-mike
They replaced rotors front, pads, caliper bracket, and caliper bolts. Rear they replaced pads and resurfaced the rotors.
Hopefully it will be a permenant fix.
-mike
I have the same problem on my '04 SE bought 12/03 where the AM radio station cuts in and out. More often when going over bumps. I have had the radio replaced 3 times and some other antenna connection part replaced. Nothing has worked. I thought the same about a loose ground connection point. Dealership says that is not the cause. They still say it is the radio because they can make it happen when they beat on the unit. Dealership (Peoria Nissan, AZ) advised when I can't take it anymore to go buy an aftermarket radio. My concern is that the steering wheel controls and back seat controls won't work with an aftermarket radio. Best Buy and Circuit City could not guarantee they would work.
I am no stranger to this board, I have had my 04 Armada bought back by Nissan last year. The problems were numerous, and they could not fix most of them. I was stupid to buy another 05 Armada because I believed all the rumors that the 05 Armadas would be better. I have had my Armada since Nov 04, and have about 11500 miles. The brakes have been replaced 6 times now, twice the new "END ALL FIXES NEW KIT" The problem seems to be worse with the new kit. The pads are noisy and the rotors have had to be cut again. The Dealer says that I'm the only one that has had a problem. My question is this: How many of you have had the brake kit installed, and have you been pleased with it? I got about 1800 miles out of my new kit, with a lot of city driving. Thanks :mad:
There has been some conversations where the latest supposedly last fix (May 2005), Nissan still will not guaranty. In fact to this date Nissan has not put anything in writing to their customers who are having these problems that the brakes are finally fixed. So anything that you hear is subject to scrutiny even from your dealer. Get it in writing from Nissan.
The tires are just unacceptable. I'm already on my 3rd set. Just recently I had a flat in the freeway and I had to tow the truck out to replace the tire with a spare. Needless to say that was expensive. Tires are wearing out fast both front and rear. I can conclude that the life of these tires are about 15K. Now Michelin offers the Cross Terrains in the Armada OEM size so these are much better quality tires. These tires may be tough to find and are expensive but a excellent choice to replace those sad ContiCraps.
Chances are I will not be keeping my Mada for to long as something is happening in the horizon.
I also did some offroading, quite challenging stuff. The only issue I found was the sidesteps got a bit scraped up, take them off before offroading in the future. I also think the front bumper/skirt will cause issue for steep obstacles. I had no problem negotiating a nearly 20 mile long offroad trail. Good fun and the Armada did well.
Other than that turned 8000 miles and no other issues to report.
-mike
-mike
So Mike, how did you find the IRS off road? Better than expected? About what you expected? Worse than you expected?
Bob
Side Steps
Bumper/airdam
Wheelbase
I figure if I had a pathfinder with a slight lift and an ARB bumper in the front it would do VERY well offroad. Took a little while to get used to but otherwise did well. The V8 power was nice as well. Also the ABLS worked extremely well and I'd definitely rather have that than a traditional LSD for offroading. Not as good as a manual locker, however it did shift power to the wheel with more grip when I got 1 wheel in the air my friend following in t Tacoma said he saw the airborne wheel stop and shift the power to the wheel still in contact with the ground.
-mike
A lot of the new IFS/IRS SUVs have these "trick" 4WD systems that shift power to the wheels with traction, So, with that in mind, I think the old "lack of articulation" argument that has followed IRS-equipped SUVs, is pretty much been neutralized. The bottom line is you're likely not going to get stuck, which is all that really matters.
FWITW, I've seen pictures of stock solid-axle Wranglers with 1 wheel off the ground when 4-wheeling. I'm sure modified, purpose-built solid axle off roaders are better, but I'm not so sure that stock models have that much of an advantage; and whatever advantage they do have, the on-road ride and handling compromises, IMO, just aren't worth it.
Bob
For what you can do with a stock vehicle though on an offroad trail, the IFS/IRS would be fine. The new pathy with the IFS/IRS would do better than the Armada due to it's shorter wheelbase, although it's not as high on ground clearance.
-mike
Also, on two separate trips this summer, the Armada has been doing some strange things. Was driving down the highway and went to pass an individual and upon pressing the accelerator, received no response/ jerky response from the vehicle. It actually slowed down. Did this all afternoon long.
Then on second trip, it did the same thing except in addition to the symptoms above, the vehicle completely died and had to be jumpstarted to get going again. Pretty scary when your vehicle completely dies going down the road. Did this three times in the span of about 2 hours. Would think it is some kind of electrical issue/ fuel pump etc.
So I'm taking it in for service again. Anyone else experience any thing like this? Was running only main A/C when this was happening.
No experience on the jerk/death with Armada. However, sounds like something that happend to me on an 1992 Toyota. The problem was a loose cable on the battery (positive side). The shock/short caused the computer to shut off the engine for some reason. Tightened it down, and it never happend again. Hope yours is as simple, otherwise start wiggling relays and cables until you find the one that's loose.
Now for the other problem and you guys will love this. The mechanic knew right away as soon as I told him the symptoms I was having. It appears Titans/Armadas have a problem with their fuel pump/filter system and Nissan is NOT standing behind the product and covering it under warranty. Nissan blames the problem on BAD GAS, causes fuel pressure to drop to zero because of contaminants.
I had family following me on both trips and they filled up at the same locations, bought the same grade of fuel as I did and none of their vehicles had a bit of problem with BAD GAS.
The whole setup requires dropping the fuel tank which makes it even harder to work on. He said GM/Chevy trucks are having the same problems with the fuel pump, but they are covering the repairs under warranty.
They are supposed to contact their Nissan rep again and complain and let me know what they find out.
In the mean time, I put in some fuel system cleaner that Nissan sells and purchased a 600 amp battery charger that I can use to jump start my Armada the next time it dies in the middle of nowhere. Also, I have mechanical breakdown insurance and I'm going to check to see if it will cover this or not.
The repair is $375.
By the way, it makes no sense that a jump start/battery charge would have anything to do with the fuel pump clog. If when you turn the key and you hear starter turn, jumping does nothing. However if there is no starter turn, there may be something more going on than a fuel pump replacement. Perhaps the alternator is dying, and the battery is supplementing it's weakness until it dies too. I wonder if there's a stereo amp, TV, or more putting a hefty drain on along with the A/C. If the power consumption is more than the alternator can keep up with, eventually the car will die while driving.
I have the Gold plan also and they still wouldn't fix it. I'm going to call another Nissan service department, give them the problem, my VIN and see what they say about covering it.
If you read 8.6 of the plan it exludes coverage for any failures caused by contaminated fuels.
My point is they don't know until they drop the tank and examine it if there was any problem caused by contaminated fuels. They should say we'll drop the tank, if there's no evidence of contamination, Nissan will cover it, however if there is, it will cost you X $ to get it fixed.
Secondly, when washing the interior around the radio, the paint came off. I don't recall any discussion about that on the board. Has anyone else had the paint come off of the bezel that is around the radio?
Edtrucks
On the wierd problem I think it's electrical. This was common on some Isuzus I delt with a few years back. Similar problem where it would die and a jump would fix it. Turned out to be a bad alternator (there are some other circuits in there that regulate the power going back into the vehicle)
-mike
-mike
http://www.nissannews.com/?http://www.nissannews.com/multimedia/nissan2004/pathfinder.shtm- l
Bob
Any other major issues I should be afraid of? Has this v8 been out long?
I love my seq and have 95K miles on it with no reparis. But my trrailer weighs 6K lbs close to capacity for the seq.
The LE with everything looks good sort of boxy compaired to the curves of the seq, but its all a matter of taste. If I am going to buy now is good with rebates and end of model yesr sales plus high gas cost....
On Armada, they just started MFG them with the brake latest fix, which is not old enough to see how long it lasts. However, it does not matter if it comes from the factory, because they will replace the parts at the dealer if your shows a problem. Get a copy of that corporate letter stating 2004-2005 models have a 3 year unlimited mile warranty on the brakes for more peace of mind.
V8 is strong, and grew up from the award winning technology tested over years in their 3.5 V6. Nissan has good engines. Some people are complaining about the factory tires not lasting, but other than the brakes nothing major has been wide spread and consistent on this forum since the Armada sales began late 2003.
He said there was no "FIX" on the '05 vehicles they will only replace if there is a problem, don't know about the '06. modles
As for the upgrades in 06, not much which is nice that there are no major changes going on. The only downside to the MP3 player is that you will most likely loose the Aux-input that the 04/05 models have which would be a bummer for folks with Ipods and other input devices.
I just turned 10k miles on my truck and started using Amsoil City MPG is 13.5 consistently and highway is 19mpg.
-mike
Bob
-mike
Any help would be much appreciated!!!!!!!!
-mike
-mike
I know that some Armada's have second row coach seats that you can anchor a car seat on each side with a removable center console. With enough leg room in the back seat there should be no problem getting to the third row through the middle of the SUV.
With regards to a stroller I use a combi 10 pound stroller for everyday outings and that fits with the 3rd row up. When I take the graco coach rider the 3rd seat must be down. The liftgate is electric to open and close so there is no stress with arm strength and the height works for me with no problems.
Hope this info helps!!! By the way I love my Armada
Auto Sliding Doors on a Van wins over swing out doors, in many ways including protecting other vehicles around you from being whacked by the kids, and getting in and out if parked in a garage.
Low step in Van much easier for the little ones. Accessing the middle seat in the Armada is difficult if using a baby carrier there.
Deep well and wide opening rear much easier for any stroller in the Van. I used a double stroller there, and was able to still keep the 3rd row available, while Armada is not so giving.
Flip up seats in Armada totally easy to operate to get into 3rd row compared to most Vans. Seating issues are the same if using car seats, except you can fit 3 in the 2nd row Armada, not in a Van.
Only really big kids with long reach can make frequent use of the rear seat air and radio controls in the Armada.
Safety? You bet the Armada feels better and it is safe with all those air bags. However, vans get some good safety ratings too.
All that, I've got 3 kids from 0 - 9 years, and would not go without the Armada at this stage. The van was good for the younger years and only two kids. On my last 800 mile road trip, I was able to really load up the rear of the Armada, put all three kids in the 2nd row, and not one complaint about elbow or leg space. Also, towing is much better on the Armada, . . . practically stupid on a mini-van.
Bob
CVB
I have twins with 2 car seats and I love this vehicle. It is spacious and my kids love it and my back is thanking me for it because the height is wonderful for getting seats in and out. I keep my seats behind the driver and in the center so that I have free access to the 3rd row without having to move my seats in the event that I am carrying extra passengers. I love the Armada The 3rd row is pretty spacious as well even for adults. My friends husband rode back there and at 6'4" he said it was a comfortable ride and that he could probably do about 2 hours or so back there without being too uncomfortable. Gas prices make it bittersweet but I still wouldn't trade it because I love it so much.
-mike
MODERATOR /ADMINISTRATOR
Review your vehicle
