-Colin
-mike
Without a functioning oxygen sensor, you're going to get very bad gas mileage. Oxygen sensors aren't expensive and they're no more difficult to replace than a sparkplug anyway.
-Colin
-mike
Touch-up paint comes in a small bottle a little bit bigger than a nail polish container. Works the same way, though. $4 from...oops, I really miss Darlene.
AC power - I have used my cell phone there and it works and charges the phone. A notebook computer crashed when I started the ignition once, though it could be the charger (works fine all other times).
-juice
I did a lot of driving on my OB this weekend as I had visitors from the East Coast. OB did fine except for one of the speakers making a noise every so often. If you can say this really fast, you will know what I mean:
ch ch ch ch ch ch..... It does this noise really fast. But it happens so randomly and is quiet. Not a loud noise. We can't tell if it is the speaker in the back door or the tweeter in the back by the trunk. Or if it is a speaker at all. But, what else would it be? All the speakers work. Not sure how to pinpoint the problem. Anyone have any ideas or suggestions? I would really appreciate them. Soon enough will be time for my first oil change!
Old Subaru's used to have a light that read off the code of the CE light. I am not sure what the new ones do. There used to be a little flashing light with a morse code of some type. That is how it worked on my 90 Loyale. One time the light went on and I lifted the mat looked at light and called a garage and asked what was the code for e.g., "3 fast flashes and 1 slow one". They said it was O2 sensor. Made sense since light went off after replacing it. They are expensive!
On my 90 Accord with 161K the light has not yet gone on! I must do a great job at maintaining it. Any help on the speaker noise will be great!! Thanks.
You just can't compare pre-OBD cars to new ones like that.
-juice
Any idea about the speaker noise. I can't take it back to the dealer unless I can spot the problem. It is annoying! Any ideas?
Patti
Patti
..Mike
That way if the message said "Gas Cap Loose", the driver could fix it themself. If it said "O2 SENSOR", then you make a trip to the dealer. Simple (and cool) enough for this techie.
-Brian
That is my problem. How to duplicate the noise. I can't. It is so random. I drove for hours and hours yesterday. Everyone in the car was on the look out. We could not really pinpoint it. That is most annoying part.
I have never driven an H6 but am beginning to see the need for it. Especially when the rpm's go to 4.5 in order to maintain speed in California hills. Doesn't happen too often.
The drive back from Santa Cruz was great. After spending a week in the Trooper, the Forester felt almost like a sports car. I felt like I was riding extremely close to the ground. The steering and throttle felt very responsive. The suspension felt great as it quietly and firmly absorbed road irregularities. The chassis felt so solid as I took the turns. I had a huge grin on my face as I wound through the "hill" on highway 17.
Gotta love the Forester!
Ken
-Colin
Ken, I love that hill on 17! What a great drive.
..Mike
Patti
Anibal: can't help you on the speakers, but you may consider replacing them. People who have report far better sound (I listened to Hutch's and I have to agree).
-juice
One thing to keep in mind - if the light is on steady and the car is performing okay, it is usually something that can wait until the next service visit. With the gas cap issue, once it is tightened and your fuel level gets to about 1/2 a tank, it will recycle and check again. The light will go out.
With OBDII, the codes are actually stored in the system, so even if it goes out, the dealer can double check it during service to clear the code and confirm that there isn't a bigger issue.
I think the day will come soon where the auto industry gets more self diagnostic tools to help the consumers. But, that's just my opinion.
Have a good one!
Patti
I was told they only repainted part of the fender. I took a very close look after I got home yesterday and they did a very good job in color matching. The black on the Foresters have a slight red tint to it so I was worried about the color matching, but it seemed to have gone okay.
There is a very slight orange peel texture. Kind of looks like very faint "waves" in the clear coat. It's difficult to notice even to my picky eyes -- do you think I should complain?
The shop also repainted the entire front bumper so it looks like new -- got rid of some other scratches and rock dings.
I also had them work out a door ding using paintless dent removal. I am very impressed with the results. I can't even see the slightest hint of having a dent in the rear drivers side door.
Ken
I have a dent in the rear pass. door, I ought to consider doing the same.
-juice
What exactly causes orange-peeling? From what I can see, it's just a very slight imperfection in the texture and not the paint color.
The dent removal cost me an additional $75. I think it was well worth it since I got so used to focusing on that one sore spot. It's like it never happened.
Ken
$75 eh? Not bad.
-juice
bit
I think orange peel is the opposite of overspray. When they try to avoid overspray thet put extremely thin coats of paint and if they don't use enough clear coat then you get orange peel. Usually you can eliminate the orange peel with more coats of clear coat. but unless you allow some time in between for it to dry some you will be left with overspray. It is a very thin balance. It once took me and a professional painter 8 hours to paint my VW rabbit! Most places paint a car in hours!
You can always remove orange peel by wet sanding the car. But leave that to the professionals!
Like bitman says, it will look fine outside by the sunlight!
Am I being too picky? Is it unreasonable to ask for a factory quality finish?
Ken
bit
The reason a body shop will never be like the original paint is because most body shops don't have dust free facilities and state of the art technology! So to have the shop do it again does not warrant they will do it better. No one is going to put their face inches from the car and say nice paint job.
But if they see the whole car under a tree on a sunny day they might look at the glare and say nice paint job. So no need to worry. If by standing next to it you can't notice I would leave it alone. Don't fix it if it ain't broke!!!! As they say...........
BTW, the body shop does a lot of Subarus and was highly recommended by Santa Cruz Subaru. That was the main reason why I went so far out of my way to have it done there. Off topic, but the manager who took on my work order also owns a WRX wagon.
Ken
bit
or any MT for that matter:
I've heard recommendation to not use the clutch when stopped on an incline... does this mean to put into neutral and not engage the clutch, and to use brakes or emergency brakes only? If so why?
Yes, the best trick on a steep hill is to use the e-brake and slowly let out as you're accelerating.
Dennis
-Colin
They cannot bake the finish like the factory can, but given it's about 3 years newer than the factory paint, it should be cool.
I just wish they painted my entire Miata instead of just a few panels!
-juice
Cheers Pat.
juice -- Yeah, I think I'm being way to picky. I'm sure the unknowing person wouldn't be able to pick it out.
Ken
Mike
OCD Master
bit
snizave: the same thing happens to me when i pull out of my spot in the garage at my apartment. all i try to do is just go real easy on the gas and not use the brake.
But noone can beat Bit. He's the OCD King.
Though I am picky about my cars. When the Miata was done, I pointed out a few flaws and left it there for some touch-ups. There was a little overspray on some black trim, the center wheel cap wasn't replaced, and a loose piece of trim actually broke when they tried to secure it. It's fine now. I imagine lots of customers wouldn't even have noticed.
-juice
Cheers Pat.
-juice
It all started when I had everyone on the list measuring the ride height of their Soobs since mine was about 1/4 inch lower on the left front.
I think it says something about Subaru when us ultra-picky types are happy with their vehicles.
Ken
Leo
-Greg
just kidding
"Midas Plus™ brake replacement parts are designed to meet- and in many cases exceed- the performance of the equipment that originally came with your car. Vehicle Specific Design (VSD™) makes them fit better, stop faster and last longer than any other replacement pads. And, they're quieter, too. Thanks to our rigorous quality standards and unmatched installation skills, your brakes will perform as well as the originals- or better!"
The special expires this Saturday. FWIW, I recently had brake pads installed by Meineke. I was very unhappy with the service and the pads are so-so. They are quieter (read: softer) than the stock pads and don't seem perform as well. Not too concerned since I'm leasing. I would go with OEM or better aftermarket if it were me.
Dennis
