chevy Silverado - Continued
O nly
R olling
D ownhill
their Siverado ext. cab 1500..it only does it
on occassion, feels like you've had a blow out
and can't control the steering wheel...you can
control the steering , but it goes 1-2 inches
each way while coming down the road esp. 50-70mph.
They have balanced and rotated tires, eventually
put a new set on, then they replaced the drive
shaft...they have been unable to "duplicate the
problem"...it stops when you stop and may not
do it for another mile or 200 miles..Bought the
truck on Sat and it was vibrating on Mon when I
took it in to get it cleaned up...they will not
replace my truck(under the Lemon Law)stating they
can not duplicate the problem...theywon't even
give me the District Managers name and number...
anybody else had any problems like this...this
has been going on since Jan and I am tired of it..
I watched them take a drive shaft out of another
new truck and put mine in it,,,is that legal...
that truck is now for sale on the lot?
Someone with any ideas please contact me at
sbowles@bellsouth.net,,,Thanks,,, I have already
contacted a lawyer and he's the one that got them
to put in the new drive shaft..someone said the
rack and pinion steering was under investigation..
Thanks for the help....
BTW, I drove a Toyota Tundra 4WD. I don't know if it's just me but they have a long way to go to catch up with Ford and Chevy. I am mainly referring to the interior ameneties. I drove the Toyota for one day. The ride is phenominal, best driving,riding 4WD truck I have ever driven. But I have been spoiled by the little things that are not available. Like backlit window/mirror/radio controls (well the radio did have some of the stuff lit up, and no there was not any burnt out bulbs)The interior is just not there either, at least for me. The tundra is supposed to be a full size truck. I don't think so, maybe 7/8 full size but not full size. Well enough about the Toyota. I am very pleased with the Chevy so far and look forward to reading comments on this forum.
I can even recreate the problem by driving down certain freeways at high speeds between 50 - 70. The truck begins to shake sometimes quite violently to the point I have to pull over and stop.
I took it into the shop and they told me to go replace the tires which I recently did. The tire shop balanced the tires saying they had never been balanced. Then I took it back again when the problem still occurred and they replaced them. When I replaced the tires the tire dealer told me that a service bulletin has been issued regarding this problem with some 99 Silverado pickups, something to do with the driveshaft and that a kit is coming out in late August, early September to fix the problem. I called my Dealer and they verified this.
I called the Chevrolet Customer Assistance 800 line to get information about the bulletin and spoke with a Michael. This guy was an idiot who appeared to only be able to ramble out a standard response to my complaints. All I wanted was a copy of the bulletin and he had no knowledge of it. He told me that vibration was a common feature of the truck.
I am impatiently waiting for the kit which I hope will resolve this.
Been hauling lots of gravel. Seems like the rear springs are a little low on spring rate. Rear axle ends up on the bump stop with more than 1/2 of a yard of material. Might haveta go to air bags like the quad guy.
Oil change light came on after another 3,600 miles. I think I will just follow it's schedule from now on.
http://members.aol.com/motronix/friends.html
Just bought a new Loaded LT Z71 SB. I had a 97F150
Lariat and quite honestly can't find anything bad
to say about the Ford just wanted something
different. On the Ford 3 years ago I bought a soft
tonnau cover made by Custom-Form mfd. in Elkhart,
IN. Tried to call them to get another for my Chevy
and but they are out of business. This cover had no
snaps or velcro, there is sort of a "O" ring type
piece that fits in the frame. Works great and I
would like to find something very similar. Anyone
know if another manufacturer makes a similar cover?
Anybody have comments on Zaino Brothers car wax? How about you DAVE40??? I see on your web page that you use it. Is it really that special?
Let me know!
-Fetz
www.zainobros.com
Looking to buy a Z71 ext. cab. Would like 3.73 and limited slip rear end.
Does anyone think that waiting for the 2000 model would be beneficial?
Do you think that some minor problems may have been corrected and also maybe an extra feature or two?
Local dealer has quite a few 99's.
Thanks for any advice.
http://www.75sunny.com/extang.htm
Y2K prices out on Kelly Blue Book
http://www.kbb.com/
had fords in the past but this chev is much better.
The reason I touched it in the first place, was to try and tighten up the slack in the steering, and get a crisper on-center feel. I put shims underneath the clamps holding the steering gear to the frame, to add compression to the rubber bushings, and reduce the amount of movement within the clamps. And I tightened up the preload adjuster on the rack and pinion.
I got the crisp steering I wanted, but also got a shimmy I didn't have before. So there is a balance, difficult to achieve.
But I reiterate, as you have, not to over-tighten the preload adjuster....the steering wheel should return to center freely, not bound.
county dump and they weighed my truck ('98
GMC Sierra, ext-cab, three-door, K1500, Z71, short-fleetside bed with 5.7L engine and auto trans.) with empty bed and the total was 5620 lbs with a full tank of gas (25 gal tank = ~175 lbs gas), my wife (150 lbs) and myself (270 lbs, and it's all muscle!...yeah, right!). I also added a hard tonneau cover that weighs about 30 lbs. That means my truck's weight is real close to 5000 lbs even. I'm just curious how that compares to the other trucks particularly the new
body style GM's. They probably list curb weights somewhere, but I'm not sure if that includes things like trailer hitch, big tires (265-75R16), tow hooks, Z71 suspension (all present on my truck). I'd appreciate any input. Thanks.
-Tim
P.S. I'm going to post this message on other boards as well so sorry if you're reading this many times.
E-mail---- Grizzly@jps.net
Also, there have been a few people who posted that ordered 99 trucks which never made production, so they had to reorder a '00 truck, those orders are definitely before ours. I have been pretty patient (NOT!), its been over 2 weeks since my order request and GM still hasn't picked up my order for the assembly line yet (no order number) - try and get an order # from your dealer so you could at lease check progress at the factory, check www.chevrolet.com for the customer service phone #.
I am hoping that for the most part all of the problems in the 99 new body style trucks have been ironed out by our model year. It just seems to me that as much as I wouldn't go with Dodge or Ford, they aren't having as much trouble filling orders, and they seemed to be pretty timely about it. What's Chevy's problem? They might still be catching up on the strike from last year, they also just got back from 2-week shut down this month, and well, when they are under pressure, the bowtie guys, probably are just slapping them trucks together as fast as they can.
Anyone else have info/an opinion on the delay??? All in all - I still believe that we are buying America's BEST TRUCK. Can't wait to get into my Vortec 6000!
I ordered my 99 in Dec and it showed up 14 weeks later. Some guys have gotten orders in as little as 5 weeks.
I think the factory is busy pushing out ext cab Z-71 1500's in the $27-30K range to sit on dealer lots and can't be concerned about sold orders. I don't understand why they can't turn around an order that has money down on it.
Mike
By the way, how do you enjoy your truck? Any problems? What options do you have? Color?
Thanks, Cindy
Cab 4x4 LS a couple of weeks ago, and so far the
only complaint that I have with it is the AC. The
weather here has been in the mid to upper 90's
since I received the truck, and it seems that the
truck never quite gets comfortable?
I go through the whole routine with the AC, open
the windows for the first mile or so, start out
with High/Recirculate, but if I then change to
fresh air, the truck just never seems to get cool.
If the sun is beating down on my side, it's just
plain uncomfortable. If I leave it in recirculate,
and set the fan to about 3, it seems all right, (at least I can hear myself think!), but it never
reaches the point where I can simply turn it down.
Granted, most of my trips are short, but the drive
from work/home is about 25 minutes, and this should be plenty of time for things to cool off!
Is this just the nature of the beast (the "new"
freon), or should I have the dealer check it? I
have owned two other K1500's, an '86 and a '93,
neither of which suffered this problem. Chevy also
advertises in their literature that the Silverado
has the "quickest cool down" of any half ton!
Thanks for any info.
By the way, what's up with the drive shaft! Is
this thing going to hold up?
I don't know if that was the dealer's idea or GM's but that kind of behavior is what made people buy foreign cars and trucks to begin with.
GM has a potential hot truck on their hands but the attitude still hasn't changed.
I'm sorry--I'll get of my box now.
I'm sorry--I'll get off my box now.
Don't start with the "what made people buy foreign cars" crap, though. I know too many people that own Toyota trucks that had head gasket problems (like EVERY V6 in the past few years ... there's even a topic on this board). But the Toyota owners just call it a "fluke." (nothing EVER goes wrong with a Toyota, right?) Yet there is ONE trans failure in all the time I've been reading this board and the Silverado must be junk. I don't get it.
Granted, I haven't had my Silverado more than a month yet but the 1600 miles I've already driven prove it's a great truck. One of the best. And my old '91 S-10 with 120,000 miles when sold never once let me down. If you want a Toy, buy one. If you want a truck, buy a Chevy/GMC, Ford or Dodge.
Richard
Also, there is a squeak from the steering column when the wheel is turned full left, and then turned to the right when starting forward from a start. Dealer looked at it and has an S.I.R. on order. Something to do with the airbag system, and they have seen two other Silverados with this squeak. They downloaded the latest codes for the engine, but the 4.8l still idles a bit rough. It is a rythmic vibration on a ~3 second cycle. Any other 4.8 owners with this?
To turn off the daytime running lights, just push in your parking break a little ways. The break doesn't even have to engage but the lights will go out. I do this every time I start up to avoid that headlight flash at startup. Good luck!
-Tim
I also got the Med. charcoal grey metallic, I have seen only 3 of those on the road (that color), it is an awesome looking truck in that color.
Cindy
Mine is as cool as a cucumber like quadrunner500. But I like a quick cool down also. After you have had the dealer look at it (and when you don't have passengers) you can close all the other vent with the lower roll knob and dedicate all the air to your side. I have the center storage between the front seat and can reach 3 of the 4 vents without unbuckling. There is a lot of air coming out of them that you divert. It really helps.
Jeff
I totally agree with you about the headlamps. It's not that I don't like the automatic features, but I'm irritated or worse that you can't turn the headlamps off with an override. The DRL's, on the other hand, can be disabled by pulling a fuse, but I feel safer with them on.
