chevy Silverado - Continued
ordered a 2500 LT extended cab long bed 4X4 back in january. options were locking diff, HD trailering package, skid plates, 5th wheel wiring. everything else is part of LT package or 4 wheel package. lock diff helps immeasurably when in a fix even with 4 wheel.
well my dealer who has been nothing but super, got chevy to except the order in mid june, but for a 2000. truck has been built as a 2000 last week of june. so you can guess i am drooling awaiting to received it.
i have kept up with every notation everyone has inputed to this and do find it great. will watch out for the pitfalls to come.
dealer has raised the price about 1% from original quote due to an increase to him from chevy. no big deal.
thinking about a rhino liner or x-liner. what's the difference? will be towing a 5th wheel. leaving behind a 7200GVW 2500 l989chevy 350 TBI pickup. served well. only l04,000 miles on it.
can't wait for the new toy. any hints shoot away to me the info. thanks for all your input here.
Steve
My brother in-law painted his front fenders and inner fenders with this stuff on his Jeep and it worked great. He had previously worked on the front fenders twice w/auto paint, but due to flat design they were just rock magnets. The spray on protection looked great on the fenders, and virtually invisible in fender well.
I installed aluminum running boards, otherwise I probably would have used the liner spray. I have two tone Indigo Blue w/Pewter, so running boards actually look sharp.
Good Luck.
http://community.webtv.net/dp2000/TRUCKFORCEACTION
Later, we lost a pretty close game, about 21-16. Amy, Mike's girlfriend, and I are doing shots of Hornitos Tequila. She's being very friendly to me, but I like Mike. She stands up in the bed of Mike's '98 K1500 ext cab, then steps up on the roof of the cab! Everyone implores her not to put a dent on poor Mike's truck roof. But she hoots, and then strips naked throwing her panties on the ground. The scene wrapped-up pretty quickly after that.
When I complained my steering had a slight pull to the right several months back, the dealer performed a chassis alignment that fixed the pull, for a while. I took it to a Firestone dealer since it came with Wilderness A/T's on it. They reported the alignment was off slightly, adjusted the left camber and front toe, sent me away. It pulled to the right even worse. This perplexed us all. They said the wheel with more positive camber will have the pull in that direction. This was the right wheel before the alignment. After the adjustments were made, they were evened out, yet the pull was more pronounced. We put it up on the alignment rack for a second time after the test drive, and it still showed all four wheels to be in nearly perfect optical alignment within the specs, including thrust angle, and demonstrated the repeatability of the Hunter alignment machine.
So why did it pull to the right? It was the radial tire influence. Because what they did was swap the wheels on each axle. Then the pull went to the other direction, slightly. Since this works against the influence of the road crown, I said leave it alone. It's perfect. And right now it is. Tires are imperfect. Everything about them, how the bead seats, how they cure, vulcanize, hand laid plies etc.
They told another patron if you don't feel a vibration, there is no need to balance the tires just because they are off the car. They can put a balanced wheel on the spin balancer, and it may call for up to 1 oz of weight to be put somewhere, even though it was just balanced on the same machine.
You should get some mileage out of that one in the future.
Steve
Have digital camera batteries charged for Wednesday game.
5.3 + 15 hp + 10 lbs torque
6.0 + 25 hp same torque
Also I'm debating between a 1500 and a 2500 X-cab, 4WD. Besides the bigger engine and HD transmission, what else accounts for the 800 lb weight increase and nearly double payload?
Hope so!!
325 would be [non-permissible content removed]!
Come on August!!!
It's all Beefier!
Only way to go
Tim
325 HP is on the way!
..As Homer would say...."Whooo Hooo!!"
Tim
325hp 6.0 ! GM is on the move!
Wait to you see whats coming next!
A modern Day version of the 454SS??
cdean
Are they even in Business any more?
Henry Who??
I will say that they look better than F-150's....those are a Joke!....Like something out of a Bad cartoon!...can't stand those gay [non-permissible content removed] Mirrors on SD's though.....it's like a Truck version of Alfalfa going down the road!...with big [non-permissible content removed] ears sticking out!
Ford's beefier alright...they got the Beef ...right in the palm of their hands!
Enjoy!
Tim
In reality...all The big 3 are about Equal
...With Chevy in the lead of course
hehehee
Tim
It's not a big flaw, and in fact I didn't notice it for a few days. But when the light hits just right, you can see the reflections bend due to the "ding."
The dealer said they'd try to straighten it, but didn't know if it could be done easily. Since it's the way they seem to be stamped, I'm not sure I care. I'm just wondering if anyone else has the "problem" and/or ever noticed it on other '99 Silverados.
Richard
"Service Engine Soon" - Warning light came on and stayed on. Checked the gas cap and it was tight. Dealer says it had an "EGR" error code and they fixed it.
Right speaker rattles constantly when using a lot of bass. Dealer wouldn't fix. Said that the rattle is the entire door panel and all doors will do that with a lot of bass. What a bunch of [non-permissible content removed].
Truck pulls to the right and steering wheel is cockeyed to the left. Dealer says that GM won't pay to repair alignment until after 750 miles. Says it might self-correct in the meantime. Another pile of smelly crap.
The passenger side power seat controls were so loose that they would jam up inside the plastic holes. Dealer fixed this.
Passenger seat rattles constantly and can see a constant vibration of the seatback.
Some sort of mysterious thumping sound in the rear when I turn right. Doesn't do it all the time. Obviously the dealer acts stupid and won't fix.
Lots of sounds and rattles in the interior.
Very disappointed with my truck. I probably will try to sell it soon. I'm not putting up with shoddy quality.
the suspension has a chance to settle. Sounds hokey, but apparently often when the alignment is done at low mileages it needs to be
redone again. Check for tire wear; if it is showing any at all, then the dealer should do it no matter what mileage.
My LT, also built in Canada, now has 1200 miles in just under 3 weeks and is very solid.
The speaker problem is unusual. Ask the dealer to show you a model on the floor that does it. Mine does not (although I now have a
Bazooka subwoofer, so the regular speakers no longer have to do much in the way of bass). Call Chevy assistance if the dealer
refuses to budge. My guess is that the dealer didn't do the prep work that they are paid to do (i.e. washing, tightening bolts that may
have loosened during shipping, etc.) There should be no rattles (mine is almost eerie it is so quiet).
Richard
The 6.0 tows like a dream except that it will shift a lot on random hills. I only tow in OD on flat or moderate roads. Ran 4 to 6% hills at 65 and 70 mph. Gas mileage was about 8 to 9.5 towing and 12 empty.
Does anyone else like these sorry Firestone tires that Chevy puts on the 2500's? Mine have already developed indentations on the sidewalls.
Maybe you should go play elsewhere.....
I'm gonna rush right out and sell my Chevy to buy a ford..right now!!!....(Did hell freeze over already?)
Just what have you been doing with those Cows Mikee??
You enjoy that Ford!
Found
On
Road
Dead
F#@ked
Over
Rebuilt
Dodge
Tim
.....Thanks Markbuck..
I guess Fords are pretty Boring!
* Less horsepower
* Less torque
* Less room (especially in the rear)
* Bad looks
compared to the Chevy.
I guess I see Farmermike's point... What was his point again?
O bjects that resemble
R oad horse
D roppings
Love it!
H auling
E nvied
V ictors and lots of
Y ounger girls
A new vehicle won't make you smarter, richer, better looking or ........
A man has to speak for what he believes in though..
