Visitor Agreement.
For comparison, let us use 1998-2002 Accord EXV6 (3329 lb). It had about 17% more torque in the mid range than this K24A (195 lb.-ft versus 166 lb.-ft). But, courtesy of having five speed auto and possibility of gearing shared with RSX (base), TSX will have 18% shorter gearing. Which mean, TSX, despite of having less torque from the engine, is making up for it via tighter gearing. So, do not be surprised if TSX feels as much powerful as 1998-2002 Accord V6, even with 5-speed auto. It certainly would match the 0-60 (upper 7 seconds) and quarter mile run as well. That is more than enough for all but drag racing.
Now, here is another perspective. I have recently put over 5000 miles on a rented Hyundai Sonata V6. On paper, the 2.7/V6 has considerable advantage in torque and power compared to my 98 Accord (2.3 liter I-4). However, based on my experience, the Accord, despite being heavier of the two, feels much more peppier, around town, from standstill or from rolling speeds. This is probably due to the willingness of engine to rev and respond quickly to any driver input as well as proper gearing. And most Accord owners will tell you (including me) that the H23A is more than enough for most of the driving needs. K24A in the 2003 Accord is even better (note that several reviews of Accord with I-4 have mentioned the engine to match or beat some V6s in execution and smoothness). The TSX version of K24A is even more advanced, with more power and torque, and uses drive-by-wire throttle as well (like 2003 Accord V6).
I see your point in increasing the displacement and adding another cylinder to do so. But I doubt Honda will take the route of a transversely mounted engines. There are some benefits to it (as was apparent in the mid-90s when Honda developed DOHC versions of the 2.5 liter I-5 SOHC then used in Vigor for Argento Viva and SSM concepts, both RWD, in 1995). But, Honda practice is now to mount the engine just in front of the front axle (instead of FM configuration) for front drivers, probably to reduce torque steer and improve traction. Transverse engine mounted Hondas also had very long wheelbase (notice that the wheel base shrunk from over 111 inch to 108.1 inch with redesign of TL in 1999). This can mean considerable design changes of the platform. A simpler solution would be to stretch TSX to Accord Coupe dimensions, and put the J25A or J30A. In this case, the difference between TSX and Accord would be only in styling and suspension tuning, and with the additional features, it will cost almost as much as the next TL! So, instead of having another $28-30K V6 sedan, Acura might be settling in for a lighter and smaller sport sedan priced from at about $26K.
BTW, are people really comparing this car to the Mazda 6? I don't care what the comparison looks like on paper, these cars will be leagues apart. The Acura looks classy, while the Mazda tries too hard....and never mind the 6's Ford genes....
As for weight, with all the safety and solidity that is being built into cars and a long list of features that go with it, cars are gaining weight. Considering that Prelude was about 3000 lb., I wouldn't be surprised that TSX weighs about 150 lb. more. Audi A4 is a smaller car, but it weighs 3252 lb. (with 1.8T, 5-speed manual, and 15" rims in base trim, about 3450 lb. with 1.8T Quattro). TSX is comparable to Passat in size, and Passat weighs about 3350 lb.
And here is the dyno plot for K24A in American Accord.
I'm guessing not much will come optional except for NAV system and maybe a performance variant later.
Will it have side curtain bags for front and rear passengers?
Side airbags, side curtain airbags, 4-channel 4-disc ABS w/EBD (electronic brake distribution), VSA (stability control) are standard.
Lets keep this in perspective - there are nearly a decades worth of Corvettes from the seventies and early eighties that could not keep up with this TSX. At the time nobody was calling them underpowered, or not able to keep up on the freeway.
Regarding weight. Where did this 3200 lb number come from? There is no way the TSX will weigh that much. The Accord weighs 3109 lbs in EX trim (a DX model is 2989 lbs). I expect the smaller TSX to come in close to 3,000 lbs. Add about 60 lbs for the automatic.
One can extrapolate that to the NA model based on minor changes for this market.
RSX: 2694 lb. (5-speed manual)
RSX Type-S: 2767 lb. (6-speed manual)
RSX: 2767 lb. (5-speed auto)
I would be dissapointed if the TSX weighs more than the larger EX Accord. Even a 6 cylinder Mazda 6 weighs 3,243 lbs. I have a minivan (first gen Odyssey) that weighs about 3,500 lbs, so a little sports sedan approachinig 3,300 seams bloated to me.
2025 BMW i5 - 2017 911 C4S - 2024 VW GTI - 2026 MB GLE450 - 2024 Genesis GV60 - 2019 Cayman
But everything's still in the air at this point.
I was on the road today and some punk kid in his RSX cut me off and sped away. Needless to say, I was eating his proverbial dust.
A little thin on info for a splashy intro. I suppose they are trying to drive you to the showroom, but I want some more data.
http://www.hondanews.com/forms/acura/TSX/index.html
It has been there for quite a while. The rear seat IS tight on the paper. But how we feel when we sit there in person could be a different story.
I hate Honda to put up the password for us to download the high res pictures. But the 2 interior pictures look really nice.
What gives? The whole point of having a 4-cyl is to be more efficient and have less weight. Now it looks like the car is a heavy guzzler. It looks nicer than the Accord, and probably handles a little better, but looks are about last on my list anyway - I can't see the car when I am driving it and don't really care what others think. If I had to chose between the two I would definately prefer the Accord at this point, and as a bonus I would save thousands of dollars. The "luxury" features are wasted on me anyway, as I would pay extra not to have some of them - most notably the sunroof.
Yes, it will have all the nice things that Accord EX (leather) has, and then some more. The additional standard equipment/upgrade over Accord EX-L,
8-speaker audio system (360 W)
Perforated leather seats
Side Curtain airbags
Vehicle stability assist (traction + side slip control)
17" wheels
Sport Shift with automatic and 6-speeds with manual
Xenon headlamps (HID)
wgr,
TSX appears to have sufficient torque to offer a pleasant driving experience. It is not always the torque rating of the engine, but also its eagerness to rev and the gearing. TSX has more torque than Accord EX (a comparable car), and if you have driven the new Accord, as some reviews have noted, even with only 160 HP, the Accord feels like it is using a small V6. TSX should feel stronger than the Accord, if not as strong as the new Accord V6.
TSX is probably using 'performance gearing' as opposed to 'relaxed gearing' offered in Accord, hence the difference in EPA estimates. Based on your needs, it appears to me that TSX isn't the car for you. It is being marketed as a sport sedan, and the choice of I-4 probably had more to do with balancing the chassis and making it more nimble than would be possible by stuffing a heavier engine on the nose. Not always is it gas mileage. Instead of offering the same car with a different look, I prefer the idea of seeing TSX and Accord as two different cars in attitude and execution.
Note that this is not the official EPA number. It's just Honda's estimation.
On the paper, its interior dimensions are almost the same as 94-97 Accord EX. It's too big outside for a 325/330 shopper to consider TSX.
So less room than a Civic, with more weight than an Accord EX-4 (maybe even as much as a V-6 if some estimates are correct), and worse mileage than a V-6 Accord. It may still be an engaging car to drive, and it is nice looking, but it does not seem to fit Hondas mold. I am whole heartedly in favor of the concept, but the execution seems a tad off. I am all for small cars, in fact I prefer them (my favorite car is still my 1980 Scirocco at just under 2,000 lbs and 156 inches), but not one that has the space of a Corolla with a 700 lb penalty.
FWIW Accord coupe even has a skosh more room at 91.1 cu ft.
More important, don't take those numbers on the paper seriously. They can be extremely misleading. Find the spec of the cars you have driven and you will know why I said this. For example, I feel I have the same rear leg room in IS300 and Civic. But on the paper, it's 30.3in vs 36in. Another example, Galant and E320 has 36.3in and 35.6in rear leg room, respectively. But E320 feels way roomier in the back.
I have been trying for years to get some explanations to this discrepancy between the numbers and the real feeling. So far I have had no luck. You may have noticed Consumer Report doesn't use those numbers. Instead, they post their own measurements.
Civic EX
Length 174.6
Width 67.5
Height 56.7
Weight 2601
Head Room (F/R) 38.0/36.3
Legroom (F/R) 42.2/36.0
Shldr Room (F/R)52.6/52.0
Hip Room (F/R) 51.2/49.8
Volume 88.1
A4/1.8T
Length 179.0
Width 69.5
Height 56.2
Weight 3252*
Head Room (F/R) 38.4*/37.2*
Legroom (F/R) 41.3/34.3
Shldr Room (F/R)55.1/53.4
Hip Room (F/R) NA/NA
Volume 90.1*
* Numbers are without moonroof
TSX
Length 183.3
Width 69.4
Height 57.3
Weight 3150 (est.)
Head Room (F/R) 37.8/37.3
Legroom (F/R) 42.4/34.2
Shldr Room (F/R)55.4/53.5
Hip Room (F/R) 54.4/54.4
Volume 90.9
Passat V6
Length 185.2
Width 68.7
Height 57.6
Weight 3373
Legroom (F/R) 41.5/35.3
Shldr Room (F/R)55.8/54.6
Volume 92.0
Accord Coupe V6
Length 187.6
Width 71.3
Height 55.7
Weight 3265
Head Room (F/R) 37.5/36.1
Legroom (F/R) 43.1/31.9
Shldr Room (F/R)56.1/55.4
Hip Room (F/R) 54.2/46.1
Volume 88.0 (91.2 cu. ft without moonroof)
Consumers Reports is a pretty good benchmark for interior measurements, since they measure every car the same way.
dudleyr,
My post with specs was in response to your earlier post. That said, TSX isn't a car to go for if size is what one is after. This car satisfies them who thought the Accord has gotten too big for their preferences.
TSX is basically a small Accord with a different atitude. It sounds like a perfect sedan for me and all that remains is... does it deliver what it seems to promise?
Just for reference, C&D tested a 33K Saab 9-3 Vector 6-spd manual (3361 lb) and got 7.3 seconds 0-60.
In other words, the TSX has less interior space than the Honda Civic LX !!!
Why buy the TSX, especially if you need a small car package ? Buy the Civic for a much cheaper cost and much lighter package and much better mileage, if the interior appointments are not that big a deal for you. If the interior features are a big deal, then why buy a Honda ? Buy an Audi, that has one of the best interior designs in the industry, bar none.
JMHO.
On another note, I too somehow received the "teaser" email from Acura about the TSX. I didn't like the styling of the Accord version that's been around for some months, but now it seems to be growing on me. That, and if it's being sold as an Acura, you know it must be a pretty decent car, even if it is a 4-banger. I want to find some more pics and look at it more sometime.
Oh, Audi....I think they're absolutely beautiful and still have just about the best materials and fit & finish in the business, but the reliability and mechanical quality under the surface doesn't have much of a good reputation. Gorgeuous, but troublesome.
An Acura RL and TL have the same interior volume at 96 cubes. Are they the same size. I don't think so. I much prefer my RL in terms of overall feeling of space.
We can look at the numbers all we want but until we sit in one we won't really know how it feels...
I'm sure Honda could have increased the interior volume by going for MacPherson struts front suspension (Camry, Altima, Civic, Saab 9-3, BMWs etc.). Instead of a 5-link double wishbone rear suspension (Accord, TL, CL, Benz E-Class), Honda could have used a more compact 4-link (89-97 Accord, 2001+ Altima, BMWs) or 3-link (Civic, RSX, pre-89 Accords, Benz C-Class) or MacPherson Struts (Camry) or semi-independent (Passat, Golf, Corolla, Insight). These alternatives would have increased the interior as well as the trunk size, but some would still find plenty to complain about (like Honda going cheap as it happened with Civic). It is impossible to please everybody, and TSX is a classic example.
Now, if you read anybody muttering why Accord has gotten bigger, you know the reason.
Diploid:
TSX is the same size as 94-97 Accord. Since it will come with Moon Roof, the interior volume would be identical to 94-97 Accord EX (may be a little better in some areas).
