Visitor Agreement.
If I have to wait that long, I'm going to wait for the 2000 year models with 4 doors!!
Also, what are the advantages/disadvantages of the 3.73 vs. 4.10 rear axle ratio? I plan on eventually pulling a mid-size trailer with this truck but that's not my primary concern. What kind of fuel mileage hit would a 4.10 cause?
The dealership has gotten and still is slowly getting 3/4 ton trucks in. Do not know of any delays although they may be true???????
I've a Sierra LT Xcab 2wd with a GU6 rear axle, 3.42 ratio and the Z82 trailering package on order with a build date of Jan 11.
Although as of right now I don't intend to tow, it seem a vehicle like this ought to be able to do so in the future.
Now I'm having some doubts about not having ordered the G80 lock. axle, which was restricted at the time of the order: Under what circumstances do you think I'll wish I had ordered the locking axle?
(I wonder if I can even change the order this late in the game without causing additional delays!)
I guess Chevy has started building Sportsides as mine is and is on the way!
Chevy said my truck was built 12/17
given to transport on 12/18.
Still no truck.
1) Why does the 3/4-ton 2500 weigh approx. 1250 pounds more than the 1/2-ton 1500? Is it because of the 'beefier' suspension?
2) Are the new aluminum head V8 engines as reliable as the old castiron head 5.7 liter (350 ci) V8 currently produced? Everyone whom I know as reliable (mechanics, mechanical engineers, etc.) recommend to stay away from aluminum head engines because of aluminum warped heads.
3) Suspensions: Is it possible to get the Z71 46mm shocks on a 2WD truck or must I settle for the 36mm shocks? Why doesn't GM offer the Bilstein shocks for pickup trucks as they do for the big SUV's?
I have never owned a GM product before but I am seriously considering a new truck. My brother has worked for GM for 35 years so I can get his Option 1 discount. Don't ask me why I've have never used his discount before. I went with Toyotas that were commonly reliable with 300,000 miles on each one I had (I keep vehicles for a long time). I hope that I can get similar reliability from a truck like this. Thanks.
i am in no way an expert on this but the 3/4 tons have a different front suspention set up than the 1500's different steering too .. the 1500's have rack and pinion the 2500's have the recirculating ball type for more durability And the vortec 6.0 engine DOES have iron heads on it for more durability.. these differences between the 2 are my guess where a lot of the weight comes from..In the tests i have read from various sources-- mags ect.. this makes less than a half second time difference in the quarter mile times... i have ordered a 2500 excab long bed can't wait...
Started to order but heard a rumor about Chevy
having problems with the new frame. Is it true??
should I delay my effort to order?
I ordered the 4.8.....
Jim
Gregg
The 3/4 ton trucks are heavier than the half tons mainly because the frame, axles, springs, and other suspension components are beefier.
Also, in the case of the 6.0 liter, it has iron heads, which add to the weight over the aluminum heads of the other engine choices.
I imagine the new aluminum heads on the 4.8 and 5.3 engines would be reliable enough as long as you never let the engine overheat. That's when alumninum heads warp.
I don't have an answer for your shock question.
FETZ
An afterthought on the shock question:
I suppose you could always buy the stiffer shocks as an aftermarket item and install them yourself. It would not affect your truck's warranty.
http://www.4are.com/project.htm
you find aluminum heads in almost everything now,even toyota's(which we own a few). they do not take well to being overheated. But GM has a new emergency cooling system if you run the coolant dry. Read the edmund's test drive report they talk about it. Aluminum is good.
K25753 Ext Cab SWB 4WD LT
E63 Fleetside
Z85 Firm Ride
C6P 8600 GVWR
LQ4 6.0L
MT1 HD auto w/ Aux Trans cooler
G80 Locking Diff
GT5 4.10 axle
1SC Prefered Equip
QIZ LT245 All-Season SBR BSW
A95 High Back Bucket seats w/heater
ZY1 Solid paint
NZZ Skid Plate package
Z82 HD trailering Package
UY2 Camper and 5th wheel wiring
I don't drive like a mad man when on bad roads, but still there are times you got to give it a little gas. Last spring I was pulling a utility trailer and had to take a different road I hadn't been on in a while. Narrow couldn't turn around and ran into water on the road for about 80 feet. Didn't have much choice but to gun it and go. The trailer was dragging on high spots but the ol Chevy made it. But without skid plates you can never be sure in a case like this whats under the water. Especailly when the roads are only graded once a year at best. ..... Rich
I wish I had my specs for the truck in front of me, but earlier posts seem confusing. I think the 2500 has a 10" clearance vs. 8" for the 1500 (recall from the motortrend article).
The 2500 was definately more of a step up to get in and I think the height spec puts its about 2.5" taller than the 1500.
Another note on my test drive today in the 2500. I took it in a snowed covered parking lot and checked out the autotrac and anti-lock brakes. Both performed very well.
I have renewed my aching pain to get my 2500. Ordered back on Oct. 18th (was supposed to have a Dec. 21 build date) Final note for 2500 folks - the dealer I was at today (north central Wisconsin) is getting two, 2500, ext. cab, short boxes in Mid-Feb. I hope they are right and they finally start kicking these things out.
I tried in in the snowy lot in 2wd and in autotrac 4wd. Definate slip in 2wd, but not too bad due to the locking diff. In 4wd it took off with no slip unless I punched it.
4.8 v8, auto, 3.73, extended cab, ls with bucket seats,
BUT, I was wondering if anyone else had any problems besides me. When I bought mine, it had a slight thumping noise in the right front brake, that we though might just be a rust or rough spot on the rotor. (yah I know, stoopid on my part) When it didn't go away after a few weeks, I took it back in. They wound up replacing the front rotors, and a damaged lug bolt. At the same time they replaced the rear rotors due to a factory advisory. Now the brakes feel great with no problems. BUT now since its finally gotten cold down here in Tn, my auto trans has "thumped" twice now starting off, once when cold, once when a bit warmer. Almost like it slips a bit, then catches. Anyone else having xmission thumps? Is this related to the cold (20 - 30 f in the morings) or is it something to worry about.
thanks,
rm
thanks,
rm
