Honda Odyssey: Problems & Solutions:(1995-2004 Models)
Dave
Has anyone heard of a "fix" for this problem, or any possible compensation for this problem until this serious problem is fixed?
"We purchased our '05 Odyssey 12-31-04 in the Chicago area. As soon as the temps got cold, the driver-side passenger door would no longer automatically open."
Same thing happened to us--same door. Van was delivered last Thursday; a couple of days later, on a very cold day, the "sliding door" light illuminated. We are taking the van in tomorrow and will let you know what the problem is. According to the service manual, it could be a number of things; we need to wait until the tech can download the diagnostic codes.
I don't have a problem operating the doors manually. Be sure that the switch that controls the electric doors--to the left of the steering wheel--is not set to "on." Turning the switch off disables the power doors and permits them to move manually. (These are the instructions in the owners manual.)
Good luck--to us too.
Pry the clock from the bottom with a screw-driver, its designed to snap in and out (be careful not to scratch the plastic). The light for the clock looks like a set screw in the back. Just turn it 90 degrees and it will come out.
I picked my van on 12/20/4 and observed the same problem. I called the delareship and they just did some lubrication and told me that the problem have been fixed. But when I cam back home and noticed the same again. I called dealership again, this time they told that the door was misaligned. but this this will not resolve the problem Now they are saying that Honda is aware of this problem I called Honda and opened up a case for my Van but even after one week there is no response from American Honda. I will wait for another few days then I may take up this case with the LEMON law because I have already taken my Vehicle to the dealership three times. I can't waste anymore time. This rattling noise from the Passenger side sliding door kills.
It has been my experience that Honda wants to live up to their outstanding reputation for reliablity. If my old '94 Camry made it to 160k with the original trans, then Honda should also. Look for another dealer for servcice.
Occasionally, when I brake either at an intersection or getting off the freeway, the car will accelerate when I brake. This double action causes the car to slow but not stop completely. Luckily, I have not been in an accident.
Because it is intermittent, the dealership cannot find the problem. Help?
It may be something really stupid on our part but has anyone had a similar problem or have any idea what could have happened?
BTW he tried boosting battery with our other car (after carrying our son home in -31 Celcius weather) but no luck - though he said the slidinig door did start working again.
Waiting for Hond roadside assistance to show up...
You have got to be kidding about a tranny job costing 5K. I have never heard of any costing even half that much.
If anyone finds a tech service bulletin for this, I'd love to see it.
Karl
Call your local Chrysler/Dodge dealer and ask them how much for a replacement transmission.
I just was pointing out that it's just not Honda trannies that run that much - it's all brands.
Point is, call and take it politely to a higher level, it never hurts to try.
I confirmed the cost of the transmission and this is the cost for a new transmission and of course dealer's installation rate. I did some more research and saw costs of rebuilt transmissions around $2900.00 and labor cost is extra.
The Honda replacement transmissions are all new components inside a used housing - they replace everything with new OEM parts. The labor to swap is about 8 hours.
I have a 2001 Odyssey with Automatic Sliding doors, I live in North Carolina where the winters are quite mild. However every year when the temps dip belowing freezing our Honda's sliding doors freeze closed to the point where they can not be opened either electricaly or manually. Local service center advised using Vasaline on the rubber seals. I tried that one year. That was nothing but a mess!!! Surely there are Odyssey's in the North East and Middle Northen states where the winters are longer and worse than we have. Can you direct me to where this has been discussed before or offer any advice please, my kids are tired of climbing out the front doors and the lift door. Thanks dano585
Try getting some Shinitsu grease from the parts dept at the dealer and apply it to the seals on the sliders. Dealers use it to prevent sticking - perhaps it will keep moisture from forming on the seals as well.
Good Luck.
Honda Automotive Parts, one of the internet parts retailers, lists the current 5 spd Ody tranny at $4100. What you get for that price is pretty much new guts in a salvaged case, and bench tested. That large aluminum casting is a few hundred $$, and assuming it is not cracked or damaged by spun bearings, is cleaned and reused.
Yes, I am sure that a private shop can rebuild it in the back room for much less. But what you get is only as good as the skill of the rebuilder. They have to inspect and mic each and every part, and assess it's suitability, ordering what is deemed not salvageable. The results range from great to poor. I have gone both routes, and in part, it depends on the value of the vehicle, and how long you plan on keeping it.
Steve
Is there a way to bypass the alarm or reset it?
I seriously would want a manual in my '05; my right arm twitches every time I stomp on the gas.
Maybe you already knew this but the service manager told when I took it in that the proper way to start a Honda was to turn the key then wait fo the green key light to disappear "before" starting the engine. Takes a couple of seconds. Apparently it goes through a self diagnostic and while you can start the car before the green key light disappears it depends on where in the diagnostic you cut it off. He said that if you happen to try and start it when it's checking thefuel line that you can shut it off and therefore the car won't start.
I'm not sure if this is what happened since we also had no juice for the sliding door but that could hae been a coincidence with our freezing weather.
Been fine since.
Who knew after years of owning Hondas?
We have 79k miles on our '00 EX. Last week we had the transmission replaced for the third time. So, we are now on tranny #4. In addition to tranny problems we had the same door problems etc. that other Ody owners have experienced. We just counted that we have had the van in the service department for 19 different repairs in total.
Our concern is that when it comes time to sell to a third party, our car is not going to be worth what it should be.
We told the Atlanta service department that we want something beyond them just replacing the transmission. They sent us on to someone in Honda corporate who handles decisions about extending warranties. She told us that extending our 100k mile warranty is not an option. So, that was a pretty quick dead-end.
The only other thing that we think would make us happy is if they (I'm not sure if "they" is Honda, or the dealership) give us retail value on our van (KBB assuming the car had a good service record) and sell us an '05 at invoice.
1st, do you think our expectations are unreasonable? If not, what is a reasonable expectation?
2nd, who do we deal with? Does anyone have specific names for people we could contact?
We are still on the original transmission on our 1996 Caravan at 80K miles, and other than a few minor recalls and two major air conditioning repairs, almost all maintenance has been the routine preventative sort; one set of brakes, one set of tires, two batteries, oil changes, one transmission fluid change, two or three radiator flush and fills, and one fairly minor transmission output shaft seal leak.
This good performance from a brand of minivan that is supposedly below average in reliability.
I've NEVER heard of an Odyssey going through transmissions like that! I have to wonder if there is another side to the story, an abusive teenage driver (like I was)or if it's been used like a beast of burden, pulling trailers etc.
I have no idea.
I can see maybe one rebuilt where the job wasn't done right causing early failure, but THREE?
Even so, anything is possible. I could win the lottery tonight too.
Very unusual.
3 Transmissions replaced? It must be abuse! Ok!
Almost 4000 posts on the Honda Ody Problems board. Naw, it's just my imagination.
I think that's what I said while just considering that there just possibly could be factors contributing to the high failure rate.
Can you even consider such a possibility?
When I was in high school I distroyed the transmission on my parent's Buick one night when I was out street racing it.
I managed to limp it into our garage. Neither my parents, nor the Buick dealer could understand why it had failed at I think, 30,000 miles.
I wish you wouldn't put words into my mouth.
