Regarding buying used, determing how the previous owner treated the car is something of an art. The best potential purchase is one where you can talk to the previous owner about the car. Things to look for are the maintenance records. If the owner took the car in for service religiously (all service intervals were performed at the earlier of time or mileage) and premium maintenance was performed (e.g. Mobil 1 was specified for the oil changes, brake fluid was flushed at a minimum of every 2 years, etc.), you can probably infer that the car was well-cared for. An absence of a comprehensive service history tends to indicate the opposite. Additionally, you can check the warranty repair history by running the VIN through a local Chevrolet dealer. If there are a lot of warranty repairs, you probably want to avoid the car.
Hope this helps.
thanks so much for the help..
I went to a dealer here in virginia, and he was trying to sell me a 97 Vette, with a C5 Body, silver, with the moonroof, 67000k miles on it. the exterior is SCratcheless..there is not one scratch on the body, the interior is great every thing works fine, the passenger seat is just a bit loose.
I was just wondering what hte performance numbers on the 97 are, is it 345hp and 350lb ft of torque.
Also its a 2 owner car and there are no serivce record, but heres why i love it,
21000$ for a c5 body 1997 with 67000 miles.
he can also sell me a warranty for 1500$ which covers everything except cosmetic, like some one scratches your car.
What do u guys think im in college, i can walk out the door paying $21,000 tags titles warranty and car.
My question is, how much do you think the car can go, ill drive it fast maybe floor it once a week, park it in a covered garage, what do u guys think. buy it or look else where.
Its silver.??
Thanks in advance.
The performance is probably close to my '02 6sp and with so/so driver I've done 13.3x in the quarter at 107, should do about 12.9 at about 111mph with some one who is good.
Be careful going Wide open throttle, it has a lot more torque than most and is easy to lose it, seen it done at the track and damage repair is expensive, if you are lucky enough to get away with hurting anyone. Keep it on the track.
Don't forget to wave.
Do u think i should purchase it, will it be reliable, as it will be my only car?. i wont be driving it in heavy rain as i have freinds with Suv's and We hardly get snow here?
At your age I bet insurance is a couple of grand a year.
Things to look for:
You said that it doesn't have a scratch on it.
What about the front end I would expect there to be nicks in the paint from stones and rocks. Are there any? If not it has probably been repainted.
Mechanical:
Have someone start it up cold while you stand behind the car to see if any blue smoke comes out of the exhaust pipes.
While the engine is running put it in reverse then drive then reverse again.
It should immediately go into gear. If there is any delay then there might be tranny probs.
Drive the car at various steady speeds 35,45,55, etc. and listen for any rearend gear whine.
If you hear a whine take your foot of the gas.
If it goes away then there might be some differential probs.
Also have someone drive the car away from you and see if it tracks true. No crabbing down the highway.
Check carfax for accident histroy.
On one of the Corvette boards there has been discussions on this issue and premiums vary WIDELY to say the least...some at less than $500 per year to $4000 per year.
Vettes to me are cheap to insure...maybe it's because a bunch of us old farts drive them.
Good example, in '01 I sold my '97 Supra Twin Turbo for which I was paying $625/year, and bought a new '01 Z06. Called the company to change cars and they advised that they would be sending me a refund as the Vette was going to tun $500/year. When I traded the '01 for an '03 Z06 the premium went up $28 for the year. Each year since '01, the premium has gone DOWN!
Damn few advantages of aging, but I suspect this is one of them.
Been there done that.
It's all a matter of weight and the fixed roof is lighter. Also, Chev trimmed weight whereever possible in the Z06, going so far as to use thinner glass. You cannot get a power antenna nor a CD stacker either---just a few pounds but when added up, you get more grunt from a 3100# car versus a 3400# one.
I don't remember all the other "minor" items done but 405 ponies in a 3100# sled makes for lots of smiles.
Now, if the C6 Z06 comes in at 500 horses and they hit their weight goal of 2900#....oops, gotta go change my shorts!
If the C6 comes in at 500 hp/torque and 2900#s the power to weight ratio goes to 5.8 from 7.65. WOW!
All the rest of the comments about any C5 issues being livable are very on the mark. Fantastic car. But I didn't understand the comment about active suspension for those not used to HP. I've got Z51 so I can't dial the suspension but not sure what difference that would make. OTOH the active handling has been a savior twice, once due to wide tires in big downpour, got to slow down there. The other time let's just say it was helpful for an over enthusastic driver.
http://www.corvettemuseum.com/specs/2005/index.shtml
I particually liked the 400/400 HP/Torque in the base car and the Z51 upgrades in the new package. But remains to be seen what the new one costs and what the option prices are.
Higher top speed! Too bad there isn't any open limit roads around. I'm guessing that means about 180mph. Where does 'super car' start? And probably a coupe for still under $50K.
Looks like the General did some serious homework and also listened to the C5 owners complaints.
Car looks terrific.
Only downside is that I will have to wait a year+ to even see the C6 Z06.
The $16.7k was for a '95 and that is a C4, but with only 18k miles at the time it too was a great deal. It now was just over 24k miles and I expect I will deal it before it hits 40k. Fun but as you note, it is a long step behind the C5 in terms of everything, especially ride and generall comfort. Getting in and out is a little bit of a pain, compared to the C5.
The C6 is going to be better than the C5, it just remains to see by how much after it gets some miles on it. I don't expect I'll look at one until it gets a couple years older. What I expect I'll do is keep the eyes open for a very low miles, late '02 - '04, C5 that has been a garage queen for several years when someone has to trade up. That way I won't feel so bad about tracking my current C5.
Living in the greater Los Angeles region and having to deal with constant and regular traffic, would cause me to opt for an automatic transmission. Hearing at the car show that the C6 would be equipped with a 6-speed manual or 4-speed auto, I was dissappointed. If Cadillac's XTR and the C6 Corvette are sharing platforms, why can't Chevy use the 5-speed tranny from the XTR in the Corvette. That would make the car so much more appealing and provide customers with a viable alternative to the 6-speed manual tranny.
The lack of a 6-speed, or at least a 5-speed, auto tranny is the only thing that would give me pause to consider purchasing the new C6.
Four month exhibit on Corvette 50th in Sacramento.
It's too bad, as at least 40% of all buyers choose a Corvette with an automatic.
Interesting look back. Who buys the new model vette? Presumably the real fan with long history and experience as well as money. Well the 40% take rate for manual was true for the two years before '01, but before that the take rate for the first two years of production was only in the mid 20% range. Seems like those who want more performance, I'm suggesting younger drivers with fewer bad knees, etc., wait for the deals to start showing up as the model ages some. Then they jump in and get the 6 speed at 5k under MSRP rather than the 5k over MSRP some will pay early in the introduction.
I've often thought that the Corvette and an automatic are a good match because of the size of the car. But, I mean, a really competent automatic.
It may be a bit skewed in terms of choice or lack of it in the Z06 Corvette, which is 100% 6 speed manual(this moniker is 10-15% of the yearly Corvette production) . So if you want a Z06 automatic, it is not available. So the next path in the decision tree is; does the Z06 moniker outweigh the lack of choice in the transmission. So IF the Z06 would have a manual/auto choice, I am GUESSING that the auto population would be at least 7% higher for autos. (65 + 7= 72%)
Since I've never driven a newer auto in a performance car, can they be downshifted, 'smoothly'? I'm not great but I'm learning to heel/toe and when you get it right on a down shift to maintain balance it is amazing near the limits of traction. Until the knees go, hopefully never, I'm going to row the gears since that's what I've always done. Glad to see the MN6 as the standard tranny now since it did seem odd paying extra to get manual.
Any advice would be appreciated.
Also, should I take the car to a trusted mechanic under any circumstances?
How would one handle any objections from the salesman? (such as he says our mechanics already checked it out)
I think a C5 is pretty sturdy so mostly I'd look out for prior collision damage, obvious neglect and abuse (like checking the inner fender wheels for tire debris) and for a conspicuous lack of service records or car history (Where did this car come from? Who owned it last? What's it's service history?) Oh, a rental unit from Florida bought at auction? No Thanks!
The R&T survey suggests these problem areas to watch for:
Computer-controlled sensors/operating hardware (23% of owners surveyed complained)
Glass & weatherstripping (9%)
Tires (8%)
Battery (8%)
Exterior body parts/trim (7%)
Brake rotors (6%)
As you can see, for the most part the complaints center mostly around build quality or materials quality, not so much mechanicals.
Other than that, the "Worst Quality" about the car was listed as "Quietness" (too noisy inside the cabin) and the next worst was "Quality of Materials".
Best Attributes were, as you might expect "Performance and Acceleration" followed by "Handling".
Whenever I have traded a car in I give all the service records to the dealer and advise that I would welcome a call from any prospective buyer. I have received several calls over the years from those potential buyers. I don't B.S. them---give them the facts and I find it difficult to believe that someone would not want to be contacted, or "bothered" as the dealer might say.
Certainly you could be "set up" by a salesmans friend who claims to be the prior "owner" but a few pertinent questions would reveal the truth.
No guarantee for sure, but if I were denied access to prior owner I'd be suspicious.
If you want to be the first on your street with a C6, then you are probably looking at 13-14k more than what you could get a C5 for now. (10k current discount; MSRP another grand and the dreaded ADM). 3-4 monts after that you may well see some discounts off MSRP---it's the old "supply/demand" thing.
When I decided on a Z06 in May '01, the dealer wanted MSRP PLUS $3,500. Two months later in July I bought for MSRP MINUS $5,000. Add the tax on that and it cost me $9,000 less by waiting 60 days. Well worth it to me.
Cannot cast in stone this will happen to the C6's but there always seems to be a fall off at some point.
Then again, instant gratification is something else.
Doubt this helped you much but it is something to gnaw on a bit. Good luck.
