Entry Level Luxury Performance Sedans
1141142144146147435
  • readerreaderreaderreader Member Posts: 253
    The problem with Saabs is that they drive like Saabs,= Sucky.
    Their front wheel drive platform was sorted out somewhere around 1992 meaning lots of tourque, and under steer. The switchgear isn't all that hot, and they are overpriced.
    I doubt RockyLee has a license, or a job, so his opinions on vehicles should be limited to bikes, and bigwheels from now on
    Why do you see the need to be so unfriendly? :confuse:
    Gratuitous insults are unnecessary.
    Saabs are very popular here in the Northeast where I live, so they work for some people.
  • dhamiltondhamilton Member Posts: 878
    Rockylee have you driven a Saab? I guess it doesn't matter because the 2018 Saab is going to kick butt.
    Yes I've driven a friends late 90's 9-3 once and was lucky enough to take a 2000 or 2001 9-3 convertible out for a drive at a used car dealership.
    Rocky
    P.S. It's going to be the 2008' or 2009' Saab 9-5 that kicks butt. :P
  • fedlawmanfedlawman Member Posts: 3,118
    "little ole me at 5-7..."
    Hey Blueguy,
    I think I have a way to spare you the agony of ED.
    I've never been to Europe. How about you give me your passport and FF miles? I'll assume your identity and go to Germany for you, take delivery of your 335i, break it in for you over a two-week period, drop it off at the port, and then return home.
    I'll even pay for my own meals and lodging!
  • habitat1habitat1 Member Posts: 4,282
    "...and was lucky enough to take a 2000 or 2001 9-3 convertible out for a drive at a used car dealership."
    By "lucky enough", do you mean that it didn't tip over? ;)
    Seiously, in the Websters Dictionary of convertible terms, under "rigid" you see a picture of a Honda S2000, Boxster and 3-series. Unfortunately, Saab's picture is used to illustrate the phrase "cowl shake".
    As I said, Saab has several positive attributes. Chassis engineering - at least as it applies to handling - is not one of them. It's likely to take longer than 2008 or 2009 for them to get remotely close to the class leaders in that dimension. If enthusaistic driving is not your thing, then certainly Saab deserves consideration. And they are indeed popular in New England.
  • circlewcirclew Member Posts: 8,666
    Hey, that seems like a good idea for a start-up! You can call your new firm "FED"
    I'll book my 2009 now, please!
    OW
  • nyccarguynyccarguy Member Posts: 17,684
    While you can't get XM from the factory in a BMW, any competant aftermarket audio shop could probably make the switch for you.
    That being said: I'm addicted to SIRIUS. I have friends who have both and most prefer SIRIUS. The music stations have ZERO commercials. As for O & A, they do watered down bits (and are on Terrestrial Radio for half their show) that Howard did 10 - 15 years ago.
    Drive the 335i and listen to SIRIUS. You'll quickly find out why BMWs are the Ultimate Driving Machine (and the benchmark for this class) and why Howard is truly the King of All Media.
  • joe131joe131 Member Posts: 998
    Nope.
    Do not consider treadwear ratings from one manufacturer to the next. The figures are innacurate at best, and intentionally misleading to the point of being fraudulent at worst.
    If you don't like Discount Tire, then read about it at Tire Rack.com:
    Unfortunately, the rating that is of the most interest to consumers is the one that appears to be the least consistent. While the Uniform Tire Quality Grade Standards Treadwear Grade was originally intended to be assigned purely scientifically, it has also become a marketing tool used by manufacturers to help position and promote their tires.
    The problem with UTQG Treadwear Grades is that they are open to some interpretation on the part of the tire manufacturer... the tire manufacturers... extrapolate their... data... their grades can... reflect how...optimistic their marketing department is. Typically, comparing the Treadwear Grades of tire lines within a single brand is somewhat helpful, while attempting to compare the grades between different brands is not as helpful.
    Tuner chips? Are they kinda like Tornado air intake mixers?
    Like the tuner's Honda Fit on Redline TV that got worse gas mileage than a Mustang GT? And which could only run on 3 cylinders? Hahaha!
    My guess is that the aftermarket chips cause more problems than benefits. Otherwise, why didn't the manufacturers just put the 350 HP chip in to begin with? BMW is not dumb.
    Capitalism. Its a system based on the old adage, there's a sucker born every minute.
    Or am I just too cynical?
  • kdshapirokdshapiro Member Posts: 5,751
    On example, tuner chips increase the hp and torque of an STI from 300/300 to 300/430. With a turbo it's much easier to get a performance bump than without a turbo.
    at what cost and detriment to gas mileage and reliability?
    And do you lose any factory warranty if your motor blows up?
    Ain't no free lunch.
    Dinan mods are fully supported and warrantied by BMW. Use of other tuners are at your own risk.
  • ggesqggesq Member Posts: 701
    Some info about it I came across (Motortrend):
    For the U.S., expect the engine range to be the C280 V-6 (228 horsepower), C350 V-6 (268 horsepower) and the C550 V-8 (380 horsepower), all with the automaker's seven-speed automatic. After a year a C55 AMG is expected. If the current German horsepower war continues, there's room under the hood for a C63 AMG, ready to out-gun even the upcoming V-8-engined BMW M3.
    The new C-Class uses front strut suspension with two lower-arms, and a multi-link rear axle - familiar Benz principles. The main chassis innovation is a new type of amplitude-dependent damper, able to provide extra compliance over small bumps for ride comfort but stiffening up during bigger movements caused by sharp steering maneuvers. The system is entirely hydraulic - there's no electronic intervention.
    The bodyshell is a claimed 13 percent more torsionally rigid than before, enhancing comfort by reducing vibration, as well as giving the potential for more precise handling. Around 70 percent of the new body is high-strength steel, which improves the strength-to-weight ratio. There is no significant aluminum in the body, and less in the suspension than competitors use.
  • louisweilouiswei Member Posts: 3,715
    :surprise: :surprise: :surprise:
    MB has truly gone mad...I guess they really want to take over the horsepower king title huh?
    "MB has truly gone mad...I guess they really want to take over the horsepower king title huh?"
    Not as "mad" as their AMG counterpart. They decided an R63 - 500+ horsepower minivan - is just what the neighborhood soccer mom needs. The should use Forest Gump as the ad man on that one. :surprise:
    If the uber-horsepower addicted engineers at Mercedes/AMG would wake up, they would realize that the former C32 was already within spitting distance of the M3 in straight line performance, but light years away in terms of handling, driving dynamics and the real "fun to drive" department. So what have they done to fix that? Why add more horsepower of course. Like complaining to the restaurant waiter that your Salmon filet is undercooked and he simply refills your wine glass.
    And louiswei, just to show fairness and consistency, I think AMG is considerably more abysmal than Lexus in their pig headed stubbornness not to engineer a manual transmission in ANY of their cars, period. Not a single one. What do they think? Us Americans (70%+ of AMG sales) can't count horsepower and shift gears at the same time? The SLK55 might actually be a fun car to drive if it weren't attached to a sloppy, slow shifting slushbox (in fake manual mode). The owner of my Acura dealer sells Mercedes and even he steered me to Porsche (and drives a Cayman S himself) :confuse:
  • kyfdxkyfdx Moderator Posts: 269,790
    This is a great idea!!
    How about you let me drive your M3, while you are gone?
    any of you rear wheel drive fans see the S6 come a tenth of a second behind the M5 at Button willow, and then "beat it handily on a shorter figure 8 track?
    Benz AMG vehicles are a joke, they are built for the rich guy with bad taste in cars.
    habitat1, looks like Lexus is following MB's footsteps by not offering manual (not even SMG/DSG) on their -F series cars. Rumor has it that the upcoming IS-F might have 500 HP (previously reported 425 HP) but will be mated to LS' 8-speed automatic transmission. If Lexus won't offer manual on the IS-F then I don't like the chance of GS-F and SC-F getting it. Hopefully Lexus will wise up and decide to give their upcoming halo car, LS-F, either a manual tranny or SMG straight from their F1 cars.
    Let me make myself clear first, I am not trying to defend AMG's decision on not offering manual on their entries, however I think there are at least 2 reasons:
    1. AMG is more of a super luxury cruiser with sports aspiration. Those cars are not serious "sports" such as Porsche, Ferrari or even M and Audi's S/RS. Thus their targeted market is vastly different and mostly aren't interested in "shift-'emselve".
    2. Americans traditionally buy more automatic than manual. I believe the auto-to-manual ratio for the 3-series sold in US is around 70-30 and this maybe your most "sporty crowd". Taking that into consideration I don't blame MB (or any other manufactures in this case) to not offer manual here on their cars. However, in Europe and Asia then that's a different story.
    Louiswei,
    I think there is a dichotomy that the tuner teams at the respective manufactures are playing off of.
    Some people define luxury as a slushbox vs. rowing in traffic jams and would never track their cars unless they could have a latte and be on the cell while their instructor drives!
    The sport or performance set know how to make their rides do what they were designed to do and have fun driving.
    The AMG guys and gals just want the designer set to have bragging rights! (IMO)
    OW
  • blerner2blerner2 Member Posts: 47
    I went back to the BMW dealer today to test drive the 335i again.
    The salesperson told me that while I could not switch the module to Sirius, I could add an aftermarket unit, hid neatly in the console and plug it into the Aux input that is located there. I would just have to install an aftermarket antenna.
    After my visit at BMW, I went to a very reputable Audio installer, explained the scenario, and he said, "I can't touch a BMW. They will void the warranty, if they find out that it has been added to the vehicle".
    All I'm looking to do is wire up the XM antenna and run it to the console, where I will have the aftermarket unit plugged in.
    I'm going to be leasing this vehicle. Is this true, that I can't have this done without voiding the warranty? Can I ask the dealer if they will do it in their service department.
    Adding an XM module in the manner described by your dealer is no different than hooking up your iPod via the same method. Your dealer is correct.
    Best Regards,
    Shipo
    Shipo,
    You may be correct. The installer had explained that I have 2 options to get XM in the vehicle:
    1. An upcoming "box" that would plug into the Sirius module in the vehicle and "translate" the feed to XM. Apparently this box works both ways (XM to Sirus and Sirius to XM), it was designed for just the scenario I have been describing. It's about $300, and will be availabe for BMW shortly, he says.
    2. Wire up an XM aftermarket antenna into the console and plug the aftermarket XM unit into the Aux input located there.
    In retrospect, the installer must have meant that he could not pursue option 1 on my vehicle, as he mentioned that BMW does not allow you to "plug in" any device to their electronics without voiding the warranty. I assume this is similar to an owner who wants to "chip" the engine.
    If I pursue Option 2, and plug in an aftermarekt unit in the console, how will it be powered? I can't recall if there is a charging port located there. Anyone know?
    Louiswei,
    I agree with your points on why AMG does what it does. However, I would note that, at least in my area, a previous generation M5 (6-speed only) has a much better resale value than a previous genration E55 (auto only). And the E55 cost more to begin with. I believe that that is because the former E55 was focused upon only horsepower (and luxury), which gets quickly superceded by more horsepower (and more luxury). The previous M5 was a complete enthusaist's car and the joy of driving one doesn't wear off just because it may no longer be king of the hill at the dragstrip.
    I am not surprised a bit about M5 having better resale value than the E55. To me, although not an enthusiast but I think AMG's not as prestige as the M.
    Also, generally speaking, doesn't BMW usually have better resale value than MB to begin with? According to Kelley Blue Book:
    2004 BMW 530i: $36,865
    2004 MB E320: $34,865
    I believe back in 2004, a new E320 would cost more than a 530i.
    2500 miles is a long way to travel just to drive my 20 year-old BMW for a couple weeks!
    As I always say... "Beats working"..
  • goodegggoodegg Member Posts: 905
    The power ports are for that
  • plektoplekto Member Posts: 3,738
    The percentage of automatics versus manuals is skewed, though, since there are precious few offered in the U.S. to begin with. Yet the demand is definately there.
    Take the Honda Fit. It's the manual transmission ones that are hardest to find because they are all spoken for. Yet Honda in its infinite wisdom has decided to ship 85-90% automatics to the U.S. despite the split being about 70/30 in actual demand. Toyota(Lexus only exists in North America - its "Toyota" everywhere else), Mercedes, and all of the rest offer manual transmissions on their entire lines over in Europe. And I doubt that people are that different in the U.S. than in Europe.(ie - a LOT more people would drive manuals, especially in luxury cars, if they were offered)
  • blueguydotcomblueguydotcom Member Posts: 6,249
    First, talk to VW 1.8T and 2.0T owners. Chipping has been really common with those engines for about a decade and they're all running fine. Yes, some blow up their engines or strip trannys but that's the drivers, not the engines.
    Second, BMW couldn't officially release the 335i with 350/400 tq for one simple reason: M3.
    The M3 is using a variant of that torqueless V10 in the M5/M6. It's going to produce - if they're lucky - 420 hp and 330/340 tq.
    If they released a 335i with more torque and nearly the same power they'd eat into M3's sales in a big way. Right now at 330 hp the 335i is pulling 4.9-4.7 0-60 runs. That's besting/matching the current M3. The next get M3 which will be heavier will be lucky to pull sub-4.6 second runs to 60. quite simply once you reach sub-5 seconds every drop from there takes serious torque and HP. Guys with chipped 335is are pulling mid 4 second 0-60 runs.
    What would BMW gain from having the 38k 335i run to 60 as fast as the 60k 2008 M3?
    BMW is not dumb.
    Correct, see above. They have to protect the M3 name.
    The sucker is the one who thinks a manufacturer limits power to increase engine life and not protect the top of its sales line. The profit margins on the M3 are surely insane and they sell in really high numbers. Look at the sales of the e46 M3 v. the e46 coupes. Not a big difference. Yet the price gap was massive. Look at the differences between the M3 and 330i of the e46...yeah the M3 sales were neck and neck and more profitable. Plus it makes the brand look better.
    Nah. Just not looking at the whole picture.
    Not anymore.
    Now Lexus is available in Europe, China, Taiwan and Japan as well.
  • jensbjensb Member Posts: 3
    Please keep me posted on this. My, perhaps mistaken, understanding was that "the box" was available and could be installed. I wasn't informed it would affect the warranty. As for plugging an aftermarket in, I've had that for the past two years. It certainly doesn't look very good and is not very user-friendly--though maybe they've improved them. I started out with Sirius and switched to XM and like the latter much better. It really is a deal-stopper for me (as is manual transmission). So I would love to know if the "box" is a viable option. Again, who would have thought it would be this hard?! (I may write directly to the BMW website if I can find it--I'm tired of all the misinformation from the dealership on this. Plus, maybe they should hear that they're losing sales over satellite radio...) Thanks
    Yeah, yeah.
    And then after that new M3 comes out with the V-10, some chip company will come out with a chip to increase its horsepower too, right?
    And then I'll pose the same question: Why didn't BMW just put the higher performance chip into it in the first place if increased performance is so easy?
    I suppose you'll answer because BMW ain't dumb, it just must protect the upcoming 2009 M5?
    And what was VW protecting by not putting higher performance chips in those you mentioned?
    (Oh, and the 335i is 300 HP and 300 Torque. Just drove a coupe a couple weeks ago. Pretty car.)
    What is your authority stating BMW warranty covers Dinan performance chips? I could not find any support for it.
    But I did read a little which tends to show you may be in for big warranty headaches if there is engine failure in a re-chipped car.
    Consider these tidbits from the Bimmerfest message board:
    1. He (Dinan) actually does void the (BMW) factory warranty... he just states that he matches it if there is an issue... if there is a problem, BMW will not cover, and (if) you can prove that it was dinan's fault.. then dinan pays... if you cannot prove it was dinan's fault... and BMW will not cover... you are HOSED (S.O.L.)! (And remember, unless you pay a whole lot extra,the Dinan warranty only lasts until the original BMW factory warranty expires.)
    2. ALL Dinan products void BMW's warranty. It's just that Dinan offers a (concurrent) warranty to supposedly cover any warranty denials by BMW. But Dinan products DO void the BMW warranty.
    3. (here I am paraphrasing an entry posted by a lawyer)
    If you make a claim for BMW warranty coverage and BMW decides (as it almost certainly will in the event of engine failure where a Dinan chip is installed) that BMW does not need to pay for the repair, you will need to go to court to pursue your claim further. And once there, even though the burden is on BMW to prove that the Dinan chip caused the damage, it probably would not be a difficult thing for a jury to find. And when the jury does find the aftermarket chip was the cause, the BMW warranty is voided for that damage claim.
    So then you end up with a claim against the Dinan warranty. But to win against Dinan, you as a plaintiff must prove that the Dinan chip caused the damage. If you don’t get a jury to agree on that, you lose and the Dinan warranty will not pay either.
    And even before many months or years waiting to get to the courtrooms, you either pay out of your pocket for the repairs, or do without the car as you hope one warranty will eventually be forced to cover the damage.
    Bottom line: Do not re-chip your BMW while it is under the factory warranty.
  • ajmtbmajmtbm Member Posts: 245
    let me ask this question - what makes an IS350 or BMW $5k more expensive than a G35?
    the G35 seems to be priced about the same as the IS250 - big difference being the IS has the smaller engine. to move up to the IS350 to make the engines better match the price goes up quite a bit.
    same pretty much true for the BMW vs. Infiniti.
    Question is this - is there $5k worth of better parts in the BMW/IS, or just more profit for the manufacturer?
    Happy New Year!
    Since there aren't chips out (commercially) for the 335i, talking about a rechipped ECU voiding the warranty, right now is moot. But I do remember reading, that BMW will install and honor the warranty on after markert parts in it's cars. The manufacturer may not have been Dinan.
    BTW. The market for aftermarket chips is huge in turbo cars. It may not be a route you want to go, but the market is there nonetheless.
    Maybe you pay for what you get in terms of refinement and quality of materials. The VQ engine using in the G35 does not cost more than a handful of $$$ over the 2.5 used in the IS250. I think some of the differential is materials and workmanship and some of it is market. Lexus is now doing what BMW and Mercedes used to do. Because it can.
    So there isn't any Dinan chip for other BMWs?
    If there are, how does the whole warranty thing works for those?
    ajmtbm, I think the new G35 right now is the best bang for the bucks in this class. Given their similar pricing there is no way I would opt the IS250 over the G. However, after test drove the G35 last week I think there are at least 2 reasons why the Lexus and Bimmer cost more:
    1. Interior build quality and inferior material used. Generally speaking the new G's interior is light years ahead of its predecessor. However, one can still find cheap material being used in the cabin, for example, lower door panel.
    2. Less refined engine. Don't get me wrong, the new VQ is very good and competitive. But I don't think its as refined as Lexus' 2GR-FSE and Bimmer's twin-turbo I6. I drove the G35 and 335i back to back and I have an IS350 so trust me, there is a difference.
    I am not sure if BMW and Lexus' advantage over Infiniti in those 2 area are worth $5K more expensive. That's up to the customers to decide.
    This is straight from Dinan's website...
    The installation of Dinan Performance Products and systems may affect the vehicle manufacturer’s new car limited warranty. The vehicle manufacturer’s new car limited warranty may not apply to modifications to a vehicle or the installation of any performance accessories or components attached to the vehicle which substantially alter the original engineering and/or operating specifications or which result in damage to other original vehicle manufacturer’s components.
    Link
  • spiritintheskyspiritinthesky Member Posts: 207
    blueguydotcom,
    I generally agree with your posts and appreciate your insights. However, I have some disagreement with your most recent one:
    My nephew recently purchased a 335i sedan. While it diplays impressive acceleration for a "regular" 3 series, the overall performance still falls well short of the M3, especially in the area of handling. What distinguishes the M3 from all of its competition is near 911 quality steering and handling. You don't get that with an aftermarket Dinan chip. And the 335i, while an ELLPS segment leader, will never play with a 911 around a track, chipped or not.
    Secondly, as others have pointed out, the Dinan chips do indeed pose a warranty risk. A significant one. I have several fellow M5 owners who have looked into it and all concluded that you better have the intestinal fortitude to go to court.
    Thirdly, hand built "M" engines are at least 3+ times as expensive to produce as their non-M mass produced counterparts. If you've ever visited both factories, as I have, you immediately know why. While I don't dispute that the profit margins on the M3 and M5 are high, most of that is because 90% of M models are sold at full MSRP, with no discounting or ED discounts. My nephew bought a 335i for the equivalent of $1,500 under US invoice via European Delivery.
    For those that might think the difference between a 335i and an M3 is a 0-60 time that can be bridged by a Dinan chip, I respectfully suggest they don't really know what Motorsports is all about and what separates them from the horsepower addicted drag racers over at AMG. Sorry if I sound defensive. My loyalty to "M" goes back to being an original owner of an M1. It's pretty easy to pump the power of a turbo engine. A hell of a lot harder to live by the mantra, "make the chassis faster than the engine". And nobody in the sport sedan and coupe market does that better than Motorsports.
    Great post Spirit.
    Wow, hmm...maybe that's something to think about 4 years from now when I am about to replace my IS.
    Better start saving up 'em vacations...
    Oh yeah, and 'em frequent flier miles.
    :blush:
    spiritinthesky,
    Thanks for your insight on what M really means. I agree with all of the enthusiasts with gobs of knowledge and experience with the BMW line. I am amazed at how far the "straight six" concept has come.
    I think the most improvement that the 335 concept has shown is the turbo effect to the power band of the 3 ltr. The torque is finally quite impressive and looks to enhance performance as a leader in the ELLPS segment.
    I believe those in the know would agree that this new output will be hard to beat.
    OW
    The 335 renders my favorite car [Audi S4] useless. A bummer for me, but unless the deals on the S4 go crazy, ie lose the gas guzzler tax, then I'm sold on the 335.
    And then after that new M3 comes out with the V-10, some chip company will come out with a chip to increase its horsepower too, right?And then I'll pose the same question: Why didn't BMW just put the higher performance chip into it in the first place if increased performance is so easy?
    Emissions, an ability to offer more performance easily later on, a decision not to intrude on the power levels of the next step up, etc.
    Look at Audi's work with the 1.8T. In 2001 you could get it with 150 hp in the Jetta/Passat. In 2002 the power was bumped to 180 but structurally nothing was different. The exhaust was slightly different but really what changed: ecu. That same engine in the TT made 225 hp.
    See above. The 150 hp 2001 Jetta v. 180 hp 2001 A4 and TT. Eventually VW put the A4 and Jetta at the same power levels as they realized most people don't opt for a Jetta over an A4 or vice versa. Currently the 2.0T in the A4, A3, Jetta, Passat and GTI makes 200 hp. Well, the upcoming TT will make 220 hp - same engine.
    Again,do some research. Dynos show the 335i makes ~330/330. BMW's marketing guys say 300/300. The SAE rules make it impossible to overrate an engine (like honda did the TL for years) but they don't bar a company from underrating the engine.
    Why underrate the 335i? Two reasons:
    1. The competition is around the 300s. So to stay level but offer more performance BMW simply claims 300/300. If the G35 or IS350 sees a bump to 320, BMW can match without ever changing a thing.
    2. The last year of the M3 and even the upcoming e9x M3. The current M3 is a lame duck. At 50k+ it's a hardsell to push someone into an e46 M3 when the e9x 335i makes the same power for less money. The e9x M3 will make far more power but really the performance reward won't be huge. So BMW must make the gulf seem large enough on paper to entice people to drop 65k of so for an e9x M3 in 08.
    KD vishnu is selling a Xede for the 335i. I posted the dyno on it. He's charging around $1400 for it. The power gains are immense.
    According to automobilemag.com, the 335i posted 275 RWHP on its dyno run.
    335i Dyno Graph
    275 RWHP. Allowing for a 15% driveline loss, that equals about 325 HP at the crank.
    Based on the curb weight, gearing, and 1/4 mile times, I'd say 320-330 is about right.
    Yes Dinan makes chips for other BMws, but they haven't released their 335i chip yet.
    Here's a chip for an M3: http://www.dinancars.com/Series.asp?Series=14&Chassis=10&Model=9&Class=Engine - Tuning#133
    Very little gains.
    look up GIAC, APR, Neuspeed for chips for audi turbos.
    Ah, but keep in mind: an M3 is 10-20k more expensive than a comparably equipped 335i. You can add some serious mods to a 335i sedans and come in well under 50k without even trying. Out of the box, the 335i posts near e46 M3 handling and performance numbers - check the lap times of the 335i. Remove the RFTs, slap on a chip, add thicker roll bars and maybe some springs/shocks and you have an easy e46 M3 beater (a car that's really old school at this point).
    BTW, I have no loyalty to BMW or the M models. I feel the V8 in the e9x M3 is a very bad idea. Using a modified version of the torque-deficient M engine from the M5 and M6 is a super bad idea, IMHO.
