Visitor Agreement.
I would remove the cross rails and see if the wind noise disappears....
There may be a few others floating about, but this is what I remember as the fix.
For those experiencing it now, when were your vans made (you can tell by the last 5 digits of the vin, or look on the door sticker). I'm assuming (hoping) this will be addressed as a running change, so newer production should have it fixed at the factory.
I have a 2000 Honda Odyssey and I am thinking of chaning spark plugs. The plugs are located 'deep' in the engine head-are the plugs easy to change? Do I need any special tool other than a deep socket and wrench?
Thanks in advance.
Paul.
Messages Page 188 of 188 Go To Msg # Search This Discussion
1 ... 182 183 184 185 186 187 188 Recent Msgs
#3736 of 3737 Grinding by stickguy Dec 08, 2004 (9:25 am)
Bookmark | Reply
that sounds like the ABS self-check (initializing). It is actually normal and is supposed to happen when you first start driving forward like that.
#3737 of 3737 Change Spark Plugs by psm18 Dec 09, 2004 (9:43 am)
Bookmark | Reply | Edit | Delete
I have a 2000 Honda Odyssey and I am thinking of changing spark plugs. The plugs are located 'deep' in the engine head-are the plugs easy to change? Do I need any special tool other than a deep socket and wrench?
Thanks in advance.
Paul.
COnsidering it is really a 1-time expense, I would pay to have it done. That way, if someone breaks a coil pack or some other expensive piece, they will have to pay to fix it!
Bot too likely a person would ever need to do this but you sure can!
Is there something I'm missing to reset this?
I checked the owner's manual and it appears that avg. mph, mpg, and trip odometer should all return to 0 when reset.
Is anyone aware of a fix for this?
Rick
We have a 2004 that we leased in Jul. '04. I hear a "thump" once in a while mainly during braking. I assumed that it is due to the fuel tank slushing problem, but am not sure. Any thoughts?
Emil
We have a blurb about how to do it here on Edmunds:
How To Change Your Brake Pads
Getting a C clamp if you don't have one is a good idea.
Wrapping your vehicle around a telephone pole might not be worth the $60 you'd save by doing it yourself.
The problem with those "$60" advertised jobs is that it would end being a $500+ job as the garage shop scares/sucks you into doing other supporting or unnecessary brake work. I have seen it happen to many folks, especially women.
One good practice is to replace the brake fluid yearly in the reservoir in the engine compartment. Very simple use a turkey baster to suck out the brake fluid and then pour in fresh fluid. The ideal way is to bleed out all the fluid from the system, but I believe that changing the fluid yearly in the reservoir is an adequate compromise.
The same can be done as well for your power steering.
My dealer has addressed this problem several times without charge but in the most recent case the switches had to be replaced at a $500+ cost to me. It seems from reading this board that the problems have been common enough that Honda ought to do something about it. Was wondering if it was worthwhile to start a letter writing campaign to Honda.
I do not have crossbars on my Ody. However I do suspect that there will some wind noise though at high speeds, especially above 70-75mph. Have you observed that?
Just some initial diagnosis...
If the out of balance or out round condition is in the front tires, you would feel the vibration/shimmy/bumps more in the steering wheel. If it is in the rear tires, you would feel it more on your behind while seated.
Improper wheel balance normally causes vibrations and not "bumpiness".
Never heard anything like this before!
The van has 93k on it and is very clean. Paid $9k for it - any comments? One catch, after driving it for a couple of days I realize it needs a new tranny.
I called my local Honda dealer before buying it and they said they would fix it under the 100k mile warranty extension if needed.
Did anyone go through this process? Is Honda reluctant to give away a "free" tranny? I know GM, Ford, Chrysler would not do this for free.
You can easily check this by unscrewing the filter and checking for the (double?)gaskets on the filter itself or if any remained on the engine block. Whenever I perform oil changes on my vehicles in my garage, I always check for the gasket on the old filters.
In the CRV case, the dripping oil was right over the hot exhaust pipe causing a fire in some cases.
Honda America has some TSBs/recalls on this problem - which you can refer to.
Of course, some media publicity, if necessary, would help if you encounter resistance.
I was experiencing delayed shifting from first to second gear. Also, on a 15mph roll and then accelerate, the trans would slam to first gear.
The trans is new (or rebuilt) from Honda and will be shipped in a crate w/new torque converter. Will be fixed by Friday...Honda service is by far the best that I've ever come across.
Hopefully, the engine will last another 100k miles.
