Visitor Agreement.
XTR1 SIRIUS Satellite Plug and Play Receiver
XM seen unveiling wearable satellite radio (MSNBC)
I just got the Alpine unit with the XM tuner built into the head installed today. It is SO nice not to have to depend on the FM modulator! The Roady gets moved into the house with the house kit, so now I have the best of everything.
I have the JBL premium 6-CD system that I want to keep. Dealer said I can run Sirius through that with an RF modulator. Will that affect the signal or sound quality in any way?
Do I need an antenna and, if so, does it have to be mounted on the outside of the car?
I travel in mid-Atlantic and New England, mostly DE, PA, NJ, CT, MA, VT and NH. Is there adequate signal coverage in those areas?
Coverage is generally better in southern states, but it should work just fine up there (maybe a few more cutouts due to the area (at least that is what happens with XM - better in the south).
-Paul
I have pictures of my install up at webshots (under the BMW section):
community.webshots.com/user/skimblz_
No wires displayed at all. This kind of installation may be an option since I seriously doubt Mercedes uses optical connections for their antennas.
-Paul
From what I read (and I'm certainly no expert in this matter!) the Roady 2 has a built in wireless modulator, which is the main difference I saw between it and the original Roady, like I have (I did read about it when I was considering whether to get the Alpine head or a second Roady for my new car). I would think (but again, don't know because I haven't done it) that you could easily hard wire the Roady 2 into your electrical system and not have to tie up your cigarette lighter. Of course, that still limits you to using FM stations. If that is what you are trying to avoid (like I was), then I don't know. I never considered the Commander and don't know anything about it.
BTW, where did you mount your antenna? I've heard conflicting stories about reception and the antenna location on a convertible. Some say it is fine under the soft top, others say no.
What did you do?
-Paul
I had been using the Roady's antenna on the roll bar (under the soft top) for a month without problems. When I talked to the shop guy, he said that some convertables use metal in the top lining, but I never had a problem with the Roady's antenna at all. They just tucked the antenna further under the padding on the roll bar than I had put it (there's a ton of padding - my '98 Sport has very little). They did route the wire under the padding on the top bar and then down the windshield. I probably wouldn't have done it that way - I would have gone down the roll bar and then under the carpet, but it doesn't really matter. I'm not planning on folding down my windshield any time soon! The antenna wires are invisible and there's no antenna on the outside of the vehicle.
Putting an XM antenna on a roll bar works very well with either the soft or the hard top!
I figure I'll try it there first. If I have a problem, THEN I'll move it. It is easy to do in a Wrangler!
-Paul
Thanks for the info on your install. Is that a BMW or Mercedes it was installed on, going thru the Antenna input. The commander unit has a combination Tuner/Modulator, but I'm not sure of the antenna input? I tried to access your web site adress to see pictures but the adress wasn't valid or I did type it in right. Could you give it to me again so I could try again.
Also, does anyone have any experience with the Roady 2 and the sound quality using the built in wireless modulator?
Ed
http://community.webshots.com/user/skimblz_
Just look for the BMW link once you get there.
-Paul
I have XM radio in my car (XMCommander), and mr. kirstie_h has coveted it since day 1. His birthday is approaching, and I'd like to get him XM as a gift. The problem is that the car is leased, so replacing the radio is out of the question and I don't really want to do something that will be difficult to remove at the end of the lease, or get us in trouble. It also doesn't have a casette player, so I can't go that route.
Some of the new products, like the SkyFi2, state that they've got a "built-in, wireless FM modulator," yet the car adaptor photo shows a casette thingy. So, I don't know if this means you have to have a casette player or not!!
I'm going to a mass-market electronics store this week, but sometimes one encounters less-than-fully-product-educated sales personnel, so I was hoping other members might be able to give me ideas first.
Thanks!!
kirstie_h
Not the host of this board, just asking as a member
MODERATOR /ADMINISTRATOR
Review your vehicle
Review your vehicle
http://www.xm411.com
The Roady2 (and I guess the skyfi2, though I've never looked at them) does have a built-in FM modulator as well as coming with the cassette adaptor, so people have the option of using either one (reason for the picture having the cassette attachment shown in the photo).
I understand that you can get adaptors that allow the Delphi (either SkyFi or Roady) systems to be plugged directly into the back of (many) car radios. If the radio has the ability to play an optional CD changer or other device, then you can go this route. It sounds like an install that would be easy to reverse when the lease is up.
I never really looked at the Commander, since I wanted something portable (move it between cars and house). However, I was under the impression that this was another add-on unit and while it required more for installation than the Roady, it would be another one that would be easy to reverse.
Pao, I'm seriously technically deficient, so unless I went the adapter route, I sure wouldn't be doing any install myself. Thanks all!
Review your vehicle
Don in Atlanta Ga.
I found out later that as part of the installation charge, they will also remove the unit when your lease is up (or you just want it out of the car) for no additional fee.
I thought that was a pretty decent deal.
Your mileage may vary, of course.
Review your vehicle
-Paul
Yahoo News
I'm also having a hard time deciding btw systems. Like Sirius better over all, but we love MLB. Guess that's a decision I have to make.
a receiver piece (like the XM Roady 2)
a tuner piece
an antenna
In portable systems like the Roady or Roady 2, the receiver and tuner are one piece. An antenna may be built in, it may not be. But the portable setups usually have all you need. These will usually 'connect' to your sterro by tuning your stereo to one of a few possible radio frequencies. Once that is set you can change your channels on your satellite radio tuner to whatever you like (but leaving your car radio on a particular frequency).
My unit uses RF modulation (as described above), but it is a permanent installation. This to me beats having any cables visible. This will definitely cost more in terms of equipment and labor to install, but the result is very professional and many times factory looking.
There is an option to get an XM ready unit like the Alpine CDA9280XM unit that mtngal has. All you need besides installing that is a satellite antenna, everything else is built in.
If you want to use this in multiple cars, the portable option is probably the best. There are all kinds of mounting systems you can use to keep the unit from sliding around your dash or in your center console. The drawback to this is that with RF modulation, you won't have as clear of a signal (though my RF is soldered into the antenna on the back of the radio so it is clear), and if you live in an area with a lot of radio stations, finding a clear one to tune your car to for satellite reception may be difficult.
For example, if you have to tune your satellite to 88.7 but you have a massive rock station putting out lots of power on that frequency, you may have problems.
You may want to look for portable units that have selectable frequencies. This is pretty common and should not be too tough to find.
As for Sirius vs XM, only you can answer that. I have XM and personally love it. For sports, I like watching football, but listening to baseball, so XM makes sense for me. Choices are wide on both services. I believe Sirius is associated with Ford/Mazda, so you might be able to find factory units that could be installed in either or both of your cars for a very nice and clean look.
Hope this helps.
-Paul
As Ericpl noted, you can get a box that hard-wires the satellite radio to your existing radio, but it will be a more expensive install. It does improve sound quality dramatically.
I am also a total non-techie, and whatever you get, you'll want to have it professionally installed. It'll take them a whole lot less time, and look professional.
I'm not sure about the Sirius plug-and-play, but I suspect an antenna still needs to be installed for vehicle use. I've now had it done in 2 cars, and it hasn't taken over an hour either time.
There's not a huge lot of difference between the two services, so I don't think you can go really wrong either way. Once you have it in one vehicle, you'll want it in the other and in the house, so beware!
kirstie_h
Review your vehicle
http://www.dishnetwork.com/content/products/receivers/sirius/prom- os/index.shtml
$99 for the receiver + car kit... but it doesn't say anything about install. You'd have to call.
from the cheapest host on the block,
kirstie_h
Review your vehicle
Sirius-ready: You need to add the tuner (~$49) and the antenna (~$49), then you're ready to subscribe & listen. You might check to see if the tuner is included.
Sirius-compatible: Well, aren't we all? Most modern radios are Sirius and XM compatible. This means you can buy a Sirius radio, the antenna, car kit, and any other equipment you might need and have it hooked up to your existing radio.
$395 additional for Sirius-ready? Depends on how much you like the particular radio they sell. Depends on whether this $395 means the tuner & antenna and install are included.
There are a number of aftermarket headunits ranging from $120-$2300 on Sirius' website. So if you're not sure what to do, you can always purchase later.
kirstie_h
Review your vehicle
Next year we can hear em on XM!
-Paul
One of our main reasons for going XM was to hear the Cards games - we do a LOT of driving, so it'll come in handy.
kirstie_h
Review your vehicle
I have since bought the Alpine head that includes the XM tuner and had it professionally installed.
I still use the Roady in one of my vehicles and at home and work (awesome music when played through a Bose Wave Radio!). It takes only seconds to unplug and re-plug it in, and I don't have any desire to go back to broadcast radio.
I was reading on another board about someone who just bought a MyFi - the new XM walkman unit. According to what this person said it comes with everything needed to use it at home, in a car or while out jogging, including headphones, antennas etc. I haven't looked at one (I certainly don't need it), but it might be something to check out for a first unit.
Review your vehicle
If your Mach 300 system has an AUX input you can wire a "plug & play" unit directly into it for far cheaper and get great sound. If no AUX input, you can still go the more-affordable plug & play route as these units have an FM transmitter and will work with any car stereo. The only difference is that you will get slightly better sound quality if you connect it via an AUX input rather than relying on the FM transmitter.
I recently bought a new Ford and declined the Sirius-ready factory unit in favor of the basic radio for my model. Saved far more in the purchase price of the car than an aftermarket headunit, tuner and antenna will cost me.
-Paul
Hopefully, XM will take a slightly different path!
kirstie_h
Review your vehicle
There are several alternatives - if you get the aftermarket offerings from Sirius or XM professionally installed, you can end up having NO dangling anything, and the antenna is mounted on the roof (it's tiny), and the wires completely concealed. Before paying that much, it's definitely worth a visit to a local car audio shop. They'll have a variety of headunits and can talk to you about quality, seamless installation options.
Check around - some offer very cheap or free install. My XM was installed by a local shop that does $1 installation if you purchase there - and the price for the equipment was within a few bucks of the big chains.
kirstie_h
Review your vehicle
I understood that the $395 quote was including installation. I found the Visteon Ford/Sirius tuner and antena on eBay for $265 and the dealer said that they would be happy to install it for me for $100. If the originall quote does not include installation this eBay deal would look so much better.
XM and Sirius don't have static - you either have a signal or not. It seems to me that the quality of sound has more to do with the speakers and radio you are playing through, rather than the tuner itself, so I wouldn't hesitate getting one of the generic tuners to connect to an XM (or Sirius) Ready radio. As I've said before, the quality I get from my little Roady hooked up to a Bose wave radio is outstanding.
