Toyota Sienna Future Models
13334353739
    http://pressroom.toyota.com/photo_library/display_release.html?id=20050729a
    Thankfully, Toyota did indeed decided to make front seat side chest and three row side curtains standard.
    ~alpha
  • saneonesaneone Member Posts: 11
    When are the 2006 Sienna's scheduled to come out
  • bobob20032000bobob20032000 Member Posts: 69
    Alpha01, all grades now receive standard front seat-mounted side airbags and side curtain airbags for all three rows. This is for 2006 Models.
  • paulepaule Member Posts: 382
    September.
    The pictures are of an '05 model. The '06 is basically a carryover so the site lists an '05 for an '06 because the crash results are the same EXCEPT that side airbags are now standard where they were optional on most trim levels for '05.
    The front end is the same as the '05 lengthwise. It may be a perception issue from the way the picture was taken.
    Sienna Crash Test Results
  • philg87philg87 Member Posts: 74
    08/08/06 thats when the dealer will be able to discuss pricing and new options.
  • hop1hop1 Member Posts: 3
    Just decided that I am going to wait for the '06 Sienna's to hit the lot instead of purchasing an '05. Can someone answer the following:
    1.) The actual date that the '06 will arrive in car lots in Canada
    2.) what will the approximate increase be in MSRP? If any?
    Does anyone know the following in detail?
    1.) What date will the '06's be hitting lots in Canada
    2.) What will the increase be in the MSRP? If any?
  • maxellmanmaxellman Member Posts: 43
    Power fold mirror, to name a few. And believe me, it is a better minivan than Honda.
  • doggybonedoggybone Member Posts: 1
    Looks much better than 2005. If your only objection to the 2004/05 styling was the front end, you should wait for the 2006.
    I just googled some key words and found it, I wish I could tell you where to find it, but I think our membership agreement would not permit it. Good luck hunting!
    Slightly different styling on the headlights and taillights as well.
    They started production last week.
    1.) They should hit the lots between 9-15 thru 9-22 for the first allocation.
    2.) Increase for 06 $335-$365
  • 3kidsinback3kidsinback Member Posts: 74
    Toyota website says VSC can be had in the CE trim, but the build and price does not list it as part of the package options.....Will this change????
  • jchan2jchan2 Member Posts: 4,956
    Depends on your region. Toyota is notorious for making certain option packages available only in certain regions.
    A $35,000 Sienna XLE located in California might have different equipment than a $35,000 Sienna XLE located in New York.
    If you want a specific option package and color combo, you will probably have to settle or go the special order route.
    Can someone who has brought or seen a 06 Sienna tell me what size the DVD screen is. They said they would make them larger than the 05 Sienna by 2 inches is this true????
    Phil
  • cptpltcptplt Member Posts: 1,075
    when will Toyota change the Sienna again ? 07 or 08 model year?
  • hansiennahansienna Member Posts: 2,312
    WOW...Is this forum dead! :sick:
    I bought a 2006 Sienna but think the front end of the 2004/05 is more attractive. I would also prefer the CD and Cassette player in the 2005 to the 6 CD in dash changer with MP3 capability of my 2006. :cry:
    However, the instrument cluster of my 2006 Sienna LE is much more attractive than that of the 2005 Sienna LE. ;)
    Yes this is true.
    The 06 Siennas have a 9" DVD screen while the 05's have a 7" screen.
  • vinijinvinijin Member Posts: 28
    I currently own 98 Sienna LE with 200,000+ miles. I am ready to buy a new minivan but discouraged due to these gas prices. I am wodering if Toyota is working to bring V4 Sienna like they have some models in Asia
    I doubt it. There is simply no market.
    The Sienna gets pretty good mileage for a car of its size though.
  • vaskiervaskier Member Posts: 3
    Does anyone know about when the 07 models will come out? I am hoping that they do away with the run flat tires on the AWD version considering all the problems with these tires.
  • rorrrorr Member Posts: 3,630
    "I am hoping that they do away with the run flat tires on the AWD version considering all the problems with these tires."
    The CAN'T do away with the run-flat tires on the AWD version until they figure out a non-invasive place to stow the spare.
    Any ideas?
    As pesky as those run flats are, Toyota has to keep them because there is no other place to put the spare tire and still have a fold flat third row seat and all the AWD gear.
  • wheelz4wheelz4 Member Posts: 569
    Can't they just do what Mazda does with the Miata...supply decent tires and a can of tire inflator? That would work for me.
    "Can't they just do what Mazda does with the Miata...supply decent tires and a can of tire inflator? That would work for me."
    Uh, I think the typical buyer of a minivan would be slightly less 'adventurous' than a sportscar owner. I think trying to sell a prospective Sienna buyer on that whole concept might be a tad difficult.......
  • kdhspyderkdhspyder Member Posts: 7,160
    I believe that you may see a hybrid Sienna in the new model, MY 2008, linking the 2.4L + HSD like in the the new Camry hybrid. This is already out in Japan for seveal years as the Estima.
    2.4L + HSD would give you V6 power like your 98 - 02 model but fuel economy - real world - in the low mid 30 mpg range. Most new owners of the sleeker, lighter hybrid Camry are reporting FE initially in the high 30 mpg range.
    This would be a killer benefit for the Sienna over the Odyssey. Fuel economy is so important to the typical van buyer with a tight budget.
    For example: take your choice
    $27000 LE V6 3.5L with 268 hp and estimated FE of 22 city and 29 Highway
    OR
    $27500 Sienna hybrid ( TSH ) with 190 hp and FE of 33 Highway and 38 City
    The new Sienna will definitely have the 3.5L powerplant now in the Avalon, RAV, Camry, ES350, RX350 and new Highlander. It's an amazing engine.
  • samnoesamnoe Member Posts: 731
    We're all sure that Toyota will put that 3.5 engine in the new Sienna - along with the new 6-speed tranny... but the question is: WHEN? '07? '08??
  • sathish1sathish1 Member Posts: 1
    Vinjin,
    WOW! you got 200,000 miles. I would like to know what maintenance did you do. What are the problems did you have with this vehicle? I would like your input because I'm looking for a used 2002 Toyota Sienna. Thanks.
    Changed engine oil/filter every 5000-7000 miles
    Changed air filter every year
    Changed spark plugs 4 times so far
    Replaced tranny at 155,000 miles with one year old used tranny (That was my mistake because I did not change transmission oil for 60000-70000 miles). I strongly suggest to change transmission oil every 30,000 miles.
    Don't do everything which dealer suggests because lot of things they suggest don't make sense.
    yes, one more thing
    I changed timing belt at 130,000 miles
  • woodwilliewoodwillie Member Posts: 1
    Hi all,
    I'm about to but at 2006, but think I may wait until the 2007s come out.
    -Does anybody know when these typically hit the dealers?
    -Any idea what new features they might have?
  • bakeroidbakeroid Member Posts: 39
    Currently have ventillated seats (AC and heat) on my 05 Avalon. Has Toyota talk about offering them on the 07 or 08 Siennas. I live in FL and they are great in the summer.
  • mkk62mkk62 Member Posts: 6
    new engine should be available for order dec 06 and delivery jan 07,,,,3.5 liter avalon engine
    check out this link
    http://www.arifleet.com/pnews/2006/pn608.pdf
    on the sienna .org site, one engineer states these times and dates....and we should hear officially within 6 wks ?
    I am trying to wait but baby coming Dec....maybe wait for the news of the larger engine to get a real bargain for 06 model.,...
    mk
  • coupedncalcoupedncal Member Posts: 252
    Did anyone notice this link states the 3.5 liter engine is AVAILABLE for 2007 model. Does this mean it will not be standard across the model line ? I was looking into 2007 LE model and this will be a deal breaker for me. Has anyone heard this ?
  • meekmanmeekman Member Posts: 1
    From reading the threads, it sound like the 2007 Sienna is a few months away -- and I can't wait that long.
    So the decision for me is to by this week, or wait until September. Does anyone know, historically, if Toyota will increase their factory rebate (currently $1000 through 8/31/2006) on the 2006 models in September?
    Thanks in advance!
  • mchouremchoure Member Posts: 2
    Even I have same question. Only thing we can negotiate with dealer is that we rebate is increased in next 10 days then they should pass on rebate to us
  • jdconradjdconrad Member Posts: 11
    Does anyone know if and when Toyota is going to offer a satellite capable radio for the Sienna???
    WHERE did you read the FE 22 City and 29 Highway for the $ 27,000 LE V6 3.5L Sienna?
    Are these numbers BLOATED ( Overly Optimistic ) like the 2006 Ody 3.5L with VCM 20 city 28 highway were that have been reduced for 2007 to 19 city 27 highway? :lemon:
    The current Sienna is rated 19/27 with the 3.3L based on the old testing methods.
    The new 266 hp 3.5L which will be in the new '07's is significantly more efficient than the older engine. My guesstimate back in May was 22/29 City/Hwy. However according to the press release last week the new ratings are 19/26 City/Hwy.
    I will venture that the new ( more difficult ) EPA testing criteria are incorporated into these ratings since it will be mandatory for 2008 MY anyway. This engine will be in the new 2008's and beyond so I'd be shocked if it wasn't tested under those criteria.
  • gujuguygujuguy Member Posts: 19
    One of the dealer called me and said that 2007 invoice lists 3.3l and not 3.5l engine as projected. Can someone confirm as I hardly believe dealers.
    If thats the case than Odyssey is my first choice.
  • exb0exb0 Member Posts: 539
    Here is an email snippet that I got recently.
    "I am your Internet Sales Specialist here at Fitzgerald's. Regarding the 2007 Siennas, we expect these to begin arriving in January and we anticipate having pricing and ordering information sometime later this month. The only substantive change will the the change to the 3.5L V6."
  • caravan2caravan2 Member Posts: 198
    I still can't figure out why the delay and secret about this. I can think of two possible reasons: 1) there are some problems with the model that was identified late and could not be fixed in time for Jul/Sep/Oct release.
    or
    2) They over-produced 2006s and have to get rid of those first. I can still ses 50+ at large dealerships.
    I emailed Toyota and could not get straight answer from them. This is strange.
    How about issue #3 - Toyota is rolling the 3.5L out across its entire model line formerly powered by 3.0L/3.3L engines, AND its RWD platforms. Thats a TON of vehicles - and capacity/tooling requires significant changeover. My guess is that capacity was not there for Toyota to accomplish this all at once, and it was deemed much more important to have this engine available in other vehicles first (redesigned Camry, ES, '07 GS, etc).
    ~alpha
    ... plus the new RAV ) Along with the continuing Avalon.
    Just received the new pricing, in line with what FitzMall emailed to the prior poster.
    Yes the only change is the 3.5L
    Remember the 'anniversary' of this Gen Sienna is March. It was first intro'd as a 2004 in March of '03. Toyota has had great success with these 'early-in-the-year' launches.
    2003 Sienna
    2005 Avalon
    2006 Camry
    2007 Tundra???
    The Corolla recently has also been an early-in-the-year debut.
    Interesting observation....
    Do we have to wait till March :mad: ? Will this be 2008 Model, I don't think so :surprise: And if it comes out in March, wouldn't that would make 2008 model in September too soon?
    Since pricing was just announced I believe that the new 2007's are on the way. Typically the pricing comes out just before the vehicles do.
    Also the Holiday time is a big minivan purchasing period.
    Just a guess but I'd say the 'all new' 2009 Sienna will be out in about 18 months.. May/June of '08. Hopefully there will be a hybrid version in that debut.
    I checked the toyota.com Is this correct that LE, XLE and XLE limited have two packages each?
    I'm not sure what you're talking about.
    http://www.toyota.com/sienna/options.html
    Quite a bit more than two packages each, but less than the ABSURD number in the past.
    ~alpha
    If you go to this link, it has only three options for CE,LE,XLE, Limited
    http://www.toyota.com/byt/pub/showModels.do
    If you go to Toyota's website under sienna ==> options you'll see:
    CE - 2 packages
    LE - 8 packages
    XLE - 12 packages
    XLE Ltd - 4 packages.
