thanks,
This annoys me, too. You can thank the Trial Lawyers of America for that. . . and for the ugly airbag warning on your visor, and for the fact that your manual is the size of an encyclopedia because of all of the warnings and disclaimers, etc., etc. etc.
"- The map database is not up to date. A 4-lane major road in my area has been in existence for at least 2 years but when I drove the RX330 on it, the Nav system showed the car was like “swimming in ocean” and kept asking me to “make a legal U turn.”
While this may be true, it's not HALF as bad as the data on my '03 Jaguar's nav system (which is the same Denso system as in the Lexus and Toyota). My development is about 6-7 years old. We ARE on the map on the Lexus (and my neighbor's Toyota) nav system, but NOT on the map on the Jag. They recently released an "new" disk -- and our neighborhood isn't on that one either!
Craig
The manual's pages 34-42 cover the rear hatch operation but I found no text about changing its range-of-motion.
When fully open, it clears our sectional garage door by about 2" - and I seem to recall that the RX300's hatch did not go up that close.
The gas you buy at Costco is no different than the products they sell inside the warehouse: It's a product they have purchased and are re-selling to you, it's not something they manufacture.
My guess is that if you disconnect the battery briefly then reStrain the rear door so it can only open as far as you wish and then cycle it several times against the false "stop" it will then "remember" the new fully open position.
Worth a try??
You can't do any damage since it's designed to auto-stop on encountering any unusual resistance.
Mine is Michelin 235/55/R18. I check the gap between the size wall of the tire and the sock spring, they are less than 1 inch gap. Not sure it will fit the 255/55/R18 tire size!!!
2) Theoretically, increasing to a 255mm tire width should cause both the inside and outside edge of the tread (relative to the center of the wheel) to grow by 10mm, which is about 0.4" both directions. This may still provide the required clearance. Another issue is whether the wider tire will properly mate with the stock Lexus 18" rim. Obviously, there is a limited range of tire widths that will properly mate with a specific wheel width, and a 255mm tire width might be considered too wide for that wheel. One reason I warn about this possibility is that some auto manufacturers use as narrow of a rim as recommended for the advertised tire width, in order to reduce a few dollars cost on the rims. One option is to check with a tire and wheel expert, such as at tirerack.com. Another option is to check a tire manufacturer's website. Some of these websites are very informative, including tables that list minimum and maximum wheel widths for a specific tire size. (BTW, I don't know the width of the Lexus rims, but that info should be readily available.)
I hope some of this info is helpful and not duplication of what you already understood.
I currently have a GS300 that is as smooth as butter. How does this RX engine compare to other Lexus models? I've noticed the increase in engine noise. What other comments can you make?
Tedcruiser
"[4] Tires fitted with 17- or 18-in wheels are expected to experience greater wear than conventional tires. Tire life may be substantially less than 20,000 miles, depending on driving conditions."
Is this what I can expect?? If it is true, less than 20K miles, that is disappointing. I realize that "depending on driving conditions" covers a lot of ground, but less than 20K?
Al Jennings
Keeping in mind the RX is an SUV, I think the engine has good pickup. I think it provides a little better passing acceleration than our previous '01 240hp MDX. If you give a good push to the accelerator, the RX330 will definitely get up and go.
On the other hand, I am not very fond of the transmission. Compared to other cars I have driven, including my current BMW 5-series 5sp automatic, it seems that the RX330 transmission is a little hesitant to downshift when applying a small, light tap on the accelerator. So when I apply a stronger push, the transmission sometimes decides to over compensate and shift down a full 2 gears. I believe there is a TSB out for an ECM program update to the transmission, but it seems that not all the dealers are aware of it yet. As it is, I am not overly concerned. It certainly isn't a significant problem causing me any concern. I still give the transmission a passing grade, but I just don't think it is as intelligent and/or responsive as it could be. The new TSB may improve matters.
Personally, I like the un-Lexus-like engine sound that some owners of the previous RX300 model have complained about. I don't consider the engine loud. I only seem to notice any engine noise if I am paying attention to it. Keep in mind that I am not a typical Lexus driver. My last two automobiles were BMW and Audi. I like the little bit of sporty flavor Lexus added to the RX330 when compared to the RX300.
A low-profile high-speed grade tire (such as "Z" or "W") will have a shorter life span than a typical "S", "T", or "H" rated tire, regardless of the tire size. I believe the 18" tires on the RX330 have a "V" speed rating, which is between "H" and "Z". I believe the 17" tires for the RX330 have a lower speed rating. The RX330 is equipped with all-season tires, and so I wouldn't expect the tread compound to be too soft.
Even a low-profile "W" rated performance tire can often achieve more than 20K miles of tread life. I would be shocked if most of us are not getting at least 30K miles off of the 18" tires equipped on the RX330.
Narrow sidewalls have less "flex" and so the tread must take the brunt of the impact from irregular roadbed surfaces.
I'm not so sure that a tire with 5" (for example) of sidewall height on an 18" rim is going to wear much faster than a similar tire with 5" sidewall height on a 15" rim. Sure, the ratio of tire sidewall to wheel diameter changes, but I am not easily convinced that the ratio is as important as the length of the sidewall.
Surely you don't believe the Lexus 235/55R18 all-season tires are destined for a tire graveyard when they reach 20K miles of age, do you?
(Correct answer: "No, I do not..., and DON'T call me Shirley.")
As I implied in my previous message, don't allow my feedback to carry much weight.
Are tires rated for wear at maximum load??
Dennis
Two definite tach movements also.
http://www.lexus.com/rx330/3ddemos.html
http://www.lexus.com/rx330/satellite_cam.html
I sold my 2001 Honda Accord for an AWD Bamboo Pearl (with Ivory Leather). I opted only to get the Performance package primarily because the Bamboo Pearl color was more important than nearly all of the added features I didn’t get. But, I agree with others on this site that the options packages are unusually restrictive and not very flexible.
Queen Lexi had her 1000 mile check-up today. Top on my priority list was the updated transmission software. The dealer installed it and I can tell a huge difference. The vehicle shifts MUCH faster in lower gears. But at times it feels as if the transmission is literally kicking and screaming itself into third gear. It’s as if Lexus overcompensated for the sluggishness of the original transmission installation. I will have to drive her for a few more days to see if I will raise this as an issue at the next regular service check.
Based on previous posts on this site, I had my dealer check the exhaust system. I was told Queenie didn’t have the problem identified by other owners on this site. I still, however, think the engine is louder than it should be on acceleration. The dealer gave me a new ES330 as a loaner and it was much quieter than the RX330. Are the engines in the new ES330 the same as the one in my RX?
I have had the RX330 for just over a month. The rear power door failed to open once from the front and with the remote key. I reset the switch in the glove box a few times and that seemed to take care of the problem. The backlight of the center console also failed to come on once very late at night until I put the car into gear. The dealership couldn’t find an explanation upon examination today.
I haven’t had any of the sunroof problems described by others on this site. My RX has two separate switches to control the roof one for tilt and the other to fully open the panel. I noticed the ES330 I drove today had only one switch to operate the sunroof and I can easily see how it could cause confusion.
After my experience today I am SO glad I didn’t buy an ES. It was quieter but it didn’t ride as well and I felt like an old lady in it (no offense intended, I am just not ready to be old, yet!). The interior is bland and the dark cherry wood almost looked fake (maybe it is I don’t know).
The rest of my complaints about Queenie are minor. I wish there was a place to put change (this is the only thing I truly miss about the Accord). I wish Lexus offered a non-wood interior package. I know the performance package has less wood but I would love to have an RX with NO wood. My husband bought a Mercedes C230 sport sedan because the interior trim is aluminum and not wood. Finally, I wish the Lexus medallion on the front grill was solid metal. I think a $40,000 plus luxury vehicle should not have a cheap, plastic front grill medallion.
The RX330 is, by far, the best SUV in its class. I drove every other luxury competitor and this is the clear winner when it comes to comfort, styling and standard options.
Was your dealer familiar with it and have it readily available?
Tedcruiser
I know exactly what you mean about the ES. I don't want to offend anyone either, but the word "bland" came to mind when I was driving the ES loaner after I had taken my wife's RX for its 5K service. I would have preferred an IS300 for a loaner. I also think some of the trim in the RX looks richer than the ES. The RX seems to have a nicer-looking instrument gauge cluster and audio/climate cluster, imo.
If the power rear hatch fails to open from the front or with the remote, you might try manually opening the hatch door. Once it is open, try hitting the power button on the hatch door to see if it will automatically close. I've seen a couple reports where the power hatch worked again after being manually opened, without having to go into the glove box. That was also my experience a few weeks ago. (We've experienced this problem only once.)
By the way, I hate to get off-topic (ok, not really, but I'll just pretend that I hate it)... If you could casually sneak a line or two into this discussion regarding your impressions of your husband's C230 sport sedan, I would be most grateful. I currently drive a 528i sport, but my next car will likely be a little smaller (both in size and price). PS, I also don't care for wood. I really wanted to buy the RX330 with just the Premium Package instead of the Premium Plus Package. The cheapskate in me didn't want to spend the extra $$ for the Performance Pkg. Unfortunately, the basic Premium Package was not available in our region. I like the power rear hatch and HID lamps within the Plus Pkg, but I didn't want the wood steering wheel! Sorry, but wooden steering wheels are too "Cadillac" for me!
I always thought the tire wear rating number was a relative rating(?). It's useful when comparing similar types of tires, but it doesn't provide an accurate estimate of your total mileage, regardless of load. Seem reasoanble? (Note: I should probably fix that spelling error, but I'm still feeling too lazy.)
Someone once told me that if you multiply the wear rating by 200, the resulting number equates to how many miles you should achieve with that tire. However, I know that isn't realistic with most of the lower-profile performance tires. I bought a set of 225/45ZR17s, with a "200" rating, for a sport sedan I drove a few years ago. Most of the tread was gone in less than 22K miles. That was under fairly casual driving. I rarely carried additional passengers or baggage. Well, maybe some emotional baggage, but no additional load on the tires. I've read a few other accounts that echo the same findings.
I had to drill a hole in the plastic cover and used wire ties to secure it to a cable that passes directly under this upward turned part of the cover. Climb under the RX just behind the front seat and you will see what I mean.
I find the transmission a lot noisier than the ES. In fact there is a different whine starting at 27 MPH to around 40 MPH that is very annoying. The dealer said they have received other complaints and are working on a solution. May be a vibration or motor mount problem. Anyone else having this problem and what is the solution?
ii
I had trouble reproducing these symptoms for the Lexus technician during a test drive at our 5K service, but he took my word on it. He glued a couple thin strips of foam along the inside edge of that cover. For the past 2 weeks we haven't heard any more tapping sounds.
Because the end of the plastic cover is not firmly secured, I'm surprised this problem hasn't been observed on more RX330s.
Ted...I found out about the transmission software update from previous messages posted on this site. Someone actually posted the TSB number (big thanks to the person who posted it). It's TSB#TC005-03. My dealer knew about it but I have a feeling they don't do the update unless there are specific complaints about the shifting. I had the update done at the 1000 mile service. They must have the software handy since the car was only at the dealer for one day.
Hope this helps.
Rob...thanks for the tip on the power door. Hopefully I won't have to use it. As for the C230...we purchased this after driving the IS300, BMW325 and the two larger Volvo sedans. We almost bought the IS300 but in the end, we felt the IS was a bit "too young" for us. The new design seems to fit a teenage boy better than a middle age man. The IS300 also felt smaller inside and we weren't thrilled with the color choices. And my engineer husband loves the set-up of the Benz dash computer. I drive it when I feel the need for speed. And, the C230 is the turbo...it has more punch than the C240.
I would recommend you test drive both the IS300 and the C230 back-to-back if possible...it is much easier to compare the similarities and differences.
Finally for all...I put about 80 miles on the RX today. The engine is still louder than I wish it was but the transmission seems to have calmed down with the added driving. And, my gas mileage is MUCH better (21 versus barely 18 before).
Glad to hear the tranny is behaving better!
The Pinging happens around 3000rpm to 4000rpm. Any similar experience. No code shows up on obdii.
I would really like to know if someone has had this looked at by Lexus and what they did.
Dennis
