Pontiac Grand Prix: Problems & Solutions
Curious though. Do you have a floor or column shift? My '98 GT floor shift has never had that problem. Or do all GTs have a floor shift?
Oh, and the car was still outside this morning....
Glad your car didn't go on a joy ride last night. See .... there are advantages to not owning a high profile ride.
Hldonprtnr@aol.com
My wife was driving our 2000 Grand Prix gtp today and it died on the highway,she pulled over and the car was dead. She was able to start the car but it would die after 5 seconds any time she tried it....anyone have any ideas on what the problem may be
--end quote--
Have them check the crankcase sensor.
Loren
That's crankshaft position sensor. Check fuel pressure.
Wade Hosic
and later that evening...... The part I am referring to above is the Electronic Park Lock and is a white plastic switch that can be reached by taking off the steering column shrouds. It has a wire into the bottom and the wire is what actuates the lock. I don't know if the wiring was bad, the switch was bad or the plunger (lock part) was damaged. I just know that it works now. Be careful, without the switch the key can be taken out of the ignition without the car being in park. Has never been a problem for us, but wanted to make you aware of it.
- Sam :sick:
Anyone know a fix?
http://www.magnusonproducts.com/reman/reman-Pontiac.htm
I also own a 99 Grand Prix. The windows are a known issue that GM/Pontiac refuse to correct or compensate for. I have replaced 8 windows on my vehicle due to faulty regulators. The break even if they are not being used and slide down in to the door. These run about $600 each. I do not believe the dealer has never heard of your problem as it is related to the same issue I described and Pontiac has been contacted by my dealer who said that Pontiac knew about it. :lemon:
http://www.epa.gov/otaq/consumer/warr95fs.txt
My son was driving my car and while driving the car started revving. He got it off the road and called home. This is what I have, You can shift into reverse and the car works , neutral and park also fine but when you put it inot drive ,second or third nothing, the car sits there and when you put on the gas it just revs. It is a 96 grand prix. Does this sound like something broke on the front rear maybe something with the front wheel drive or does anyone think it is the tranny?? I have to get it towed home in the morning but for now it is parked at a relatives house. We had to drive it in reverse to get it there and luckily it was only a few blocks.Thanks for any help anyone can be.
It uses Mobil One synthetic instead of standard gear oil. My Grand Prix now has 105,000 miles on it and runs like a bear.
Good luck
- Sam
it sounds like the engine is revving a lot higher than it shoud be but its not. The noise is scarying me but the car is running fine. If any one has any ideas I would greatly apperciate.
Tks, Grand Prix Gal in Ontario
