have a 04 mdx, 56k had a leaking transmission gasket that needed for the
traany to be replaced. luckily had serviced at dealership.
Acura came thru with me paying only $100.
Lucky!
I know it's probably a dumb question, but I wonder if this is normal.
Let me know if you find a solution, I'll do the same.
i am having same noise problem with my 2008 mdx.
i took the mdx to the dealer twice and all they did was to spray some rubber softer. the noise came back after 2 days. i am going to take the mdx back to dealer tomorrow. i should have brought lexus or bmw.
Had you find out any resolutions yet?
I did test with all radio and A/C off and have this loud sound all the times.
Is it normal? I hear some friend said the Lexus have much better noise reduction inside the car. Any thoughts?
It wasn't a Cobra was it?!?
Seriously though it sounds like a blown fuse.
I have had the compliance bushings on my '08 MDX changed twice. The second time they needed to be changed because the original clicking problem persisted. Now the cllicking has gone away, however, it seems like there now is a buzz or a hum (high frequency vibration) when I get above 70 mph. Did you experience anything similar to this? Thanks
kdias
Last week, the car suddenly lost its steering power when my wife picked up my 17 mo old boy. My wife had to do an emergent stop on the side of road and had to call the roadside service. Fortunately it happened on local road. I cannot imagine what would happen to my wife and kid if it were on highway. The tow truck driver came and found the crank pulley sitting on the ground when he checked the car. I was shocked to see the actual crank pulley piece of medal laying on the ground. This MDX is only 26k.
Obviously the vehical is not under heavy use. But still over the past 3 years of ownership, it has given us problem after problem. First it's the air conditioning system failure within one year. Then it's the wind shield fluid dispense system failure. Now it's the life threatening incident.
I would never buy Acura anymore.
-Dennis
Took it to Honda because Acura is an hour away, they took the center console apart and found the shifter cable was corroided on both ends, lubed it up and will be ready by the end of the day, no parts just labor, $85.
John
What fuse is the alarm system on for the 2005 model, I have looked through the manual and cannot find it. Please help thanks.
I have the same problem you summarized. Still no power to my radio, ac adapter, a/c controls, trip computer, etc.
Also, thanks for the reply Upstatedoc.
Dealer is clueless or is pretending to be. Does anyone know about this?
