BMW 3-Series 2006
330i sport package you need to down size from 18 to 17 inch snows.
325i non-sport you need 16 inch snows, not 15.
325i sport package you need to down size from 17 to 16 inch snows.
Tire Rack suggests what size for your car when you enter make, year,
model and if car has sport package or not?
I just ordered a 330xi, (AWD), and it comes stock with the 17" wheels. I live in cold-weather climate and was curious to hear so many people reccomending a set of winter tires. Are the winter tires more for snow handling or to simply save the tread on the factory tires?
I just bought a 330xi. I went to tirerack.com and they have RF tires for my car...but no rims showed up as available. Would the stock tires, 225/45 R-17's, be fine in the snow? It's an AWD vehicle...so I was wondering if I'd be OK. Anyone else have an AWD with the stock tires? Any thoughts?
-Tony
Could you please tell me the additions items that i need to pay apart from car cost? what is the best discount i can get in the current market for 2006 325i
Thanks in advance.
You negotiate a price. You make it clear that price includes MACO, mats, etc. An invoice should have MACO listed. Dealers may have to pay say $300-365 extra in fees for regional advertising called MACO. That's still part of the cost you negotiate. Don't let them shake on a deal for say $1000 over invoice and then during papers they pop up and tell you they have a $365 maco fee to add. Make it clear if they have MACO fees you're negotiating it within your buy price.
discount is whatever you can negotiate. why is it everybody is so concerned with getting what other people pay? if buyers a through y got 1500 over invoice, I still want to pay $500 over invoice. i don't care what other people are normally paying. i negotiate differently that most it seems...
DL
And you know what? Ever since I bought my car (325i) I try to park as far away as possible on any parking lot. I know things like that still are unavoidable but still I am trying to do everything in my power to prevent it.
mike
mike
Winter tires will have the effect of both saving the tread on the factory tires and providing superior handling in the snow--this is true for cars equipped with summer tires or all-season tires. They are only necessary if you have summer tires and plan to drive when it's cold outside, but may be desirable if you have all-seasons.
Your new 330xi when compared to a 330i (non-SP which has the same tires) will most likely exhibit the following characteristics:
1) the xi will accelerate a little slower in dry weather (it weighs more)
2) the xi will accelerate substantially faster in snow, slush and on ice
3) the xi will exhibit very similar abilities to handle (ie. getting around a curve at any given speed), however, the attitudes of the cars will most likely be rather different
4) the xi will most likely have worse braking performance on all surfaces due to its higher weight
With all of that said, other than acceleration in the snow, the differences between the two cars should be so negligible that most drivers probably wouldn't be able to tell the difference between the two.
The real difference comes in when someone says, "Hmmm, do I spend the extra $1,200 on a 330xi SP or do I buy a similarly equipped 330i SP and then put $1,200 toward buying a nice set of winter wheels and tires." In that scenario the "xi" with its compromise all-season tires will most likely lose to the 330i (properly shod with season appropriate tires) in every performance comparison year round except for accelerating in slippery conditions (and even then it won't be too bad).
Best Regards,
Shipo
That's a little dicey. It's like saying the car will have worse braking with 4 passengers and a full tank of gas, than with the driver alone on an empty tank and that's a good reason for never having four people in your car.
If I had to do it again, it would be AWD all the way. I'll put up with less than razor sharp handling to have a more sure-footed vehicle in all types of weather conditions. AWD systems have advanced to the point where there really is no reason not to get that option should you want it.
I would suggest if you're worried about scratches, find secluded spots in the middle of nowhere. I'll park at the most remote locations to avoid any chance that other drivers can get near my car.
The one scratch from a door on my car...it happened at the dealership when they were servicing my car. 2.5 years and I got a scratch while the car was in bmw's care. Figures.
just something to think about when you doublepark...
Hmmm, I rather think of it as carrying around a 210 pound passenger out over the engine compartment full time, hence the less optimal weight distribution. If the weight difference isn't enough, the 3-Series cannot be had with a true sport suspension and AWD, and after owning one of each, there is no way I'd ever willingly go back to a non-SP car. To my warped way of thinking at least, a 330i SP plus a set of winter wheels and tires will cost virtually the same as a 330xi SP, and with the exception of acceleration in the snow, the 330i should handily out perform the 330xi in every other performance category. What's not to like? ;-)
Best Regards,
Shipo
With AWD I won't swap snow tires anymore and I'll deal with the all-seasons. To me it's a fair tradeoff.
If it's not refinish the whole bumper bad, then try this. First, use a clearcoat polishing compound. That will safely remove any surface scratches. Then use BMW touch-up paint on deep scratches that you can't compound out. They'll probably have to order the touch-up paint for you though, unless you have a color which is not new. I have Sparkling Graphite (a new color), and I'm still waiting for my touch-up paint to come in. But in the meantime, I picked up some No7 Clearcoat Polishing Compound, which worked wonders on the surface scratches on my bumper. I'm waiting for the touch-up paint to touch-up the few deep scratches.
Hmmm, if it was only "some" dry pavement handling I might be inclined to agree with your argument, however, the difference be a 330xi (SP or no) equipped with the OEM rubber and a 330i SP with its OEM rubber and its stouter suspension is substantial. In fact, it ain't even close.
I'm not sure I buy the "additional handling of xdrive" part as well. Additional handling versus a non-xi with the same all-season tires? I'm thinking it's the other way around, but as I stated before, probably not by much (regardless of which configuration turns out to be the most capable). Additional handling versus an "i" model (SP or no) with a set of winter tires? Nope, I don't buy that at all. Dedicated winter tires simply offer way too much extra traction compared to all-season tires for that to happen.
A number of years ago one of the car rags did a comparison test with four cars and three different sets of tires for each car. IIRC, the cars were an E320, E320 4Matic, Audi A6, and Audi A6 Quattro. In that test, even when all four cars were equipped with winter tires, the two non AWD cars stopped the fastest, and it is my recollection that the RWD E320 displayed the best handling of the lot. The only place where AWD showed a distinct advantage was in acceleration, an advantage that was great enough to allow the all-season shod AWD models to out accelerate even the winter tire equipped 2WD models.
In the end, my thinking is that it all boils down to one question: How much "turn" and "stop" prowess are you willing to sacrifice for "go" prowess?
Me, unless I move somewhere where I need to climb a ten percent or greater snow covered hill with any regularity, I'm willing to "go" a little slower so that I can "turn" and "stop" that much better. And if I did need to climb that steep hill? I'd probably get an Audi with a true Sports Package and STILL buy a set of winter tires.
Best Regards,
Shipo
Shipo - I cannot say for sure how much one loses, if anything. But whatever it is I'll put up with it. Obviously AWD with 4 rims and snow tires is the uber-way to go, but I'll forgo that as well.
It would seem to me if AWD has extra weight in front, I would help with braking to put more bite into the front tires.
Regards...kd
If so, what makes and models? What carrier?
-Tony
My sales guy tried to assure me that I could probably get around all right in a RWD model...with the all-season 17"'s on a 330i, but I have to drive about 60 miles every day in rural, 2-lane highway in a very cold and snowy winter climate that can, in some winters, see frequent blizzards and other inclement weather.
If you control your speed, stopping and turning is usually not a problem. Driving too fast for the conditions is one of the greatest sins that winter drivers commit...and the sin that usually does the most to cause an accident.
The less-dangerous, but equally as frustrating snowy-weather problem is traction and the ability to get the car moving when you have to stop at an intersection...or when you're trying to navigate a poorly-plowed parking lot. These are the every-day winter challenges that I would face. For this reason, I chose the AWD model. (330xi)
I've considered getting winter tires and a spare set of rims for it, but I think that it will probably get along fine on the All Season stock OEM 17" tires. If I had the SP and 18" wheels...I'd probably be buying different rubber.
I'm sure we'll see our first snowstorm by the time I get my car. It's still in the factory in Germany getting the final touches put on it. I should have it in 4 weeks. My first Bimmer!
Woo hoo!
Tony
Actually it's the other way around. Extra weight in the front prevents the rear wheels from doing as much as they otherwise would be able to do. Just as AWD cars spread the acceleration duties to all four corners in slippery conditions, cars that are better able to spread the braking duties to all four wheels will as a rule stop faster. The fact that the better balanced RWD E320 won the braking test in the comparo that I cited just underscores this point.
Best Regards,
Shipo
I heartily concur with this. This is my fearful/frustrating winter issue as well. Getting stuck. And for that reason I believe AWD gives you a better chance of NOT getting stuck even with stock OEM tires. Oh and by the way congratulations.
shipo - I understand where you are coming from. But as far as stopping distances go, the driver has to manage the car appropriately. It is not my real-world experience that snow tires = 4 wheels being powered. Not to say they won't navigate just fine or just as well as AWD in some conditions. But if you exchange not getting stuck for longer stopping distances, I think it comes out even.
I had performance tires on a FWD Nissan Maxima GLE. Not only were these tires horrible at making the car GO in the snow, they made it almost impossible to TURN either direction in the snow. So, all around...performance tires STINK in the snow.
I've also driven RWD vehicles with good snow tires that go VERY well in the snow..but whether you're driving FWD, RWD or AWD...you are in control of vehicle speed...and speed is the major determinig factor in most snow-related crashes.
Just watch the local news after the winter's first storm...you'll always see pictures of SUV's spinning in circles down a street and smacking into parked cars, power poles, etc.
Shipo is right. AWD helps you go...Summer performance tires are horrible in the snow...All-seasons are fine with AWD....Snow tires are a better bet if you have RWD.
No, and as far as I can see, don't need it.
Three sets? Did they include summer tires? (Would have been funny if they did...)
Best Regards,
Shipo
I know Verizon does many funky things with bluetooth phones to disable many features. Was wondering if anyone has had luck with non-motorola bluetooth phones from verizon??
But I digress.
My friend has an 2006 A4 and for some reason they gave him the North American DVD. We were hoping to swap DVDs and save a little, but I think there is probably a software difference. Both discs are offered by NAVTEQ; I've queried their website but haven't gotten a response yet. Anyone know anything?
I'm just speaking from E46 experience, but my dealer does this activation as pretty much a standard thing since almost everyone wants it. Not only does the clown nose blink, but your parking lights flash when locking or unlocking the car, which is a nice indicator for you.
Who has 2006 325/330 WITHOUT alarm installed AND was able to get clownnose flashing by requesting software update from the dealer? And what date was it done?
