Honda Odyssey: Problems & Solutions:(1995-2004 Models)
"Working with the ABS sensors and the electronic control unit (ECU), TCS monitors front-wheel slippage. If detected, TCS activates one or more brake calipers to slow the spinning wheel to regain traction. TCS can also help maintain stability when starting out on surfaces with split coefficients of friction."
For what its worth, changing front disc pads is pretty darn easy. You can order the pads from Handa-accessories.com for about 35 bucks and do them yourself in about an hour. Takes some of the sting out of changing them so often.
Good article on this Edmunds site:
http://www.edmunds.com/ownership/safety/articles/46352/article.ht- - ml
but seeing how TC works at slow or start up speeds, do you think it has much to do with brake wear?
who knows? how much low speed icy or wet conditions do you encounter? do you floor the gas off the line (ie induce wheel spin)?
and further, when the next yr ODY comes out with some form of Vehicle Stability Control (VSC), the form that senses vehicle yaw rate and modulates braking at specific wheels to assist in under- and over-stear and coerce a corner of the vehicle to help matters, there will be another potential contributor to consider.
one has to imagine these technologies contribute in some way to wear.
proponents of the technology will point out it's better to replace pads, than loose control of the vehicle and thus loose something much more valuable...
Dealer Svc Writer came back and said my RF rotor had "heat spots" and surface fractures...$525.
WHAT??---just had the Oddy in for brake inspection in 6/03 and "everything was fine". Svc Writer said that 6 months is a "long time" in auto wear and tear. AND "driving thru rain or a puddle of water" while the rotors were hot could cause this problem." I've had hard working 1 ton flatbeds that never had this happen...so I smelled some bull****.
So I said that it was amazing that a rotor...not both...could have that type of damage. And that I felt it was a defective part and Honda sould meet me part way on the cost...he agreed to reduce it to $380.
Lucky for me, I had to do the service another day and didn't allow the Dealer to do it. So, just for the heck of it...took the Oddy to a brake shop for an estimate. This time I was able to see the rotors myself, with the mechanic...SURPRISE...rotors are fine! Only need pads...$125.
I've seen this "rain ruins oddy rotors" post on this and other oddy message boards...so beware Oddy Lovers...double check your Oddy with another mechanice before believing the dealer's mechanic.
To me this action by the dealer mechanic was STUPID...why be caught for fraud and p**soff a loyal customer?
HONDA...are you listening????
Possible culprits I've thought of:
- tires unbalanced
- tires under/over inflated
- suspension/struts
- my imagination :-)
Finally the mechanic replaced all of the pads, for free, with new ceramic pads. The only time I get a squeak is after I have been driving for a while without touching the brakes. I figure it is the rock salt dust building up. I get a squeak the first time I touch the brakes, and then nothing. Nice and quiet.
Am I the first one to experience this?
Just curious.
Patrick
On the day after taking delivery, when the whole family was in the car on their first drive, my wife pointed out the shudder/vibration. You notice it on smooth roads, not when the road surface is rough. Goes away if we keep varying speeds. Comes back if I hold speed constant at 59 ~ 60 mph or even as much as 65 mph.
I mentioned it to the salesman when he called today to see how we were doing. He sounded like he wants to help get it resolved and he is going to have a technician look at it.
Does anyone have suggestions on what this might be and how to handle this so we get it fixed right before it gets too long in the tooth? Other than this, we absolutely LOVE the car! Thanks.
If I increase speed to 65 and hold it steady there, it shows up.
Thanks for the tip. I will try switching to neutral to see what happens.
Current Ody: 98 messages/month
Old Sienna: 69 messages/month
New Sienna: 62 messages/month
I just took the total number of messages for each topic and divided it over the reporting period (I cut off the old Sienna at 5/03 where the new Sienna started getting "problems" reported). I also added the "transmission problems" section for the Ody to the general problems topic to get a total number of messages reported for the Ody.
Ya'll have fun with it.
Honda hooked me with an 1988 Accord LX 5spd I bought new. I put 437,000 miles on the car before I donated it to a youth group. It still ran great - didn't burn any oil and started at -30F. The condenser did need replacing and the scissors lift went out in the driver's door at ~430,000 - that was one well built vehicle!!!
I noticed a long time ago that the Honda newsgroups had many more posts than the other ones (Toyota, Mazda, etc.)
Just my opinion.
Tom
Brakes? I am at 30k, and when I put on the snows in December, I had plenty of pad left all around (might make it to 50k or more...).
Traction control does indeed use the front brakes. Remember that they are not just trying to slow the vehicle, but also fight engine torque. It has got to be hard on them if you engage the TC system often.
Steve
Vibration is most likely due to tire balance or out of round. If you get vibration without braking, then it is not caused by the brakes.
Currently at 71K miles; second set of tires (I replaced the Firestone Affinities early) - Michellin X radials.
Can anyone give me some feedback on what may happen in turms of harming my vehilce.
So what did she experience when she turned it off? If she wasn't spinning wheels, probably nothing at all!! If she was spinning a single tire, she might indeed have gotten more engine output (no engine control intervention), but probably much less grip to the road. If she was spinning both, then she might have gotten a slight benefit with the system off, but more danger of sliding sideways and off the road. Under normal conditions, I would advise her to leave the system alone and let it do it's thing. But turning it off should do no harm to the vehicle.
Steve
Honda reccomends 105,000 miles on them. If it snaps, you will, at the least, be stranded somewhere. It could also severly damage your engine.
Wanna take a chance?
Any thoughts anyone?
I was wondering if anyone could help me with this one. I have a 2000 EX Odyssey and every once in a while, I hear a siren like sound. It is the strangest sound I've ever heard and it sounds as if there was a police siren next to you. It seems random but we have noticed it several times after starting to move from a stopping position. It also happens while driving on the freeway.
Does anyone have any idea what this could be? It is so random that I can't even pinpoint where it is coming from.
Mike
Does anyone know how to fix the clock light on an EX 2000? The Cruise light on the cruise button (not the dash) also went out so I was wondering if there was a magic fuse controlling the clock and cruise light? If not, any ideas on how to replace the light for the clock would be appreciated.
Mike
