Right now we are at 2800 miles and will be at 5000 by the end of the week. Other than the problems the truck had initially its had no others and has been great.
I've had worse with a Ford and a Mazda, so I'm not complaining. As for brand loyalty, nope, don't have any, but I do love my Titan.
I also test drove two Chevy Silverado trucks and could not find problems like these at first glance.
"Rockford Fosgate stereo system practically inoperative - only one speaker worked."
if the fade and balance controls were adjusted, this may explain it.
"outside of tailgate peppered with nicks and dings down to the primer and bare metal, paint defect from the factory on truck's side, shallow dent in the roof"
other than the defect on the side, someone screwed this truck up at the dealer.
"jammed A/C switch (could not turn A/C off with the switch)."
if the "max a/c" button is on, you cannot turn the a/c off. you have to turn the recirculate button off.
"if I find this many problems in five minutes, how many are there that I could not see and that wil come out later?"
i would go to another dealer. its obvious that this dealer was either negligent in the PDI duties, or someone vandalized it.
also, it could have been on their showroon floor for a time. broken pieces are common on a popular vehicle when EVERYONE messes with them.
1.Inoperative stereo: both myself and the salesman tried everything possible to make it work, we tried to adjust every setting, including fade and balance controls, and nothing worked.
2. Paint damage on the tailgate, misaligned or pushed in bumper: I believe you are right about damage after manufacture - the truck was probably damaged during transit. Their inspection process should have flagged this damage.
A/C switch: I do not remember if the A/C was in the recirculation mode, but it is possible. I tried A/C switch in another truck and it operated properly.
Question: can you get a limited slip (or locking)differential on these trucks without the offroad package and/or big tow package? I wish they would offer a "regular tow package" for about $ 400 on these trucks with a frame hitch, wiring harness, and transmission oil cooler. This should be available on all TITAN trucks. Not everybody needs a $800 tow package good for 9500 lbs. I hope this will be coming for 2005.
Problems to date: Warped front brake rotors, turned against my wishes then replaced under a Nissan service advisory, along with pads, shims and caliper bolts. 4 lo light flashing, to be repaired as soon as the back ordered sensor comes in. Tailgate trim is loose, repaired once with new clips that immediately fell out. Dash squeak that has been repaired twice by the dealer.
I couldn't be more pleased with the Titan, the problems encountered have been minimal,(I was a dealer mechanic with factory training from BMW, SAAB, and Nissan). I haven't read about any rods coming out of the blocks, transmissions spewing oil, wheels falling off, heated seats burning, wipers that don't work, lights that don't turn on, doors that don't shut, doors that don't open, and the list goes on and on. I traded in my 2002 Chevy 1500 pickup with 5.3, 4x4, auto, extended cab. I had been very happy with my Chevy and GMC before that, but the Nissan performs in every way superior to any of the 1/2 ton pickups that I had before.
I can't believe the guy complaining about brake dust, brake dust has been around since disk brakes. He obviously doesn't have any BMW's.
i would have a 2WD SE KC, popular w/power buckets, and utility bed pkg.
if you have floor mats and mud guards, invoice is $23.9k, less the $1000 rebate.
this gives an OTD around $24.3k including taxes.
p100...
the "regular" tow package is available, but its a dealer-installed setup.
SE crew cab 4X4 with popular package with captains chairs with power driver's seat,floor mats, and splash guards(no other options):
MSRP: about $ 32,000, can buy for about $ 27,000 plus tax. This an extremely versatile truck priced thousands below similar Tundra or Silverado trucks.
If you add the big tow package to this, you will have one awsome truck for a great price! The crew cab is huge, for five people to travel in comfort, and the bed at 5ft 6 inches is still useable.
"I wish they would offer a "regular tow package" for about $ 400 on these trucks with a frame hitch, wiring harness, and transmission oil cooler. This should be available on all TITAN trucks."
Actually, ALL Titans do come with a transmission cooler and a wiring harness. The wiring harness for a 7 pin trailer connection is tucked into the bumper. So for $200 (less than the $400 you mentioned), you can buy an OEM factory hitch receiver, which is a bolt on job, and be good to go.
We towed a 22 ft Nash travel trailer weighing approx 6500 lbs for 1000 miles round trip through the mountains and down to the coast. The Titan didn't so much as hiccup, it acted like there was NO trailer there. No problems with sway or bumps, the Titan handled it perfectly.
My husband drives a Ram 3500 V10 and he is BLOWN AWAY by the Titan, he said its by far one of the best trucks he's ever driven or towed with. In the campground we had about 20 people come over and ask about the Titan, all were impressed with it.
After dropping the trailer in the campground, we drove down to the beach through very deep sand, no trouble there either.
We were able to pass going uphill no problem, accelerating from 50 to 70 mph with little effort. The truck averaged a consistant 10 mpg which is respectable considering the mountains and city driving involved. The Titan had no trouble accelerating from stop lights with the trailer in tow. Very impressive truck, put any worries we had about buying a travel trailer and towing with the Titan to rest, no doubt there.
We have put 4000 miles on this truck in 3 weeks and other than the little things like the 4LO light flashing and a couple other small problems, the truck has been flawless.
The Hitch is rated at 7500lb but the big tow package is rated at 9500lbs.
What your taking about is the Weight-distributing hitch ball mount that is to be use with the reciever to tow anything over 5000lbs.
Thursdays are a double header chat night now. First up from 5-6pm PT/8-9pm ET we have the brand new Saab Enthusiast Chat. Stop in to meet and greet fellow Saab enthusiasts and your fellow Town Hall denizens and take your favorite automotive topics LIVE in our chat room.
Saab Chat Room
Then immediately following...
Join the Subaru Crew every Thursday evening for a chat session from 6-7pm PT/9-10pm ET. The chat room opens about 15 minutes before the scheduled start time, so stop on in, even if it's just to say Hello! All things Subaru is the general theme, but anything automotive is fair game too. Come on in and get to know some of your fellow Town Hallies better! See you there...
Subaru Crew Chat Room
PF Flyer
There is a Carmax (Kenosha) that sells new vehicles near me and none of the dealers will match their prices on new vehicles.
I live in Southeastern Wisconsin and have successfully used the CarMax prices to get a very comparable deal (not exactly the same price) on the Nissan cars at local dealerships 3 times in the last 5 years.
If your shopping for a Titan, challenge Rosen Nissan on south 27th street in Milwaukee to match the CarMax price and I suspect you'll be pleasantly suprised.
Of course, it's always wise to "do the dance" with the sales people first and let them sell you on the vehicle. Once I'm "sold", I tell them I need to do some more research, get the sales persons schedule and business card.
I just bring in (on a second visit to the same sales person)the printout for the same vehicle from CarMax and tell them I'll buy it from them if they can match the CarMax price (including the $99 fee at CarMax).
They never match perfectly but I've never been more than $200 over carmax's price (one way airfare out to DC).
($3,200) I am very pleased with the Titan.
-David
second, blanket statements will be ignored. they are usually from kids under 15 that have too much time on their hands. settle down and tell us, exactly, what happened, and how you are handling it with nissan.
I'm at 5500 miles and the truck is great, its hauling firewood, towing travel trailers, no problems at all. Have had it a whole month.
From what I am reading, Renault and Peugeot produce a lot of French built different models that are very popular in Europe. Their lineup includes all kinds of minivans with efficient turbodiesel engines, etc. Their quality certainly must be better than that of Renaults produced in the US for a short time. None of these cars are imported into the US, however.
I own two Nissan vehicles: a 98 Nissan Maxima SE and 95 Nissan SE V6 4X4 pickup. Both have been very reliable and believe it or not, I am afraid to trade them in on new Nissans, because I have seen definite lack of quality. I walked away from a new 2003 Maxima SE because of vibration during the test drive, and two new Titan trucks because of fit and finish issues.
I hope that Nissan will realize that quality is very important to their customers. It is not enough to merely design a superb powertrain, win a few awards, and then slip the quality to save money. This attitude will eventually backfire.
In order to produce a well built reliable vehicle, a company must institute adequate quality control in all areas of production, and vehicle delivery and service: parts manufacturing, assembly of the vehicle, and predelivery inspection at dealerships. Also, dealership technicians must be more than "part changers" to be able to diagnose and repair problems within the warranty period to customer's complete satisfaction first time.
"i owned a new pinto, and it was the worst car ever. therefore, i wont buy a new f150."
i dont think renault has anything to do with quality issues. IMHO, it is mostly due to a brand new plant in an area that has never built cars before, with employees who have never built cars before (and some that probably never HAD one in the first place). not only are the plant, region, and employees new, but the 3 main vehicles built there are all-new models as well. quite frankly, im impressed with the level they have to begin with. it can only improve.
also, the maximas, most altimas, frontiers, xterras, and sentras are all built in the same place that your vehicles were...and probably by many of the same exact people.
Can anyone comment on Nissan's view on using Synthetic oil in a Titan especially based on the engine design?
Has anyone used synthetic oil in their Titan? Please give feedback on experience.
Several posting have talked to valve/engine noise so I think this is a good topic.
Please refrain from citing brand names and just refer to "synthetic oil" or "conventional oil".
Quite frankly I find the mechanics are in the dark on this, and just cite their opinion of synthetics with no real knowledge of the 5.6 liter engine in the Titan. Most don't know its an all alluminum engine nor do they know about the rings or valve seats.
I agree that a break-in with conventional makes good sense. I am monitoring my oil consumption to get an idea when the engine is truly broken in.
Thanks again
Imagine, these are the people who will be taking your engine apart if necessary, and putting it together again. Don't you feel confindent that the job will be done right?
I hope it is not quite as bad as you describe.
It is specifically designed for the utilitrac so you don't have to drill any holes in the truck box. The only issue is I can not flip over the bed extender while I have the tonneau system in place. I can however just remove the extender from the brackets and put it in the truck box so it is still usable with the tonneau.
Don
I love it, best truck I've ever had, bought it June 11, 2004 and currently have about 6000 miles on it. Its had a few things go wrong, but I'm not complaining, its fun to drive and a real nice versitle truck.
I'm averaging about 15 mpg in mixed driving with some offroad. If I'm easy on it and just drive hwy last time I checked it got 17 mpg. Better than the 04 Explorer I traded in on it.
So, what color is yours? Mine's Sedona.
0 to 60 mph: 7.3
45 to 60 mph: 4.9
Quater-mile: 16.0
All times were the fastest aginst their competitors(Tundra, F150, Silverado, Ram 1500 with Hemi)
