Dropped the vehicle at the dealer to service squeak from rear console, broken passenger seat lever, and imperfections in windshield. Sqeak is gone, lever on order, and I have to see service mgr next week (on vacation) for windshield replacement.
My complaints were mild ones, so I waited until I ran the mileage up to find all defective issues and have them all resolved at once.
I am very happy with my Armada. The only nightmare I have is cleaning the beast!
There are obviously more first year problems with the Armada than anyone would like, but me, and a bunch of other people are happy with our trucks. I see no reason for me to think that my great running truck is junk because of the messages on this site.
ummm....no.
they are looking way ahead of them, trying to catch up to the 305 HP.
If you are experiance the same problem be sure to post a complaint on their web site.
yamamoto "Infiniti QX56" Aug 10, 2004 10:56am
The Titan/Armada Salesman's Manual states:
(page 51)
"Federal regulations now require that the right front passenger airbag be automatically suppressed when a rear-facing child safety seat is installed in the right front passenger seating position, or modified when that seating position is occupied by a child or small adult under approximately 45 kg (102 lbs.). Armada and Titan are both equipped with an Occupant Classification System (OCS) to determine the weight of the right front passenger. This system may suppress or modify passenger airbag deployment depending on seat occupancy."
As confirmed by Nissan Customer Care:
Suppression means the passenger airbag system is completely disabled,
Modified means the passenger airbag system is enabled, but will deploy with less force.
In other words under 60lbs the light is on the airbag is off, over 60lbs less than 102 light is off airbag set to modified deployment, over 102 light off and full functioning airbag.
I stated that it seemed very unlikely that a 120lb passenger could sit anywhere on the seat and not exert over 60lbs to turn off the light, unless they are clear on the edge of the seat which has never been the issue. I got the it works properly if you sit "exactly in the center of the seat" response. BS!
I'm not going to accept this response. On another issue they voided my warranty for fixing the roof resonance because "the headliner was entered without a Nissan Certified Tech present". My entering the headliner consisted of taking down the plastic overhead console and reaching into the hole behind the console, replacing a missing bolt in a support bracket (QC have anymeaning with Nissan), duct tapping the foam blocks that had fallen out (from the excessive roof vibration I'm guessing if they were even installed correctly) back in place and a piece of tape on the video wire that was threaded through.
Everything was done by reaching through the access hole and nothing pulled down. How they can even make such a statement is beyond me. I will be re stating my case and asking for written proof that my reaching into the hole would of caused the resonance and banging sound that is coming from above the rear passenger area. Also a letter stating the passenger seat is functioning as designed. I'm contemplating some other avenues if they don't step up and provide satisfactory results.
I would strongly urge you to file a complaint with the nhtsa, and contact an attorney who may take you case on contingency. I was advised not to use the Better Business Beureu (sp?) Autoline because it may hurt you if lose then you take it infront of a jury.
Best of luck, dont stop until they fix it.
I just received my Armada back from the Dealer because of a grinding noise from the front. I didn't even think it would be the brakes considering they were just replaced at 8400 miles. (I now have 12200 miles) This is now my 2nd brake job!!
When I spoke to the service manager he told me that replacing brakes on "such a large suv" within 6000 miles is normal. He said that Toyota has the same occurance on the Sequoia. I can't seem to agree with this. My previous suv and cars would last 30,000-45,000 miles on the pads.
Because of my litigation with Nissan regarding my Armada, and the fact that I was just over the 12000 mile mark, they did not charge me for the $390.00 it would cost for the front brake job. Nissan is no longer covering the cost of the brake jobs under warranty on the Armadas!! He also suspects that Nissan will be coming out with a TSB that would include bigger pads and calipers.
If his statements are true, could you imagine going to the dealer for a brake job every time you get an oil change?? I cant!!
1. Popping noise when I take off, sorta a clicking, popping, hard to describe but does it in a double or a triple click. Rear end? Front end? I can't tell but it does it every time you take off after sitting only a couple of minutes. Every time!
2. Both front seats squeak bad! When you shift your weight or go around a curve it will drive you nuts.
3. Drivers seat has problems. If you sit on the edge of the seat (not touch the controls) the seat back will close in on you. When you sometimes slide out, the seat will close in on you. When I get in the vehicle each morning, the seat back has to be lowered back. (each and every time) So it somehow moves after you get out. I think maybe a short? A friend has leather seats and his is doing the same thing so he is waiting for me to be the guinea pig.
4. TSB- Brakes- This is my second time. They refuse to replace the rotors even this time. I called the factory reps as people here said to do but they said they have to follow the bulletin and unless the rotors are out of spec, they only turn them. I argued but it was useless. I don't know what else to do but the brakes are shaking really bad. They lasted about 3,000 miles before they started to pulse from the last time. Hopefully the rotor is out of tolerance.
5. Front End - Steering wheel shakes wildly when you go over bumps, it is hard to hold it.
6. TSB- Roof Fix- Finally had all I can take of the rumbling noise. It will be fixed or they will have a problem on their hands.
7. My front overhead console has already been replaced. It is very tight. I felt of the rear one and it is loose, you can press it up and down. It should fit tight like the new front one. They can deal with this when they do the roof fix
8. TSB - Front End Alignment - My Armada has 12,500 miles on it. The tires have been rotated 3 times already. The passenger front tire is wearing badly. I expect to get about 20k miles out of it if I am lucky. The others are ok.
9. Tire Balance - Tires need balancing again. This is my 3rd time to balance them. The last time was 2,500 miles ago. This thing has so many shakes and shimmies it is hard to tell what the problems are.
NOTE: Loud Rotor Sound under hood - It mysteriously stopped. It did it for about 10,000 miles and then stopped. The dealer could not figure it out even when I posted a fix for it that someone else had done. They have never heard of a purge valve control. Anyway, it will probably come back.
Sorry for the long post. This is the most problems I have ever had with any vehicle. You name it, I have or still have it. I talked to the factory rep and they told me that there have been many complaints and to take it in and ask for everything to be completed. We will see. I am prepared to leave it as long as it takes.
this part was probably a post from a troll. these happen alot, so try not to rely on fixes posted on message boards.
let me know how everything goes.
Well, I dropped it off early this morning but didn't hear anything back. I know they have their hands full. I did request the dynamat for the roof and said I would gladly supply it and even install it, but don't have an answer to that either. I am going to give them time to do what is needed and try and be patient. If it isn't fixed, I just won't pick it up, until they confirm with either another dealership how to fix a particular problem, or get help from the factory.
As far as the purve valve, there was someone who posted quite a while back having my same problem (which is gone for now) about the rotor sound from under the hood. He said he finally took it in and it did seem to work. I posted again, and he said the name of the part was a purge control valve or something like that. I belive it was legit. They (dealership)was supposed to check into it the last time and get back to me after they looked up the part and what it does,(in April) but I never heard back. I will let that one go for now because how do you repair something that isn't there? Again, I am going to be patient and give them the chance to make good on what is wrong. No need to jump to conclusions that they won't fix the items when they just got it this morning.
I've had a lot of the issues that you all have had- brakes, resonance, squeaks, rattles, window regulators, etc. etc.
Pretty much all of the issues have been resolved by the dealer, and all of them (except maybe the resonance) have been minor. I'm pretty sure with the new round of fixes in Canton the 05's will be great.
The engine and tranny in this vehicle are excellent. Actually, they're outstanding in my opinion. I know reading different forums that the newer Titans and Armadas are already improved.
If you're shopping for an Armada, check out other forums (titantalk.com is great) and do your research. This site is full of negative air- way more than most other forums I've visited. That's not a judgement against anyone, by the way, as I've vented my share of frustration in the past here.
After getting these 1st year issues fixed, I am really pleased with my Armada. Unlike my Tahoe (which left me stranded at 20k miles on the side of the road) this SUV has really turned out to be a joy to drive and I'm confident will be good for the long haul.
Has the dealer not fixed your issue? I have the occasional problem with my driver's side window not wanting to roll up, but if I wait a few seconds and try again it will. It's going into service today for that and a wheel alignment.
You can view all of the TSB's for the Armada at
http://www.nissan-techinfo.com
The only thing I've seen on windows is the regulators. If you are experiencing your window problem even after taking it to a dealer for repair I'd look around for another dealer. I have only seen a few posts like yours around the internet, and all of those folks got the issue resolved. The ones that had the most trouble were dealing with crappy service departments.
1. Squeaky drivers and passenger seats. (pivot bolts or something like that will have to be greased over time)
Thats it!
They say I have no popping when I take off that they can find. ( It does it every time, loud!) The tech who drove it the last time when I took him for a ride heard it and said, man that is loud, I didnt' hear it before. That is when I was picking up my vehicle so couldn't leave it any longer. Well, he is no longer there.
They say I have no resonance and they can't hear any roof noise over a bumpy road. I have one of the first builds and it isn't all the time as you all know. But when it is doing it over the bumpy roads, it is quite annoying. Even with high winds it is bad.
The seat moving when you sit on the edge, (keep in mind I am not touching the controls) they said it doesn't do that and they have tried. I can go and make it do it right now.
Front end is badly out of alignment. Yes it is out pretty bad but sorry, you missed the warranty (even though there is a TSB out on it) by 450 miles so you have to pay 79.95 for the alignment. The worn out front tire is my problem. (been rotated 3 times but they only show 2 times) They said I must have ran into a big pot hole and knocked it out of alignment.
Steering wheel shaking bad when you go over bumps. They said they can't make it do it but I must be driving very fast as the way it is, is normal. I told them to keep driving as it is not normal for the steering wheel to shake on a bumpy road.
Brake TSB- Yep there is a problem but a new brake TSB just came out because the old one must have not been working. They said now, I have to have some sort of shims but they don't know what it is. They don't have them so have to order them. They will not replace my rotors so this is my 2nd turning.
Tire balance. Yeah, you had them done 2,500 miles ago and they need it again, and you pay!
I refuse to pick my vehicle unless these items are fixed. I am tired of fooling with them. I have a call into Nissan consumer affairs to see what can be done. I do need my vehicle to drive but I will not pick it up until these items (which are not my imagination) are repaired. The front end alignment really makes me mad. Why did they put out a TSB if there wasn't a problem?? So now I will soon have to buy a new tire because that one is cupped pretty bad and the tread is really low compared to the other tires. The service rep is very nice and I feel she is trying, but that isn't good enough. I need to get this thing fixed. I have no complaints about her customer service, just the dealer for not figuring this out.
I just left 2 messages with 2 consumer affair reps. I don't know what to do. I am so aggravated. I expect that in order to address these things, I am looking at another week of being without my vehicle. I don't think it is right to not provide a vehicle when one has so many problems that aren't my fault but simply factory defects.
The dealer still insists I am the only one who has complained about the Armada. Everyone else is happy. Funny thing is, when the mechanic rode with me the last time to hear the popping, I did ask him if he heard of any problems and he said 6 or 7 people have complained about the roof noise but we didn't know what to do since at that time there was not a bulletin out on it. Strange that no one else heard about it. Doesn't a vehicle have to go through other parties before it gets to the mechanic?? Of course it does. Thats all for now.
I don't understand...there's a TSB out for the roof (had mine done in May) and it's no big deal. Why don't they just do the steps in the TSB for your resonance? Same with the brakes.
Seems like the dealer is screwing you around.
We've had the resonance problem - had it fixed and now have the extra work to do to repair the damage to the interior that the dealer caused - sunvisor falling off - rattles, dirt. The brakes are beginning to show some shudder - no worse than our Jeep.
Some of the interior is not as well thought out as it should be - lack of split fold seat, not the nicest quality of controls.
But here's the thing - every time my wife or I get in and turn the key we enjoy driving it. It is a big SUV, but there is little compromise in terms of performance, or comfort. We've shipped our 3 kids under 5 and family visitors around in comfort, safe in the knowledge that the safety equipment surrounding us is some of the best in the class. We've moved house and used it to cart untold quantities of furniture and rubbish around.
We've cleaned disgusting substances off the seats and carpets that our kids have left there, and the interior looks great - a little battered in a family way - but still smart.
Can the Armada be improved? Certainly - there are a thousand minor irritations that show this is Nissan's first attempt in this class. And there are quality issues that are simply unnecessary.
But when I add it all up, the car is a faithful member of our family and one that we continue to enjoy despite its shortcomings.
I do agree on the TSB fixes. I think they should be done and believe me, mine will be done no matter what I have to do. The factory told me yesterday they would call me back (after I called them again with no call back) that day or if not monday. Can you believe?? They know my Armada is sitting at the dealership and I need to drive it. I use if for me work. I am in Real Estate and I can't very well show property in my Trans Am. If it isn't fixed by mid next week, I have no choice but to get it back, take it to another dealership and rent a vehicle large enough to haul people around. When I asked if they would provide me a vehicle, the answer I got was, maybe for one day but thats it. Now what good would that do me??
Oh, also I had complained about the rear console not being tight. They told me the screws were tight and it wouldn't fit as snug as the front (new one I got) one. Now why would that be? It was loose before but now the new one is very tight. I also asked about installing the Dynamat on tuesday but not only do I not have a response to the roof (other than it isn't doing anything) but that they would get back to me on whether they would install the Dynamat for me. Sorry to vent!
"To fix it they pulled the axle, cleaned the splines, lubed it with a silicone lubricant and retorqued an outer nut." another fixed clicking was "Axle Nuts on rear axle loosened. If this happens to you, you will get a rattle from the rear end on light acceleration and de-acceleration."
I'm not sure but I think your warranty should reimburse rental up to $35/day. I have extended warranty but they said my regular warranty covered my rental for the week it took them to say everything was "within specs". Might get out your warranty book and see if there is anything in it.
good luck.
