I just bought an '06 Passat 2.0T. I don't know if this how the key fob suppose to work. When I press the key fob to stop the engine. If I don't pull the key out immediately, I have to push the key back to position 2 in order to pull they key fob out. The manual says I can pull the key fob out even in position 1. Is there a problem with my car? I keep reading the manual over and over and my key fob is not doing what the manual says it shoud be doing. Help!!
David
Vibration felt from the steering means your front tires are unbalanced. Vibration felt through the seat indicates that your rear tires are unbalanced.
Check that the front rotors are not warped.
Check your alignment (even if it does not pull to any side).
Have your tires roadforce balanced when hot.
Check the steering rack settings.
Check that your driveshafts are not unbalanced.
Just bought a brand new Passat 2006 a few weeks back, the car is ok and it is a really sharp car that make people turn their head everytime I drive it around.
Just got a question that I'm not sure if other 06 Passat owner experience the same thing and I will appreciate if someone can post their experience on the forum as well.
I notice that the car take extra long cracking time when I start it up in the morning or after a long period of idle. I got a feeling that i might fail to start at some point specially the winter is coming soon and the weather is getting colder..... Some people say it is due to the anti teft system that lock the engie after you shut it down for a long period of time but I didn't find it on the menu.
I just wondering if any experience the same thing or it just that I'm over caution.
Thanks :confuse:
Alex
none of them has vibrations as mine.
but the dealship is not accepting this.
When I turn on my ignition, I see no lights except for the airbag light. And obiviously the car does not start. My stereo works (even when the key is not inserted) but the Air conditioner does not turn on.
There are national holidays in this country and dealership will open in a weeks time .... any solutions .... ????
Any ideas guys ?
VW Dealership here in saudi are blood sucking animals. Recently I had to purchase the alternator for 950 USD .... I just checked the web and its around 350 USD. :mad:
I've been out of pocket for a few days. So sorry to hear you're still having all these problems with your Passat. I've been driving ours every day for the past three days and it's still doing great. The compass is still not calibrating correctly, but that's minor. I believe you may need to take your car to a dealer of the particular brand of tires you have. They may be better suited to diagnosing your vibration problem than the VW dealer is.
i might agree with the poster who said to take it to a tire shop, however, think about it... shouldn't VW dealer be responsible for it? contact BBB and i'm sure they will be more than happy to assist you. good luck.
amit
Lemon Laws, each state has its own and you can check with your state govt.
Normally I would think BBB should have been the first place to go, however, in your case, I will do both now since your dealer didn't seem to want to take care of your problem.
People pay so much for cars now a day and these dealers/manufactures are trying to get away with murders... :mad:
good luck :shades:
you save me a weekend project
I was about to complain about it to my Service Manager when I noticed the same effect on all the models (both 2.0T and VE) on the same dealer lot.
Has anyone noticed it or brought it to VWoA's attention? Am I being too critical?
My problems didn't turn out to be condensation. I eventually removed the plastic covers under the bonnet(very simple to do by removing the rubber beading) and saw that the battery was swimming in a pool of water. Due to time constraints I haven't been able to remove the battery but i suspect that there is a drain hole underneath which is blocked up by all the leaves and dirt which comes down from the window. This seems a very bad design flaw by VW as once this compartment fills up it just pours down the air-inlet directly into the passenger footwell. What compounded my problem is that our driveway is on a slight slope and we park the car nose upwards, which forces the water to run back towards the car. Once I take the battery out and have a decent look around I will reply again.
I know that a faux wood trim is available as an option # however, I note that European Highline models have a brushed aluminum finish which is far more appealing look if you have the lighter trim.
Does anyone know if there is a US supplier who sells such an item? Or can anyone suggest any other alternative. B6 Passat options are scarce right now.
Agreed that it's a poor design, further aggravated by the complete lack of mention in the owner's manual that these even exist, let alone a recommendation to clear them.
I'd jump on this pretty quickly. If the water's deep enough, it's possible for the brake systme to ingest water and could hydrolock the engine (per at least one recent commend here on Edmunds in this forum or another Passat one).
thanks in anticipation
i asked my dealer to re fix it,but they declined saying that,they all come the same,volkswagen is bad in customer service.sucks
I raised the same issue with my dealer ship.the district service manager,declined to fix,saying,those dash trims are loose or loosely pasted,for noise reduction,beats me???
what noise reduction they goona achiev.I still feel,that this years model is damn cheap,as if,they were rushing.
they it is 80% assembeled in Germany,i read on some forum,that german workers are lazier due some kind of unions?don;t know?Also,when i bought the car it had a wrong tyre on it.yeah a wrong tyre,i am going to call volkswagen soon
i never recived one
www.vw.com
can you tell me plzz
1. TSB C550503 unknown; 2. TSB C370503 - transmission fluid lines are not leaking fluid at this time; 3. The B9 update - the coolant hose retaining clip located by the electric fan was removed and re-installed after being rotated to face the opposite direction. CEL was computer fault; new sensor needed, tire installer has agreed to pay. Maybe best to have tires changed at dealership.
Make sure you save all of your oil change receipts, for as long as you own the car. Make sure they have the mileage included, and the grade of oil (that special VW diesel spec).
any one wants to contribute there expiriences on this.
no one seems to talk about this,does thise means that my car is only having vibrations.?are german cars more vibrative,or as the service manager says,german cars will give you more road feedback????Road feedback,means,unconfortable ride,is the suspesion right for this vehicle???can any one tell p[lzzz???
I just purchased a 2006 Passat 2.0T. One thing I noticed during the test drive (tested two cars) was that there is a hesitation when first pressing the accelerator. Since it happened on both cars I tested, I figured it was just a quirk w/ the Passat, but since I have not seen anyone else mention it, I'm wondering if it is a specific issue with the car I purchased.
Any thoughts?
That's my experience so far.
