i installed a bug screen right in front of the radiator and invisible from the outside. works great, protects your radiator and cheap! you can only see the screen if you look under the bumper or peek through the grill.
took me less than 30mins. to install it.
just buy fiberglass bug screen and cut to the correct size. it's better if you can get another set of hands to help you.
- remove 2 bolts/brackets that holds the radiator.
- lift the radiator a bit so you can slide the screen underneath it.
- lower radiator so it will sit on the screen and hold it in place. pull up the rest of the screen and use the bracket on each corner to hold screen in place.
- screw back in the bolts and you are done!
you may have a bit of pulling to do on the screen so it's tight. other than this, the install is real easy. i did this for my sienna van as well. works real great. lots of room between the grill and radiator for the 03' corolla so it's real easy to install the screen.
btw, cost of the screen was about C$5.00
good way to keep your radiator from getting damaged by rocks or bugs
jumbieman: I have not noticed this behavior of the cruise, and it may be that yours is malfunctioning...BUT, it is programmed to cancel its set speed if you drop below 25 mph, so if you hit the brakes and go below that speed, you are supposed to have to set the speed again.
Your fuel consumption figures are right on for a relatively new car, and well within the range of the EPA figures. There is nothing wrong with the car and nothing Toyota needs to do. Our '03 LE automatic ranged from 27-39 mpg, with a suburban average of 30-32, and a highway trip average of 33-37. The only way you are going to exceed 35 mpg consistently is to drive at speeds not exceeding 65 mph [which is how the high figure of the EPA estimates is achieved]. As an OVERALL avg, my usual rule of thumb is about 10-15% over the EPA city figure. If you do better than that, you're ahead of the game. And if you don't have at least 5000 miles on the car, it will continue to get gradually better.
The smell you refer to means you are using a gasoline brand that has an excess of sulfur in it; not unusual depending on where in the country you are, and who is the supplier of the crude that the refinery is using. Switching brands sometimes helps. Where RFG is used [CA, some parts of Oregon, some areas of the NE], this happens less often because the RFG formula calls for reduced sulfur, which incidentally will eventually happen nationwide, though not for a few years yet.
And no, there is absolutely no connection between the smell and your fuel consumption - which, as noted above, is well within the parameters you can expect for this car.
Having said that, measuring fuel consumption can only be done religiously with a log book and a commitment to doing the calculations on every fillup. I do and have always done. If you do, then you've got accurate figures. And NOTHING varies from car to car and driver to driver like fuel use - that's why the EPA tests are just benchmarks. Most people will have a hard time matching the EPA figures [which is where I got my 10-15% over the city number from], and there will be the occasional cotton-foot who can consistently beat the EPA numbers.
An automatic '03 Corolla that averages 30-35 mpg is "in the lane" ... I was merely reacting to the claim that it should somehow be dramatically better.
For a good real-world benchmark, the fuel consumption that Consumer Reports publishes with their road tests has, in my extensive experience, been VERY close to my overall annual average for most cars I've owned [and I've had 50 new cars in the past 37 years].
Anyone else have the same problem?
would give this big "clunk/jolt" when you shift from park to reverse.
did you check your tranny fluid just to make sure it's on the right level?
As for fuel economy...in all 5 previous Toyotas, I have consistently gotten 2-3 MPG above the highway rating on trips, and that is driving with the flow of traffic on interstates. On a trip 2 months ago, I got 29.5 MPG from my 1998 Camry V6 which is rated at 27. If the dealership can produce 37-38 MPG on a fuel diagnosis scan of the 2003 Corolla, it means my car is capable of getting that kind of MPG. Yet I haven't been able to reproduce that MPG on several tanks of fuel, no matter how I drive. I disagree with you when you say there is absolutely no relationship between the smell and fuel economy. The sulfur smell is intermittent. I believe that when the car emits the odor, it also delivers very poor fuel economy.
As for the sulfur smell being caused by the gasoline, and not the car...in the past few months my family has owned a 95 Corolla, now replaced by a 2003 Matrix, a 96 Tercel, replaced by a 2003 Corolla LE, a 98 Camry V6, and a 2001 Echo. We each use 2-3 different brands of gasoline in each of the vehicles. Why is it that the only cars emitting a sulfur smell are the 2003 Corolla and Matrix?
Re egg smell, I have seen many complaints about it on this forum. You may want to search in this or similar board. It sounds like a small percentage of Toyotas has this problems and it may be difficult to repair. Someone had to replace converter to get rid of it.
Good luck and keep us posted.
We have never had this problem since going to RFG in our CA cars, including our '03 Corolla. Your profile gives me no clue as to your location, but I will bet it is not in an RFG state.
The catalytic converters in these cars [to achieve ULEV certification] do NOT like sulfur at the levels that some refiners can still legally get by with. Complain to your Congressperson about the ridiculous amount of leeway that the current law gives the oil companies to get the sulfur out of our motor fuel. This issue was settled in Europe many moons ago. We will have to wait years more for the current law to solve this problem nationwide in the USA. It is also why we can't use the clean diesel technology that is widespread in Europe - the crap that gets sold as diesel in most of this country is poison for the emissions systems.
In order to validate this as a 'it's the gas' problem per jrtc9454 suggests, go to your Toyota dealership where you bought your car and go test drive about 3 or 4 used Toyotas on the lot. Tell them you are shopping for your college kids, or if you are too young, you are shopping for your Mom.
If they stink with the windows down like jrtc says, hey, then maybe it is the gas in your area.
You can also try Toyotas at another dealership to cross check.
If the cars you test drive don't stink, then your car has a problem. If the dealership doesn't deal with it and fix it, put them and Toyota on a lemon law "3 strikes and you are out" plan.
Hydrogen Sulfide is a culprit the stink. It's chemical formula is H2S. It mixes with H20 (water vapor in the air) to give H2SO3 and H2S04, which are known as sulfuric acid. Long exposure to it isn't probably very good for you or your car. In areas of the country where high sulfur coal has been burned, it creates what's called acid rain.
Good luck!
As for going to another dealer to resolve the problem, I believe the dealership is saying exactly what they have been instructed to say. I don't believe they have been given any kind of notice from Toyota Motor Sales USA as to a way to correct the problem. And, until a number of displeased Corolla customers go on record, there won't be any effort to correct the problem.
Right now, I am communicating with Toyota Motor Sales USA. In the past, they have always come up with a solution for me. I'll keep you posted.
if you look under your steering wheel, sort of under the 9 o'clock and 3 o'clock position - you will see a hole on each side. do you have plugs covering these 2 holes? if look closely, you will see a screw/bolt inside. i just find it strange that toyota didnt put plugs to cover the holes.
my dealer said they dont know if those holes are left open on purpose or supposed to have plugs there.
And this is where I have no idea.
Based on an anecdotal story that converter replacement helped a previous poster here, one could assume that defective converter is the culprit. I bet that the converters are made by part suppliers and not by car manufacturer (but I don’t know for sure). Since converters contain precious metals (palladium I believe), it is easy to assume that the makers try to put as little of the good staff as possible to cut costs. But again, this is a speculation.
One more disclaimer: my chemistry knowledge bases on a high school course, so do not quote me in you correspondence to Toyota (and no, my 2003S does not smell like rotten eggs, not yet ;-)
There is a guy with only one car (of many) with H2S emission problem. He is being blamed for buying wrong type of gas with high sulfur content, even though he tried different brands and his other cars using same fuel do not stink. If lax US fuel sulfur regulations are to blame for H2S emission problem, how come our roads don’t stink like rotten eggs? Don’t get me wrong, sulfur in fuel and acid rain are big problems, but would not account for the fact that same cars stink regardless of fuel brand and others just don’t.
You almost sound like a doctor seeing a psychotic patient and saying “it is just in your head.”
The other issue. Nowadays, most people do not see any difference in mileage after break in period. I didn’t, other posters didn’t. Unless you experience clearly indicates otherwise, I see no sense in repeating this old truism, which is apparently not true anymore. Perhaps it was true in the past when the first oil change was needed after 500 miles and the used oil was full of metal shavings.
Irct, do you work for Toyota? You advice sounds exactly like the advice people are getting in the dealerships.
Jacek
Do any other Matrix owners share this problem?
Up to 23,000 km on my XR, no major problems, love my car!!!!!!!!!!
on the steering wheel, at 9 and 3 o'clock position... look sort of under or if you turn your steering wheel to the right/left, you will see 2 small holes at 9 and 3 o'clock. the holes are about half an inch in diameter and not covered.
you mentioned u saw this hole at 9 o'clock that is covered, probably the same hole i'm talking about. look on the other side and there's another one there.
on my car and many other corollas i saw, the two holes are not covered!
If you go back a million posts, back to the April to May 02 dates....many said the rotten egg smell goes away after a few hundred miles.
this happens everytime when your compressor kicks in to maintain the cool temp. you will notice this happen more when the weather is really hot and your a/c is on. when the compressor kicks in, your RPM rises... its like you stepped on your gas a bit so your car inches forward if its in gear. this happens only on cars with auto tranny.
you will notice this more if your car is a 4 cylinder. if you have a v6 or v8, you wont notice it very much unless you look at your RPM gauge.
now you know what is going on... all you do is when your a/c is on and each time you come to a complete stop, make sure you step on your brakes firmly. this will solve your problem of the car inching forward.
I've seen the previous posts re a scratching noise that comes from the speedomitor housing. This is defenitely not it. A sort of cracking sound. It may be coming from the windshield itself, and has only happened since it got colder. Less annoying, but there is: A slight vibration in the driver's side window at certain RPM when it's closed, a slightly squeeky clutch when cold, glove compartment makes a noise over big bumps, and a buzzing vibration at certain RPM that seems to be coming from the front passenger side speaker cover area. I'm a bit picky with noises, especially with a brand new car. Otherwise, I love it.
Also, apparently, it is very common for rattle/buzz to occur at speaker covers, and for a buzz to occur in upper dash area at certain engine RPMs. The master tech I had riding with me said there was no fix for these yet, but a certain amount of buzzing and even a little squeaking was to be expected from such an extensive use of plastic.
Check the kick panel in the footwell - passenger and driver side - it can be loosely installed and will buzz at certain engine speeds as well.
I think squeaks and rattles are inherent in a design that uses this much plastic. That is to say, I don't think they can really be "fixed". Nothing is out of order to cause them in the first place. They probably will get worse as everything on the interior loosens up.
For me, cars are a long-term investment usually, so I will grit my teeth and keep it a while because I do expect to have the longevity of Toyota engineering, but this may be a factor in the next new car NOT being a Toyota.
Thanks!!
Nice to know I'm not alone.
Imagine your car rattling and squeaking like a ten-year-old right from driving it off the dealer's lot!
On all these little cars, they use a ton of plastic, both to keep the price down, and because it is light and therefore efficient. But I think in recent years, Toyota has gone a little overboard. I have a couple of rattles that aren't even drowned out by the stereo unless it is pretty loud...
Problem is, I think most of the compacts and subcompacts out there are like this. I think the notable exception is Jetta and Beetle, BUT UNFORTUNATELY in those vehicles, buttons will begin to break off at 25K, the windows will quit at 40K, the electricals will be shot at 50K, and the transmission will quit at 75K. At least the Toyotas do not have these type of problems. While they may be annoying, they are cheap to own and operate.
