It came to the Subaru dealer in a thin plastic bag - no box, no nothing - with 2 nicks. The service manager noted that fact on the receipt and told me I have 12K miles to see if the nicks start to corrode.
The dealer said Subaru's parts distributor (contractor) sucks - at least for the metro NYC northern suburb area...
I am going to watch my tire installer like a hawk when I get new tires put on this weekend... I'll bring some felt along to place the wheels on! LOL!
Ralph
lars11
Not sure about the clutch, sorry.
-juice
I wonder if it will hold up to the action of the window pushing up against it. The tear is right at the apex of the gasket.
Ken
Time to get crafty. I would put a layer between the caulk and the window, maybe some saran wrap or something else that could later be removed? Maybe wax paper since it doesn't stick to anything?
After the caulk dries you could remove it.
The stuff sticks like glue, but it dries flexible.
-juice
Steve
Join us tonight, 6-7pm PT/9-10pm ET for another round of automotive trivia and member-to-member chat. Test your skills (or multiple choice guessing ability) against other Town Hall members.
http://www.edmunds.com/townhall/chat/townhallchat.html
Hope to see you there!
MODERATOR /ADMINISTRATOR
Review your vehicle
I have tried many things but can't seem to conquer this. I have:
1- changed fuel filter
2- changed plugs and wires
3 - replaced pcv valve
Often when I do something it seems to be OK for a while but lately that hasn't mattered as much. Sometimes I've found the spark plug tip loose and will retighten it. Again when I would do something, it would be ok for a while ... perhaps several weeks.
Now it seems to be happening almost every day. so I took to a mechanic. He thought it was the coil and replaced it. The problem still happens though. He hasn't been able to find the cause. He says he has switched fuel injectors, wires, spark plugs, etc but can't find the cause.
I checked the NHTSA board and found several similar complaints but no clear solution. One note indicated there is a known problem with bad head castings and that Subaru might be recalling.
I'm at a loss. Does any one have any information or suggestions?
TIA
I've seen you post this before and would like to make a comment on your "synthetics strip seals" information. This is complete malarky that your mechanic passed along to you. Not only will synthetic not do anything to seals, but there is no such thing as a substance on the seals to prevent leaks.
Just wanted to stop an urban legend from developing. You should get your source for this on line with us so we can set him straight, eh?
IdahoDoug
IdahoDoug
Doug: it was the SoA mechanics that hosted that Edmunds.com chat. In fact, I bet it's in the transcript if you feel up to looking for it.
They said that dino oils form a layer of sludge on the seals which actually help seal them up, and that synthetic oil use can strip those and cause leaks.
They did say it would be OK to switch early. I don't recall if they mentioned spefic types of synthetics or not, but again the transcripts would show that.
-juice
Since it's only 1 cylinder missing and you do not mention replacing the distributor cap, I think it could be the culprit. Remove the distributor cap and clean the contacts, or if they're worn out - replace the cap.
If so, you may need to re-program the ECU.
-juice
-juice
Cutting the holes for the Side markers is more of a challenge especially since I do not want to use any of the hokey aftermarket ones that are held on with screws I intend to use an OEM style where you have to drill or cut a fairly large hole in order to clip them in.
Hopefully when I do mine I will post photos.
Cheers Pat.
Steve
Wish I were on the chat - would have provided a different perspective on it. Yes, a little grundge is deposited on the seals and in fact all other parts of the engine. But the grundge does not in any way "block" oil leakages such that removing the grundge would be a bad thing. Interesting theory, however. I'm sure the dino oil makers would love to take out full page ads in all the papers "Dino oil automatically seals up engine leaks as you drive!!!" and the like..... Heh.
Pop an engine open and you'll find the grundge can be wiped away with a finger - hardly a factor against 30-80psi oil. Anyhoooo back to the regular programming, I guess
IdahoDoug
Found this at the Mobil1.com site: http://www.mobil1.com/why/myths.jsp
MYTH: Mobil 1 will leak out of the seals of older cars.
REALITY: Mobil 1 does not cause leaks. In fact, new Mobil 1 with SuperSyn™ was tested in dozens of industry standard and OEM tests to prove its seal performance. It is fully compatible with the elastomeric materials from which all automotive seals and gaskets are made.
ExxonMobil engineers are wary of conventional oils that tout their use of additional seal-swelling agents. With extended use, these agents can over-soften engine seals, resulting in leaks. More to the point, an oil additive will not rejuvenate worn or damaged seals. The damaged seal may have been caused by a worn rotating metal component in the engine.
If an older engine is in good condition and does not have oil leaks, Mobil 1 with SuperSyn™ provides the same advantages as when used in a new engine. ExxonMobil recommends taking measures to repair the leaks, then using Mobil 1 with SuperSyn™. ExxonMobil also always recommends following the automobile manufacturer's manual for the proper oil to use.
To me, this means that an older engine that develops a leak after switching to synthetic would have still developed a leak sooner or later using dino.
FWIW, YMMV, :-)
-Brian
With the OB, I think you have to remove the glove box for access. Still didn't sound too hard though. I heard that the Odyssey's are nearly impossible to reach and require all kinds of tools.
-juice
Interesting tid bit, but of course the manufacturer of the product is gonna claim that. If they said "our oil can cause leaks" they'd have a million lawsuits overnight.
-juice
The amount of salt used on the roads this winter has created 'dust storm' like conditions in places. Never felt the need before for the filters, but am rethinking it.
Steve
I have one in my Forester, but then again I have asthma.
-juice
Cheers Pat.
I'm thinking that something came loose in the exhaust near the headers. Any one else care to guess what it might be?
Last year, I had the dealership replace my heatshields because they were coming loose. In the process, they inspected the y-pipe and exhaust for any other damages. I'm guessing this might be a result of that work. Any guesses?
Also, would a leak in the exhaust result in a slight loss of low end power due to a drop in backpressure? It seems like I have a little less off-the line grunt, but I'm not sure.
I'm going to make an appointment with the dealer soon.
Ken
Anyway, I tore a section of the wheel well cover, about 1", when trying to move it out of the way to insert clips.
So, is a DIY repair/patch available?
TIA
-Dave
A little glue, a little dirt to cover the glue - good as new!!!
Steve
-Dennis
Yes, I would recommend them.
I was just not being careful at prying the wheel well cover out of the way. Didn't realize that there is unexposed edge behind the rim of wheel well.
-Dave
http://pub1.ezboard.com/fultimatesubarumessageboardsthenewgenerat- ionofsubarus
- Does anyone know if this is an upgrade to the 2003 WRX clutch with the bleeder valve?
Anyway I noticed that the RR mud flap was not seated to the body as closely as its counterpart on the left. Closer inspection revealed that the flap was loose, with the middle of the three hex head screws that hold it in place popped out from its hole. (I can only imagine that I did that by backing into a snow bank.) I can't tell if I stripped the hole as clearance is tight and I can't get a ratchet wrench, much less my hand, in the wheelwell space between the flap and the tire.
I guess I'll have to remove the tire to make the fix, or else find a pivoting head for the wrench.
Ed
cheers Pat.
I presume you tried just jacking the car up? curious if you wouldn't have enough room to get in there with that corner of the suspension at full droop...
-Colin
Contacted Patti and she's awaiting a new PC at home with DSL service. She expects to be back (with a vengeance) in about 2 weeks.
-juice
Thinking out loud here it’s hard to imagine Subaru isn’t aware of it. Just log on to a couple of discussion groups and you can see how common it is. If 8% is accurate and they know about it, it would be poor business judgment to ignore, in my opinion.
It's been unusually quiet here so I'll post a link to my original post/question:
kens Mar 22, 2003 5:40pm
I'll be bringing my Forester in tomorrow to the dealer.
Ken
For the folks under warranty, they are covering it, right? I wonder what % of those happen after the warranty runs out.
60k miles is longer than a lot of companies offer, but still.
-juice
If so, I'd drive the front wheels up on those, then jack up the rear at the rear differential (I've done it and it managed the weight fine).
Then get under the vehicle and try to trace the noise. If it only happens at certain rpm, you might need the wife to hit the throttle to try different rpms.
It could just be it was rusty after this winter, and one good bump knocked it loose. They can sometimes re-fasten it if that's the case.
Is the OE exhaust stainless? I wonder, if not it's prolly not worth saving. Here's your excuse for an aftermarket one.
-juice
If you are gonna be under the car use proper jack stands especially if you are going to have the car running and somebody goosing the throttle.
Cheers Pat.
-juice
Cheers Pat.
There are lots of things you can reasonably expect would go in a car, but I think you should be able to expect the head gaskets to go longer than 100K (or longer than 150K, to my high-standard way of thinking!) barring abuse.
The noise is most noticeable when the engine is under load and around 3000 RPM. Any higher than that and the engine noise drowns it out.
I'm pretty sure there's a leak somewhere because my garage stinks like exhaust fumes when I start the engine in the morning -- not to mention the aftermarket exhaust like sound I get.
I'm hoping whatever it is will be covered by the dealer since they did exhaust work on it about 6 months ago. I'd consider an aftermarket exhaust, but I'm saving my pennies for my next Subie! ;-)
Ken
