it would be a waste of time since the v6 dual exhaust isn't really dual. the one pipe just splits into two just aft of the rear suspension. it is for looks only...unless that is what you are looking for?
Any idea what something like that would cost?
I just purchased a 2000 Honda Accord Coupe and I am finding it bothers my back because it's so low to the ground. I am 6'5" so don't have a lot of clearance. Any ideas on how I can modify it to make it more comfortable?
Luke
-thanks.
There's lots of reading about tire recommendations at www.tirerack.com.
i have about 3500 miles on my car right now. when should i be getting my first oil change? i have read anwhere from 3000-7500 miles? do i wait until 7500..it sounds like a lot of miles. a lot of my everyday driving is stop and go, waiting in traffic. maybe about 40% highway miles. also ive been getting about 23mpg...does that sound normal or is that low? just curious
but at least know this: your car came from the factory with a special 'break-in oil' and it should NOT be changed until at least 5000 miles.
What if it takes 9 - 12 months to reach that 5000 mile barrier?
Btw, my name is Leland also.
Would you happen to have specs. on the 2004 Accord EX V6, 5 Speed Auto? Is the 5 Speed Auto top speed also 135 MPH?
I also think the 135 mph top speed is due to limiter.
Is the 135MPH top speed limiter is that for all the Accords, manual and auto?
The driver, the track, the car, the conditions can probably vary the times by several tenths. I'd guess that the car mags rev the automatics while holding the brakes on whereas Edmunds doesn't. The Edmunds numbers are almost always slower than MT or C&D.
As good as automatics are these days, I wouldn't expect to see more than .2 or .3 improvement from a manual trans.
Now you got me curious. Have you noticed any difference between the Japanese built vs. the Ohio built Accords? Secondly, what are the limits for the MPH of your Accord?
Changing oil every 3,000 miles is a waste of your money and more importantly a waste of limited fossil fuel resources.
I am suprised that some apparently knowledgeable people keep touting a 3,000 mile change as "cheap maintenance".
When my billfold gets too heavy with ones , I usually burn a few to reduce the weight as a "cheap maintneace" to my body carrying too much extra weight.
I advocate making those Saudi sheiks even richer at our expense. Haliburton doesn't have enough money. Let's consume more oil to help those poor guys out.
Let's continue the same oil change intervals recommended for the poor quality oil used fifty years ago in those antique engines. Why should we consider the advances in automotive technology and lubrication chemistry made in the past half-century?
I continue to marvel over the mystery of it all.
Engine Oil & Filter - Flush and replace at 1,000 mile intervals
Brake Fluid - Flush and replace every 3 months
Power Steering Fluid - Flush and replace monthly
A/T Fluid - Flush and replace every 6 months
M/T Fluid - Flush and replace annually
Tires - Deflate completely and refill with fresh air monthly
MMO - Add daily
Spark Plugs - Sand blast weekly, Replace semi-annually
1) Carmakers don't use oil change interval as a selling point. We don't see ad lines to this effect in any public media. However, to a very narrow slice of the motoring public, those who read the maintenance part of the owner's manual, the 10k or 7.5k numbers may be a buying criterion. But to the rest ?
2) There's testimony in this forum from owners who followed the manufacturers' recommendation and actually achieved 100k plus repair-free miles.
3) There's also testimony from owners who follow the dealers' - not the manufacturers' - 3k recommendation, reporting repair-free ownership.
4) With manufacturers bearing full litigation and commercial risk for their recommendations, and with dealers knowing that short oil change recommendations drive customer traffic, whose advice is more consumer-oriented ?
