15615625645665671306
    Does your '57 Desoto have reverse position at the top of the shift quadrant or the bottom?
    I think the '57 DeSoto had a pushbutton setup. Apparently with no 'Park' button. The Ramblers of the late '50s were the same way.
  • uplanderguyuplanderguy Member Posts: 17,078
    edited March 2013
    You're right--I don't believe any Corvair with Powerglide ever had a 'Park' position. I lumped 'early Tempests' in with Corvairs and it came out not meaning what I meant.
    I believe some '64 Pontiacs and Buicks still had a "PNDLR" quadrant, as did Studebakers through '66 ('63 and '64 Studes could be had with "PRND21" quadrant--discontinued for '65).
    Probably sacrilege here, but to me putting a tachometer on the hood wasn't very smart and a small bulge there doesn't add to styling IMHO. I know that's considered a desirable option today on that era Pontiac today, and I'm very pro-big Pontiacs through '68 otherwise.
    Speaking of Tempests earlier...I'd just love to own a maroon '62 Tempest LeMans coupe with the 215 V8. I read online that that was only used in 1-2% of production. I know, I could just get a Buick or Olds but I like the Pontiac's styling details a bit better and well, I think Pontiac then was just cooler!. I used to like the '63 revision of the Tempest better, but I don't anymore. A friend of mine says I'd have to be a masochist to want a 'rope drive' Tempest though! ;)
    I believe some '64 Pontiacs and Buicks still had a "PNDLR" quadrant...
    Sometimes I get "splinters in the windmills of [my] mind!" Somehow I was picturing Desoto automatics with that "PNDLR" column shift instead of the pushbuttons Andre was posting about.
    Those early Tempests were pretty cool...lots of innovation going on. I wonder if the GTO package would have ever been built on the second gen Tempest if not for all the investment Pontiac put into the first gen. Pontiac was building its "Tiger" image for the Tempest even before the GTO.
    I recall the 63 Olds 88 I once owned had a quadrant something like that except that one of the gears was labeled "S" which I guess meant low? I had to repair that transmission and the mechanic said they were notorious for breaking down.
    I think that the 'S' stood for 'Second'. This transmission was a 3-speed. What I don't know is if selecting 'S' started out in first and then shifted to second but not third, or if it locked the transmission in second.
    That link to a '66 Corvair instrument panel made me realize something...apparently in those Corvairs, the clock also was in the center position instead of the speedometer. Goofy I think.
    Otherwise, that's a sharp panel I always thought.
    I remember some adult once trying to tell me the "S" position in those old Pontiac and Olds transmissions stood for "Slow"!
    Yeah Eunice, you ain't playin with a full deck! ;) I just did some googling, and the '54 Desoto automatic did have a column shift, with just "RNDL". You can kind of see it in this picture.
    The 1955 Desoto automatics had a lever on the dash; here's an example. Again, it's just "RNDL", no Park.
    For 1956, they went to pushbuttons. here's a close-up.
    From 1955-61, Desoto still offered a 3-on-the-tree manual shift, but it was very rare. I've heard that by '55-56, something like 99.6% of all DeSotos were automatic. I've seen a 3-on-the-tree '57 Desoto from time to time, but it's always been a low-line Firesweep, the Dodge-based model. The 3- was technically standard on the mid-range Firedome, which is what I have, with a 2-speed Powerflite being optional, and a 3-speed Torqueflite optional above that. I've never seen one, though. I've often wondered if the 3-on-the-tree or even 2-speed Powerflite was one of those mythical options on the '57 Firedome, like getting a cloth interior in a Lexus. Where it's "offered", but the when the dealers order their cars they bypass it for pricier options, and even if you tried to order one, the factory would reject it?
    Pontiac tended to also use "S" for "Second". At least, that's how my '67 Catalina and '76 LeMans are. PRNDSL. My '69 Bonneville was most likely the same, but I can't remember now.
    As for the position of the "R", wasn't it the old 4-speed HydraMatic that had the R all the way at the end of the quadrant, while the Slim-Jim had the more normal PRND21?
    Here's a '63 Riviera shift quadrant, showing PNDLR....either a two-speed or a three-speed that starts in second:
    http://www.lowridermagazine.com/features/1205_lrmp_1963_buick_riviera/photo_14.h- tml
    Why did Buick put a big engine in a Riviera and call it the 'Wildcat 465'? Shouldn't they have called it the 'Riviera' engine and then offer it in 'lesser' models? That's like the biggest Chevy engine being called the 'Bel Air' engine, for installation in Caprices!
    And why was there a Dodge Coronet 440, when they offered a 440 engine but that had nothing to do with the name "Coronet 440"? (I know Dodge used the '440' moniker before there was a 440 engine, but still....)
    I recall someone saying the S stood for super, but I think Bhill is right about second. I don't remember all of the quadrant labels, just the S and weird R location.
  • ab348ab348 Member Posts: 20,620
    I believe the official GM party line was that "S" stood for "Super", as in "super range". The idea being that it was a passing gear (remember that term?) that gave you super acceleration.
    I think it was similar to what Ford did when they offered "Thunderbird" engines in lesser cars. Transfer some cachet from the most powerful car in the lineup to the other models. The "465" or whatever number that was used was supposedly the torque rating. I had a '64 Skylark that had a 300 inch V-8 with a 2-barrel carb that was called a Wildcat 310 engine.
    I think Dodge went to those numbers around the time the downsized 62's came out. IIRC the base model was a 330, then 440 and top of the line a 500, the latter like at Ford (which back in the mid to late 50's I think had a Custom 300 base series model as well). Back then I think Rambler products had a somewhat similar numbering system where they went up the numeric chart repeating the first ordinal. Except, the lower numbers were for Americans, the middle ones for Ramblers and the upper ones for Ambassadors. I know being a Studebaker man you had a fondness for those American motors products!
    I agree, same as Studebaker putting the 'Avanti' engines in lesser models and labelling them as such, but putting a 'Wildcat' engine in a Riviera seems like something's going the wrong direction! LOL
    I think Studebaker and AMC were similar in the early and mid-sixties only in that their standard-sized car was an intermediate by Big Three standards, but I think Studebaker did so much more with what they had than Rambler, and they were a smaller company by then as well. Just MHO though of course.
    Even though a Wildcat would've been below a Riviera in catchet, perhaps people recognized that "Wildcat" meant performance, so when they'd open the hood of their luxury car Riviera and see that "Wildcat" under the hood, they'd feel proud that their luxury car had a musclecar engine in it?
    My old '69 Dart GT, which just had a 225 slant six, had a sticker on it that said "Charger 225". Which I thought was kinda lame, because it was just the generic 145 hp (110 net) 225 slant six that they used in everything back then. And no "real" Charger would have a slant six, anyway!
    edited March 2013
    Some years back I worked with an auditor who worked at the Belvidere. IL Chrysler plant for awhile when he got out of the military and was going to college. I'm guessing late 60's or first half of the 70's. He said the plant made full sized Plymouth Fury's and Dodges back then and was one of the first to get into numerical control systems. Anyway, he claimed that once in awhile a car would pop out part Plymouth and part Dodge because of either the wrong front or rear end clip, or seats. Supposedly the work rule restrictions and wages were so high that the plant scrapped them instead of reworking the issue. I was always a bit suspect because I thought if that was the case one of them would inevitably avoid the crusher and end up at a car show. But then again, those vehicles weren't really collectibles and were fairly similar as I recall, and someone could actually do the same thing in their garage if they wanted, so maybe it was true.
    i think that's just an old wives' tale, which probably came about when somebody in rural America saw a Canadian version of a U.S. car for the first time.
    Well, he worked on the assembly line, but it may have been an old myth there, or he may well have been pulling my leg. OTOH, early NC did have it's hiccups. But if that was the case, I've got to think those things would be easily repaired. Of course, IL is like CA - over regulated and over lawyer-ed, so maybe something in that realm came into play, like they couldn't then sell it as new?
    edited March 2013
    That's interesting. I wouldn't totally rule it out, at all.
    Over the years, hanging out at Chevy dealers in my 'yout', I can remember seeing these things:
    1) '77 Impala with Caprice Classic rear seat (same color and vinyl, but didn't match the front seat).
    2) '77 Caprice Classic cloth interior with three cloth-insert interior door panels and one vinyl-insert door panel.
    3) Nova Concours with thin side molding on one side and optional wide molding down the other.
    4) Early nineties Lumina with standard trim down one side and red "Euro" trim down the other.
    A friend told me about "Plodge Homnis" (Omnis with Horizon nameplates or vice-versa) would show up at their dealership. But that's not an entire front clip that was wrong or anything.
    Someone, I think mr. shiftright, posted earlier in this thread about his preference for mid to late '60's Mopar larger cars over GM and Ford.
    I grew up GM, big-time, but a Mopar product I think was just lovely when new and still is, is a 1968 Plymouth Satellite two-door hardtop.
    Graceful proportions, and I even like that very light metallic moss green seen so often on them.
    I literally wouldn't change a thing on them. I even like the looks, size, and location of the ornamentation on them.
    To me, it's as perfect as-is as the '65 Chevrolet Impala Sport Coupe. I don't think there's a bad line on it.
    edited March 2013
    OK, even though I'm a Studebaker guy, and I know why they did this (cost)--but I wonder about the 'smarts' of putting the '59-60 Dodge truck bed on their '61 Champ 1/2 and 3/4 ton pickups? It was wider than the cab.
    The Champ was introduced with the old double-walled Studebaker bed with 'external' rear fenders, but I've read that marketing showed people wanted something they could put a 4' by 8' sheet, flat, in the back of.
    I met the guy who engineered the Champ a couple times. A big guy who had a bigger-than-life personality, named Otis Romine. He reminded me of Willard Scott in size and personality. He said he approached Dodge about buying that bed as Studebaker did not want the expense of tooling a new bed, considering the size of their truck business at that time. Part of the deal was that Studebaker would build Dodge's replacement beds going forward.
    I will say that the crease down the side of the bed, and the shape of the rear wheel openings, actually (to my eyes) match the styling of the Studebaker cab better than that of the earlier Dodge cab. Studebaker did fabricate a new front panel and of course, a tailgate with "Studebaker" across it.
    But, I even know Studebaker guys that won't touch one because of its bed width. The short, wide bed is the worst offender IMHO. I'd still enjoy a long, wide bed version with Deluxe trim and whitewall tires. The old-style Stude bed was available through '62, but only the wide Dodge bed was available for '63 and '64.
    I was not aware that the slant six at that time was called the "Charger six". We had a six-cylinder '67 Chevelle and later a six-cylinder '73 Nova, and both had a label that said "Turbo-Thrift 250" on the air cleaner. Kind of a joke! "Thrift" and "Turbo" don't seem to go together very well! Of course, most of Chevy's V8's were called "Turbo-Fire" except for the 396 and larger engines, which were called "Turbo-Jet".
  • fintailfintail Member Posts: 58,783
    edited March 2013
    I've seen a 96 Cougar with a Thunderbird steering wheel. My grandpa had a NUMMI Nova company car that came with rubber floor mats stamped "Toyota".
    I've seen year change mixed up cars too. My family had a 1985 Tempo built 9/85, must have been built on the last day of 1985 MY production. It had a factory CHMSL and a 1986 model steering wheel
    I'm surprised that any domestic with a 9/85 manufacturing date would be anything but an '86 model year. But I don't know Fords of that era very much.
    There could have been an issue - probably not a lot of pent up demand for a facelift Tempo :shades: I remember I noticed its odd pieces as a kid, especially the rear light. Our car had a 4 spoke steering wheel rather than the "A" shaped one usually seen on 84-85 models. It was also disturbingly reliable for a Tempo, approaching 200K when it finally left the family, and having very few problems before 140K or so.
    That's good to hear. I seem to remember that they weren't darlings of CR either.
    My aunt and uncle were AMC people (and as a teen I ribbed Uncle Bob about that quite a bit!). They ordered a '74 four-door Matador, I think a Brougham. Dark maroon with black vinyl top, black knit cloth interior, and intermittent wipers--I will say it was the first car I was aware of having those. It came into the dealer in August and I can remember Uncle Bob saying the dealer said that interior material was 'new for '75'--similar to the kind of thing you remember with your folks' Tempo.
    Just like maybe 1 out of every 50 Civics is a lemon, maybe 1 out of every 50 Tempos was a good car. My mom got lucky. The car had its issues, primarily slowness, but it served faithfully.
    Little details like that get lost over time. My fintail has a fully round horn ring - usually found through 1963 (my car is a May 1964 build), but I suspect it was simply a leftover piece, and Euros didn't really go for model year changes back then anyway.
    AMCs are odd ducks. I really disliked those Matadors when I was young, so clunky looking - but now I don't think they are bad, and the wagons are fairly decent looking. The coupes are still bizarre though.
    I can't say their Matador was a bad car, but at the time I remember thinking that vent windows in the front doors were so passe, and that coffin-nose jutting out in the front was bizarre to me. The color combo made it look richer than most similar Matadors I think.
    It gets better than that. In '63 the 427 ci engines were called 'Thunderbird High-Performance V-8'. They weren't available in the Thunderbird.
    I think the '68-70 Mopar intermediates in general were near-perfection, although I didn't really care for that double-loop bumper on the '70 Coronet.
    I always thought it must have been hard to sell a Fairlane/Torino, or Comet/Montego in that era, because they just seemed kind of generic and wallflower-ish, and even a bit petite, compared to the stylish, muscular Mopar and GM intermediates.
    The Fords did bulk up a bit for '70-71 though, and I thought they looked pretty good, considering they weren't an all-new design.
    And, I agree...I think a '65 Impala is just about perfect from any angle. Even the 4-doors looked good.
    Well years of recording oral histories for my local historical society taught me that anecdotal evidence, while immensely entertaining, is incredibly error-prone.
    Never let the facts get in the way of a good story.
    edited March 2013
    One thing that I remember seeing, that struck me as very odd, was a Malibu that had the more formal 1981-83 roofline, but a 1980 grille/headlights. It was 1988 when I saw it. I can't remember what the taillights looked like, whether they were the '80 or '81 though. I'm thinking they were 1980, but that was 25 years ago. I do remember the car was black, and looked like it was in good shape.
    I actually saw it during freshman orientation at the University of MD. I was with a group of students, out in front of one of the buildings, when it drove by. I got the guy who was orient-ing us a bit miffed when it caught my attention and I spoke up about how odd it was to see an '81 roofline with an '80 grille. Apparently, he didn't think it was quite as newsworthy as I did. :P
    edited March 2013
    I liked the 71/72 Satellite Sebring coupe, but I don't think it was as popular. What I never understood was the popularity of the squarish 73/74 models. I think they used that chassis to put out the nice looking, downsized 75/76 Fury when the full sized one went over to Grand Fury.
    I think the 65 Impala was one of the better looking ones in all of its forms. The only ding I'd give it is the station wagon. Don't get me wrong, it was a decent looker too, just I think the Ford and Plymouth wagons looked better that year. A school buddy of mine unfortunately wrapped a white 65 Impala around a pole. Neither he, nor the car fared too well from that event, but he did live to talk about it later! To this day I bet he still misses that coupe, even if he still has an occasional sore rib.
    Well, here's the rundown for the Plymouth's intermediate coupes in the 70's:
    1970: ~65,000 sold (Belvedere/Satellite/Sport Satellite/Roadrunner/GTX), plus 1525 convertibles.
    1971: ~80,000 sold (Satellite/Sebring/Roadrunner)
    1972: ~74,000
    1973: ~128,000
    1974: ~73,000
    1975 "Small Fury" coupe ~54,000
    1976: ~45,000 (by this time the Volare was probably stealing some sales)
    1977: ~46,000
    1978: ~26,000
    And yeah, the '71-79 intermediates are all pretty much the same platform. I think the biggest change was that for 1974 they started isolating the front sub-frame from the body with giant rubber bushings, that supposedly improved the ride, but were a real b!tch when those things would start to deteriorate. 1978 was the last year for the "New Small Fury" and the Dodge Monaco (nee Coronet), but the Cordoba and Magnum lasted through 1979. And the 1979-81 R-body New Yorker/Newport, St. Regis, and '80-81 Gran Fury were heavily modified versions of that old midsized platform, known as the B-.
    I wonder if those rather low small Fury numbers were the result of a 1-2 punch: 1) mid seventies recession and 2) I think Mopar had some issues in the mid 70's with all the environmental and fuel economy changes. They seemed to struggle with it more than GM and Ford for some reason which I think affected the consumer quality perception. Part of it may have been a learning curve with their new electronics.
    I wonder if part of it was just marketing? Plymouth's Satellite/Sebring seemed to go for the more sporty crowd, while Ford, with its Torino, and Chevy with the Chevelle/Malibu/Monte Carlo, were going for more of an upscale, personal luxury type clientele?
    By the time Mopar started going for that more upscale style, I think it was too late. The Cordoba was actually pretty successful for a few years, though. However, the Coronet/Monaco and "New, Small Fury" were popular (and pretty good) as police cars and taxis. But unfortunately, the coupes bore a strong resemblance to the sedans, and perhaps those plebian police/taxi duties took their toll on the civilian market?
    Looking at those cars though modern eyes, I guess they can all look pretty tacky. But, trying to put myself in a 70's mindset, I can totally see someone picking a '75-76 Malibu or Torino over a Fury (or Monaco). They just had a more upscale, more with-it look about them. Not that the Torino itself was a popularity champ by then.
    Oddly, when looking back through modern eyes, I can appreciate the style of the '75-78 Fury/Coronet/Monaco coupes. They have a clean, uncluttered look about them. But, back in those days, ostentation is what sold.
    Oh yeah - crushed velour interiors, an assortment of vinyl roof alternatives and fake wire wheel covers! To me, the mid 70's Ford's had nice looking seats, but all the rest of it looked kind of cheap. The Cordoba was a nice looking car with a great ad campaign. The GM intermediates were very nice looking to me and the 350 was a smooth drive train. The materiel quality seemed a step up too from the competition.
    One thing I remember reading about the '73-77 GM intermediates, was that the chassis was fairly sophisticated for such mainstream cars...handling, steering, ride, etc. I remember CR testing a plain-jane '74 Malibu and saying "The Chevelle inspires driver confidence".
    One tiny 'quality perception' thing I always liked about GM's was that starting with the '65 big Chevys and '66 Chevelles, the "PRNDL" indicator was down in the instrument panel instead of being tacked onto the column. Ford and Chrysler took a long time to do that. I also liked how the vent windows on full-size GM's in the sixties were operated by crank. A small quality touch IMHO.
    Oldsmobile was still doing that in 1979. My 1979 Oldsmobile Ninety-Eight Regency had the "S" on the shift quadrant for Second.
    It wasn't just an American thing. A guy I knew bought a VW Scirocco and the taillights were mismatched: one taillight was for the base model and the other for the performance model.
    Ugh! I just can't stand the "Jimmy Durante" snout they put on those Matadors from 1974-78. The 1971-73 model was fairly attractive in a conservative way. I remember them best from later episodes of Adam-12.
    Cadillacs had power vent windows. It's pretty wild seeing six power window buttons on the driver's door versus the usual four. I'm thinkink the six-window sedans may even had eight if you include the rear vent windows!
    They did. Back in college, I test drove a '66 (I think) Sixty Special (or was it just "Fleetwood" by then?) that was for sale at, of all places, a used car lot that specialized in imports! They only wanted $2500 for it, and it was really nice. It was really, wild, seeing the power window setup with EIGHT switches! Another thing I thought was cool was how they had these little tray tables built into the back of the seat that would fold out of the way.
    A Fleetwood Sixty Special would've had a plain steel roof whereas a Fleetwood Brougham would've had a vinyl top.
    Both the '66 Sixty Special and Brougham were magnificent IMO. They still had the dash with a lot of decorative metal on it (in those last pre-crashworthy days!) and the seat trim and tray tables and door panels were awesome.
