Oil changes are are every 10,000 miles and one must use the one of the 3 'approved' lubricants that are available in North America.
Clutch is not a problem with 'normal' driving. In fact, It should last LONGER than with a gas engine because the gobs of low end torque eliminates the need to use the throttle while starting off from a standstill. (One rarely has to 'slip' the clutch for any reason.) The only time I have seen complaints about the TDI clutch is on a MODIFIED engine that is producing so much torque that the clutch cannot handle it.
A/C odor is not a TDI-only occourance. Virtually ANY vehicle that is operated under the conditions that allows mold to grow on the AC-coils will have this occur. The 'solution' is simple, turn off the AC and allow the coil to dry-off by blowing air thru it.
If those are your only 3 concerns... by all means, get a TDI ASAP and start getting over 52MPG. On the highway, you should realize more like 55-57 MPG. (with proper driving technique.)
I am getting over 50MPG with country driving. (40-50 MPH on country roads)
The minimum CZ (cetane rating) for the ALH engine is 49.
(Technical data, Engine data, pg 00-2, VW Golf, GTI, Jetta 1999-2003, Jetta Wagon 2001-2003, 1.9 Liter 4 cyl 2V TDI...CD Bentley)
It would be worth a check in the state or states that you buy diesel/operate to see what is the minimum product delivered standard. With that information, you can decide if the extra cost and performance of fuel additives, you wish to use/not using a cetane boost and or other additives makes sense or not.
CA is "supposed" to be 45. I have read that the minimum legal standard for #1 and #2 diesel in other states is 40. #2 diesel, as you know is the commodity of choice.
So by behavior I am ok with 45 cetane (CA) vs the standard of 49. I use Primrose 405 and frankly can not tell a performance difference either in SOTP feeling or mileage numbers While it says it boosts the cetane numbers 3/4 points (.93 oz to 14.5 gal or 1-2000 dilution rate) I use it for the lubricity and emulsification of H2O. (no real seat of the pants feeling)
But now, the heart murmer has come back after filling up at a station here at home-one I have filled up here before with no problems. I threw some PS (white bottle) in it, and it did not take care of it. Of course, it only boosts it 4 numbers, and so I am wondering if I need to put some of the grey in to boost it some more. Or should I look for other issues?
So, I was wondering if the poor fuel issue will create these problems, or do I look for something else? Mileage is coming up to 40K, and so I was wondering if I need to look at the timing belt. Sure could use some feedback.
Timing belt issues are varied. The 2003 VW Jetta TDI has the "new belt" and is good to go in the 100,000 k range. I know for certain that lower year model's sit around 80,000 k. I have also read in passing that if you have automatic that the interval is even less. So I would consult either the dealer or the technical manual for the year's specific model.
I am new to diesel engines. This is the first time I have had a symptom of a problem. I just do not want to have it go further and develop a larger problem. If I drain the filter, will the problem go away? Providing the problem is not the timing belt.
My beetle is 2001, and so it has the 50 to 60K timing belt. At least that is what I was told. Since I got my beetle used, I only have half the warrantee-up to 50K miles.
This morning, the car started up the same way. Warmed up, the car runs very well.
I will take it in this week and have a complete check up done on it-including checking the belt. Tune up time anyways. Any other feedback?
I'm getting ready to jump on the wagon
Is it good idea to go Jetta Wagon TDI in Alberta, Canada. Car won't be in the garage, so how is it for starting and initial heating? Is there such thing like car plug for a TDI? I'd appreciate some input from people living in the Canada or American states with similar climate. Also, how does it handle snow/ice? Would ESP be a god idea or just a gimmick?
Another question is what kind of deals are we getting in Canada these days? Are dealers willing to talk about prices or everybody is paying a sticker?
And finally, is 2004 model worth waiting for?
TIA
kid
There is a heater you can buy I believe, and it will help you as far as getting heat ASAP when you start up. The TDI does take a few minutes longer than most cars to warm up fully, but the heated seats really help with that.
ESP is a pretty good option, not just a gimmick, but I guess it all depends on how much you trust your driving ability. I know I can do without it.
Can't really help you with the Canada part, but I would suggest waiting for the 2004 model if you are not in a rush to buy. VW will be putting a new TDI engine for 2004, with 100 hp instead of 90. It is supposed to be much smoother though, and it might (don't know for sure) get a bit better mileage.
Good luck with your purchase, if you have more questions, I would suggest you check out the site in my profile (it is THE source for TDI owners).
Do-it-yourself
http://members.porchlight.ca/benad/zerostart.htm
-or-ready-to-go-kit
http://www.tdiheater.com/
I will be leaving on a 1,200 mile trip over the next 2 weeks... I look forward to enjoying fantastic MPG. I am shooting for over 650 miles per fillup. (Gee... that would be only 2 tanks of fuel for the entire trip 8-))
Fuel cost per mile is between 3-4 cents!!!!
That for me is truly one of the major advantages to the TDI ! Not only is diesel fuel cheaper and less resource intense to bring to market, but per gal it give much better mileage. On a Jetta 1.8/TDI EPA ratings are between 24/31, 42/49 respectively or 18 mpg MORE.
I get between 44-46 mpg with the A/C running and three persons in the car with app 200# of luggage @ XXX digit cruising speed. I think you would probably get more like 700 and up per tank!! In any case, I hope you enjoy your trip !!!
Actually, the 5000 mile service was just completed so my TDI is still breaking in. It can only get better as the engine loosens up.
I wonder why when Consumer Reports tested the TDI... they only got 37MPG??? I could get that if I stayed in 3d gear.
Just curious, what TDI oil are/did you go with? While I can't tell a seat of the pants difference, I went with Delvac 1 5w-40.
For $50, it was not a bad deal to have the dealership look over the vehicle and for me to become aquainted with them.
Certainly the "Mobil Delvac1 5-40" is perhaps the best lubricant available for the TDI... I may go with that later.
The "Shell Rotilla 5-40 synthetic" is also a good oil. (and available at WallMart by the gallon.)
There ate not many lubricants available in NorthAmerica that meet the VW505.1 spec
Care to comment for me? thanks
First the bad news, if you have EVER stripped down an engine that has been routinely serviced through the conventional gravity fed oil drain plug, that actually had sludge in it, 2 things become VERY clear:
1. not ALL oil is drained 2. that if the gravity drain were truly able to remove sludge why is it there!!?
With the TDI model's requirement for synthetic oil, synthetic has FAR greater resistance to sludge formation than conventional oil.
(Just this one point alone would be a reason for me to go to synthetic oil) I have been using Mobil One 5W-30 for over 660k miles AND have seen both valve covers and oil pans removed. The usual comments of most of the Toyota Landcruiser mechanics is that the innards are clean as a whistle and the parts show little or NO wear. For the TDI I am using Mobil Delvac 1 5w-40. There are other EXCELLENT oils but for me it was a no brainer to use the other Mobil product. Off topic but I am also seriously considering using Delvac 1 on ALL my vehicles in that the Delvac conforms to both the latest diesel specs and SL and SJ gasser requirements. The ability to stock less products and less product is tempting.
As you probably are aware, MB and more germane, VW OEM actually specifies a model # evacuation tool for oil changes!!
The evacuation tool actually is not only faster (took me all of 10 mins to do the oil change and app 5 min were spent marveling at how fast the oil change went.) and less messy but one does not have to JACK the car up to change the oil. Also the TDI seems to have app 7-10 screws bolts that have to be undone to access the oil drain plug. Combined with the fact that the oil filter canister is to the right of the dip stick (must remove the top engine cover) makes topside access almost a no brainer.
While I don't want to get too technical, Toyota and Corvette for example, specific a minimum 15 min DRAIN time! VW seems to be silent on this issue, but given the design and oil viscosity I would guess it is about the same.
There are many units on the market but two stand out, 1. Pella 6000 (?) 2. Mity Vac
I chose the Mity Vac hand pump (activation) 45 dollars or so.(1.7G capacity) There are models that are electric and air driven also (naturally more money) and have more volume capacity...
You might do a search for one or both models and it will give you dealers that carry these products. I got mine from The Tool Warehouse in NJ.
If I can answer other questions that come up, just fire away.
also: http://www.liquivac.com
It is a manual pump, you pressurize it by pumping the arm about 40-50 times, stick the tube into the oil pan, and release the pressure. Pumping it is very similar to using a super-soaker water gun.
Thanks once again,
Jason
Draining the water from the filter is really very easy! It is the encumberances that are a bit a PITA. There is a plastic twist drain plug on the bottom. All that needs being done is to untwist it and drain 3-5 oz of fuel, then re tighten. In my case there was NO H20 in the fuel. The technical data says to reprime with diesel fuel, but I didn't and it started just fine.
The conversion if I did my math correctly = .02641720 gal x 128 oz per gal = 3.3814016 oz.
If you are installing a NEW filter it says to fill with diesel fuel.
Either way, you can't hurt anything by letting out too much, its just easier to let out a little (you dont have to worry about where to dump it). I guess what I am saying is that I am making a pointless argument. ;-)
I have the local distributor deliver BP Supreme to my farm which is really handy because the closest station with Supreme isn't in the most convenient location. I have had circumstances where I've had to fill-up at truck-stops and such, and I can tell the difference immediately. BP Supreme is a low-sulphur (30ppm I think) and high cetane fuel. I don't run any additives when I'm using BP Supreme, although it does get treated with anti-gel in the winter. MPG stays the same regardless of what fuel I run, I just like to run the supreme for environmental and engine smoothness reasons.
My diesel pickups and tractors get the same supreme fuel. Costs me about $.08/gallon more than plain old truck-stop crud. FWIW, my Dodge Cummins doesn't seem to care whether I run plain diesel or Supreme. Pulls the same, runs the same, etc. I've never gotten smoke out of this new Cummins (2003 HO) even with a 16,000# load and wide-open throttle.
All I know is that these cars run best the higher the cetane level in the fuel. And I would pay the difference.
The 2003 VW Jetta TDI technical data specifies the TDI or AHL engine at 49 CZ cetane.
First of all, diesel #2 fuel is legally mandated to be delivered at the pump with a min of 40 CZ cetane rating in 49/50 states. Given fungibility issues, it would almost be RARE to find a distributor that somehow delivered better than that.
CA diesel #2 diesel is legally mandated to be delivered at the pump with a min of 45 CZ cetane.
So for better or worse in 49/50 states 40 CZ cetane is probably as good as it gets. In fact, to boost the cetane can be done easily with the cetane boosting product of your choice. (P/S can do a 3 and 6 point boost (cost: 3 cents per gal and 6 cents per gal respectively) depending on self administered dilution). So by using cetane booster you are already doing the correct "corrective" action. So if you see a supplier vendor that offers 43 and or 46 CZ at the price of 3/6 cents or less, they are doing it cheaper than DIY, and it would make economic sense. If not, DIY, which I got from your post, you are already doing.
The official VW OEM position is: there is no requirement to run fuel additives.
Current corner store #2 diesel is 1.64. On interstates or major truck highways it is app 1.39. Again CA #2 diesel @ 45 CZ cetane.
About 2 mo ago on the eastern seaboard (RI) #2 diesel corner store was 1.99.
Bellaisola, I looked high and low for a used TDI when I bought mine; and really came up with only two or three. I believe one was a 2001, auto, with 70K miles they were asking 10K for...the other was a 2000, 5-speed, 98000 miles for I think 8K (it has been a while). The price you have seems kind of high...All together (with tax, title, prep, etc.), I paid about 19K out the door for my new (2003) 5-speed...and it has more "stuff" than the older models.
By the way, Ruking....thanks for all the help and advice...it is greatly appreciated.
Jason
AS for the timing belt, if it's an automatic, the '00 would have a 40k mile timing belt. If it's not been changed, that can be expensive (and down right fraud by some dealers). A five-speed is good for 80k miles.
The VW service Manager said sysnthetic oil every 5,000 miles and a timing belt change every 40000 miles.
However, I have heard from others first oil change at 5,000 then every 10,000 miles and timing belt at 100,000
What does the manual say ?
Thinking back about it, it would seem to me a product like simple green would work just as well. I have never had a problem with simple green on plastic or silicon seals.
Oils that meet the VW spec for the TDI will not "gunk" like dino-oils will.
only SAE 5W-40 should be used.... you choose which one;
Mobil Delavac1
Shell Rotella synthetic
dealer-supplied Castrol SYNTEC
If you are concerned about leaving metal shavings and other nasties in the pan.... YES! you will be doing that by using a sucker to remove the oil from the dipstick tube.
Removing the drainplug on a level surface allowing plenty of time for drippage is most effective at removing all of the nasties from the pan. Allowing 20-30 minutes of draintime is not uncommon. (ALWAYS DRAIN OIL FROM A HOT ENGINE TO GET ALL OF THE NASTIES IN SUSPENSION!!)
I have two Landcruisers, that as soon as you turn off the ignition and raise the hood (1-2 min max) you can wipe the dipstick, reinsert and pull out again for an accurate measure. max/add, middle area, you are OK! and the difference between max and add is ta dah: 1 quart!! You can also take this measurement overnight and it is still the same. Not exactly rocket science and pretty clear!
On my other two vehicles, Corvette Z06 and the VW Jetta TDI seem to want to elevate this TO rocket science !!!
If you have read the oil level measuring procedure, for both vehicles you will know over time you can get different measures!!??? But the OEM does not give you a range of time!! The most germane point for the hot oil extraction in the TDI, is that of you let the car cool for say an hour or more you are actually draining from a larger pool!!! And if you let it drain longer, even more also. So in fact if you drain it while it is hot you are actually leaving a lot of oil in the vehicle which negates all the "nastys" being held in suspension. (in the TDI, overnight as much as 1/2 quart)
The owners manual for the TDI says specifically not to take an overnight reading because it will not be "accurate". By process of elimination, this means that MORE oil will hit the gravity sump rendering the measurement "overfilled"
For fuels available in NorthAmerica.... a cetane booster will help. (except perhaps in Texas, where I understand that the cetane at the pumps is higher by law.)
FWIW... Since briand new, My TDI has been getting between 4-6 oz of the GREY BOTTLE (PowerService Diesel Kleen + Cetane boost)avaialable at wallmart. (the WHITE BOTTLE is for winter use.)
Horsepower * 5252
Torque = -----------------
RPM
TORQUE is the actual measurement that is take from an engine or the drive wheels. The HORSEPOWER is derived by applying the above formula.
Instead of suggesting that you take a basic physics course or ask any HighSchool kid ;-) ... I am providing the following link that explains it all.
http://zhome.com/ZCMnL/tech/torqueHP.htm
On your electrical bill, you pay for power.
But if you want to do things with electricity you need Voltage. The power is in KiloWatts.
1 HP = around 720 watts, or 0.72 KiloWatts..
If you understand electricity, then the analogy is that TORQUE == VOLTAGE, RPM == CURRENT, and HP == KiloWatts
Computationally, F=mA (force = mass x acceleration).
Thus, acceleration = FORCE over MASS. and the force comes from the TORQUE at the drive wheel divided by the RADIUS of the drive wheel (with the radius of the wheel being the length of the LEVER technically)
POWER = TORQUE X REVS (times a constant)
Power measures how rapidly you are transfering energy.
Larger engines (and European engines) develop power with high torque at mid-speed or lower.
Smaller engines (especially Japanese) develop power with LOW TORQUE at HIGH REVs. In theory, this is the same power, except you can't use it.
The problem is that you hit peak power at the red-line, and then have to shift, dropping revs below the high torque and power speed.
That's why the high performance Civic, rated at higher power, is not as fast at 0-60 MPH as a 1.8T VW Golf, even though the Golf weighs a couple of hundred pounds more.
German cars make power at useful revs compared to Japanese cars, and that's why 200 German HP are worth about 300 Japanese HP in the real world.
(here come the flames already)
