Honda Odyssey: Problems & Solutions:(1995-2004 Models)
Steve
Chris
bjk2001 I have a colleague who is relo'ing to California and told her I would check on this for her.
Twice now after sitting in our garage and not being driven for ~5-6 days the van is completely dead. The first time it happened I thought we may have left on one of the interior lights however the second time this was not the case. It is winter in Chicago but this should not be happening. I have other cars that I don't drive for the same period and they are fine.
I am taking it into Honda on Monday so they can do a diagnostic. The mechanic said they would check the power system to see if there any parasitic drains beyond the usual. I do the factory installed NAV system but not the after market DVD yet.
Anyone encounter this problem? It doesn't seem to be a bad alternator as the battery light is not staying on...
The Ody is only 2 months old so this is frustrating because it is the wife's transportation.
BTW I mentioned the doors and maybe an electronic problem there. He said he didn't think so as Honda addressed the part problems they were experiencing with the electronic doors in their 2003 models.
taste
Thanks grandtotal..
in any weather.My 2003 has a thud anything
below 32 deg.
My 2000 LX Didn't pull either way but it always
had a shimmy,michelins helped a little.
My 2003EX pulls to the left,no shimmy.
I really think the 2003EX is a much
better car overall.
With the major problems that I have had with my 2000 Odyssey - I have cancelled my order for a new Honda Pilot that I planned on buying. My Odyssey has 110,000 miles on it. I have never missed an oil change, tune up, or any required maintenance that Honda recommends. ( I just spent over $1500 on the 105,000 mile maintenance - as Honda recommends.
Anyone else had the problems that I have had? Any recommendations?
Of course on re-reading this - it may not work for average Ody driver - I'm 6'5", so access to the top of the door really isn't issue for me.
I've done it myself, but no longer have the shop manual that describes the procedure. It took about a half hour to do. I'm sure the dealer will charge a flat rate 1 hr. Maybe not. The bulb costs less than a $1 as I remember.
steve_ Dec 11, 2002 11:32pm
1. Is this a reasonable charge?
2. Why isn't this covered under warranty? They say it is "normal wear and tear for the Ody."
3. I am not an aggressive driver. Is this indeed "normal."
Thanks....
scottr513 Oct 11, 2002 8:21pm
Honing (or "resurfacing", "turning") brake rotors is pretty typical anymore when pads are replaced. 29,000 is a bit early for wear, but not unheard of. MVs are hard on front brakes and tires anyway.
Minivans are hard on brakes. Brake wear can be all over the place so all experiences are different.
As for driving aggressively, I think that aggressive drivers may actually use up their brakes SLOWER seeing as we...er they...tend to use them less often than cautious drivers ;-)
Steve
Now it is really starting to bug me. I have heard that this symptom is consistent with CV joint problems. After I drive 2-3 miles and make another turn I don't notice any problems. Called dealer to check and they said I need to make apt and since out of warranty they charge $79/hr to diagnose. Anyone else come across this ?
Thx
2004 Honda Accord EX-L Graphite Pearl
2007 Honda Civic EX - Atomic Blue
2013 Honda Civic LX - Crimson Pearl
Next is in regards the sound of the brakes. Same question as above in regards the brakes.
After all Consumer Reports claim the Ody to be very RELIABLE.
I did a small test which shift from Park -> Reverse -> Neutral -> Reverse -> Neutral -> Reverse -> Park. The result is normal shifting, i.e., no noise. However, clank noise is repeatable if shift from Drive -> Neutral -> Reverse.
Anyone have this problem? Your insight is greatly appreciated.
As for Ody having above average reliability by Consumer Reports, I hope you're right. Last time I checked it was only average, same as Chrysler. Sienna was only van above average, but its other features (size, styling, third row "magic" seat, etc.)made Ody (in my opinion) a better value, especially if you negotiate a discount. Good luck.
In spite of the comprehensive work done on the brakes, I still hear a squeeking at slow stops. It's really kinda weird--the squeeking doesn't happen in the first half hour or so of driving. It seems to start happening only after some time of driving and ONLY when I come to a SLOW stop. On the other hand, if I have to apply the brakes more suddenly, some might say more normally, the braking doesn't feel normal and certainly doesn't feel like it did when I first bought the van. The best I can describe this braking is a kind of "catching," or "unevenness." The van rattles a bit at a certain point in the braking--a sorta shutter.
Am I making any sense at all? Before I take the van back in, does anyone have any advice how I might better explain this to the dealer? Or what the problem might be? I am confident, of course, that the van will perform beautifully, with none of these problems when I take it in. Thanks in advance.
I don't know if there was a TSB. All I know is that the service manager called me without even looking at the car and offered to do it under warranty.
Anyway. My situation is that now three out of four of the switches that turn on the inside lights when you open the doors are faulty. The front passenger and both rear doors. When you open those doors the lights don't come on. If you give the switches a light push the lights do work. Seem to be sticking. Anyone else experience this? If so what is the remedy?
Tires. Will need to think about replacing them soon (31k miles). What are people getting?
Jim d.
As far as tires - Michelin X-1's are more responsive and quieter than the original Michelin Symmetry tires - they're a bit pricey >$100, think COstco/Sams sell s a similar tire but don't remember name. Bridgestone Turanza (sp?) also well regarded tire. Both tires are much better than stock Firstone Affinitys that come on LX model
