Inconsiderate Drivers (share your stories, etc.)
1226227229231232478
    I am not talking about running a red light at all. I am talking about stopping, then proceeding when it is safe to do so. Running a red involves failure to stop.
    Nevertheless, I absolutely agree with the point of your post. A camera, however, will provide no such situational discretion.
    As for camping vs. going, I am willing to bet that a good number of the law enforcement folks around here would give a driver choosing the latter option enough hassle as to make that person wish the first choice was made! ;) :sick:
  • pulgopulgo Member Posts: 400
    In an ideal world I would agree with you to treat this as I would with a four way stop.
    Unfortunately the city roads (and highways) are full of nuts that insist in exceeding the speed limit by a very high margin.
    When one of these pinheads decides to race on city roads and ends up crashing into you, who has just decided that it is safe cross the intersection with the malfunctioning light, what then?
    I know this is way out there as an example but it could happen.
    There could be a motorcycle rider you did not see because he was approaching at a high rate of speed. Or worse, at night someone hits you because he had no functioning headlights and you could not possibly see him or her.
    I start my commute very early (around 5 AM) and there is always someone on the road with missing lights. Sometimes NO lights.
    None of those examples are "way out there," pulgo. I have certainly seen all of them and, in the case of the non-headlight-using drivers, on a regular basis! I doubt there is any place in the U.S. as prone to it as Alaska. I imagine that the same thing could be said for Canada's northern territories versus its provinces.
    Again, it is one of those things where the user must be aware of the surroundings. Even a go on green is no guarantee of a safe crossing. Just last week I posted about some yahoo jumping the median and sprinting across an intersection (pseudo-left turn) where I would have been had I not seen it and waited. I am not advocating the treatment of light-controlled intersections as though they were 4-way stops, but I am saying that there is certainly room for a driver's judgement to trump strict obedience to the light given proper conditions.
    I think this is an ideal world, even if the people and situations on it are not. :D
  • ny540i6ny540i6 Member Posts: 518
    I've been to several countries where one of two versions of "light management" happens. Version one is that at night the lights cycle as normal, however the expectation is that after a stop, the person at a red may proceed, with due caution. The other choice that I've seen is that at night the lights become a flashing red (four way stop). Seems to work...
  • fintailfintail Member Posts: 58,886
    Both of those are excellent ideas. They could work on weekends in many areas around me, as well. Nothing like going out on a Sunday and being stuck at long lights made for weekday rushour traffic patterns.
    The lights in Pendleton, Oregon, work that way, or did, at least, the last time I was there. Between 2300 and 0700, the downtown lights (which are very well sequenced during the day, but are not sensor activated) will switch from cycling to flashing. The through streets receive flashing yellows while the cross streets receive flashing reds.
    Works great, which must be the reason so many areas do not employ that tactic. :sick: :P
    The smallish (ca. 25K people) town where my mother lives has that identical idea in play, and has for eons. It works very well.
    This town also has nearly perfectly sequenced lights. Maybe it's easier when there are less of them to time, or maybe they actually care.
    It may be a combination of both those factors, but having sensor-driven lights makes timing a difficult (if not impossible) feat to accomplish.
    The drawback with timed lights is that they change on a pre-determined schedule regardless of traffic. The benefit is that once a driver is stopped at one, there is little chance of catching another red unless traffic is moving either too slow or too fast.
    I certainly appreciate the sensor-activated lights as well, especially in areas where cross traffic is very sporadic. However, in high congestion areas during peak use times, the presence of traffic from all directions is a given. The only thing sensor-driven lights accomplishes there is to ensure that light is not in time with any other light in the area.
    For those intersections, employing all three tactics might be an ideal way to go - or just install roundabouts and forget all this light mumbo-jumbo, but then one is guaranteed an intersection delay every time through! :P
    I dunno, but it is Friday night and I am just about to head home. I hope for sane conditions on the trek there. :D
  • snakeweaselsnakeweasel Member Posts: 19,657
    For those with Google Earth punch in 43 03 13.27 N 87 54 36.98W. that is a roundabout that I for years went through several times a week without seeing any trouble with people using it.
  • euphoniumeuphonium Member Posts: 3,425
    NO ROUNDABOUTS
    Pedestrians Traveling through Roundabouts
    Since traffic is continually flowing in and out of the roundabout and is not controlled by a signal, there is no time when a pedestrian can be reasonably certain that a vehicle will not pass over the crosswalk. Roundabouts can also be difficult for visually impaired pedestrians to determine the moment when it is safe to cross as many utilize traffic sounds to determine when a roadway is clear. Additionally, the route pedestrians must take around a roundabout is longer than the route they would take to walk through many signalized intersections.
    Bicyclists Traveling through Roundabouts
    Bicyclists can travel through a roundabout either as a vehicle (within the roundabout) or as a pedestrian (walking their bicycle). Some multi-lane roundabouts utilize an adjacent one-way trail where bicyclists approach the roundabout on-street, merge with the side trail via a ramp, travel around the roundabout on the trail, and then re-merge with the street via another ramp. This option presents some challenges with motor vehicles yielding at crossing points (similar to pedestrian issues described above). Notably, the reduced speeds of motor vehicles within the roundabout more closely match a bicyclist’s typical speed range (approximately 10 - 20 mph).
    Emergency Vehicles
    Emergency vehicles cannot speed through a roundabout like they can a signal light; they need to slow down and pass through the circle like regular traffic. Additionally, traffic signals offer the option for signal preemption to provide the green light to emergency vehicles; roundabouts require travelers to yield to emergency vehicles. The proposed locations on SR 4 would not be appreciated by the drivers of E.V. Check with the State Patrol before planting any roundabouts on SR 4. Neither would the city fire vehicles negotiate the obstacles without considerable waste of time answering a fire or any emergency.
    Lighting
    Illumination costs may be greater for a roundabout than a standard intersection as more lighting is typically required. More lighting may also be a concern of adjacent property owners, especially near residential areas
    Snow Removal
    As with any new roadway configuration, highway maintenance staff will need to learn new snowplowing techniques
    Parking
    The construction of a roundabout to replace an existing traditional signalized intersection may result in the loss of some on-street parking if allowed near the former intersection.
    Right-of-Way Requirements
    The construction of a roundabout typically requires more right-of-way than a traditional intersection controlled by traffic signals or stops signs, which may increase the cost of a roundabout installation if right-of-way must be purchased.
    Roundabouts may work in Europe where the cars and streets are much smaller, but over here it is not uncommon to see a 45’ motor coach pulling a toad, or a ¾ Ton pickup hauling a 5th wheel, or a tandem axle trailer with boat.
    Roundabouts are not recommended, but wider intersections are because they are safer and handle the traffic with more efficiency. :)
    We're supposedly getting a 5 way intersection roundabout this winter here in Boise right next to a busy school. Something like this. :D
    Right now there's just one at the hospital entrance that I know about. I like 'em. The one they are building at the school is gonna be trouble though for the pedestrian reasons mentioned. They really should just reroute the 5th street and make it a normal 4 way intersection.
  • tallman1tallman1 Member Posts: 1,874
    We have several roundabouts in my neck of the woods and I love them too. :)
    I have a hard time following that one. I am sure it works smoothly, but it would freak me out to come across something like that unprepared. Then again, I am definitely a roundabout novice, having only traversed the *one* roundabout we have locally. There are a few more being installed in a neighboring town this summer, but I have not seen them yet. Single lane roundabouts are intuitively beautiful things, but any bigger/more complex than that and I need a video first to demonstrate it.
    Road construction during the winter? What kind of wimpy winters do you have down there in "tropical" Boise, Steve?! :P
    As for pedestrians, it is not a roundabout problem - it is a driver problem and it happens at all crosswalks.
    I used to have a link to a video of the Magic Runabout in action. It looks nuts, but I guess it works smoothly enough once you get the hang of it. I'm sure the SUVs and lifted trucks will drive straight through our new roundabout instead of going around, especially on the occasional days when we actually get snow in town (winters tend to be pretty mild here and you have to drive up to the snow to ski or ride).
  • oregonboyoregonboy Member Posts: 1,650
    I found this on Youtube. Hard to see what's what:
    link title
    james
    That roundabout I showed is controlled by stop signs.
    Roundabouts can also be difficult for visually impaired pedestrians.....
    I would think that would be the same issue at any intersection or crosswalk.
    Emergency vehicles cannot speed through a roundabout like they can a signal light;.....
    Most emergency vehicles I see going through an intersection tend to go slowly anyway for safety reasons.
    Be fun to see an aerial shot, but that works. :shades: The next project is to drive through it and see how confused you can get your nav system.
  • xrunner2xrunner2 Member Posts: 3,062
    It would be interesting to see statistics on accidents/crashes of roundabouts vs traffic light control intersections in a same city study with intersections having similar traffic volumes.
    There is a roundabout in a suburb (Des Plaines) in my area that was miserable to negotiate in rush hour. I recall going through roundabouts in small towns out east (think Jersey) in a number of trips years ago and was not especially a problem because of light traffic.
    A roundabout at a busy intersection in a suburb with shopping centers nearby and corporate offices and drivers (inconsiderately) using cell phones extensively would be an ongoing disaster. Might as well build a fire station/paramedic facility nearby to service all of the crashes.
    Roundabouts work, as long as you know where you are going - ever look at what you get from Mapquest when one is involved? "Bear Right.... Make Slight Right (Yeah, but which one??) LOL"
    Actually, In several countries that I've driven in they are no problem. For us here it would simply be a learning experience.
    The key would be a breakdown of the pros and cons of roundabouts. It would seem that safety would trump a lot of other things such as cost to build and maintain traffic light system of regular intersection. If someone could prove statistically that roundabouts are safer (for like traffic volumes) than traffic light intersection, then a case could be made for these configurations. Of course, then there is the learning curve. Also, have to deal with cell phone drivers. Driving while talking on cell phone will require more attention by driver to get through roundabout than merely obeying red/green lights.
    There are two near my home and they do work!
    One of them replaced a very odd 5 way intersection and traffic throughput has more than doubled.
    No waiting times or accidents anymore. People got used to them very quickly.
    Isn't there some recent study that says that unsigned intersections are safer than ones with stop signs or red lights? Theory being that if you aren't protected by a signal, you'll pay more attention negotiating the intersection.
    Do you mean for example a four-way intersection? Maybe in rural areas where locals "know" to look and proceed with caution.
    In general, it seems that most drivers are conditioned to drive through an intersection unless there is a stop sign or traffic light telling them to stop. They understand that it is automatic or ok to go straight aghead and they assume that cross traffic has to stop because of a stop sign they have to obey.
  • 210delray210delray Member Posts: 4,721
    A number of them have gone in recently; all are single-lane ones. They're easy to navigate, with right turns only.
    I like them because you don't have to wait seemingly forever at some red lights, nor do you have to deal with the nonsense that occurs at 4-way stops (people not stopping, moving out of turn, etc.)
    The thing about emergency vehicles is that they normally slow WAY down at conventional intersections anyway, especially if they have to run the red light.
    Supposedly in the Netherlands, but I don't see how that could work in US, for the reasons stated by xrunner: if you don't have a stop or yield sign, you assume the crossing driver does have one.
    Even during the "learning curve" phase of newly installed roundabouts, collisions that happen are minor (fender benders) compared to light-controlled intersections due simply to the fact that traffic is all flowing in the same general direction at a roundabout. At conventional intersections, T-bones and head-ons are the ones that cause fatalities and serious injury.
    Regardless of statistics, though, people are always going to be resistant and/or hesitant of change. We are creatures of habit. ;)
    Found one link relating to removal of signs and barriers intended to protect pedestrians in England.
    "Pedestrians and motorists, faced with the need to be more aware of their surroundings and take greater care, have responded positively."
    And this link talks about how less signage for cars works in the Netherlands.
    It makes sense to me. People, in general, are only as responsible as is expected of them. Ask any overly-protective parent how well that works out for the children..... once the children are grown, of course. ;)
    Thats the one I referenced, Golf road (we used to call it goffer hole road) just before it goes under Northwest Highway (which really isn't a highway) or just after depending on which way you go. I used to use that roundabout all the time (maybe 3 times a week) during rush hour and really never had much of an issue.
  • andre1969andre1969 Member Posts: 26,141
    from a rained-out trip to the Cedar Point amusement park in Ohio. On the ~430 mile trip back home to Maryland, spent mostly in downpours, here are a few of the highlights...
    Unidentifiable car in the ditch on the Ohio turnpike, submerged up to the roof pillars in water.
    Chevy Aveo on the Ohio turnpike, kissed the median strip barrier, which did a good little number on the front-end.
    Pontiac Aztek, upside down and facing the wrong way, coming out of the fog off a mountaintop in Maryland
    2002-2005 Ford Explorer on the I-70 median, looked like it rolled a couple times, ended up right-side up, about 20 miles west of Frederick.
    Unidentifiable car off in the woods at an exit ramp on I-70 in Maryland, surrounded by rescue personnel.
    We've been going through a major dry spell around these parts, but suddenly a rainy front came through Saturday nite. Guess people suddenly forgot how to drive in the rain? :sick:
    Seems like all that dripping oil and other stuff on the tarmac gets pretty slippery when it rains. The CHP is notorious for pulling people over when it sprinkles to warn them about driving hazards after a light rain (and these are people who are going the speed limit).
    Naturally. The others are going way to fast for him to catch. ;)
  • im_brentwoodim_brentwood Member Posts: 4,883
    Andre,
    The Aztek wasn't an accident, it was proof that there is a god.. heh heh.. couldn't resist.
  • oldfarmer50oldfarmer50 Member Posts: 24,631
    I just had to get my two cents in on the roundabout issue due to several recent experiences.
    At the intersection of two well-traveled road in the middle of town there is a traffic circle. Over the 40 years it has been there it has been the scene of multiple accidents usually due to drivers failing to yield right-of-way.
    NYS in it's wisdom redesigned this circle several years ago so that people would stay in the same lane all the time they were in the circle. Large signs and pavement markings gave people ample notice of which lane they should be in for example: "Rt. 9 south right lane" or Route 2 west left lane." Simple really. In addition, it has always been the law that cars entering the circle must yield to those in the circle or exiting the circle.
    The other day I'm driving through the circle in the inner lane when a woman in a mini-van makes a 90 degree turn in front of me while changing lanes. (Remember, changing lanes is a no-no). I honk and get the finger for my trouble.
    A few days later I'm in the same position when a woman yacking on a cell phone blows through the yield sign as she enters the circle and comes within inches of getting T-boned by me.
    I guess the most high tech solution can't compensate for the circle jerks. :sick:
    I can see it now...
    God: Wait a minute there are still some Azteks on the road????!!!!! :mad:
    Grrrr
    Lighting Bolt boom crash flipped over Aztek. :sick:
    One of the first roundabouts I experienced was in Cornwall NY off Rt 9. :) Some of it is a learning curve, but that doesn't account for the idiots.
    As I said before, I love roundabouts. My only complaint is that people should use their turn indicators when exiting so that those waiting to merge don't have to guess if the car is continuing or exiting.
  • redmaxxredmaxx Member Posts: 627
    a parking meter or a Red light camera. In this day and age of science a human is not necessary to enforce and fine the tresspasser. It is not important that the Red light company gets to keep most of the fine, what is important is the driver meets justice and should pay dearly for driving with the attitude that his journey is more important than my safety.
    Darn it! I missed another red light camera debate. Oh well, I can add my two cents again.
    You make the mistaken assumption that the equipment is infallible. This is a highly invalid assumption, since we have already seen a camera on the 101 "catch" a driver going faster than his car could go. Also I had a defensive driving class years ago, where many people that were there, with pictures to prove it, were wrongly issued tickets.
    Let's recap:
    Red light cameras:
    - Issue tickets well after the fact, they do not give immediate notification.
    - Issue false postives
    - Are used to reduce police presence
    Red light cameras do not:
    - Catch drunks
    - Catch distracted drivers
    - Catch illegal lane changes
    - Catch equipment problems
    - Catch drivers without headlamps
    - Catch right on red
    - Are often used only on the most traveled direction
    - Are not used at every light
    - Are used to violate your constitutional rights
    And that's just the short list. In this day and age, we should not accept anything less than an intelligent human being providing true, complete enforcement to our roads. We should not accept these poor revenue enhancing substitutes.
    Violating one law to catch people breaking another? I see motorcycle cops hiding on the sidewalk, catching speeders on the local speed trap (and it is the very definition of speed trap). Since it is illegal to drive on the sidewalk, how do they justify driving on it to set up shop when there is no crime being committed?
    Well, if you're speeding and the cops chase after you, then they're speeding too, aren't they? I dunno if that argument would hold up in court, though! :P
    Seems to me though, that a motorcycle cop hiding in ambush on a sidewalk is an accident and lawsuit just waiting to happen. Especially if it's a sidewalk with a lot of pedestrian traffic.
    This is different. They're authorized to speed to catch speeders. But when they drive onto the sidewalk, there is no crime being committed, so how is it legal for them to do that?
    using that logic we should stop enforcing the law altogether as nothing is infallible. People get falsely accused all the time and some even get falsely convicted.
    For most of what you say they are not supposed to do those things, but they can free up resources that can go after those. But let me address a couple of them.
    All the ones I have seen have them in every direction.
    You have a constitutional right to run red lights? I think that argument is a stretch.
    THANK YOU
  • grbeckgrbeck Member Posts: 2,358
    snakeweasel: For most of what you say they are not supposed to do those things, but they can free up resources that can go after those. But let me address a couple of them.
    Except that they don't "free up more resources" to go after those other offenses. There has not been a corresponding increase in police patrols with the use of red light cameras.
    Plus, just the presence of police at an intersection, even while pulled over with an offender, has a deterent effect on other drivers - and not just with red-light running.
    snakeweasel: You have a constitutional right to run red lights? I think that argument is a stretch.
    That's not what he said.
    Suggesting that the accused retains the right of due process and the right to confront the accuser, even for a relatively minor offense, is not the same thing as saying that the accused has a right to commit the offense.
    This is pretty funny
    I am sure some of the blindly deferential/inheritance elite/crony capitalist/imagined tycoon types here will still defend the revenue enforcement scofflaws.
  • imidazol97imidazol97 Member Posts: 27,788
    I love it!
    There's a whole series of Jimmy Justice videos on Youtube.
    This one
    Youtube.com jimmy justice
    Shows the side of a police car parked in front of a fire hydrant. Does it say "Courtesy" on the back door? I'm having trouble reading it.
    You forgot again to include: the independent business man capitalist who worked his way through college to have the privilege of employing thousands, most of whom think the military industrial establishment is out to get them.
    You forgot to include the retired military officer who defended you in two wars after spending most of his adult life in harm's way.
    You failed to mention the elite business person who took many business risks to make it big, but others haven't the testicular fortitude to do the same because they are "satisfied" with their little financial cocoon, thanks to union mentality.
    I have issues with youtube from work, but I will check on it at home. Sounds like amusing stuff. Practice what you preach, this should be taught to the revenue enforcers.
    I should make a youtube video of the sticking stoplight on my morning commute (which I had to run again the other day). I am sure a red light camera would be justified in nabbing me there, and I should be expected to sit and wait for maybe 30 minutes until another car comes along to maybe trip the switch.
    Luckily, my fair city, while completely unable to sequence lights and manage traffic, has not resorted to lowest common denominator tactics such as these cameras which truly exist to subsidize yet another well-connected pseudocapitalist.
    My bad, I often forget things that don't exist
    Defended me, oh time for the hip waders.
    Capitalist...hehe...some believe that actually exists, in their little realm of bizarro world socialism where the many fund the good of the few :P
    Let's get back to the drivers please.
    Coming back from the dentist this am, I signaled and moved into a plenty big enough gap so I could get over to the left lane for a shopping errand. Got beeped at by some yahoo in an X5. I flipped 'em off with a peace symbol - my license plate holder may have to come off my Outback so I can flip with impunity, lol.
    See more Car Pictures at CarSpace.com
