these pads. Let me tell you why. When these pads fail they generally fail when the door is open. The only way to close the door is manually. And these doors are not designed to close manually. It is very difficult to get the door completely closed doing it manually. Somebody eventually is going to get in a wreck with a door that isn't closed properly because the pad failed, and somebody's child is going to get killed. Think about it.
I still believe they need to do a recall.
And yes it could have cost me more money. But to me that's not the point. I believe Honda should have designed doors to work longer than 50,000 miles. Don't you? I mean the sliding doors are kind of important since it is the only practical way to get to the rear seats.
Being covered under warranty was the good news. The service manager mentioned that Honda is now holding all replacement tranny's until they figure out why the bearing is defective. He couldn't give me time frame of when a replacement would be in (bad news). He of course assured me that it is safe to drive - although he said the sound would probably get worse and I would start to see an oil leak.
Of course I already sense that it is making the sound more frequently and louder than when I took it in. Hopefully Honda will address this issue quickly.
Did he give you the service bulletin number?
bjk
He didn't give me the bulletin number and I just grabbed my service invoice and it has no mention of the number either. To be specific on the problem - it is a faulty differential carrier bearing.
jmg
Mmm, my 01 EX has the same 4 speed tranny as your 00. I have almost 15k on it, I don't have any problem yet. Not sure how extensive problem is this faulty differential carrier bearing affected? I better keep my eyes on mine!
bjk
It sounded like the service tech was just as amazed by this as I was at hearing the message. I will let everyone know how the replacement works. BTW the dealership said Honda would cover a rental for the day while they make the switch.
jmg
My 99EX got 65k miles on the original tires before they had to be replaced.
Has this happened to anyone else? Do you have any suggestions to fix it?
Thank you in advance for your advise.
