Chevy Silverado: Problems & Solutions
Problem very noticeable on un-even roads (where trucks are supposed to be driven!!)
Anyone else had this problem?
Good luck!
1. Routine oil change - no problems.
2. Comp fuel filter replacment from GM - old fuel filter was full of rust. Had never changed it and they suggested switching gas stations to buy our fuel.
3. Had the seatbelt recall work done - who cared to begin with?
4. All the paint was coming off the volume knob for the radio - they ordered the part (for the second time, they lost the last one).
5. Needed state inspection sticker - right fog light not burning, they fixed.
6. A/C makes a ticking noise while it's running and even after the vehicle is shut off - they could not hear anything. Started right up within a mile of leaving the dealership. Will stop back by for that one.
7. They did discover that the freon was low in the A/C and added.
8. We complained of poor fuel mileage (15 or less highway or town). They found a fuel rail pressure sensor leaking, removed, inspected, resealed.
9. Steering wheel is off center about an inch and half. They suggested an alignment.
10. Paint coming off the dash around the steering wheel. Ordered a new one.
11. We complained of the turbo making a strange noise. No codes but they found an air inlet tube missing?
12. We had an engine oil leak. Right upper valve rocker cover leaking, they resealed.
And this was just one trip, we've already had the speedometer replaced, steering fluid pump replaced, a hose on the steering system replaced, a transmitter replaced, something nearly fell out of the rear-end and they tightened it...
I was shocked to see this many "things" wrong on a $40K+ truck that has not been exposed to harsh driving environments - we don't tow, we don't off-road, we don't haul anything heavier than a lawn mower.... And, we wonder what the truck will be like with a few more miles on it and no warranty?
in drive speeds going down the highway. Had the fuel filter changed but no change or effect.
I'm puzzled as to why you bought a unit rated for more than your truck can handle?? Did the salesman tell you "it will be OK" . :confuse: You have exceeded what your truck can handle.
Ray T.
I hope that someone posts you with the fix. I am having exactly the same problem that you are with my 2001 Silverado 1500.
Triott
Timbrens
Check with your dealer!
1.seat belts 2times still bad
2. tranny 3 times and working on my 4th.
3. rear differential. 2times and still f-d up
4 ac no flow of air
5. doors falling off
6 leather seats tearing
7. tailgate fell of with replacement rear end on it backing into loading ramp it fell off and dented rear quarter panel and demolished tailgate.
8. all weather stripping on doors replaced twice and still coming loose.
9. intermittent license plate light since day one.
10. 3rd door plastic handle broken off
11 rear quarter panels cracked behind tires.
12.oh yeah transfer case replaced
13. throttle positioning sensor bad
14 oh piss on it gmc won't do a thing even though most of these problems occurred within the first 30,000 in fact the first tranny was gone at 6,000
good luck
fritter
I would further suggest that charging $2000 to fix a problem that they don't know how to fix is bordering on CRIMINAL, both from a personal safety and financial perspective. I am the original owner of this vehicle. I have had it at the GM dealer no less than five times for this fuel injection problem over the 98,000 miles that I have driven the vehicle. Also, this vehicle has never been serviced by anyone other than a certified GM dealer. Today is Sunday October 16 and I am planning to take it in again tomorrow. It almost left me, my wife, and two dogs stranded in the Lowes parking lot while on our way to our weekend retreat on the Gulf of Mexico. The vehicle cut off in the parking while at idle and re started with great difficulty. So we returned home. This telltale stall is first hint that things are not right. THIS IS NOT THE FIRST TRIP THAT THIS VEHICLE HAS HIJACKED. (more)
Of course I haven't always known the extent of this problem. Only after repeated trips to the dealership, over the years, have I come to know that they can't fix or won't fix the problem. Early on, it never crosses your mind that they can't fix the problem. But after 9 years experience, I am here to tell you, they can't. The will put a patch on the problem that gets you 10,000 to 25,000 miles down the road till the fuel injection system fails again. The most confounding thing ,however, is GM knowingly putting the driving public in danger by having a very large vehicle, usually pulling or carrying a very large load-- since it is a diesel, positioned to lose power and control at freeway speeds endangering the vehicle's occupants and surrounding drivers alike with a high speed accident because of the sudden loss of power and resulting confusion that accompanies such loss. It makes no sense, but is a fact! Do yourself a favor and find a diesel shop that may know of a work around to fix the problem because GM doesn't t have it. By the way, I am still under warranty, 9 years now, with two to go. But a warranty that patches the problem is no replacement for a permanent fix. I continue to put up with it because I am in no position to buy a new truck capable of pulling a trailer. So I just have to plan my trips very carefully and have a good towing service, and take the truck in for repair on the first hint of a problem.
In first gear there a rattle that comes from the manual transfer-case lever. Sorta sounds like an empty pop can banging around. It's not real noisy, but enough to be annoying. It only happens in 2wd mode. If I apply a little forward or backward pressure on the lever the noise stops. Switch to any 4x4 mode, noise is gone. Anyone know what might be causing this or is experiencing the same problem.
If you have a jack to raise the front end - a tape measurer and a socket wrench you can raise it yourself -
Jack up the front to take the weight off the wheels - then give each adjustment nut on the torsion bars about 5 turns - drive around the block - measure to make sure the truck is level & raised the amount you want. Adjust if needed - repete until you get it right. The number of turns to raise 2.5 inches may not be the same on each side (seems like it should be - but its not always) Also a good idea to keep track of how many turns you do to each side - so you can put it back to stock if you want.
Would then be a good idea to get a front end alinment.
BTW - if you don't know what torsion bars are - just crawl under your truck - you should see two steel pipes that go from the front end to a cross member (metal piece that goes between the frame rails - its about even with the rear door handles)
alone. Hope this helps
Thanks, Joe
Took it twice to a good transmission shop. He was able to duplicate it. Apparently the valve opening in the valve body is restricting. My "hard shifts" were 1 to 2 and 2 to 3 and less "hard shifting" when down shifting the same points. The valve was replaced with an aftermarket valve by the same guy. It might be a press-in/ press-out affair, possibly even drilling and tapping or chasing threads even, i dont know. A skilled trans specific place can do it. The valve company was called "Sonics"? Cost $60 for the valve and labor another $100 or so. Very Happy with results. I recommend that guy to a lot of people.
Has anyone else had these problems or similar problems?
I have a 2000 Silverado 4.3 litre and it quit running. I have spark and the fuel pump is running.
I need some trouble shooting advice... is this a common problem?
glassman2
I did notice that when I disconnected the battery while working on my truck, all the normal chimes returned--but only temporarily.
The manufacturer of the PAC interface says that all the chimes should work, while the stereo install guy said that the only chime this product replaces is the one I'm hearing. One of them is full of it, and I'm sure neither wants to help solve my problem. Anybody here experienced this?
I know this for a fact because I have both - 1999 Z-71 4x4 and a 2001 2WD.
The abs sensor has been replaced, but the truck still has the false abs activation. The service manager told me the issue is the "hub assembly" and it would cost just under $500 to repair. I told him to hold off and I would contact GM customer Care.
Called GM Customer Care. After having me answer about a dozen questions that they used to figure out how much money I spend on purchasing GM vehicles and where I have them serviced, they told me there was nothing GM could do for me. They told me there was no recall issued for the hub assembly.
I explained the vehicle is still safe to drive due to the outstanding ABS malfunction. I also told them that GM should have issued a recall to repair/replace the hub assembly in addition to the ABS sensor since they work hand in hand together.
I have contacted the NHTSA to file a complaint on the recall and GM avoiding to fully address the ABS issue.
My guess is GM is trying to apply the 80/20 rule. If they can fix 80% of the ABS issues with addressing the sensor only, they can avoid having to issue a recall on the hub assembly because the complaint numbers can be reduced.
What they should be doing, is fixing the hub assembly on the vehicles that require the work to be done in order to get the ABS working properly again and not have another ABS matter publicized again.
Even bigger slap in the face, when I went to pick up the truck, they wanted to charge me $40 diagnostic charge to tell me the problem still existed and it is the hub. I refused to pay the $40 and they gave me my truck. Customer satisfaction does not appear to be a GM focus.
Disappointed GM owner,
N
