Cute Cavalier covers your needs (New Haven Register)
I have a very short commute, so I am not in a hurry to get an XM radio even hough I think it would be cool to have. I would not get my moneys worth out of it now.
However, if I had an hour or more commute sitting traffic 5 days a week, like many thousands of people do, I would get an XM radio right away. Same if I either drove my car around town all day or did long distance driving on a regular basis.
If I ever start to take long road trips on weekends or whenever, I will still eventually get the XM or buy a car with it already in from the factory.
As far as the cost, as others have said, it's a better deal at under $10 per month than buying a single CD at $12-18 each. If you don't buy CDs and XM does not interest you, while AM and FM suit you just fine, then that's fine. Not everyone will want XM.
"but you can buy almost any CD used for under $10 on amazon.com,for example I just bought 3rd Eye Blind's new cd for $4.50,people buy cds record their favorite songs then sell them cheap. Also file sharing sites like winmx allow you to download almost any song-free!Kenwood has just come out with a car audio system [saw it in Crutchfield's catalog] that lets you download up to 5000 of your favorite songs[if you have that many]using your computer."
Now, I just get in the car, turn on the XM and listen. No planning on which CD's I want to bring or buy or copy. No MP3's to download, no muss, no fuss just great programming.
I used to buy 2-3 new CD's a month before XM. Since June 02 when my unit was installed, I've not bought another CD. I'm saving money (on CD's), and I'm saving time (managing them)and the XM programming is far better than I can select myself.
I hear songs daily on XM that I haven't heard for years (and would consequently never think to load in my CD player).
Which AM/FM/CD/MP3 do you tune to for the comedy channel without XM?
With all the consolidation in the traditional AM/FM radio stations over the last few years, one could argue that over the next few years the traditional AM/FM radio stations will slowly but steadily loose listeners to satellite radio providers.
This means their ratings drop thereby causing an increase in the already obnoxious amount of advertising they must run thereby continuing to chase away more and more listeners (probably to satellite radio).
I used to do the DL and burn thing, but after a while you get used to the song order, but with XM like said above I gt in and listen. I don't have to waste time downloading and burning, or going to the store and buying, or ordering from Amazon and get a good deal on a CD but then get taken for the S&H. All in all the best bang for the buck points one way UP to the XM's Rock and Roll satellites!!
get a response yet. I bought an '03 Pathfinder about five months ago that was "satellite ready"
(supposedly the radios in the entire line of Pathfinders are "satellite ready"), but have not been able to get Nissan to do the modification, and I'm not even sure they know what to do. Has anyone else had this problem with Nissan regarding this problem? I have been told by one car radio shop that a tuner can be added that will give me the full digital-quality reception, and another shop said my only option was an FM modulator that will limit sound quality to that of the FM radio to which it is installed. I welcome any comments.
Delphi is however making an XM compatible aftermarket head unit, but I don't know what system it will interface with. Hopefully it will allow the use of a permanent mount antenna.
I will probably still get the Sky Fi unit for home and boom box use, but really wish they had a permanent mount antenna because even w/o the flush mount receiver cradle it's about the best system I have seen, I'm not willing to remove the antenna every time I go through a car wash. Maybe someone will come up with an adapter that will allow a standard antenna to work with Sky Fi.
Must admit, going the FM modulator route takes some strong mental adjustment with me...I have owned two different CD changer FM mod units dating from the early '90's, in a couple of S10 Blazers. One was a Pioneer; the other an Alpine. In both cases, I felt the modulator-transmitted CD sound was lifeless and inferior, even when compared to a good FM radio station (I noticed oldsman01 said the same thing in one of the earliest posts here). One problem was that the modulated signal was weak relative to the normal FM signal, so I would have to turn up the volume to listen to the CD's. The result would be hiss thru the radio. The modulator could be adjusted to provide a stronger signal (though still weaker than normal FM even at maximum) but the resulting distortion was unacceptable.
If I decide to install the XM setup (keeping the stock radio) I will keep my fingers crossed! Oldsman1's comment notwithstanding- -I am hoping the modulator techology used with the XM units has improved since my last CD changer experience!
Every person who's ridden in my car ( 00 Maxima with the Bose sytsem) has thought they were listening to a CD when I was playing the XM signal through the FM modulation.
It's only when I put a CD in that they believe me that they weren't listening to a CD before.
Where you really notice the difference is when you try and go back and listen to a regular FM radio station. The sound quality is so bad in comparison I'm always amazed that how many years I listened to that c****.
I can't speak to the quality of the sound system in your vehicle (since I'm unfamilar with the GM products) but with a quality install I believe all of your fears will be overcome.
Good Luck!
Also does anyone have this installed in their VW and how did they do it - with a modulator?
Thank you so much!
Got XM installed since June 2002 and love it and the programming. Isn't Sirius currently in some form of bankruptcy?
Xm's stock price has also gone from around $2 to as much as $6 in this year so they may turn out to be the survivor in this battle?
When I try to listen to regular FM radio now, I just can't make myself do it anymore. The terrible programming and static filled sound are just not tolerable for any length of time.
Now I'm starting to get addicted to the Fox news channel for my morning brief on the war as I drive to work.
I also have yet to meet anyone with Sirius installed. But for that matter it's pretty rare to see another XM antenna on the back of another vehicle, but it does happen occasionally.
Have you ever run into someone who had XM and then gave it up voluntarily?
Now I just have to install the car kit and save on my CD player...
http://www.pie.net/catsec12x.htm
Anyone know if your car subscription enables you to also use this device without additional payment?
I'll have to check into this more as the client I'm at is playing CW everyday now.........
Is it my imagination or is XM playing more commercials these days than they used to?
The initial impression is pretty good so far. It is not as much as my liking satellite radio, but is more how much I have come to dislike conventional radio.
And there are even discounts for those that would like to prepay their subscription fee for one or more years!
Now would be a great time to get that Delphi XM unit you've been waiting for, huh? Or the XMPCR instead!
All pertinent information seems easily accessible off their main website, so I won't bother to post any links.
If you're Nissan doesn't have a "Bose" audio system (and it says so on the tape deck lid if it does), I'd get an Alpine or Pioneer CD player for XM or a Kenwood or Clarion for Sirius which would be a step up from what is OEM) and add the XM module and the new Terk XM3 antenna that is so small you'd never even notice it like the old computer mouse antenna of last year.
While I agree that the directly coupled/connected XM receiver sounds a tiny bit better, don't diss the FM modulated one so easily! I've heard both and can barely tell the difference on non-audiophile level amps/speakers!
Believe me - coming from someone that has a CD changer (Pioneer) and XM Radio (Pioneer) both coupled to a nice IP-bus head unit, the difference in quality and clarity between XM and CD is QUITE noticeable. They use compression to broadcast the audio stream efficiently, and this has been tested to have insubstantial low range signals and drops off precipitously after 14.5 to 15KHz.
In the interest of retaining your dash appearance, you may want to consider getting the Delphi SjyFi XM radio. Just a cheap $69 upgrade will add on the ability to receive XM at home using the same Receiver!
As to the comment about atfermarket being a step above factory audio head units, I'd agree - but I'd say it would be TWO or THREE steps above Bose systems (the biggest piece of wool pulled over listeners' and buyers' eyes!). Bose systems sound too bright and artificially fudge with the soundstream. Now it may 'feel good' to your ears, but they never reproduce sound the way it was meant to be! Overrated!
