Honda Odyssey: Problems & Solutions:(1995-2004 Models)
1969799101102126
  • macakavamacakava Member Posts: 775
    Great! Congrats.
    It would appear that you go one of those that "fall on a certain production day". Loos connection would do it.
    I have never had to return my Ody back to the dealer for any repairs in the past year I had it.
    Happy July 4th
  • sjvsjv Member Posts: 14
    Having received no feedback from the numerous Odyssey owners on this forum, I've answered my own questions..........thanks. :P
    1. Yes
    2. No
    3. Probably Terk
  • stahlbro2stahlbro2 Member Posts: 1
    Chetan,
    There seem to be 2 fuses for my Honda radio (2001 Oddessy). One fuse is the one listed in the owners manual and it only controls the constant power to the radio that keeps the radio stations programmed in memory. The fuse that controls the radio when the ignition is on is the same one for the AUX power outlets (the old cigarette lighter), The owners manual makes no mention of this. Check the fuse that controls these outlets.
    Best regards!
  • jmnygaardjmnygaard Member Posts: 48
    My husband let our daughter and niece watch a video in our '02 EXL on aux power for quite a while. When I went to turn the van on, the battery was dead. We jump started it and now the electrical system seems to be messed up. Specifically, the lights flicker on and off (so I have now turned them off), the driver door open indicator flashes, and the doors either won't lock, or unlock by themselves after being locked.
    This happened Sunday on vacation. It seemed to be okay for most of the trip home, but yesterday, after not driving it most of the day, the problems came back.
    Any suggestions on what to tell the dealer? How much is this going to cost to fix?
  • sebring95sebring95 Member Posts: 3,241
    I'd start by replacing the battery. It may have been on its last leg to begin with if it was the original. Bad batterys tend to make cars act goofy and your situation would certainly make me suspect that.
    I have to agree on that.
    I noticed a month ago that the battery on my Lincoln was getting weak when it was turing the engine slower than normal. The electronics/memory for all the toys were also not functionaing properly. The battery was 4 years old and I have always changed my car battery every 4 yrs, irregardless of its condition. So it was time. I have always preferred to change batteries on my terms instead of being stranded somewhere.
    TO make a long story short, I changed the battery by getting the biggest one that could fit under the hood. Got a $58 Walmart MAXX brand rated at 1000 CA/830CCA and installed it immediately. Since I do this every 4 yrs, I do not really care about the brand - besides Walmart will honor any warranty issues with no hassles. Engine nows turns fast and all electronics are back in order.
    What happens is that a weak battery has its voltage dropped a noticeable level below its 13.5V to affect the vehicle electronics and the power to crank the engine.
    So I would change the battery in your car with the most powerful one to fit under there. I believe that you would have to reset the radio as well when power is disconnected.
  • mhillmhill Member Posts: 1
    I just replaced the factory radio/tape player on our 2001 Honda Odyssey with a Panasonic cd/tuner.
    The problem? The CD sounds great; FM sounds great; AM sounds lousy (lots of static) and I like to listen to NPR on AM.
    Has anyone else had problems with AM reception after they switched out the factory unit?
    Has anyone had SUCCESS with a cd/tuner that got good AM reception in their Odyssey van?
    I realize the problem might be with the cd/tuner, but I traded the Panasonic for a Pioneer (both reputable) and had the same problem. It could be that they're simply focusing more on XM/FM at the expense of AM, but I thought I'd seek the advice of others.
    Michael
  • irongalirongal Member Posts: 1
    My DVD player worked great last week but isn't working now. Yesterday I drained the Odyssey's battery and needed to jump it. After entering the "security code", the CD player and radio work fine. The DVD player power seems to be on (the power light is green) but I can't get the previously loaded DVD to eject, play, or respond to the controls at all.
    I see from some discussions above that it might be the battery but the battery is pretty new ('05 Honda) and everything else is working fine. Any thoughts?
  • dave594dave594 Member Posts: 218
    Did you make sure the RF filter was put back or installed with you put in the new radios?
  • carolinablondecarolinablonde Member Posts: 2
    It bothers me too! But I wouldn't have noticed it unless the little triangular piece on the side of the dash(right at the glove box) between the dash and door didn't keep popping out. I thought maybe my glove box being out of whack was causing it...
    Were you able to adjust it? I'll try adjusting mine tonight..though I don't buy the 'early build' issue. Mine was built in mid May and still had the glove box issue. Mine also has the triangular piece between the dash and door jam(beside the glove box) which pops out constantly. Does yours do this?
  • yczycz Member Posts: 25
    fibber2:
    You are right, I have rear disk brakes. Thank you for theadvise. My friend's brand
    new Acura has the same squeak, the dealership said the same thing - won't fix the squeak since the brakes work fine. I guess I will just wait until change the brake pads. My wife divers the van most of time, she does not notice the squeaks as I do (She is fine with that!)
    lastwraith:
    Thank you very much for the advice on watering brakes. I guess I have to
    stop doing that. I did not realize the consequences.
    Thank you both again for your advices.
  • tawneycattawneycat Member Posts: 114
    I have pasted a bunch of VCM info in order to get this going again.
    Let me know if I have dog ears....
    1) I liked WCM at first but now I have 6,000 miles and….
    2) Either I am attuning to VCM freq and being annoyed or the annoyance is actually growing worse.
    3) My 72 year old father noticed the vibration/hum/rumble when highway driving and slight downhill coast at 60 mph. In fact it got pretty noticible. Not tires not anything but definite engagement of VCM. Floor the gas and go on smooth and nice.
    4) anyhow, I now wonder if VCM feature can fail either the radio portion or engine mount portion.
    I admit when new it seemed near perfect and not overly detectable but I could discern the engagement.
    I have some mild mid range hearing loss as does my father. Funny if the audio challenged ANC the ANC. Kind of a counter counter measure!
    pasted from other forums...
    VCM is very noticeable. Whenever it kicks in you can feel a slight vibration in the steering wheel. I could feel this on every oddysey that I drove although it seems to be more pronounced now that I have a few more miles on my van. At first this didn't bother me but now It kind of makes me wonder how long it will be before it breaks or the vibration becomes even more pronounced. I expected more from honda.
    According to the service manual there are two microphones but I have not found specific reference to where they are located.
    To test the ANC (cliff notes version from the service manual):
    Shut all the doors
    1) Turn ignition switch to ACC or ON
    2) Turn radio off
    3) Press and hold presets 1 and 6. While holding them push the PWR knob. Release the buttons and the radio display should say "DIAG"
    4) Push preset 1 and it will display "ANC ON". Push it again and it will display "ANC OFF". When it displays ANC OFF you should hear a low frequency (50 hz) hum for about 1 minute.
    5) Start the engine while the hum is sounding. The hum should stop
    6) Test drive at 55mph. Enter DIAG mode, turn ANC OFF then back to ON and it should activate.
    should sound like a "low-frequency hum (50Hz)"
    With key in ACC (1) position.
    Turn off radio.
    Push & hold 1 & 6 preset buttons while turning on radio.
    "DIAG" text will appear on radio.
    Press the 1 preset button and the ANC will sound for a minute.
    Turn radio off to exit diag mode.
    When I drive and enter ECO mode and all is very quite I can hear just a very subtle low freq hum from the front or right around me. It is noticable enough to kinda bother me though. Maybe I just have dog ears
  • crjnccrjnc Member Posts: 1
    The passenger-side mirror on our 2005 EX-L had a close encounter with the garage door opening. (I won't say who was driving, but she feels very bad about it...) I bought a complete, genuine Honda replacement mirror on the internet for about 2/3 the price quoted for the part by my local dealer. It did not come with any installation instructions, but it seems pretty straightforward. The only challenge is that it appears I need to remove the small triangular panel on the inside of the door to access the bolts that attach the mirror. I'm wondering if someone out there has done this and can tell me the trick for pulling/prying/sliding this cover off in the correct manner? I'd hate to force it the wrong way and end up damaging the cover. Any advice would be much appreciated. Thanks!
  • breindersbreinders Member Posts: 23
    carolinablonde or gizzanks,
    Did either of you try adjusting the upper glove compartment door? Any success?
  • rockycow33rockycow33 Member Posts: 76
    I posted a msg that my 99 ody tranny went in the tank at 106K. It was replaced and 300 miles later I am waiting on another tranny to replace the faulty rebuilt. One would think by now Honda would have sorted out the tranny malfunctions. The new rebuilt is still drivable with no CEL light on but it is noisy.
    :confuse:
  • ldwohlldwohl Member Posts: 1
    I had the same problem...even dented the tailgate! My solution was to get a piece of pipe insulation (I think that's what it is).....you can cut it any size....and I just put it on a part of my garage door so it cushions the tailgate when it's raised!
    It probably is time for a new battery, but it turns out that wasn't the "electrical" problem.
    I noticed that the only "alarm" type light that was flashing was the driver door open indicator. If the door wasn't shutting for some reason, that would mess up the lights and the door locks, right? And right before the battery went dead, my husband had slammed the door on the buckle part of the seatbelt; it bounced off rather than shutting. When I told my husband what I thought, he rolled his eyes and said the van clearly had "major problems." Well, it's my vehicle, and I know it really well, so I was still thinking it was the door.
    Anyway, I took it to the dealer. When the guy asked what was wrong, I told him it was a long story. He rolled his eyes, too, but luckily he listened to me anyway. He called over the body shop guy to take a look. Sure enough, slamming the door on the seatbelt buckle had dented the door frame right where the button that senses the door is shut is on the frame. So every bump or jiggle made the door loose contact with the button, and the door indicator light and interior lights flashed on and off! It took them a couple of days and $280 to pound out the dents and repaint the door, but I haven't had any problems since!
  • imidazol97imidazol97 Member Posts: 27,734
    And you aren't going to remind your husband that you figured it out and you were right, are you...
  • kmj2kmj2 Member Posts: 1
    We are having similiar problems with our run flat (Dunlop) tires on our '04 Toyota Sienna XLE AWD. We just had to replace all four tires at 13,900 miles (at the cost of $1200.00) Tire availabilty is very limited and many owners are experiencing uneven and premature wear on their run flats. Wondering if Honda is having the same problems? May be too soon to tell. See Toyota's forum to read the frustration of many Sienna owners. Unfortunately, no one is taking responsibility for this defect...our dealership told us to rotate the tires every 3000 miles and check tire pressure every two weeks. How ridiculous... I am beginning to think these run flats are not worth all the work. Hopefully Honda will have better luck. Time will tell...
    I wish I could! But Wed., June 29th, we left Knott's Berry Farm (L.A.) for Yosemite, ordinarily a 4-5 hr. trip. A tractor-trailer carrying jet fuel had crashed on the "grapevine," closing interstate 5 in both directions for hours. It took us 2 hrs to go 6 miles, then we got turned around by the CHP and had to take an alternate route. It took us 12 hrs to get to Yosemite! He drove that day and, in fact, for the whole vacation, so I really can't rag on him just because I know my van better than he does! :) (And thanks to the DVD, our 6 yr. old didn't complain at all!)
  • joanrjoanr Member Posts: 1
    my 04 odyssey makes a high pitched whine upon acceleration, even at low speeds, stops when taking foot of gas, then starts up again. service tech said all do. i have test driven others and they do not have this noise. Any ideas?
    also, any suggestions for securing a canoe on top.. where to best install tie down bolts? thanks
    hopefully, the whine is from a belt. when the car is in park, can you get it to whine by pressing on the accelerator? if yes, then someone should be able to listen to the engine with the hood open and help you locate the general area of the sound for relating to the tech (I presume you are bringing it in).
    if no, i.e. the whine only happens when you are in drive, it *might* be the transmission. in this case you really need to drive the vehicle with the tech (again, i presume you are bringing it in).
    no - you are correct, other odysseys don't have a whine when you press the accelerator so get it checked out. you should be under warranty anyway right?
    now then - canoes and proper securing... you mention tie-down bolts and that is confusing me. first things first - do you have roof rails?
    on the LX trim odyssey, the rails and cross bars are optional. on EX and above, i believe the rails are standard but the cross bars are optional. what configuration do you have? i'm thinking to secure a canoe, you have to at least have rails (rails are the things that go front to back on the left and right of the roof).
    personally, i would not let the canoe sit on the roof itself.
    for cross bars (if you don't have any) you *might* be able to use modified pieces of 2x4" lumber. you'd have to secure a couple of pieces to the rails (and i think i'd modify them so securing them to the rails was easier and solid), then have the canoe sit on them. then you'd secure the canoe to the rails and the cross bars / lumber. you don't want the canoe or the creative cross-bars moving, so it's all about securing using a good technology. using elastic "bungie cords" might or might not work.
    remember also, you need to secure the canoe properly so that even in a panic stop, it does not leave the roof but stays in place so side to side securing is important, but so is front to back. a canoe is not a christmas tree. ;)
    to do it right (say you didn't have cross bars), i'd probably go aftermarket for some strong cross-bars capable of carrying more load. the main point is - you have to have rails at least and cross members for the canoe to sit on. aftermarket probably even has special devices for canoes. is there an odyssey accessories forum? you might ask there as well.
    good luck.
  • walynmacwalynmac Member Posts: 1
    My 2001 Ody has 87,000 Kms (Canadian) & the service manual says to change the timing belt at 100,000kms, if operated in severe conditions, like -29C. If not in severe conditions, then change after 160,000kms (100,000 miles). Since we have never driven it in winter conditions in the Canadian midwest as we go to Arizona for 6 months each winter, my thinking is we should shoot for the 160,000 Kms schedule. My concerns are, is this correct thinking & am I risking a expensive repair bill? We will heading south in a couple of months & don't relish changing the belt before we leave, which will only be in the low 90kms. Maybe shoot for next summer or later. Any experiences out there would be appreciated.
  • soz05odysoz05ody Member Posts: 12
    Hi, All,
    My first post here... I'm supposed to pick up a new Ody EXL RES NAV tomorrow (I'll post pricing once I really get it, but it sounds promising).
    I'm a long-time Honda fan, but our 2002 Accord V6 EXL bottoms out coming out of our driveway, which is kind of steep. I just noticed that the ground clearance of the Odyssey is about 2 or 3 inches (a lot) less than the Sienna (which I tested in my driveway and barely made it). Problem is that the Honda dealer is kind of far away to test it in the driveway, but I don't want to take delivery and then have a problem.
    Would you be concerned?
    :confuse:
    Dave
    Since you have a "unique" situation with a steep driveway, I would want to test the Ody like you did with the Sienna to make sure that you have the clearance.
    Even though the Sienna barely made it, do you know how it will fare with passengers and load? I have seen some folks driving up their driveways at an angle to clear the ground.
  • dgreene1dgreene1 Member Posts: 9
    Hi. I apologize if this has been asked before...
    Got a chance to drive my wife's '04 LX this past weekend around the hills in Pennsylvania and noticed some pecularities with the tranny shift lever on the vehicle. There were times, especially after a start, that I could not shift from D to D3. The user manual also indicated that I should be able to shift from D to D3 without pulling the lever forward... I could do that with the van stopped (shifting from Park) but not with the van moving. Am I missing something here???
    Note that my van only has 14K on it and it's VIN falls outside of the range of vans identified with tranny problems.
    Thainks for your help!
  • marine2marine2 Member Posts: 1,155
    Just had to comment on the center tray. It is one of the many things I love about the Odyssey. It is the perfect place to stick your purse, completely out of sight! I am on my second Oddy and really miss that space when I don't have it.
    If you think that center tray is nice on the Ody, you'd flip if you saw the storage in the two wells near the middle seats of the 2005 Dodge/Chrysler. You could put just about anything you could put in that big well behind the Ody's third seat in them and it would also be out of sight. Gobs of room.
  • jntjnt Member Posts: 316
    Michael,
    Most OEM radios have better AM reception comparing to the Aftermarket equivalent.
    For Aftermarket unit, the emphasis is always on Audio Fidelity: more stereo separation, more high frequency audio content and Bass boost. All of this stuffs, on the flip side, generate more noise, especially for AM. On top of that, the Aftermarket unit probably has a cheapo AM tuner just enough to make sound
    To have better AM reception, two things are needed in the radio: better AM tuner sensitivity and reduced Audio bandwidth (for weak signal or far-away stations). You, of course, can not change the tuner sensitivity since it is the hardware of the tuner. But you may reduce the static noise by turning down the TREBBLE knob. If your radio has Autotone function, select "TALK" option. It will reduce the audio noise for you. BTW, reducing Audio bandwidth for both AM/FM is the trick that radio engineers do to reduce FM Multipath noise and also AM noise for OEM radios.
    Another thing is radio antenna system: AM is very fuzzy about having a good antenna connection. If your connection is bad, your radio will lose quite a bit of sensitivity. Having say that, the antenna co-ax cable is also important. For whip antenna (antenna rod found in vehicle fender), the shorter the co-ax cable, the less signal loss. Also not all co-ax cables are created the same: some has more loss than others. The lower loss cable, the better.
    jnt
  • garygary Member Posts: 39
    I have an '05 EXL-RES. Has anyone noticed the volume on the wireless headphones seems to be inadequate? The battereis are new but I have to turn the volume to the maximum but the volume still seems to be low. I also get a fair amount of hiss as well.image
    Is there an adjustment somewhere in the system to increase the 'master' volume?
    Please advise.
  • aggie76aggie76 Member Posts: 266
    I'll let expert owners reply but the sales guy showing us the van last Saturday had to adjust some volume control on the dash as my son had same complaint.
  • danesidanesi Member Posts: 11
    2005 odyssey with 12K miles. Front brakes making grinding noise after three or four successive stops in high speed/ high traffic situations. no noise with normal driving/ no loss of braking ability. Dealer can find nothing wrong/ no tech bulletins.
    This is our third odyssey and we know there is a problem. Van was delivered in November
    Any ideas on next steps ??
    PDanesi
    My wife cannot pull the outside door handles on sliders to easily open them.
    Dealer feels they are within spec and states there is no way to adjust without extensive repair. Using key fob to open not always an option for her.
    Any similar experiences or fixes ??
    P Danesi
  • jjtrindcjjtrindc Member Posts: 24
    The brake noise you describe is one that others have had issues with as well. A lot of vans that came off the lot in late '04 seem to be experiencing this - though that is a generality. Seems that the issue is the design of the brake pads themselves. Deglazing the pads and resurfacing the rotors will only fix the problem temporarily. From what I've read, Honda still has not put out a service bulletin so your dealer's statement is correct. The good news is that there is no safety issue here. Next steps, make sure your dealer logs your problem. I would also call Honda explaining your problem and get them to open a case file. Also, do a bit of research. Search this forum and the 2005 forum for braking issues to collect information to build your case. If you e-mail me I can point you to other info on this particular issue. Honda will only work on this problem if enough people complain. Good luck.
  • jaysmithjaysmith Member Posts: 2
    I too am very disappointed with the 2005 Odyssey interior light settings. What kind of fools do they have creating these things? You have 3 settings to choose from for the interior 2nd and 3rd row lights: always on (for when you're parked and reading), always off, or turn on when the door opens. The problem is, they don't turn off when the door is closed, leading to a dead battery!! So, if you have it set to the third option, the light will thankfully come on when you open the door at night when you take your kid out of the car seat, but then you either have to a) click all 4 lights off manually, or b) go back to the driver's seat to click them all off at the main setting switch (first option), and then click back to the third option so that the lights will come back on should you load your kid into the van the following night. Or, you can leave the switch in the off position, but it is awfully difficult to load your kid in the dark, so you need to visit the driver's seat first to switch them to "all on" and then make sure to click it back off. Ridiculous. The third option should be truly activated by the door - open the door and lights on, close the door and lights off. Isn't this basic? Thanks Honda. Still haven't fixed my whistling windshield yet, another bonus for $30k.
  • sjazsjaz Member Posts: 7
    I have a 2004 LX and have started to notice that the passenger side slider door will automatically close if left open for any period of time. I was cleaning the car with the door open without the keys in the ignition and the door closed on me after approximately 5 minutes. This has happened several times and noone was using the remote, touching the buttons by the steering wheel or touching the door handle. I looked in the owners manual and didn't see anything that mentions a time-out feature on the doors. Are they supposed to automatically close if left open for a period of time? There have also been a few occasions where the door will partially open and then stop. It won't respond to the handle on the door or the remote. I have had to manually pull it closed and then it works again. It hasn't happened a lot so I'm reluctant to take it to the dealer since they probably won't be able to recreate the problem.
  • rshtrsht Member Posts: 277
    P Danesi, We also have the same experience with our 05 Ody sliding doors. I know 6 other people from work are with the same concern. A couple of weeks ago, we all drove our 05 ody to work and made a side-by-side comparison. Yeah, 2 of them although felt a bit easier/lighter but still not as easy to pull as the front doors... I guess that's the way they are... Oh! By the way, one of the guys did re-adjusted the "stricker" position and made his sliding door inoperable and had to bring his Ody to his dealership to re-position the door stricker, sensors and etc...
    Yeek!
  • rorrrorr Member Posts: 3,630
    I'm confused. :confuse:
    My wife and I have an '05 EX-L. We leave the switch in the 'door' position. The lights come on when the door is opened and then after a time delay of 20-30 seconds after the door is shut the lights go out. The only way (for our van at least) for a light to STAY on is if that individual light has been manually turned on at that position.
    Personally, I think the time delay should work on those individual lights which have been manually turned on as well. So far however, we haven't had a problem.
    That's the problem...if the lights are turned on individually. We used to come out and get in our Tahoe and after starting it up find one/two of the interior lights on. The Tahoe would turn off all lights after 30 minutes if they were left on, regardless of how/why they were turned on. We've been doing double-duty to make sure this doesn't happen as folks have run their batteries dead leaving the lights on. Especially since we mainly only drive it on the weekends so it may sit several days. I've considered buying a battery protector, as it's probably bound to happen.
  • lyantoslyantos Member Posts: 2
    I've same problem. I can hear a clunking sound at the bottom. Did you figure this problem out?
  • lyralyra Member Posts: 1
    I am interested in purchasing a Honda Odyssey, yet I have been told that they often have transmission trouble. And then, in confirmation of that, we were going to check one out at our local dealership, only to have it taken off the lot due to transmission problems. It didn't pass the Honda certification process (it was a 2000 model). So I am puzzled. I've found Honda to be the most reliable vehicle (I've owned two Accords myself), but the transmission rumor does concern me. Although it appears to do well in Consumer Reports, I am still worried. Any opinions would be appreciated. I wonder if a certain year/model is more prone to difficulties. Or maybe over a certain amount of miles. Any ideas? We'll be checking out a 2001 EX Odyssey tonight.
    Lyra
    I am hoping that your whining noise is not the transmission. However, we just had a replacement tranny develop a whine at the gitgo and after 300 miles on the new rebuilt another is on order. My daughter discribed the noise as the whine a jet makes when it takes off, my wife (it's her car) has tinnitus and the whine added to her missery. Remember that Honda has a 100K warranty on the tranny. Oh, yes, the whine would ebb and flow with the accellerator, as you push on the gas it would increase and seemingly go away when you took your foot off the accellerator pedal. I would take your car to the Honda dealer you like best and voice your complaint and have them check it out.
    good luck,
    rockycow
  • ajahnkeajahnke Member Posts: 1
    I have a 2003 EXL Odyssey w/ the same problem. Many trips to the dealer, no solution. This is my first Honda and I'm learning to hate it and the company. MACHZ1000 - I see that you posted in March. Any luck in fixing this yet?
    The steering wheel also shakes at 70 mpg. Ug!
  • masterpaul1masterpaul1 Member Posts: 421
    Do a name search in this topic forum "transmission" and you will see the problems that people have had and what model had them. :)
  • xxonxxon Member Posts: 13
    Hello fellow Odyssey officianados! I've just had the transmission replaced in my 2000 Odyssey (66,000 miles). The transmission was hesitating between 2nd and 3rd gear and it banged when going into reverse. I have a question about the rebuilt 4-speed Odyssey transmission that Honda just placed in my vehicle. I'm wondering what makes this transmission any less prone to problems? What has Honda done to beef up the original design?
  • lastwraithlastwraith Member Posts: 350
    But for all the Ody owners who hear a grinding when they brake, why don't you (or have someone who is even remotely handy) switch out the brake pads for something else. You can even change the rotors for a small price. Ceramic pads are softer and generally superior to what is on your car in just about every way except for wear and price. NOW: I am not saying that Honda should not placate you by doing this themselves especially considering it takes about 30 mins and minimal investment on their part to make a customer happy, BUT if it was really annoying to me and I was convinced they were not helping then this is what I would do.
    Driving a car that annoys you every 4th braking instance is pointless. Spending under $100 on parts to keep myself happy in my car is worth it (to me). I understand you are all unsatisfied and angry, but I'd rather be happy and out the $100. Just a thought.
  • stickguystickguy Member Posts: 53,889
    A known problem being discussed on another Ody forum. SOunds bad, but doesn't affect the performance. It seems to be related to the pad composition, which is casuing them to glaze up.
    So far, there are rumors tha honda is going to issue a revised pad, but they aren't out yet. The aftermarket is just starting to gear up for it (trere really aren't any other choices at this point).
    Best bet is complain to the dealer, but don't let them turn the rotors. You can also start a case with Honda customer care, so they can build up a database of complaints.
    My guess, they will issue a new pad in the not too distant future, and probably put out a TSB about the noise, so some folks will get a free brake job.
    Whenever mine wear out, I will go with a high-quality aftermarket pad, which should be easy to find by then (I hope).
    Sadly, you are right. There doesn't seem to be anything available aftermarket. That's ridiculous.
    Some disgruntled '05 Ody owner should start selling an alternative, they would clean up.
    do you hear a rattle from the right front strut going over little bumps? it could be the strut / strut tower interface. there are welds that might need deburring with the application of lubricant and re-assembly required. i think the Pilot or MDX had similar issues and a TSB was developed for it if I'm not mistaken.
    steering wheel shakes at 70mph (h) ? ;) suggest you first determine if you have proper and nearly identical tire inflation pressure. you could have a tire with internal problems, a wheel missing a balancing weight, or you may need an alignment or all the above. do you have excessive tire wear? may be time for a new set.
    I believe that the noise you are both hearing is normal. I hear it every morning after I pull out of my driveway and am about three or four house down the street. Approximately 10 mph or so. From what I've read, it has something to do with the VSA system engaging or self testing.
