Visitor Agreement.
I took it in and left it all day, as requested. I didn't even talk to the mechanic when I picked it up, having wasted enough time making two trips out there, but was told by another employee that the bracket attached to the glass was a little out of adjustment. If I'm reading the print-out correctly, they're billing Subaru for 24 minutes.
All's well that end's well. That was Thursday. Saturday I received a letter from the dealer telling me that I would get a survey soon and to be sure and call the dealer first if I had any complaints about the warranty work.
How much do I get paid for using my time to fill out another form? Close your eyes, what do you see? I know, I know. It's important - to them
John
Stopped by the dealer Thursday afternoon and was able to show them the problem in action.
Dropped the car back at the dealer Fri and had a call 2 hours later, they are going to replace the throttle position sensor but it will take 3/4 days to get the part. So I'm driving the car with the bouncing idle until then.
At least they are seem to be looking in the right direction, Blaming it on a tune up just didn't feel right to me.
John
I have to slow down one of these years.
Otherwise, car has been flawless.
Ralph
-juice
The score so far:
(8) trips to various dealers for service
(27) days in the shop since I received the car in October
Over $400 in lost wages
128 gallons more fuel used than my previous 2001 Forester (at current prices, about $180)
New catalytic converter, O2 sensor, and spark plugs
Still not fixed.
I have another call in to Subaru, but everyone I know is telling me to throw in the towel and go the Lemon Law route. Although I hate the idea, after 6 months of trying I'm running out of options. I can't keep putting in this effort while the car slowly poisons my family.
Over in the Toyota threads....the rotten egg odor disappears when the cat coverter is fully "broken-in".
bit
I had a cat go on my '81 Mustang, and that's what it felt like.
Bit: maybe put that FR tire on the RR, and see if it changes?
-juice
Cat broke down....and clogged up the exhaust pipes (and the cat was rattling also)
Basically, you'd be driving along just fine, and then slowly your speed would decrease and the exhaust note would slowly silence. Pulling over for a few minutes (to allow it to cool a bit) would help, but it did get replaced soon after that.
-Brian
It could be the cat, but a clogged cat would usually be clogged all the time, and would thus deliver poor power all the time. It shouldn't be hard for them to test that in the car, as the exhaust flow would be lower than it should be. In the worst case scenario, removing the cat for inspection should resolve whether it's clogged or not. This problem is very visible when you look inside it.
It could also be a pinhole leak in a head gasket; also very checkable with a compression gauge. The fanciest version of this is a leak down test. It's a gauge with several hoses that checks all the cylinders at once for leaks when they're under pressure. I had a similar problem with an old Volvo that drove me nuts trying to track it down. It would work fine, then no power, then fine again.
Hope this helps.
A clogged fuel and or air filter could also be the problem, but I'm assuming you're way beyond the "simple fix" stage of diagnosis.
the timing belt should be replaced on the
98 Outback with 2.5L engine. The dealer said
the interval has been changed to 105,000, but
other still say 60,000.
DB
the timing belt should be replaced on my
others still say 60,000.
DB
-Colin
105K replacement on my OBS and wife's OB (although she had hers replaced during a crank/cam shaft reseal).
-Dennis
Habit -- Older Subarus had 60K change intervals. From what I hear, they failed pretty much on schedule.
Conservatism -- As Colin wrote, it's cheap maintenance compared to the potential damage to your engine should it fail. The maintenance schedule in your owner's manual is a minimal set of requirements based on ideal driving conditions.
Extra money -- Based on the above and a lack of any additional knowledge, many owners simply let the dealer do what they say is required.
My suggestion: Have the dealer inspect the belt at 60K and replace at 90K. Replace immediately at any time the belt looks worn.
Ken
-mike
What if you left the car for overnight and then let the sun shine on it (with cold engine underneath)?
Have you ever experienced a no start with the engine not running for 24 hours and left in the sun?
My problem with accepting your theory is that I do not see how the heat of the sun alone could cause this. I'm not saying absolutely you are misdiagnosing, I'm just extremely skeptical at this point without some solid field testing of the problem.
Jon
I am also thinking of changing my spark plugs a bit earlier at 50k rather than 60k.
Jim
One of my local dealers was trying to push spark plug replacement every 15K miles on my 2K Legacy...until I pointed out Subaru specs in my manual. Then they backed off.
I recently hit 15K on my Legacy and priced around for the appropriate service. I live in Utah, which by default qualifies me for the severe service schedule because of salt and extreme temps. According to Subaru I should have my tranny, brake, and diffy fluids replaced every 15K. No dealer seemed to understand that, though. I had to insist on the fluids being replaced (cheap insurance to prevent expensive repairs IMHO) during the service. It pays to know the manual, because apparantly the dealers don't.
Ty
Not speaking specifically for any manufacturer, I know that the same timing belt goes on all models sold in the US as it would be ludicrous to find a way to be sure that somehow timing belts installed on vehicles that eventually sold in California were the "higher grade" belts. Most cars built in the last 5 years are "50 State" cars, meaning they are certified to be sold in any state. For a time, some mfrs did build different emissions for CA, but they quickly realized it was cheaper to build all to CA's higher standards. Of course if you live in Kansas and the belt fails at 104k you'll pay for it, and if you live in California the factory will, but the belt is designed for 105k. Personally, I will run my belt to the California mileage even though I live in Idaho, though I will personally inspect it at some point prior. If I were the type who constantly towed, raced, or otherwise stressed my engine I would not do this.
General comment on intervals - read your owner's manuals. Dealers are generally reputable but they'll gladly sell you all kinds of extra work. So you can pay yourself perhaps $500 for the 15 minutes it takes to read the maintenance schedule by avoiding the extra work the dealer "recommends".
Finally, a question. I was told the 2.2L engine in my '97 is a non-interference engine, meaning that a broken timing belt will not allow the pistons and valves to hit as a result. I was at the same time told that ALL Subaru engines are this way. Can someone clear this up for me and others on the board? Thanks.
IdahoDoug
On my last dealer visit, Subaru tech line advised to try different gas (Exxon mid grade) and an additive from BG products. This has not worked either. Throttle position sensor sounds interesting. My car does exactly what yours does, so I'm dying to see if that works.......
As for interference/non interference:
Interference:
2.5l DOHC (OB, 2.5RS, 2.5Legacy GT)
3.3l DOHC (SVX)
2.0l DOHC (WRX)
Non Interference:
1.8l
2.7l
2.2l
2.5l SOHC (OB, 2.5RS, Legacy)
Unsure:
3.0l DOHC (VDC, LL Bean)* This one uses a chain, so I'm not sure it's applicable
-mike
I've just started to experiment with differnt gas (grades, brands and locations) I live on the boarder between MN and WI. Gas is about $.10 cheaper per gallon in MN, but I believe has more ethanol and other additives?? (gas tax is the reason for the price difference...) So far I have noticed some performance difference.
Mike: the 2.5 SOHC is 2000 models and newer right??
--Jay
2.5 SOHC is in: '00->'02 Legacies and Outbacks
2.5 DOHC is in: '96->'99 Legacy GT and Outbacks
2.5 DOCH is in: '98 2.5RS
-mike
Defective T/P/S switch 1.06volt idle 3.62V open
The part hasn't come in yet, I'll post the results when it does and I've had the car a few days.
I too tried the different brands/grade of gas routine, but to no avail.
FWIW, the Forester uses the same engine as the 2.5l in the Impreza for all years.
We had Darlene confirm, it's 90k inspect, 105k replace. Given they'll already be at it, I'll just change it at 90k.
-juice
-mike
-juice
By the way, someone was asking on one of these boards about dyno graphs for the SOHC engine. While I've not seen one of these, I do know that it's making 155 ft lbs at 2800 rpm. Discounting any spots where the curve might dip a bit (not likely given how smooth it pulls IMHO), and doing a little math with the published numbers, that means it's making 93% of peak torque or better between 2800 and 5600 rpm.
I have this from a friendly district factory rep I met at the auto show some years ago when we were shopping, and the SOHC was relatively new.
I could write you a few pages describing the BTU transfer process, but maybe another day. The problems come down to:
1) decreased air flow limits removal of heat at the condensor ('radiator' in front of radiator).
2) compressor pump works inefficiently at low RPM.
3) high temp freon returning to the compressor cannot be completely converted back to the liquid state.
4) expansion valve on evaporator (core in your dash) cranks wide open, but cannot achieve max BTU exchange (liquid to gas conversion). Air output from registers is cool but not cold.
Hope this helps,
Steve
My understanding of the poster's problem is that it cranks and cranks but won't start after being in the sun.
They offered to pay for a rental, and even had Enterprise come to my house to pick me up and bring me to their office. Very convenient. Anyway, I hope that this will solve the chattering condition, and I'll share any info with the group when I get it back.
Len
It seems, back then, if I shut the Honda down in hot weather, and then tried to start the car again, say within 5 -10 minutes, it would not start. It turned out that gas in the carb float bowl would start to boil, and somehow bubble over and flood the carb. I would have to put the gas peddle to the floor, hold it there, and crank until it started. Often that took quite some time.
Could it be, even though you have fuel injection, that something like that is occurring? Is it possible to "flood" a fuel injection system?
Bob
Ross
Once again on your Honda is wasn't the sun that did it, it was the "heat sink" effect of shutting down a very warm engine (which continues to heat up even though not running).
I still think this problem is electrical and related to engine heat, wherein a substandard electrical part is dying under the stress of engine heat and recovering when it cools down.
-Brian
-mike
Had the wife's OB in for 60K service. They even put you in a rental for the major services no matter where you bought the car.
They did a fine job on my last round of clutch problems.
-Dennis
Dennis: maybe it's the seat track? Since it didn't rattle when someone was sitting in it.
Or maybe there's light paper in the glove compartment! Holy cow, Smokey! ;-)
-juice
