By the way you guys in other countries who have the CRD in the Liberty have any kind of chip upgrades like Bully Dog or anything.
From standstill to the start of motion, the acceleration is strong (like a person can be).
The modern gas engine responds in an inverse way as it increases it's torque when it increases it's RPM. For off-road driving, the diesel is more comfortable since you don't need to play with the clutch and you don't stall the engine so easely. On the road you easely reach your cuising speed but you always need to anticipate the eventual overtaking (like if a person was running).
The chip upgrades I found on the european market will give longer injection timing in the first 1/3 of the rpm range, then about the same timing in the second 1/3, and finally more in the remaining 1/3. This helps the low end torque especially for the manual shifters, improves mileage in the city driving conditions, allows to burn out tires, does very little for the mileage over long trips, and finally helps overtaking at speeds above 75 MPH.
Another option is the variable pitch of the turbo compressor. This sets the maximum air intake pressure faster (needed for low end power), but seems a bit more delicate according to what I hear.
Cherokee IS the Liberty in markets outside of North America. As Liberty is the replacement for the Cherokee it is a logical to compare the old version to the new. The old Cherokee has many fans.
Interesting comments about the engine noise.
quote-The U.S.-spec Liberty also has considerably less engine noise and vibration than the European version. The big four-cylinder's sound is appreciably different from a gasoline engine, but without the unpleasant rattle and clattering common to big pickup diesels.-end
I noticed on the rental libery I drove, the power window switches were in the center console, which was another gripe 'o mine. I'm surprised that these were actually moved there from I assume the door. Cost savings I suppose.
25mpg average would pummel the 15mpg I averaged with the 3.7L!
By the way, I have 4 cup holders in mine and I like classical music...
http://www.autonews.com/article.cms?articleId=41376
It is so cruel for Diamler to tease us for so long;)
In any case, I need more cargo room anyway, and would be more interested in a slightly more powerful diesel in the new JGC. It sounds like that would be a real long shot. Too bad.
EXACTLY! That is my point. Wating since 2002 for the Liberty CRD. It was scheduled as a 2004 model year arriving in late 2003, 2004 arriving Spring 2004, 2005 arriving September/October 2004, and now 2005 arriving Spring 2005. When is this thing ever going to arrive? Only modifications are necessary since diesel Liberty has been manufactured in Ohio and exported since start of the Liberty build. Even the PT Cruiser has diesel installed and is exported from Mexico. We just are not offered the diesel versions in USA/Canada.
I'd rather see Jeep do it right and if it takes time, so be it. Throwing these on the streets just because they're already building them for export will result in what GM did to passenger diesels before. I want the Jeep techs to be trained and all the replacement parts avenues open when these hit the streets. I wonder if techs in CARB states are getting trained to work on them?
I'm being patient. Holding off on a purchase until Liberty arrives. Plan is to order as soon as they are available to order. Sight unseen if necessary. I'm willing to take the risk.
Excursion? I think that is a little overkill, unless you are a real breeder with a bunch of rugrats and serious towing needs. What about if you need 4wd you ask? Heck, I would not want to even try to get one of these suckers into the woods, much less try to drive one in any urban area.
I'd just like to see a midsized SUV with a decent diesel, just like DC already sells in their existing JGC in Europe.
http://www.arifleet.com/production.html
quote
Chrysler Group's announcement
to use B5, a 5 percent blend of biodiesel, in each new Jeep(R) Liberty Common
Rail Diesel (CRD) sport-utility vehicle coming off the assembly line is a
landmark choice by U.S. auto manufacturers in advancing the use of cleaner
burning biodiesel.
So are they are saying the CRD will be designed to run on B5 or just that it can use B5?
Also, what about the timing belt? In the Jetta TDI, you have to change it at the recommended frequency or risk major engine damage if it fails. Will the CRD have the same requirements?
http://www.detnews.com/2004/autosinsider/0409/13/a01-271661.htm
Do they still allow asbestos brake linings over there? That is a lot of mileage on brake pads. We are lucky to get 25k miles with the crappy pads they put on US cars. You can get ceramics for some cars and they hold up well.
Concerning the 25K miles, all depends how and where you drive. I downshift a lot and anticipate in our windy mountain roads because of the mass of the truck. I also use the permanent 4WD position going down long hills since the mechanical efficiency is lower. Added together it suffers very little wear regarding where it's being used.
http://www.stltoday.com/stltoday/autos/columnists.nsf/danwiese/st- ory/B08526F9FC4DB9D586256F0E00523605?OpenDocument&Headline=Je- ep+Liberty+diesel%3A+V-8+torque,+V-6+pep,+I-4+mpg+.+.+.+but+
This very special road starts in SUSA and goes to SESTRIERE, North-West of Italy. It's a 100% adrenalyn, 2 meters wide, you can see the bottom of the valley directly under your elbow and in some places the passenger has the same view at the same time, but on his/her side as well. Good for a Jeep...
We’ve had 30,000 hand-raisers,” who’ve contacted dealers about the vehicle in the first two weeks of September, he said.
Zero availability of Liberty diesel equals a demand that exceeds supply. LOL
Wonder how many lost sales will be created?
http://www.askmen.com/toys/cars_100/108b_car_review.html
Does anybody have any information on what options will be available for the CRD Sport and CRD Limited?
Then they will complain about nobody buying it and say "see we told you people don't want diesels".
They are setting themselves up for failure if they charge that much more.
Factory diesel engine option - $1000
Dealer paint sealant - $7000
What some people will pay
extra for the CRD - $8000
Supplies will be limited, so get in line early!
Hits head against the wall...
2FastDre.
