Subaru Crew Problems & Solutions
Mr_Shiftright
Member Posts: 64,481
in Subaru
This topic is for discussing any problems with Subaru vehicles that haven't been covered in the Owners Club Board or for people who need pointers to that Club or other resources that would help them solve their Subaru problems.
Ron
Maintenance & Repair (Topic #15) here. Enjoy!
Bonnie Rick
Conferences Manager, Edmunds.com Town Hall
Still debating myself re the merits of studded vs. studless snow tires... I really want to believe that the studless will work, but I've been driving studs on every car I've owned for as long as I've been driving. My chief concern is stopping on ice - we get a lot of warming/freezing cycles here, and the roads turn to skating rinks. "Go" grip isn't a problem (as I discovered driving home from work this morning), but stopping is an adventure on the Michelins. Anybody in the snow belt have any input on this subject? (I'll put off my trip to Les Schwab's & wait for responses)
Cheers!
Paul
1) My left windshield washer squirter shoots the fluid out too low. It squirts out and hits the bottom of the windshield. My other one squirts the middle of the windshield. Is there anything i can do that is simple enough for me to do.
2) is it standard that when I turn on the intermittent wipers, you can hear a distinct "click" as the wiper goes back and forth or is that not supposed to happened. It does not click when on the other options?
3) Interior noise - I just may not be used to it but it can be noisy. It sounds like a window is down or a door is ajar(but they are not). I do have the moonroof but that does not seems to be the case. Maybe this is normal???
4) Clicking noise or cricket noise coming from front driverside seatbelt mechanism? My wife thinks i'm nuts but this is driving me crazy. I've located the noise I just don't know what to do about. Push, pull, apply pressure, Whack it nothing helps? Can or will the dealer fix this problem for me? I've only had the car for 1 month!
5) I've tried to move the roof rack backwards to eliminate some wind noise for the moonroof and also to give an unobstructive view upwards. The allen wrench that was supplied does not fit tight enough or i'm doing it wrong. Should i leave this alone?
Thanks for any replies! K
re #3 noise: What were you driving before? My OB is noisier than my Explorer was - noise is relative.
re #5 the roof rack: If it's the generic Subaru rack, it might be a #30 torx nut - try a torx driver with a real handle for a better twist.
Welcome to the Subaru clan!
Cheers!
Paul
Thank you very much for your info on the topic.
This is to Subaru Team's post # 1261. Does this apply to 2.5 phase II engine or to 2.5 phase I engine.
I recommend that anyone who owns a Subaru should go out and purchase a lug nut wrench that has a longer handle than what comes with a new Subaru. That being said, I hope you never have to use it in an emergency!
-mike
I've also noticed that my sunroof seems to whistle all the time at speeds > 50mph even when closed. I'm not sure why that's so. Closing the inside cover deadens the noise. In any event, it does appear that much of the wind noise is attributable to the sun roof. Oh well, that's the price we pay for having a huge portal over our heads :-).
Just finished a 3000 mile road trip in my Forester (only four states, but one of them was Texas :-). Other than the above-mentioned racket, my Forester worked great. Handled the steep grades with aplomb -- that 2.5L engine pulls like a locomotive! The only problem I have is that my engine computer got used to running on "real" gasoline, and now that I'm back here in Phoenix with the funny "oxygenated" gasoline, I hear a light taptaptaptap -- a light knock -- when I hit the accelerator hard. I presume that eventually the computer will get things right again, though running on the knife's edge of detonation IS the most efficient way of doing things...
Also, the computer apparently got accustomed to the demands of the cruise control, and is now reluctant to downshift the automatic transmission when I floor the accelerator. Takes about 3 seconds before it decides. I guess this helps avoid the annoying "hunting" behavior that afflicted older hydraulically-controlled automatics (where it couldn't decide what gear to use going up grades and up and downshifted dozens of times a minute), but in its own way this is just as annoying... or maybe this is the usual behavior? I don't know, since the car was not broken in before the trip and thus I never floored it (following owner's manual advice to not rev over 4,000 rpm during the first 1,000 miles).
-- Eric
Craig
Ron
Dr.zoom - 1) Try sticking a pin in the washer nozzle and move it around to change the direction.
Dennis
Cheers,
-wdb
MikeF
Anyhow, I found that, as I'd suspected, the Forester is no off-road vehicle. No big deal, I already knew that. It handled the forest roads okay though, including stretches that a regular car would have never gone through (such as fording a small stream and scrambling up the gravel bank on the other side, and waddling through a boulder-paved section of road). I did find out that the approach angles suck. Too long of a front overhang. Nothing to do about it other than hoisting the car further in the air, and I don't want to ruin its on-road handling by doing something like that. I did manage to bang the front "skid plate" a couple of times on washouts.
Anyhow, afterwards I got the car into its garage and looked underneath to see if there was any damage. I didn't see anything, except for some scratches on the front plastic "skid plate". But I did notice that the exhaust pipe coming off of the second cat is crooked downwards, and is only maybe 6-7 inches off the ground in the middle of the car. It then veers back up and disappears over the suspension, until it comes back down to the muffler/tailpipe again.
Question: Is this bend natural, or did I manage to bend something during my rough-road travels?
In other news, I found that MRE's, much destested by military personnel, actually taste good if you're hungry because you've been hiking for several hours. Who woulda thunk it?
I also have a 2001 Legacy GT 5spd and I tried not to rev over 2800 rpm for the first 500-700 miles and then not over 3000 rpm for the next 1500 miles.
Recently I also tryed high octane gas instead of regular and it did not make any difference.
-mike
http://www.iace.com/ia/trooper
Obligatory URLs (I can't help myself):
Michelin automotive tire glossary
Michelin earthmover tire glossary (more detail & entries)
70 lb-ft was recommended by an auto-crosser. I didn't see anything in the owner's manual. Anyone know the exact factory torque specification for the lug nuts on a 00 GT (wagon) (alloy wheels)?
..Mike
..Mike
Cheers,
-wdb
[1] 0.75 in = 19.05mm
19.0 mm = 0.748 in
..Mike
PS - Metric/English converter (Java) and Interactive Units Converter.
..Mike
-Tony
Ron
http://www.jps.net/brettnkt/convert.html
It helps to have a Palmilot but then you gain portablility ;-)
Cheers,
-wdb
Just wish the vehicle could have a little more useful feedback so the driver could easily differentiate between a potential major engine problem and a loose gas cap.
So now I find out how Camelback Subaru handles warranty claims. I want a new wiper arm, I'm not going to let them get away with simply tightening it down so that the few remaining ridges inside the wiper arm make contact, because those will strip out soon enough (the wiper arm appears to be made of aluminum or very soft "pot metal").
-E
I'd suggest you upgrade to a higher wattage high beam bulb (although if you fry the wiring harness subaru will not cover it) I'm not sure how resistent the new wiring harnesses are to higher wattage bulbs. I have 80/100w H4s in my '88 XT6 with European lenses/reflectors and they are awsome.
-mike
25mpg on the way up and 27mpg back, with more traffic. Go figure.
PSI: I'm running 33psi. 29/26 was too soft and bouncy.
For off roading, I tried 20psi and it was still too firm. 18psi worked best for me in the deep, soft sand. I'd try 20psi for off road and adjust it from there based on your needs.
Paul: I bet those lug nuts were over-torqued, probably by far.
Eric: your exhaust is fine. That's how mine is shaped. Believe me, I've spent at least a few hours under Sandy.
The good news is that it can flex upward quite a bit, since they're on rubber hangers, so if you scrape it you should be fine. You'd really have to bang it up to do damage.
tex: OBD2 is a pain. They actually designed it to give the driver less information so you'd have to go to a dealer for even minor problems.
When I was shopping for a used Miata, several people advised that I go with a pre-ODB2 or even an older pre-OBD model. They're more tolerant of mods, too.
-juice
Seems excessive for a loose gas cap. Why not give specific codes if the owners can very easily fix it?
-juice
I just wish the codes were more specific. "Check Engine" for a loose gas cap? C'mon...
-juice
Mike, 70lb-ft is correct for alloy wheels. Try 80-85 for steel, but not more than that or you'll ruin the studs.
By the way, a good way to break loose lugs without getting an aching back is to put the wrench on and sticking out parallel to the ground (9 o'clock). Now stand on the wrench.
-Colin
If a loose gas cap is the cause of the c.e. light, wouldn't an ECU reset after tightening the cap do the trick?
Dennis
tincup: actually, that's not quite correct. I've filled up with the engine running before and no light came on. I know this is not recommended but I had simply forgotten and it idles quietly.
Anyhow, we could debate this to death, but it's not up to Subaru since it's federally mandated so I'll let you have the last word on the subject.
-juice
I agree with Juice that OBD2 should provide more data.
Ron
-mike
As for breaking lug nuts loose, I do the stand-on-a-pipe routine as a last resort. I've found that a "short, sharp shock"[1] with a decent breaker bar has a very good effect. I've amazed friends doing this in the past, even one guy who was heavy into body building (I'm not exactly a muscular guy); he was trying to get the lug nuts loose on his car, and couldn't. I walked up and, pop! Boy was he p*ssed .
Use a long enough breaker bar; mine is an 18" long 1/2" drive model. Put it on the lug nut so that it is roughly parallel to the ground and so that an upward pull will loosen the nut. Lean over it with your back straight your arms cocked. Pull UP on it gently to remove all slack. Then give a hard, sharp yank up towards your chest, all motion with your arms and none with your back. Works for me, even when the wheels were last put on by the ham-fisted mechanic who has no idea what torque is. If I'm using one of those X-wrenches I do the same thing except with a push-pull on opposite ends of the X. It's not quite as effective but should get most of them. The key is to remove the slack first and then to make a quick, sharp motion.
Cheers,
-wdb
[1] Okay, who am I quoting this time?
WDB, I was mistaken in <20-21</A>>. I tried 0.75 in and 19.0 mm sockets on the lug nut; both had equal play. Lo mismo, just as you said. Forgive my incredulousness, oh wise one. Oh, and thanks for the Palm conversion app, I'll dl it mañana.
[1] I shan't hazard a guess.
..Mike
..Mike
Some shops even apply some "yucky gooey stuff" (pardon the technical jargon) so the nuts don't slip, and it's never been a problem.
-juice
Cheers,
-wdb
you blokes are starting to show some real potential!!!
Does anyone make a front protector (bra) for the 2001 Forester other than the Subaru-branded one?
Why is it that there seems to be only one Subaru version? I thought that the lights and hood changed a bit in 2001; wouldn't that affect the fit?
By the way, horror stories notwithstanding, bras can be used long term with perfect safety--the only possible exception being Vancouver/Seattle type weather. Wax the hell out the hood (etc.) before putting them on and make sure that they are not flapping about. I've had one almost continuously on my '92 Prelude, which has been outside the whole time. There's no way to distinguish the covered from the normally uncovered parts of the hood.
But then, I probably wouldn't try this with GM or Ford paints...
Norman
