chevy Silverado - Continued
Huntman
The third door has been nice but trying to get my kids trained on when to close or open the door has not been fun. I can see that nice pewter paint getting messed up by 2 passengers not communicating on when to close the doors. I am always reminding new passengers to make sure the rear door is closed before closing theirs.The rubber gasket at the top of the rear door already has been damaged by a near miss.I feel like an airline steward (please my sure that all kids are in their seats with the door closed before closing yours!)
No other problems or complaints.I drive this truck from home on a 6 mile unmaintained dirt road with lots of rock and holes.Still tight and quiet.
I haven't seen much 'talk' here about trucks from the Indiana plant...anyone...?
The gear shift rendered the cup holder unusable, yet they chose to install the cup holder anyway; that would irritate me every day . Also, the window cranks practically touch the seat if the seat is positioned forward. With each rotation of the crank, my hand was squished between the seat and the crank.
These ergonomic errors in a $22,000 vehicle are a bit disturbing. Sorry, I don't want to sound like I expect perfection but these were unexpected.
Mine was built in Ind. I'm very satisfied with the quality in this truck. I waited 5 months for it!I think Ind. was one of the last plants to come on line.Most trucks I have seen built there seem to be 2500 models.Is that what you ordered? Good luck on your order.
I love this new Silverado!
No problems other than a pinion seal failure the first day.
What I would like is another set of wheels for my 1/2 ton. Prefer the steel wheels with chrome plating - anybody wanna get rid of theirs? Gonna mount a set of studded tires on the stock painted steel wheels for next winter. Really like the dark tinted sliding rear window and the seperate cargo light control. Also like the automatic headlights.
Either I am lucky with no defects, or some of ya'll are too picky! Do cupholders really matter that much, or a power seat that rattles. Seems like any competent machinist could make something up for each of your problems for almos nothing.
Mine is a 1500 LS extended cab 4wd with the 5.3L & 3.73 rear. I'm also getting the Z71 (off road) and Z82 (trailer) packages, aluminum wheels and 265 tires and deep tint on the back windows. It's black with medium gray cloth (non power) buckets.
The excitement builds.......
MikeT-Z71
Check everything!
I just sold my 99 Silverado LS EXT CAb Z71 that
was loaded for $600.00 less than what I paid for
it and drove it 6 months and 8,341 miles. Not
too bad. It will be someone else's problemS now.
Rest easy. My Oshawa built Silverado is still 100% zero defects after 4,500 miles. You're going to hear about the lemons. You seldom hear from the satisfied with no ax to grind. I'm satisfied.
Also on a 400 mile trip this weekend,my 5.3l 3.42
diff. extended cab got 17mpg average speed,75mph.
Gregg
problems very impressed with the quality of
this truck. Average 15 mpg city and 16 to 17 on
the road with the 5.3 3.71. No rattles, knocks,
etc.. would recommend to anyone. Have a very
good dealer, Huffines, in Dallas, TX who
found this truck at another dealer so did not
have to order....came in with 8 miles on it.
Gregg
Gonna buy a travel trailer this week. Probably weigh around 5,000 lbs wet. Be interesting to see how the 4.8, 5speed, 4.11 does. Going in halves with by buddy with the Ford SD V10 CC. His should pull it easy. Any guesses who will get better fuel economy loaded. I'm betting similar or I'll be a little lower.
In the brochure and commercial it shows the silver pewter color with camel tan leather....yuck.Whats the price 4 a base LT with towing package(has std. leather, etc.)!Help!thanx
After much test-driving & looking at spec-sheets, I'm going with the 1500 4x4, LS, ext.cab, sb, trailering pkg, & z85 (firm-ride suspension). I'll be using my truck for towing my horses. Anyway,I used www.carpoint.com to get a price, and got a price from a dealer pretty close by. He says he has a truck with "almost" everything I want. He says it has the trailering pkg, but not the z85??? As far as I can tell, I have to get z85 with a trailering pkg, so how did he get one? It makes me wonder if he really knows what he's talking about! What do you all think? Is this something that can get "added" on, since it's just shocks?
Also, I know this varies by person, but what kind of markup on the invoice price do you think is fair? I'm thinking 3%, but it always ends up more, because they still charge for options I don't really want, like cast aluminum wheels, and deep-tinted glass.... Is this 3% reasonable for a '99 in almost-May of '99, e.g. aren't the 2000 models coming out soon??
Kathy
Anyone know what fluid is supposed to be in the 3.72 limited slip rearend, and what level it is supposed to be at?
markbuck,
As for the lemon law, I belive GM will replace the rearend before they give in and buy it back.
Axle seals and pinion are always being replaced in our shop on the C/K's.
I find it odd that yours started to leak so soon, I wonder if they over filled the rear. Or didn't put the seal in straight.
I would not let Jiffy Lube within artillery range of my Silverado, but give them credit for asking to read your owners manual. I would rather have the dealer check the differential fluid. It ships with synthetic, so no need to change it now in any case.
kathyr,
You can also get the trailering package if you get the Z71 off-road package. I test drove both the Z85 and the Z71. Didn't find a lot of difference in the way either felt, but along with stiffer shocks on the Z71 you also get a stabilizer bar which makes it corner flatter...nice. Might also consider getting the 4.10 axle for slightly better towing capacity and feel. Sometimes hard to find though. By the way, 3% over invoice is beyond generous. Dealers around here advertise 2% over invoice, with no haggling. I think $300-600 over invoice is reasonable. Some have paid more, some less. Have fun shopping!
Pinion seal replaced again. Gonna check the breather hose for the diff and the oil level. Agree with you, 26andrew1, kinda using the lemon law as a threat. Gonna write the sales mgr and service mgr about my concerns today, how the leak has been fixed twice, and if it fails again, they better do more than just pop a new seal in. They claim the yoke has no grooves in it so could be too much play in the bearing.....
Figure put it in writing so I have more leverage.
Not pissed about this, just want it fixed for good!
will fix it one more time and for good. It kinda
bothers to have some problems on a new vehicle.
Tung
What's funny about Jiffy Lube is the tag they saw on the rear end 'probably' meant 15x45 mm level from the fill hole. (It definately had mm on the tag)
So now all thats wrong with my 1700 mile Silverado is the leaking rear window and today the compass on the mirror went to "C" meaning calibrate. Tried driving the normal 50 miles to and back from work, then tried the drive in a circle less than 5mph trick. Neither worked. (I live in AZ, and it is set for zone 5)
I've got 1750+ miles on my truck, had the oil changed (didn't want to go 3000 miles on a new engine with original oil and filter) and can't wait till tomorrow after work. I'm driving to Fontana to see both the Busch and Nascar races at California Speedway!!!! Finally my new truck will see a Freeway. Can't wait to see the mpg. Last tank I got 14.8 (having a high of 16.5), but the last tank had occasional AC turned on. (And let me say the AC is WAY BETTER than my wife's '97 Monte Carlo!)
The only freeway miles my truck has seen is a 4 mile jot a day during the work week. The rest has been city driving. (Which seems to be the best for the break-in, never traveling the same speed, keep it under 55mph etc.)
A quick stop on pavement with an unloaded pickup will also produce the same feeling in the pedal.
Faults? The design of the suicide door renders it about unusable when parked next to another vehicle. Not to pick on Chevy. I' talking about all third doors in a busy parking lot. Time you open the doors you can't access the cabin with a shopping cart to load it. Maybe sliding door on the entire passenger side, like in some vans, could be a better design to allow better access.
Comments?
Huntman
As far as opening the back door and closing the front one: You'd better backed up into the parking space or that open door will be a barricade in the way. Four doors? More of the same The club cabs are an improvement but they're even bigger...Why nor take design hint from the mini-vans and improve the utility of these awsome trucks? But I guess suicide doors are in vogue (Look at Saturn).
Looked extensively at Ford and Dodge. Didn't consider Chevrolet. Everyone I know recommended Chevrolet. Dodge mechanic recommended Chevrolet. Drove Silverado - that nailed down the decision. More power, better mileage, much better handling and ride, 4 wheel ABS standard, etc.
Ordered LS 4.8 2WD Auto 3.42 on 2/18.
Dealer said it would take 8 weeks.
Dealer called on 3/30 with 4/4 build date.
Picked up from dealer on 4/15, the 8th Thursday after the Thursday I ordered it.
This truck is absolutely the best American vehicle I have ever seen or experienced. Smooth, powerful, quiet, 19-21 MPG mostly highway driving.
Build quality (Canadian plant) is excellent, paint is beautiful.
I found a small scratch on a tail-light lens, dealer ordered a replacement without any hassle.
Dealer wanted $1300 for 100,000/60mo Major Guard but matched www.gmwarrantycentral price of 975.00
*just for me* haha.
Can you tell I'm happy with THE TRUCK? Had it two weeks and 1400 miles - extremely satisfied.
It's worth the wait...don't know why anyone would drive anything else.
Since I live in the great state of Florida, this plan is unavailable here. Thanks anyway.
