Guy says give the bad news first, doc says you have alzheimers, Geez doc the guy says thats awful, whats the good news, doc says by the time you get home you won,t remember I told you.
Cheers Pat.
http://www.vtr.org/maintain/oil-overview.html
Just an FYI though, in case anyone starts comparing the different manufacturer data.
It was written several years ago, so the numbers (Viscosity Index, Pour/Flash temp. etc.) will not probably be different in that same oil today.
-Dennis
I have a 2002 Forester and like to do a lot of my own work. I know from reading the owners manual where to place the jack, but where can I put the jack stands to stabilize the vehicle when I crawl under it?
Mike
-mike
I'm going to be changing the oil on our new Forester L for the first time this weekend. Does anyone know the torque for the drain plug?
Paul
02 Forester
71 VW Bus
Thanks for the info. I'll assume that's 37 inch/pounds and not foot/pounds.
Paul
Torque is usually measured in ftlbs although I guess it could be inch lbs in some unusual situations.
Look at your torque wrench...I'll bet its calibrated in ftlbs!
I personally never bother with my torque wrench for this. I lay on my side with my 17mm wrench and give it a good grunt. If it's snug and the crush washer is flat then I'm done. Haven't seen a leak from the drain bolt ever, definitely not stripping the bolt after 40k miles so I'd say it's not overtorqued.
I don't use a torque wrench for sparkplugs either. Lug nuts, heck yeah. Cylinder heads, um duh.
-Colin
-juice
Paul
Eric
Cheers,
-wdb
Dave
Symptoms:
Occasionally when driving in stop and go city traffic for 30 minutes or more, the clutch pedal’s engagement point will drift making every shift different from the previous one. When the engagement point is particulary low (near the floor) there is almost no pressure on the pedal for the first several inches of travel. Pedal feels “sticky” and often does get stuck while releasing it.
Same symptoms are VERY reproducable when driving at elevation (above 5000 feet) going to Lake Tahoe. Upon reaching higher elevations, the pedal will lose almost all pressure and engage only in the final 1-2 inches of travel (near the floor). Smooth shifting is IMPOSSIBLE. While releasing clutch, the pedal will rise until the engagement point (an inch off the floor), then get stuck. I will have to pull the pedal up with my toes and it pops back to its neutral position. Upon descending to lower elevations, the symptoms usually disappear.
I believe there may be a problem with a seal in either the master or slave cylinder. Others have reported binding seals giving these same symptoms.
Responses from Subaru:
I have spoken with several other Subaru owners with similar problems of the clutch sticking when released. Two of whom (in Australia) have received confirmation from Subaru that there is indeed a problem with the hydraulic clutch system in several model years. They were told by their dealer that they would receive a “modified slave cylinder, with a stronger spring and different valving.” I have invoice numbers and part descriptions from Australia.
I went to my dealer with this information INCLUDING the part numbers from the invoices from Australia. My cars symptoms have never been present when I went to the dealer, although it always happens on weekends when i drive up into the higher elevations (I live at sea-level). My dealer was pleasant to deal with, but basically said that if they couldn’t see the symptoms - they couldn’t do anything. But he took my statements to put in my record in case my warranty runs out (I have 10k miles left on powertrain). He spoke to his Subaru representatives and they claimed they had not heard of this problem, even though I have corresponded with at least 6 other people with this same problem. The rep did nothing with the part numbers I supplied for the modified slave cylinder, claiming that since they were Australian part numbers he could do nothing with them and that the cars were very different in different countries.... I don’t tend to believe that.
So now I’m stuck until the problem occurs at sea-level, or until I convince my local service manager to drive with me to Lake Tahoe (3 hours away) so he can see what happens at elevation!
Can anyone help?
You may want to set up a case with Subaru Customer Support (1-800-SUBARU3) and have them follow up on it as well. Sometimes you need to address it from both ends, corporate and dealer, for results.
BTW, which Bay Area dealer did you go to?
Ken
I've heard of weak pressure plates causing clutch chatter, but not hydraulic issues.
-juice
This isn't part of the "clutch" that gets replaced during a clutch job, so it probably needs attention. You might have luck bleeding the cylinder, 50k miles doesn't sound like enough to me for the average one to have problems. Of course if the previous owner was abusive or clueless about how a manual tranny really works, that could explain it all.
-Colin
If no luck then likely the seals are shot and replacing the slave cylinder should cure the problem.
Cheers Pat.
My OB came back from the dealer on 25 March 02 after the engine is replaced by a rebuilt short block. The dealer said two cylinder heads were skimmed (to have flat surface). It seems running fine now.
I don't personally believe it is a bubble. The reduction in atmospheric pressure going from sea-level to 5000 feet just doesn't seem like enough for a bubble to grow enough to make the clutch pressure disappear to this extent. The stickiness of the pedal leads me to believe there is a bad seal at the minimum.
Has anybody heard of this "modified slave cylinder" and/or stronger return spring that Subaru of Australia knows about but Subaru of America denies?
Here's what I received from the fellow in Australia:
"For reference, the slave cylinder was part number s/30620fc000kai and
the spring was s/36036ae000kai. On the invoice the slave cylinder is
described as 'modifed clutch slave cyl for lib/outback', so perhaps
this problem affects those models too."
Ueyn
I know it is frustrating to have a problem that can't be duplicated. It's equally frustrating for us to figure out situations like that, but it isn't hopeless. I would not base anything on your overseas contacts. They do have different components.
Any information that you have from the previous owner may help. Servicing especially.
I'm sure we can get some options for you, we just need a chance.
Thanks,'
Patti
I have recently been in touch with another Subaru Legacy owner in my area who has the exact same symptoms as me. He also has trouble duplicating them at sea-level and thus never brought it to our dealer's attention, though I told him he should just so they can get it on record. I will have him start a case as well. I'm sure there are others out there, too.
-Ueyn
Thanks for giving us a shot at it!
Patti
It was eventually traced to a master cylinder contaminated with dirt.
Anytime you have an intermittent problem, try to get it on video. It proved useful with my last clutch problem.
-Dennis
Ueyn sends the "bat signal", and Patti dons her cape. Rev up the Batmobile.
Didn't twrx trade-in for a WRX? I think he's on those threads.
-juice
Ken
Yesterday, my wife was driving our '01 VDC to Denver on I-25. Suddenly something large, dark, and harder than cardboard hit the windshield. Upon arrival she discovered most of the hood deflector missing. It appears that it failed where it wraps around the hood on the drivers side and then wrenched off the passengers side at the point where it comes down to go around the grill. The hood deflector was factory installed. Took delivery just over a year ago. ~22k miles. Dealer said they would replace it.
Has anyone else seen this behavior? Is there a structural or design weakness in these or did I just get a weak one? Seems a bit premature for it to fail. I guess I shouldn't be surprised when I take into consideration the amount of oscillating it does at highway speed when wind is gusty. Perhaps the film stuck to the hood is the way to go.(?)
Theo in Colo.
My 97 OBS is the same way.
Does yours have screws? The only way for mine to come out would be if both screws loosened.
-Dennis
Never have had a problem with it. I remove it when waxing and before any automatic car wash.
Was it the OEM Subaru one or an aftermarket one? The OEM one has 'SUBARU' on the lower right (driver side) - at least mine does.
Do you know if you have left it on during a automatic car wash? Or did someone try messing with the deflector? I suppose it's possible that the plastic itself developed a crack, which can grow easily with the pressures of wind and heat/cold.
Glad to hear the dealer will replace it. I don't believe this is common (at least not mentioned on these boards).
-Brian
-juice
Jim
-Brian
Supposedly cleared up by now. We lost 2 deflectors in high winds off of our car in less than 18 months, most recently this last January, and have now abandoned the Subaru OEM part. The last time it came loose, it destroyed the paint on the hood and both fenders.
Fortunately, we were still under warranty, and they repainted the hood and both fenders, but I won't risk a repeat - the hassle factor was enormous eventhough they stepped up to fix it.
Subaru bug deflectors are made out of acrylic, which is pretty brittle at normal temperatures, and worse when cold. When they switch to polycarbonate, we'll reconsider.
I understand there are aftermarket options out there, but I haven't researched them myself.
HTH
-mike
Patti
Steve
Since begining, the old engine had a knocking sound under light acceleration (1500 - 1800 RPM) when the engine was cold, and it disappeared after approx. 500 meters in modarate speed. The knock gradually became noticeable at 2100-2500 RPM under labour (acceleration) even the engine was in normal operational tempreture. I am using my vehicle mainly in town drive (the speed limit is 50 to 90 KPH). The speedometer reading is now 10200 KM.
Len
-juice
That's kind of strange for the light to go out so soon. I thought the source was an LED and those things last very long.
Between my 98 Forester, and my three other friends who have 98, 99 and 00 Foresters, I haven't heard of any of the control lights going out.
Ken
My question is that now that the Seals are replaced what oil should I be putting in. My personal experience has been about the same. Whether I am using synthetic (Subaru) conventional (older Dodge), or a blend (Mazda) Seals have failed between 120 and 125 thousand miles.
What do I do to minimize this repair?
Ken
I haven't had the light or time to look over the rest of the vehicle for any other damage yet.
The dealer exchanged it for me this morning. Said they had seen a couple of them break similar to mine. Not sure if those were Subaru or GMC, though. (Patti, the dealer is in my profile on my.subaru.com if you'd like inquire further of their experiences.)
The oscillation was not constant. At 80 mph it would normally bend a little in the middle. If there was considerable turbulence, then it would oscillate in the middle. It would be nice if it was a polycarbonate. If this one breaks, I guess we'll get an "invisi-bra".
Theo in Colo.
Nevertheless, I will keep a more watchful eye on it now to see if it does flex during driving.
Glad they replaced yours no problem/no questions.
-Brian
Are you sure it's not a loose timing belt tensioner and not piston slap? I'd have a dealer take a look at it just in case. Many times, the noises can be similar. I think piston slap was isolated to some engines in a particular model year.
Ken
