I have a 2006 with 87K on it. I've done nothing but routine maintenance on it. It still performs as it did when it was new. So, there is my anecdotal evidence.
If anyone wants the preponderance of the evidence, check Consumer Reports. They show it as being very reliable.
Odie
We're looking at changing boats and getting a 21' boat; total empty boat/trailer weight is 4,200 # and fully loaded/gassed up it will be about 4,400 #. I know we'll be close to the max towing capacity. My questions:
1) IF we stayed local, would you install the trans/PS coolers?
2) If we DO haul it up north three hours away in addition to the local towing, would you install the trans/PS coolers? (We're in MN...not too hilly around here relative to most hilly/mountainous areas of the country)
3) Any recommendations as to where I can purchase reliable parts? Prices seem to range from $150 to $400.
If not I think the plastic inserts in the cowl are just held in by clips and that's it.
Has anyone tried any other ideas to improve mileage? Ours is not great. About 16 MPG combined city/hwy. Would be interested in any comments.
Iukie
http://www.hondalac.com/service/Bulletins/x03-048e%20revised.pdf
My husband owns all Chevy trucks, parks them in the hay barn, and never has a mice problem in his cabin!
Any ideas on how to stop this problem?
Seriously, the mice like to nest in tight areas. Perhaps your husband's truck isn't conducive to nesting.
Just learned the other day that some newer cars are using wiring made with soy based insulation, and the critters like to chew on this stuff.
My sister had rodent problems on her Subaru a year or so ago, and the repair bill was a couple of thousand dollars. Fortunately her insurance company covered it.
Short of tarping it, I don't know what works, but keep researching. Big pain having them in there. I think some people leave the hood open at night, but that's a hassle.
Any ideas?
It looks pretty straight forward - 2 bolts but wanted to see if there was something special that had to be done to get shock on? (part #3) Thanks in advance.
link title
I recommend that you use synthetic oil and tranny fluid and change both regularly. Of course, you can get that done at either the dealer or at a Jiffy Lube or other mechanic's shop. (Some of the dealers are actually cheaper on the oil change than Jiffy Lube is if you get synthetic oils, ironically.) A lot of owners forget to change the fluid on the tranny, which should be done every 50-60K miles. The minimal cost of this service really pays for itself.
As for the life of the vehicle, you have done well to get to 250K. It says a lot for your care of the vehicle and the quality of the year model, too. My 2011 Pilot has had a lot of issues already, and I don't see that the quality is the same anymore. Bottom line: you can keep this car going as long as you want to keep paying to fix it and the body isn't falling apart and the safety systems still work. At some point, you will reach the point where you need to junk it, and just like putting down the family dog when it gets too sick to go on, you'll know when it's time.
If it does, you're ahead of the game.
As you know honda manual recommmends major service every 30 k miles, I have always had that in the past. I just wanted to see if someone had any experiences with that in a pilot with this many miles. I think I would like to keep this car for a few more years, so I am gonna end up getting the service done, even though it is expensive.
Another question btw, how often should the brake fluid be changed in the honda pilot.
>when it comes to keys, the Honda Pilot doesn't impress me....
poodog13
>What did this story have to do with the "impressions" of the key itself? Better >question: who would expect to be impressed by a key?
Yo poodog, sddeb is dead on, the Pilot ignition/keys/door locks suck! Same exact thing is happening to me right now... they don't make 'em like they used to doggy
Can someone help me with the steps involved to replace this?
Thanks very much
Steven
My fear is what could happen if this comes off after 36,000 miles and no warranty. Anyone have this separate? I believe this shouldn't separate, but when the new ones have the same symptom, it is tough to convince the dealer this is a problem. Thanks.
For sure, I will be contacting my dealer to see what can be done about this DEFECT. Personally, this just adds to a LONG list of idefects and quality issues I have uncovered with this vehicle. Quality on this model is poor overall in my opinion, and I can say that with impunity, as my front axles were already replaced at 11K miles, due to a thunking noise/vibration issue. The OEM tires suck and cause the vehicle to pull... I could not be MORE unhappy!
You expect sh@tty quality from GM or Dodge, not Honda - not when you pay $33k for a new vehicle.
THANKS for the heads up. I took a snapshot of the hatch hinge and will try to get that posted later. Meanwhile, everyone SHOULD CHECK their hatch hinge and go to the dealer to complain en masse.
I checked all the fuses and they seem fine. I had a local audio shop do a diagnostic and they said the speakers are good. Could it be a fuse in the sub woofer? I think it's a simple solution I'm just overlooking. Please help! I need some sound!
1. bad FOB battery
2. defective FOB
3. incorrect security/door lock PCU programming
4. defective door lock PCU
Definitely a dealer problem... just like the one about the trim on the rear hatch door hinges lifting up prematurely.
IMHO, new Pilots have about the same quality as a Dodge.
The fix really isn't that much better, though. Not sure what kind of double-sided tape they are using but it is not strong enough. I recommended that they use Eternabond double-sided tape, which is used on RVs all the time and has a really strong adhesive strength to overcome the spring tension that caused this lift-up problem, but they used whatever they had, as they had not heard of Eternabond.
Both issues underscore some of the many quality issues with my 2011 Honda Pilot. While I like a lot of its features, I am very disappointed in the OVERALL LACK OF QUALITY IN THE 2011 HONDA PILOT. That's my two cents.
