The dealer is looking at the seat heater turn on problems and they are looking for directions from higher up in gm.
How about the passenger side seat? would it come on by itself when temp is low?
On my car, if the heated seats are on and you turn off the engine, the seats stay on until you open the drivers door. You can confirm this by looking at the led light on the switch. The seats appear to be on the retained accessory power.
Alas, our Maxx is no longer. While, the car is still around, perhaps at a CarMax near you any day now, but we no longer own it. It was a 2004 Maxx LS 1SB. It had 29400 miles. We sold it to CarMax for $9000, which is WAY more than I thought we'd get for it--the highest dealer offer was $7500 and they said that auction numbers dipped into the 6's. Considering we only paid around $16, I'm pretty satisfied.
At first, we had a great deal of affection for our Maxx. I thought the design was great, it was extremely versatile, and to this day I have yet to see a car with better rear seat room. But almost from the onset, it was troubled. The brakes in particular were horrific, and just couldn't handle the daily grind of NoVa traffic. I'll never forget my service advisor at Mike Pallone telling me "look, these brakes weren't built for this kind of driving, you need to use them less." "Uhh...great...thanks for that."
Anyway, they were eventually resurfaced many (like, SEVEN) times, all at GM's cost, and eventually replaced completely, at mine since they were down below legal minimums. Unfortunately, that was not the only problem--various trim pieces fell off, the rear audio unit ceased working completely, the taillights for a while kept burning out because the electrical system was sending them too much juice, and finally, at around 27k, we had a new steering system put in because the old one was shot.
Our needs have changed, too...we have a baby now, and God Bless the little fella, but he sure does have a lot of stuff and take up a lot of room for a little munchkin. His strollers barely fit in the back, and if you have them back there, you can't put any luggage or much else.
So it was time to move on. And move on we did. Replacing the Maxx in our driveway is a new 2007 Honda Odyssey EX-L. We're pampered by the high quality leather, heated seats, sunroof and assorted goodies, and I got an unbelieveable deal--our van had a list price just over $32,000, and I paid $25.3 for it.
So we went from an Oldsmobile-Chevrolet family to a Toyota-Honda family. I just can't afford to mess around with GM anymore, I gave them my money and my time for too long and I wasn't rewarded. It sounds like the new Malibu is a nice car, and I hope time will prove that it is, but...I can't afford to wait around. A minivan makes sense for us now, anyway---and obviously our domestic options are limited, and I'm just not going to buy a Chrysler product right now.
Good luck to everybody and their Maxx's. But if you're at CarMax and you see ours...uhh...keep walking.
It is hard to get consistent quality on a mass produced vehicle, but I've come to believe that a vehicle is just the sum of its parts, and at least in the case of the "old" GM, those parts were just too cheap. Sure, it might hold up, but its not going to be pretty.
I'll see what kind of luck I have with my new vehicles. Since I moved way out to Loudoun, I'm driving like crazy. I bought my Camry Hybrid in June of 06 and it has over 31k now. Its had two unscheduled stops---one for a little steering vibration that I felt, and one for a foam piece on the speaker unit that had worked itself loose a little bit. The steering vibration ended up being ISS...about 6 months into the new model Camry, Toyota found a flaw in the part and redesigned it, so I got the new one and all is well. Contrast that to my Intrigue which got the same crappy ISS part over and over and over and over. (well, one more over...it had five).
I can live with that so far. I don't expect my cars to be perfect, but I do expect them to have relatively minor problems that are not reoccuring.
Anyhow, I have an '05 Maxx with 77K on it. I took it to the dealer today for an oil change and tire rotation and a new left turn signal bulb as I had double coupons. My independent shop replaced the right bulb 8 weeks ago. I thought another one burning out was just a coincidence.
I was called into the shop to inspect my headlights. Both bulbs have burned through the yellow plastic globes and there is a nickel sized hole in the top of both yellow globes. Of course, the dealer has never seen anything like it. They said that replacing the bulb is pointless as it will continue to short out.
They wanted $625 to replace both headlights as you can't just replace the globes. The headlights have always held water and fogged but I never said anything. They said that there were too many miles for GM to do anything and that my dealer extended warranty did not cover trim - which they say headlights are.
Pao and some others with high mileage: please turn on your headlights and see if you notice the same thing on the top of the yellow turn signals. I can't be the only one.
I guess I will have my independent shop look for some used headlights. Maybe I can Gorilla Glue something over top too keep the water out if I can get to the globe.
Any ideas of feedback is welcome.
Sixteen pages of rh lights (assume the same amount of lh), price as low as $75 per unit.
I havent had any fogging or water intrusion issues however.....the turn signal blub issue was first noticed early with my Maxx...and the dealership replaced the socket under warranty because it was shorting causing the bulb to burn out, havent had a problem since that..and it was over 3 years ago
Subject:Front Park/Turn Signal/DRL or Rear Stop/Turn Signal/Tail Lamp/Light Inoperative (Replace Bulb and Inspect Socket) #06-08-42-004B - (06/19/2006)
Models:2004-2006 Chevrolet Malibu, Malibu Maxx
This bulletin is being revised with updated parts information in the Correction section. Please discard Corporate Bulletin Number 06-08-42-004A (Section 08 - Body & Accessories).
Condition
Some customers may comment that the front park/turn/DRL or rear stop/turn/tail lamp is inoperative.
Correction
DO NOT REPLACE THE HEADLAMP OR TAIL LAMP ASSEMBLY.
Replace the bulb and inspect the socket. If the socket is discolored, replace the socket following the procedures below.
Front Park/Turn/DRL Lamp
Remove the lamp assembly, then remove the bulb. Refer to Headlamp Assembly or Headlamp Bulb and/or Cornering, Sidemarker, Park, Turn Signal Bulb Replacement in SI. Inspect the socket.
• If the socket is NOT discolored or damaged, replace the bulb only with Osram 3157 LCP bulb, P/N 13502322.
• If the socket is discolored at the bulb interface, replace the socket and bulb.
Important: Use only Duraseal splice sleeves (salmon, P/N 12089189). Other splice sleeves may not protect the splice from moisture or provide a good electrical connection. Refer to Splicing Copper Wire Using Splice Sleeves in SI for splicing procedures.
1. Cut the wires of the park/turn/DRL socket approximately 45 mm (1-¾ in) from the socket and splice in the replacement socket, P/N 15945363. Ensure that the splice is not above the socket when re-installing.
2. Replace the bulb with Osram 3157 LCP bulb, P/N 13502322.
Verify that the front park/turn/DRL lamp is fully functional.
Rear Stop/Turn/Tail Lamp
Remove the lamp assembly, then remove the lower bulb (stop/turn/tail). Refer to Tail Lamp Assembly and/or Backup, Sidemarker, Stop, Turn Signal Bulb Replacement in SI. Inspect the socket.
• If the socket is NOT discolored or damaged, replace the bulb only with Osram 3057 LCP bulb, P/N 15883346.
1. Cut the wires of the stop/turn/tail socket approximately 45 mm (1-¾ in) from the socket and splice in the replacement socket (P/N 15873724 for Malibu sedans or P/N 15873725 for Malibu Maxx vehicles).
2. Replace the bulb with Osram 3057 LCP bulb, P/N 15883346.
Remove the upper bulb (auxiliary tail lamp), if needed, and inspect the auxiliary tail lamp socket for discoloration. If the auxiliary tail lamp socket has discoloration, install new socket, P/N 15876348.
Verify that the rear stop/turn/tail lamp is fully functional.
Parts Information
Part Number
Description
15883346
Osram 3057 LCP Bulb
13502322
Osram 3157 LCP Bulb
15945363
Socket Asm - Front Park & T/Sig Lp
15873724
Socket Asm - Stop & T/Lp (Malibu Sedan)
15873725
Socket Asm - Stop & T/Lp (Malibu Maxx)
15876348
Socket Asm - T/Lp
Important: A full rear harness with both new sockets is available for collision repair. Refer to the Parts Catalog for new part number usage and availability.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
N0680
Bulbs, Park And Turn Signal Lamp (Right) - Replace
Use Published Labor Operation Time
N0681
Bulbs, Park And Turn Signal Lamp (Left) - Replace
N0760
Bulbs, Stop, Tail, And Turn Lamp (Right) - Replace
N0761
Bulbs, Stop, Tail, And Turn Lamp (Left) - Replace
N9537*
Socket, Lamp - Exterior (Front) - Replace
0.2 hr
Add:
To Splice Turn Signal Socket
0.1 hr
N9538*
Socket, Lamp - Exterior (Rear) - Replace
0.2 hr
Add:
To Splice Turn Signal/Stop Lamp and Auxiliary Tail Lamp
also found a pair of the assemblies for $200 shipped....here:
http://www.1aauto.com/1A/HeadLights/Chevrolet/MalibuMaxx
I'll probably do this to replace my old discolored ones....
On the TSB, any idea what the dealer will cover for free on a 2 1/2 year old Maxx with 77K?
If nothing, I may try to replace them myself. You say "plug and play" but is that a matter of a couple screws or is it more involved?
if you are replacing the entire assembly, no need to worry about the TSB as the assembly comes with the sockets and harness already....
I was blowing out the driveway this morning and my wife came over and showed me she broke the blade on the rear wiper on her car and I couldn't quickly figure out how to remove the arm. (I ended up taping a glove over the assembly so she doesn't accidentally turn it on today and gouge the glass). From a quick look it appears the whole arm needs replacement anyway. I've removed many other types over the years, but this seems a lot different.
Thanks for any pointers
What was GM thinking? Not to have a replacement blade?? Never thought that was something I had to consider when buying this car.
I just kind of played around with it by pulling it away from window and grabing the blade their is a little give way and presto at one end I was able to slide off one holder and I could then slide it off and revised the process to put it back on. I save the old blade for future replacement size comparison.
Good luck!
Single older female here, Home owner, was looking for a car that I would be able to haul things for the house if need be, with out it looking like a truck.
Also have two dogs, and the back would work great for dog crates.
Any advise would be helpful, I want to buy within the next few days.
Can't beat getting over 30mpg in summer for a 6 cyl. with all the features. No regrets on our part. An '07 is even better with the warranty.
Had steering column replaced last winter. GM will reimburse and is extending warranty. Have heard fewer problems with newer cars than with the 04-05 models on this one so maybe they've got it figured out.
Other than that I'm a happy camper. My last two other cars were an 01 Hyundai and an 07 Optima. Both ran without incident (although the Optima doesn't have many miles), but I think the Maxx is the best car I've ever had, especially considering the flexibility of the hatch. That's the reason I bought the car and I'm disappointed the new 'Bu doesn't have the Maxx--- they never knew how to market the car.
You get more negatives because the car is out of production. Fewer enthused customers waxing about their buying experiences with the car. The curve of what seems to be more negative responses is typical for a discontinued models. Fewer new buyers, more people with mechanical problem comments.
To sum up. The best car I've owned and I've owned 30+ cars.
