Stump The Technicians--Contest Rules Are Here!
Actually you're right. Even the German Chevs of that era, (1980's, don't know what they use now) used pressed steel rocker arms that use a ball nut as a fulcrum. The exhaust rocker on #3 cylinder had broken. Removing the nut and replacing the rocker is a simple job. The #3 cylinder was firing but on the exhaust stroke the valve did not open so the gas was forced past the piston and into the crankcase creating interesting effects and noises. There seemed to be no lasting effects though after repairs were done.
My friends’ father bought a new full size Chrysler in 1973 (I think it was a New Yorker) with a 440-4 BBL engine, complete with a full add-on trailer towing package and “Desert Cooler” radiator. Every summer, “Dad” would go on vacation with his wife and any family/friends that wanted to come along. Said vacation consisted of towing his “Airstream” trailer up to the northeast portion of California along the Nevada state line, and then lots of beer and fishing. The drive from San Diego, CA to Buntingville, CA includes climbing Sherwin Summit (US-395, just north of Bishop, CA), which if I remember correctly climbs from Bishop, CA ~4,000’ above sea-level to the top of the summit (Tom’s Place) which is just over 7,000 feet.
The first year Dad drove the trailer up there, while climbing Sherwin Summit; he heard a loud bang and felt a momentary shudder come from the engine. When he got to the top, he pulled off the road to see if he could discover any damage. He immediately noticed that the car was running rough, but otherwise, no problem. Dad was not much of a mechanic, so, he simply continued on his way. When he got back to San Diego, he took the car in to his dealership to have the roughness fixed. What they discovered was that the valves had been blown up into the head on the number 8 cylinder, damaging the head and destroying the pushrod/rocker assembly in the process. It was suspected that coolant had made its way into the combustion chamber from a possible cracked head (the head was damaged enough that they could not determine if there had been a pre-existing fault or not). The dealership promptly replaced the cam, head and two lifter/pushrod/rocker arm assemblies under warranty (the car had only about 4,000 miles on it at the time).
A year later, after operating perfectly for the intervening 12 months, Dad embarked upon his annual journey again. Just as with the year before, halfway up Sherwin Summit, he heard the Bang and felt the shudder, this time, he did not even bother stopping at Tom’s Place. And again, Chrysler replaced the head, cam and the lifter assemblies, this time with 18,000 on the car (and out of warranty), given that this was deemed a “Pre-existing Condition”. My friend asked them to check the block for a crack, which they did, results were negative.
For the next several years, the story repeated itself. One year the dealership even tore down the block and had it “Magna-fluxed”, checking for the possibility of a microscopic crack that they could not find via their other methods. Once again, the results were negative.
What was wrong with this engine?
Best Regards,
Shipo
there is some common denominators, only while pulling up the summit, thus, heat is playing a role since there is very little air flow across the engine while pulling would mean engine is hotter. #8 cly is next to the a/c compartment against the firewall suffering even less air.
maybe preignition from the excessive heat while the valves are in the closed position and the cam is trying to open them would be the only way to cause damage. now this is assuming the timing was correct since it was running fine prior. of course if timing was the problem the first time would have showed that so given that, that's out of the question.
the thing that puzzles me is, why a cam shaft? if the cyl damage messed up the push rods would bend in most cases and may at best collapse the lifters but to cause damage to the camshaft is puzzling.
well, thats' my story and i'm sticking to it!
lets see how far off i am.
If I remember correctly, Chrysler replaced the cam as a “Just in case”, due to the severity of the damage to the lifters, push rods, and rocker assembly. We were always of the opinion that the cam was unnecessary, however, it was their nickel.
As for the actual problem, the fact that the #8 cylinder exists in close proximity to the A/C box, and suffering less airflow *MAY* have caused a few extra degrees in the cylinder, but, given water cooled nature of this engine (and the fact that the car was equipped with a massive 4-Row "Desert Cooler" radiator), the most that could be expected would be a degree or two. With the benefit of hindsight, I can tell you that detonation was not the problem.
FWIW, for those who have never climbed Sherwin Summit in the summer, it is HOT (over 90 on most days, with some rising to well over 100) most of the time and the bulk of the 3000' plus elevation change occurs within a 10 mile stretch. Needless to say, what with the A/C running full bore and the load of the large car and trailer, we are talking about a seriously heat soaked engine.
Best Regards,
Shipo
now lets look at this another way, with it being a 440 with 4 barrel intake, older car, no mass sensor, the barametric pressure would change on the climb up the hill, thinning out the air as you climb the air mixture would tend to go out of adjustment the higher up you get, and if too much fuel would "load up" in that cyl during the climb since there was more fuel than air getting in thus cause a higher combustion explosion.
like i said.. a stretch.
Close inspection of the starter on removal reveals no problem. Brushes are OK. The solenoid works fine. Connect the starter to the battery while out of the car and the starter has speed and torque. Yet, quite by accident one day I spotted the fault inside the starter. The fault was fixed within minutes. What was the problem?
to have a starter hang on you and have to disconnect from battery means you have a completed connection on the selenoid. so, to make a connection from the battery to the starter its self, your selenoid has to be engaged where the contacts were connected to the starter plate inside. so if not a selenoid, then the starter had a mechanical hang up keeping the bendex out thus pushing the selenoid plunger back keeping the contact across the plate.
now, either you had a burr on the shaft or gears(not likly) or the bearing on the end of the starter was worn thus putting a bind on the gears so not to release.
now all this is assuming the selenoid is in fact not bad. of course another thing to look at if electrical would be to see if the key circuit was getting energized by shorting against 12v somewhere.
bob in jville.
The valve could drop into the combustion chamber and get scrunched up in there, OR
The rocker shaft studs could pull, jamming the pushrod or valve and causing the valve to drop.
So what I mean is that the "event" had to occur initially in the rocker arm area. Then, if the valve is dropped, it can damage the engine internally.
OVERFULL DIPSTICK--what happened is that as the cold weather hit, the enrichment valve jammed open and filled the crankcase with fuel. This was misread as "too much oil", when in fact the oil was heavily diluted with gasoline, too much to "burn off". This diluted oil could not properly lubricate the engine under load.
Why the lube shop did not smell all this fuel in the oil when they dropped two quarts is a mystery. Also, it seems to me that the oil would have been very dirty.
The valve can't be "pushed" unless it is dropped first.
TB
Best Regards,
Shipo
Best Regards,
Shipo
If a rocker breaks and the valve stays shut, then it's just sitting there, out of harm's way. There would be no combustion in that cylinder.
One other possibility that comes to mind would be some very nasty form of detonation. I suppose if detonation can punch a hole right through a piston it could drive the valves into the head. This would require some radical change in engine timing or a huge glowing carbon pile in the combustion chamber.
What surprises me is that the valves gave way before the piston deck or the connecting rods. Back in 1996, when I was working for MBUSA, the CEO drove his S600 through a “puddle” (one would think that he should have known better), and the engine quit. When the car was towed into the shop, the first thing that the technicians did was take a dump of the OBC. It showed that the last several moments of the engines’ life had been spent motivating the car at a steady speed of about 40mph at 80% throttle! The air intake horns on that car were about 2’ above the road surface, and he must have caused a “Bow Wake” high enough to allow the engine to gulp water through the intake system. The end result was that the connecting rods were bent sort of like a three dimensional “S”, with both left/right distortion as well as fore/aft distortion. In this case, the piston decks survived as well (I cannot say as much about the piston skirts), as did the valve train. Maybe the fact that the old 440 had a push rod/rocker assembly (which I suspect is easier to distort than a connecting rod) is what saved the lower end of that motor.
Best Regards,
Shipo
Hydraulic lock was not uncommon on Mercedes of the late 60s, early 70s era, as the air horn for the injection was down pretty low and very close to the grille opening. 280SLs were particularly vulnerable, but really, this could happen to just about any car if the water were deep enough.
Another way for hydraulic lock to occur is a seeping head gasket, where you turn the car off and it's fine and then next morning you go to start it and get just one "clunk", as you had one or more cylinders full of water.
I never considered hydraulic lock occurring from water/coolant seepage into a car engine. Given that coolant is just as compressible as oil (as in not compressible at all), clearly, just as much damage can occur from water as well.
Best Regards,
Shipo
Best Regards,
Shipo
The problem ended up as a bad "convenience control switch" which alows the windows and sun roof to be closed by holding the key in the lock position for several seconds, about the only place the sun roof and window circuts came together.
I assumed the problem was the solenoid possibly arcing and sticking in place. I am interrested to know waht you discovered the problem to be.
How'd I do?
TB
Computer Tech 8^)
Now here is where things get murky. Why was it locking up the solenoid when half of the field was shorted to ground? It would explain the sluggish action of the starter but how could it effect the solenoid?
A typical solenoid has 2 windings connected in parrallel. When the key is turned on and power applied to the solenoid, both windings are energized. This ensures that there is enough magnetic force to bring the solenoid in. However, in order not to overload the ignition key circuit, one coil is then cut off by the action of the solenoid contacts leaving only one coil to hold the solenoid in.
Somehow, when the field had shorted to ground, one coil remained energized even when the ignition key had been turned off. If you look at the circuit of a solenoid and starter they look deceptively simple. However, there is more to the circuit than meets the eye. I still haven't been able to completely figure it out yet. Be that as it may, I had no further problems after I fixed the short.
As for the oil loss, I think the oil control rings were not up to the task after the repetitive flood of tranny fluid, The engine burned a lot of oil after I fixed this problem. Needless to say I didn't keep the car long after this.
7937 thanks for the info on the starter, now if I had only read this last September before I replaced that starter... Oh well.
Lets all keep this discussion going it is good, oily, fun.
lets say automatic for this problem... black smoke indicates that you are getting too much fuel in the cyls and that when you put it in reverse, you are lowering the idle on your engine and the air mixture ratio is being loaded up with too much fuel and not enough air. , this would be due to a stuck choke if you have a carb. this problem would not exist when warmed up since the choke would normally be open by this time.
as for dropping it into drive and it working, maybe you have gotten to the point that your not idling like you do in reverse so when going forward your already pushing the pedal allowing more air to fuel flow thus not staggering like it would in idle.
now this is just going on what you have. if you would, it would help to know the engine type model, transmission standard/auto, milage on car, and any other thing you can supply us with.
bob
Foul!!!
8^)
TB
what next?
Oxygen sensor?
Steve
FWIW,
TB
if there was, it wasn't the problem
Is that true? (I don't want to be mislead if I'm reading something into the puzzle that's not realy there).
Did the new fuel filter temporarily alleviate the problem?
1975 GMC 3/4 ton pickup with a 350CID V8 2BBL carb. owned by a trucking company I worked for.
One of the mechanics went to start it. The engine would not turn. Without checking it was assumed the engine was siezed. The engine was replaced with a target master complete engine. A week later the same thing happened. This time when the dip stick was pulled it was full of gasoline. The crankcase was drained, the plugs were pulled and the engine turned by hand to get the fuel out of the cylinders. The engine was filled with oil and was fine. another week later the same thing happened again. Crankcase full of gas, hydraulic lock, etc.
What was the problem? BTW, it was summer and the truck was parked over a week end in the shop.
Jim
The car is a German DKW 2 cylinder 2 stroke of around 1937 vintage. It belonged to a friend of mine. On occasion after starting the engine, the gears are reversed - ie, reverse gear becomes a forward gear and all forward gears become reverse gears.
What was happening and what is the fix?
Dunno the fix.
TB
Best Regards,
Shipo
As for Bob's problem: I was thinking fuel pump until I reread the post and you stated gas mileage went to hell. You said it wasn't tune up so I assume timing is correct, and no fouled plugs. If both of these are true, I am going to guess a cylinder is down, worn cam profile perhaps.
The cause of the engine reversing was that the ignition timing was too far advanced. As the piston approached top dead center, the spark plug fired and the piston was forced down before going over top dead center. In the opposite direction the timing is now (relative to the piston) retarded. The engine is now much happier with the state of affairs and keeps on running.
The fix of course is to retard the timing.
it appeared to have, but started to do the same thing with a new filter in less than 80 miles.
catam.. would seem reasonable but in this case, not it.
