Subaru Crew Problems & Solutions
1155156158160161385
  • kevin111kevin111 Member Posts: 991
    They had a rep. for blowing? The reason is I had a '95 V6 with over 110K miles on it with no ill effects (the gasket valve covers were slightly leaking though, but not enough to be an issue).
  • 96subie96subie Member Posts: 3
    In regards to the Ultimate Subaru Message Board link I posted above, take the time to go through the current active messages as well as the archives (lower right of the web page). Other common problems with the H4 2.5 phase I and II engines are the oil seal leaks and piston slap/valve train noise, which I believe have been mentioned on this forum as well.
    While I haven't experienced any problems with head gaskets yet (knock on wood) on my 96' Outback, I have had 2 oil leaks, one at 63K - the oil pump o-ring and gasket, the other at 101K - crank seal. The crank seal was not a big deal as I had the timing belt done anyway, and as long as the front of the engine was opened up, I had the mechanic replace the oil pump seals again for good measure. Still, I consider these oil leaks a major safety issue as the leaks usually flow back and fall on the y-section of the exhaust below, causing the oil to burn/smoke and smell.
    Not to mention these repairs by themselves can take some serious cash from your wallet. I'd also should mention in the 2003 April issue of Consumer Reports, their "car issue", the 96 Legacy/Outback as the dreaded full black circle on the engine line.
    I believe you'll find in various forums on the web that there are attempts to gather information on these problems, and to summit the findings to the NHTSA in hopes that there will be some recall pressure put on Subaru. We'll see.
    All in all, I'm fairly happy with my Subaru. However, given the frequency of reported engine problems on forums such as this, I'm a little leary to include Subaru on my short list again for new vehicles until SOA addresses these current issues.
  • locke2clocke2c Member Posts: 5,038
    Ken,
    if it's not covered under warranty just go to a custom muffler shop* and have them take care of it. they should be able to weld any minor issues.
    *the reason I say a custom muffler shop instead of a generalist repair servicer or chain muffler store is because they probably actually know how to weld properly at the custom place. those other yahoos generally weld about as well as I do, which is to say they're better at cutting and making a mess than fixing something like an exhaust leak. bolt ons and entire new sections are their bread & butter.
    -Colin
  • once_for_allonce_for_all Member Posts: 1,640
    anyone get the impression that forums tend to feed anxiety and antagonism towards the manufacturer and dealers? Sometimes I wonder... I have had tons of good information from Edmunds, on the other hand a single complaint or even half a dozen encourages over reaction. Honestly, I think I bought the Subaru Gold warranty 6 yr 80 K because of that very reason, when logic and statistics tell me that should have been a waste of my money. The search for balance in our postings is a challenge to us all.
    John
  • stevekstevek Member Posts: 362
    yes mine are just about the same spot maybe a 1/2 inch or so more forward
    Yeah, if you're gonna trade up for something else soon, I'd patch it too.
    I forget exactly the cost, but we put a new muffler on the 626 just before selling it, and it was much more than I had expected for only portion of the exhaust.
    -juice
    True about Toyota, but remember they fought that tooth-and-nail for about 6 months, maybe more. It took a pretty serious internet campaign and lots of court battles before they finally caved in. There were threads right here on Edmunds about that.
    I'm sure some bean counter finally determined Toyota had more to lose, financially (due to a damaged reputation), by not doing anything, and that is the only reason they did it. Otherwise they would have covered those right away.
    And remember - lots of those sludged up engines had warranty claims denied. Subaru seems to be covering the gaskets under the powertrain warranty, unlike Toyota did.
    Any how, what to do? I'd suggest everyone that has had the problem and was denied any fix go to NHTSA and register a complaint about the gaskets. I'm not sure it involves any safety issues, but it's worth a shot.
    Also call 800-SUBARU3 to open a case number, that'll help them trace the problem to certain models or production dates.
    Finally, we'll keep the discussion open here and count the number of cars affected. So far I've seen about 10-12, although most were covered, only a couple were not.
    John: good point, it is a slippery slope, one upset consumer can turn a constructive and useful discussion into a nasty fight. So far I think we (and the hosts) have kept this discussion constructive, and IMO that is what will yield the best results for all in the long run.
    -juice
  • kenskens Member Posts: 5,869
    Good advice, Colin. I'll remember that.
    I thought I'd have the dealer take a look at it first since they worked on the exhaust last year. I still have the 1yr/12K miles warranty on parts and labor.
    Ken
    Okay, just heard back from the dealer and the Y-pipe is cracked. Not even a year ago, they checked it and it was fine. :-(
    They're quoting me $420 P&L to replace it.
    Is this something that I could simply have repaired?
    Any advice?
    Ken
    That's about what we paid for a leak just before the muffler on the 626. So at least it doesn't seem out of line with what a major chain would charge for a similar repair.
    I'm sure others will chime in.
    -juice
    Are there any aftermarket options for Y-pipes?
    Is a Y-pipe the same thing as a header? I see the terms interchanged on i-club.
    Ken
    Get it welded at a local shop for ~$150. I needed to have this done on the SVX recently.
    -mike
  • lakepoplakepop Member Posts: 221
    Ken the Y pipes are the modern day version of the old dual exhust look. In order to achieve that dual outlet look they put a "Y" pipe aft of the cat and add two mufflers and some piping.
     Honda uses it on their V6 even the Cadillac STS uses it.
      I personally find it a vain attempt to achieve some kind of look ...it certainly does nothing for power and only adds to the maintenance costs.
    It is certainly not a header since you can just kneel down and look under most of the cars and see the "Y" pipe.
      OK....hope that helps
    ken,
    the Y-pipe is where the two headers join. paisan's estimate sounds accurate to me...
    -Colin
    The Forester has only one tailpipe so I'm assuming the Y-pipe is then located where the headers join.
    So, for a performance header like Borla, for example, is the y-pipe built in?
    http://home.att.net/~teaguesauto/exhaust.htm
    If I do go to a exhaust shop, I may still run the risk that the crack is too bad to be welded, right?
    Ken
    OOPS...my bad.....I'm talking oranges...you are talking apples.
      Sorry...I did not read the thread....jumped on the wrong thingy and am at the wrong end of the exhaust system ...: (
    The Y-pipe on the Accord V6 and TL are indeed behind the cat, and split the stream from one to 2 pipes. Edit: just saw your correction after I posted.
    But on Subies, it's the opposite. The exhaust is basically 4 into 2 into 1. The Y in this case is the second half of that, the 2 into 1, where the two streams are joined to form one pipe that then feeds into the main cat. From then on it's just one pipe.
    The photo on Teague's shows this better than I can explain it. In essence there are three "Y"s, but I'm betting the crack is in the last one, downstream just before the cat.
    I think for $309 I'd get the Borla, though you'd still have to pay for the install.
    -juice
    $309 is attractive, but would I need to get a whole cat-back system to make it worthwhile?
    I wonder what installation of the Borla would be.
    Decisions, decisions...
    Ken
    I don't think you'd *have* to. The cat is the most restrictive part of the exhaust anyway.
    You might not get the full benefit (what, 5hp maybe?), but I bet you'd still get at least half or it.
    -juice
    I think I'm going to cave on this one and just have the dealer swap it. I just don't have the bandwidth now to be making multiple trips to dealers or other shops, let alone worrying about any problems caused by the aftermarket parts.
    We just had a big layoff at our office and I'm swamped running around picking up the pieces.
    I really appreciate the input, though folks. I'm sure the info will come in handy in the future (when things are better, I hope).
    Ken
    Sounds good. You wouldn't have spent any less going the other route any how.
    -juice
    You could easily install the Borla headers yourself. $16-20 for new exhaust manifold gaskets and you're set...
    I'd rather spend that than pay the dealer's asking price for new. Borlas make neat noises. :-D
    -Colin
    Wanna move next door, Colin? ;-)
    Ken
  • Colin is right, Subaru has got to be the easiest car of all time to install headers on, go for it.
       Cheers Pat.
  • russskirussski Member Posts: 47
    I'm new to this forum and not sure if this is a right place to ask technical question.
    Can anyone tell me how to change spark plugs on my Subby 2003x. It looks like it requires to remove some bits and peaces to access plugs
    Regars From down under...............Vitaly
  • ffsteveffsteve Member Posts: 243
    ken, Im gonna buck the trend here and vote for the dealer repair, or at least having anyone else do the dirty work. Of all the myriad jobs under a car, I always disliked the exhaust system the most. But then, I've never done anything more than change the air filter on a Subaru so maybe I'm out of touch. And I still have memories of a rusty bit of Corvair exhaust getting stuck in my eye, causing an irritation the rest of the day. It was only when I went to bed that night that I realized that something was in there that irritated the back of my eyelid, preventing sleep. Doctor in the emergency room had to pull it out of the surface of the eye where it had worked its way in.
    If you do tackle it ourself, you will gain a measure of self respect and certainly admiration from many of us here. But wear goggles!
    I used to like working on my car and making repairs for nothing more than cost of parts (sometimes less) that would have cost hundreds more if I went to a shop. But in the last 10 years, I have realized that there are many more enjoyable ways to spend time than under the car.
    Good luck on whichever path you choose.
    Steve
    ken-- I do have a lot of vacation to burn... if I had any air miles left I'd drop by just for grins.
    not much biz travel recently, so no freebies. :-( I have faith in you though!
    -Colin
    Either when I am playing a talk show, or sometimes play music relatively loud, I will hear a tinny sound comming from the passenger door, but not all the time. Does this sound like a blown tweater? I mainly hear this durring talk radio. Just curious.
    from several mechanics I know: for Subarus try to stick with dealer parts and be very carefull when purchasing aftermarket parts. They say the OEM parts just wrok better for this brand.
    FYI: I sent my set of Magnacore wires back over a week ago (for a full refund, although I did not ask for the two shipping charges, and what a mechanic charged to "professionally" install the wires), did not hear anything from them yet.
  • bluesubiebluesubie Member Posts: 3,497
    But even Subaru exhausts come from somewhere, don't they?:-) I know Borla makes some of their exhausts. Oh wait, maybe that's Bosal.
    I took my OBS to the dealer once for a bad heat shield rattle. They spot welded it for $25, and within a couple of weeks I heard a loud exhaust noise. Turns out there was a piece of weld (or solder??) that popped out from its location exposing a dime-sized hole. I took it back and they patched it up again. Never had another problem with it.
    -Dennis
  • forestergumpforestergump Member Posts: 119
    Could be a damaged speaker, but it could also be a small item or debris in the door pocket (if you have one).
  • sfdriversfdriver Member Posts: 35
    If I turn up the base in my 2 month old Forester w/ basic speakers, they have a tinny sound on AM talk stations. Sounds OK if the base is set back to the below 2. Maybe the problem is just the cheap speakers? Music sounds OK when the base is turned up, tho. Try turning down your base and see how it sounds.
    Well, I'm going to disappoint the DIYers here but I decided to have the dealer take care of the exhaust repair (bows head in shame). I shopped around a bit and prices were about the same at local independent shops. If I weren't swamped with taking care of our new house, upcoming baby and getting our office back into shape after our layoffs I probably would have tried the Borla installation. I sure miss the simpler days past when I could just focus on the car. :-)
    The bright side of it is that my low end torque is back, my exhaust note no longer sounds like some cheap boy-racer car and my garage is fume free. But, boy did that new exhaust stink and smoke right after I picked up the Forester from the dealer!
    Colin -- It's wise of you to have used up your miles. I'm nervously looking at my UA stash wondering if it will be useless in a year.
    Ken
    Forsetergump - checked the pockets, and this does not seem to be the trouble.
    It is sort of like what sfdriver is stating. What is interesting is that I do have the upgraded speaker package, and was not experiencing this before. It is more of a high-pitched tiny-vibration that is intermittent (not all the time, but specifically with talk radio), so maybe something fell into the speaker? I am still trying to locate the problem.
    Thanks to both of you for the suggestions, I will keep these in mind with the diagnosis.
  • p0926p0926 Member Posts: 4,423
    I think John makes a good point about the potential for these forums to feed anxiety when otherwise the owner would be blissfully unaware. The head gasket issue being a case in point. While this forum is good for owners who have experienced this problem to share information, it has the side-effect of creating worry for existing owners and scaring off potential owners. For arguments sake, let's assume that the 8% figure is correct. That means that 92% of owners have nothing to worry about.
    Why even the fact that there are over 1000 posts in this topic will lead some people to conclude that Subarus are problem-prone when the fact is that there are only a few problems repeated several times along with numerous responses. Add in the general questions like the spark plug one above coupled with the fact that Subaru owners are some of the most prolific posters on Edmunds and suddenly it looks (on the surface at least) like Subarus are pieces of junk when in reality Subaru is one of the most reliable makes.
    -Frank P.
  • 03xngreen03xngreen Member Posts: 36
    I think it’s good to keep issues out in the open so knowledgeable guys like you Frank, or Juice, can talk about them and all of us novices can listen and learn. It’s then up to each reader to critically digest the information discussed and make their own decisions.
    I am able to learn a great deal about my car, and potential problems, that I would normally not be aware of.
    For instance, the clutch shutter issue. I started experiencing this on my car, and would have just assumed it was normal (it was getting worse though). Finally, it dawned on me about my model having issues with glazing over the clutch, causing it to shutter. Thus, I was able to describe the issue to the dealer and explain to him what was wrong. As a result, they understood the issue, and are replacing my clutch. Probably would not have happened if I was not aware of this issue.
    - Kevin
    Oh I agree that this forum is an excellent source of information. You just need to keep the "problems" in perspective.
    -Frank P.
    I do not see as many "this car put me through hell and will never buy one again!" stories with the Subaru despite all its posts as I do with lets say, VW. It seems that a VW poster every now and then posts a horror story with a relatively new car.
    That's another benefit of having a spare car in the fleet. :-)
    For a fix like that I could afford to be very patient, and do it myself even if I'm clueless about 'xorsts.
    -juice
    Vitaly: for easier access most people remove the intake (change the air filter while you're at it) and the windshield washer fluid reservoir. Once you've done that it's not difficult.
    green: thanks, but I consider myself a novice too. I just try to help gather/share the info.
    -juice
    For those of you who like to do repairs yourself and save a few dollars, here are some excellent links on how to replace the bulbs in the climate control unit.
    http://www.med.uc.edu/pstp/students/fortner/rulights.htm
    http://www.randomsoup.com/how_acpanelbulbs.html
    The original link source:
    http://pub1.ezboard.com/fultimatesubarumessageboardsfrm6.showMess- age?topicID=46.topic
  • Got a question about the FWD slot in the under hood fuse box. A discussion came up here at work amongst a few Subaru owners about the use of it. I offered an explanation that (I think) I remember coming from the crew:
    The temporary use spare, being of a different rolling diameter, will be interpreted by the center diff as continuous slip. Constant torque transfer to the other 3 tires will take a toll on the diff. Reverting to FWD (with it's open front diff and no torque management) will spare the system from excessive wear.
    While this sounds very logical to me, I can find no reference to it in my ('02 OBW) owners manual. I even got a chance to look over the full shop manual set from my friends '99 Forester. They only have a vague reference to the fuse slot as for 'emergency use' but with no specifics. Anyone have a reference, or even confirm that my suggested use (as above) is sound?
    Steve
    Makes me smile when Soob owners go through all that trouble to help each other out. Way to go!
    -juice
    I agree with your suggestion.
    However, there is one catch - I'm assuming they'd want two full-size tires on the front axle. That means the donut goes on the rear axle.
    Better solution? Do what I did with our Legacy - get a full size spare.
    -juice
    It's not mentioned in my Owner's Manual either, but it is listed in my.subaru.com's tips list. Here's a snippet:
    Exceeding this 1/4-inch difference in tire circumference can place unnecessary wear on drivetrain components, possibly causing them to wear out prematurely.
    If your vehicle is AWD (All-Wheel Drive) with an automatic transmission and the temporary spare tire has been installed, put a spare fuse (15 amp) inside the FWD (Front-Wheel Drive) fuse holder (refer to your owner's manual for location). Confirm that the Front-Wheel Drive (FWD) warning light comes on before you drive the car. Installation of this fuse deactivates AWD to prevent possible damage to the drivetrain components that can result due to the use of the smaller temporary spare tire. After re-installing the conventional tire, remove the fuse from the FWD fuse holder to restore AWD operation.
    The manual shows where the fuse is located, but no instruction on its use. Wierd. HTH.
    You want to put the donut on the open diffy axle, not the rear axle, if you have it on the rear axle and have an LSD you will hurt the LSD with it on the rear.
    -mike
    Sorry, I should have mentioned I have two open diffys. In that case the front carries 60% of the weight of the car, so I'd put the spare on the lighter rear axle.
    If you have the rear LSD, definitely put it on the front (open) axle.
    -juice
    Juice:Thank you very much for your input
    It is greatly appriciated. I will do as you suggested.
    Vitaly
  • mw38mw38 Member Posts: 4
    I've had to take my WRX in twice for the same problem. When sitting in traffic or running the AC, the engine would miss badly, and the check engine light would come on. For the last few weeks, the engine was running rough. After taking the car in, I was told that this is a problem with the computer that Subaru knows about but hasn't solved. I was even encouraged to try getting my gas at the same place, use premium fuel (which I do), and bring the car in if the problem continues (so that "we can work together to solve the problem." My thought was, "If this keeps happening, I'd better look at the lemon laws.") Has anyone else had this problem?
