1st, not all traction control systems are created equal. 2nd, like ABS, spin/slip has to happen before the system recognizes loss of traction, so a simple chirp of the tires is probably all but impossible to avoid.
Like early single channel ABS systems that reduced braking to all wheels when only one was slipping, newer 4 channel ABS and latest generation traction control systems have improved a lot.
The traction control system in my 07 Expedition is night and day better than the system in my wife's 07 Grand Prix. The GP allows a lot more wheel spin, plus it doesn't have any mechanism to redirect power to the wheel with traction (not a knock on GM as I know they offer better systems). Even in 2wd mode, I can easily go up my driveway with ice just on one side of the drive way in the Expedition. The traction control system will activate the brake on the wheel that is spinning to transfer power to the wheel that has traction (crude way of doing it, but it is effective), plus the system in the Expe is much quicker to react to wheel spin and does a much better job of controlling the throttle.
Does the Expedition have a limited slip mechanism to do that? Or are you saying it's a result of quickly keeping the free wheel from spinning very fast?
The Expedition's traction control system uses throttle control plus it applies the individual brake on the spinning wheel to slow it down, that transfers torque to the other wheel with traction.
Thanks for making my day, with a little trip down memory lane. :shades:
I thought it was funny that the 0-60 time of the '89 SHO was half of any of the other Taurus models. :surprise:
Funny thing with the SHO...the V8 version has always seemed the tamest to me.
I've sampled both a versions and the later v8 SHO was like an executive cruiser compared to the original v6 SHO that had much more attitude. I used to own a '98 Ford SVT Contour and it was more like the original v6 SHO except with better brakes and a better suspension.
It got your day off to a good 'start'.
Also. we made it through the worst driving conditions I have ever encountered.
It was Easter weekend in 1997. On the way back from Michigan, driving on I-90 through New York, we hit huge snow.
Cars were off the highway everywhere. You couldn't read any of the signs due to the snow stuck to them and none of the exits were plowed, so we couldn't stop or get off the highway.
When we got to Mass, it got worse. I should have taken a hint by all the 18 wheelers stopped at the state border, but kept going.
At one point, after we got off the turnpike, i drove over someone's lawn to drive around downed power wires. I was able to drives around several other downed wires while staying on the road.
Less that 10 miles from home we hit some ice under the snow cover and started to lose it, but managed to straighten out and continue. At this time, I was driving way under the normal limit because we were so close to home.
When we got to the last major intersection after driving over 15 hours, ther was no power. Lucky for us, our street still had power when we got home.
When my wife decided it was time for a new car, I told her I would take the SHO and we could swap out my Explorer, but she wouldn't take that deal, so it ended up getting traded in.
I saw that car for quite a few years, after we traded it in.
One time, I even saw it for sale privately, and asked her if she wanted to buy it back. :surprise:
Starting up a nicely tuned V8 is a pleasure, indeed. My E55, with its resonator removed, sounds very nice during the fast idle time when started cold.
usually, in jan/feb it warms up for a few days and I put a heat lamp under the oil pan for a while, use my cold start procedure, run the car for a while.
we just haven't had that situation this winter.
Real nice burble but the first two years that the made the V8 for Volvo they had problems with the bearing in the balance shaft. It is fixed now but all of the first two year models need the shaft replaced at some point.
Because it's a 60-degree V8?
sound racer v8
Can make your lowly Cobalt sound like a big block Chevelle.
Is it a 68? or 67? It has the reverse hood scooops with the turn signal indicators embedded in them. Did they have that in '68?
I don't recall seeing one of those with the CS and all on the side.
Have you got a bigger version of the picture?
And yeah, pretty cool...I wish my grandma drove something like that :shades:
There was a slight waviness to the body panels but overall this car looked pretty nice.
Well, that would be tough to top. Wow a Pantera, can't remember the last time I saw one of those, it definitely was at a car show.
