BMW 3-Series 2006
I thought that was the yellow ones. ;-)
Dealer wanted $300+. I found an independent for $180 who I will use in the future for all my cars.
Check your phonebook. Many independents do the work for the dealer and charge you less if you use them directly. Sometimes if you call the dealer they will tell you who they use or would recommend.
(Whoops! Original post corrected)
macdad
That said, OZ rims are calling to me. When my RF tires are bald I think I'll store those ugly sport package rims and get some super light OZ rims and normal tires.
I posted the following report on my experience with the TL vs my 330xi in the RFT forum. I made the trip to Pittsburgh last week and made the right car choice for that 8 hour drive.
"I have a 2006 330xi with 4K miles on it. The tires are Bridgestone 225/45 R17 91H Turanza EL42 run flats. The car has tremendous potential but as others have described, the potential is just that...potential. The car magnifies every seam and bump in the road with an uncomfortable jolt. It exhibits excessive road noise at 60MPH and above. The ride is so rough that after driving from Chicago to Davenport and back in a single day (330) miles my back ached and my neck was stiff. I have to drive from Chicago to Pittsburgh and back in the near future and I will not take the BMW.
I will drive my wife's 2005 Accura TL. Interesting to note that it sports Bridgestone 235/45 R17 93W Turanza EL42 non run flat tires. The tires are very similar to the ones on the BMW but have a higher speed rating and slightly different sidewall width. The car rides as smooth as silk, handles nicely and is whisper quiet on the highway.
As Clint Eastwood would say, "I know what your thinking..." They are two different cars with distinct design features but I submit they are similar enough to compare the tires and, in fact I have!!
Love the forum and I appreciate all the input from the experts."
Not sure what people are looking for in their rides, but obviously you guys would have hated the e46 ZHP. You could feel every pebble in the road through the steering wheel...ah it was glorious.
That said, I don't think I'd want the ride in my 325i ZSP to be firmer, unless I lived and travelled frequently in a state that kept its roads in good condition.
http://blogs.edmunds.com/roadtests/.ee92424
Here's another entry:
http://blogs.edmunds.com/roadtests/139
And finally:
http://blogs.edmunds.com/roadtests/.ee922b9
MrShiftright
1. How many miles do the RFT last? They're saying 12k? That's not cool for me...So bascially every year you have to change your tires?
2. There is NO comparment in the trunk for a spare tire?? If I wanted a spare tire, it would sit on top in the trunk of my car??
3. Can I get a replacement RFT at a place other than BMW? What if I'm 200 miles away from the dealership and the tire goes out? Am I screwed? Have to call a tow truck?
If you have a 2006 3 series - please tell me if you had any issues with this? I'm really leary of the car now after reading all this....
Thanks for your thoughts!
2. There is a small storage compartment in the trunk where the spare tire would normally go. Not enough room for a spare.
3. Edmunds had no problem finding a replacement RFT in California. In less populated areas, you may have more difficulty finding a replacement tire. Ideally, you can find someone locally who is willing and able to repair a small puncture in the tread. I carry a can of Fix-a-Flat to prepare for this possibility--I hope, should I get a flat tire, I have a decent chance of keeping air in it long enough to get me to a tire repair shop.
No issues with the tires so far, knock on wood!
IIRC, BMW engineers used to brag that they designed the steering so that you could detect driving over a stack of four quarters. A Road & Track article once commented that the steering on the Club Sport was so communicative that it felt like you were holding a tie rod in each hand. I guess those days are gone forever...
macdad
The BMWs keep becoming more luxury catrs than sports cars with every iteration. The best we can hope for is some 1 series or 2 series cars. I'll take mine with the turbocharged engine, 6-speed stick, & M Sport Suspension.
Well. I jave just under 15000 mi, on my non-sport car and the tires are not even close to being worn.
"1. How many miles do the RFT last? They're saying 12k? That's not cool for me...So bascially every year you have to change your tires?"
I figure that my all-seasons have about 10,000 miles on them. Showing very little wear. I expect to get some multiple of 12,000 miles out of these tires.
"2. There is NO comparment in the trunk for a spare tire?? If I wanted a spare tire, it would sit on top in the trunk of my car?? "
Yup, that's right. The thinking is that with RFTs there is no need for a spare tire. If you would feel more comfortable with a spare tire, you would have to put in the trunk and it would take up much of your storage capacity.
"3. Can I get a replacement RFT at a place other than BMW? What if I'm 200 miles away from the dealership and the tire goes out? Am I screwed? Have to call a tow truck?"
You can get it replaced anywhere, but I have heard that there is an issue of immediate availability regardless of whether you go to a BMW dealer or some tire shop.
Thanks...
I recently vacationed in Spain (or should I say Catalonia, given last weekend's referendum result?) and France -- a Renault Clio diesel courtesy of Hertz, no BMW, 45 mpg at 130-140 kph...the hell with hybrids! The drive up from Barcelona on the AP-7 and then across to the Var on the A9/A54/A7/A8 vividly pointed out the real issue with the low profile tire handling set up in the U.S. -- the atrocious maintenance standards of initially excellent but now frost buckled and decrepit interstates.
Some of you young guys take the corners to fast that is hard on the tires.You can get RFT at Dunn tires.
If they have them in stock, I don't know ?
That's the point of a bmw
Gee, thanks! I guess 49 isn't old afterall. :shades:
Best Regards,
Shipo
You're joking, right?
The tire shop I wen to when I discovered in horror that the ire had 0 pressure fixed it. They also got a new tire but it took 3 days and ruined the rim because they did not have the proper machine in their shop.
Anyway,I do not mind the ride at the advantage of the safety factor afforded by the RFT technology. Car naldes real good and gas mileage is 22.5 mpg at the pump.
The tires have 6500 miles and look new. I will definately change at 30K since all tires are garbage by then, although these tires are built extremely stron on the side wall!
By the way, the tire still looks new!
Yes there is: BMW Jack Set
Not on the BMWUS site yet.
Guess the ole e90 is gonna see a price bump too. Hopefully not 3k like the darned coupes.
If the twin turbo I-6 does indeed weigh 150 lbs less than the 4.0 V-8, I think the 335i may be more desireable than the upcoming M3.
I'm curious to see curb weights.
True, particularly if the engine can be chipped dependably. Unless BMW really locked it down, 400hp and 400lb ought to be easily do-able.
I wonder how BMW marketing feels about this.
dave
I'm just wrapping up a 9-day stay in England and am about to turn in my Ford Focus "estate" (that'd be station wagon/avant) diesel tomorrow morning at Gatwick. It's gotten as high as 46.3 mpg and never below 41 (U.S. gallons, converted carefully), calculated for over 1100 miles.
Plus which, the torque is absolutely wonderful, as always. Having rented a series of diesels on the continent & in England (Audi, VW, Peugeot & Citroen) over the past several years, I've decided that the first luxury brand that sells their diesel in the U.S. in a car with a manual transmission (VW doesn't qualify) will probably get my next purchase.
I'm sat in a guest house in Horley this evening, and the proprietor has a 320d "estate." I'd buy one in a heartbeat, if I could -- electric red. I've seen a number of 530d's as well, for those who think larger.
I've been looking closely at a 325 for my next car, as I want a manual transmission and RWD. I also need to haul my bicycle regularly & have become accustomed to the notion of an "avant" style, given their popularity in Europe.
I haven't taken the time to look yet, but your question seems to indicate that the only 325 wagon available in the U.S. is AWD. I certainly hope not.
Thank you, EPA (& lord knows what other government agencies) for making it so difficult for the wide variety of automobiles made available elsewhere in the world to be be sold in North America.
We gave up and got a 325xi with sports package (bigger wheels and sports seats) and have been really happy with it. Fast enough and it handles exceptionally well.
Good luck with whatever decision you make.
