Jeep Liberty Diesel
1113114116118119224
  • turbledieselturblediesel Member Posts: 28
    Manley,
    Tranny won't go into OD until its' sensor says it's warmed up. Takes a couple miles in warm weather and about 4-5 in cold. Seems to take longer in cruise control. If you blast along at 70 it will help warm things up but you'll get lousy mpg.
    The big $175.00 rip-off book has lots of tricky driving methods to reprogram the tranny to shift smoother. Basically you're bleeding air out of the hydraulic system. It soulds like some of these things left the factory and/or dealer without enough tranny fluid which would cause lots of bubbles and shavings.
    Another big book item for people with rear end noises and trac-lock differentials. If you do ten to twelve figure eight turns it should distribute the differential lube to all of the clutch plates and help. Mine liked to make noise backing up and it would occasionally bind pulling into a parking space as if it were in 4wd-part-time. I mentioned that to the dealer who thought it wasn't even worth writing down.
    Only been getting 19 mpg in 2wd ever since I got it back from the blinking light trip to the lemon-dealer. It was a guaranteed 23 mpg in 2wd regardless of how I drove before lemon-dealer looked at it. Maybe they programed economy out of it since I wouldn't pay $89.00 up front on a warranty service.
    I'll keep this thing cause it's bought and fun to drive but it's looking like a trade-in on anything but a daimler chrysler jeep product. Technology is far enough along that a new car should have great reliability, fuel economy, and headlights that see down the road. Jeep gets an F+ from me in their sales and service departments.
    Good luck to all.
    Turblediesel
  • lightnin3lightnin3 Member Posts: 153
    It could be something come loose.
    I would venture to say ,to bring it in for a check up.
    Tell them the noises and when it happens.
    The turbo can be spooled in neutral and revved,
    at this point the mechanic can tell by placing a long screwdriver on the unit ,
    Place the handle on the side of the ear to hear if a seal or bearing is damaged.you can tell right away by hi pitch whine sound,a sign that it is starting to go.
    The vibrations will vibrate through the screwdriver to the ear.A good unit will have a "rrrr.." sound.
    This is the same for an alternator,or water pump that is not as easily accessable.
    Goodluck..
    Lightnin3..
    Hi Turbo Diesel,
    Sounds like your libby needs servicing.
    I would set up an appointment with a 5 Star DCX dealership that has diesel Tech's.
    It sounds like you need a tranny fluid drained out,changed and tranny filter changed.
    I would also get the differentials,and transfer case fluids changed out to ,Mopar synthetic.
    If you want better performance out of her,
    1/leave 10 minutes earlier,
    2/let it idle to warm up for 5 minutes,or
    plug in the oil heater,over night.
    This will ensure proper engine oil temp,and fluid being pumped to the tranny,and transfer case.
    Before she is warmed upm try to keep speeds under 50mph.
    There is a Temperature sensor on the tranny that disengages the 5th gear when the engine is not up to proper running temp.
    I would also suggest using anyone of these fuel additives,
    Power service
    Stanadyne
    Clean Flo
    for lubricity,and cetane improvement,for better performance as well.
    I hope you find a five star dealer,who will give you their card for future service.
    Good luck..
    Lightnin3...
  • winter2winter2 Member Posts: 1,801
    Turbo chargers are hard to kill. As long as they are fed a constant supply of oil and allowed to cool down properly, they generally do not break.
    The noise you describe is not a turbocharger associated sound. Turbos usually whistle/whine so the sound must be from elsewhere. If the turbo fails, there will be a significant loss of power and you will probably have a large cloud of smoke coming out of the tailpipe.
    I strongly urge you to have the bloody thing looked at.
    There is a drainback issue with this trans and there are several TSBs that apply.
    If you let the car sit for five to eight hours, all of the trans fluid drains into the trans sump. When you start it in the morning let it idle for at least thirty seconds in Park before putting it into gear. During these thirty seconds, the pump in the trans refills the torque converter and everything else. All air is purged from where ever it gets into. I have been doing this since the day I bought it and have not had a single problem with the performance of the trans.
    As to the binding sensation, you must have a limited slip differential. Chrysler limited slip units are from Dana. Dana makes several types of these units. The one Chrysler uses is a cone in cone design and not a clutch pack design. Unfortunately the cone in cone design likes to bind in reverse. I had one in my 1993 Dodge Dakota so I know what you are experiencing. Depending on the Dana rear end in the Liberty, there may be a clutch pack that can be substituted. I did that when I has the rear end on my Dakota rebuilt. The binding sensation ceased.
    As to your fuel economy, that is not the norm. Find another dealer. I have been fortunate enough to have purchased my CRD from a very good dealer with a very good service department.
  • crazeecanuckcrazeecanuck Member Posts: 2
    farmer52, mine is the same. You will probably find that your speedo is off by the same percentage (mine is off 6-7 %). Mine is an 06 (build 08/25/06), made for the Canadian market. The 06 was the first sent up here. Bought new in mid dec 05. 16,000 km on it (10,000 miles). Love it except trying to interprut the speed all the time. The dealer and DC say that the error is less than 10% so it doesn't get fixed. The dealer has a sister vehicle with the same build date and time and it has the same problem. They checked it with me and a GPS.
    Does anyone else have a problem like this?
  • bvcrdbvcrd Member Posts: 196
    My tech told me that on my 2006 model, the drain back isn't an issue. Some trannys have the split hose when it goes into a metal line. It lets it bleed off. But basically, if you start you car, and when it is put in gear, if it goes, you are OK. There were some trannys with build dates in '05 that were affected, but none after August 2005 build date.
  • goodcrdgoodcrd Member Posts: 253
    Does anyone know if using 5w-30 motor oil opposed to ATF in this trans will void the warranty? It works well with larger units, by giving more constant and stable shifts. It also is better at cooling the trans. I will be taking my CRD in to have a couple of leaks checked and will ask the service advisor or contact jeep myself. As a last resort anyone who is having the shudder problem my want to try flushing the trans of ATF and replacing it with engine oil. You'd have to change it a second time after a 10 mile trip to get all the ATF out of the torque converter. This has given much better trans and clutch life in extreme duty uses. But make sure it doesn't void your warranty first.
    Unless the trans is designed to use 5W-30, you are playing with fire.
    If the shudder issue is a software issue, then it will not matter what you use in the trans. A different lubricant/fluid may mask the problem to some degree or another, but the problem is still there. If there is a mechanical issue with the trans, that then will need to be fixed.
    Trying a different synthetic trans fluid may offer some relief and not impact on the warranty. The issue here is that you need to address the problem at it's source and not bandaid it. :(
    Using Engine oil has been proven to improve clutch life in automatic transmission for years. It is just getting the manufacture to approve its use that is the problem. The major advantage of using ATF is improved fuel economy! I know for a fact on Allison transmissions that when we changed over to Engine oil we doubled the life of the clutches in these transmissions. We were going through torque converters and clutches packs after about 15,000 miles or so. We had to wait until the unit was out of warranty to do the conversion. The clutches engage much harder and consistant with engine oil. Talk to a good transmission shop and verify what I've stated.
    But what about the detergent factor of the ATF? And the viscosity?
    The other issue here is the way transmissions are setup these days. People want a smooth, senseless shift. I like a good firm and quick shift. Less friction and heat to boot. Since modern transmissions are computer controlled and there is less hydraulics in them, attaining that perfect firm shift is more difficult. Adding a shift kit will attain that shift but you are limited by the amount of internal pressure these gearboxes will tolerate. There is alot more plastic and light metal in modern transmissions so they are less likely to be tolerant of a different fluid.
  • faroutfarout Member Posts: 1,609
    winter2: I wonder if the Bluetec will sell very well as the price is and will be very high. The new diesel for the Dodge Ram is going to be an additional $5,000. at least! To meet the emissions standards are quite costly. The current V M Motori is NOT just missing the emissions by "very little". There is solid reason to doubt there will be a diesel even for 2008. Only public demand and reasonable engine costs will permit another attempt at a diesel Liberty. Personally I think DCX has so messed over enough CRD owners as being their test market, it just might not be much in demand.
    Farout.
    I got the tsb on the trans and engine about two weeks ago. Today on a 360 mile trip I got all of 19 mpg! This is what I got with my 3.7 on a similar trip just before I traded it in on this CRD.
    I spent 3 hours on Wed at the dealer attempting to find out why the engine is jerking and is getting suck rotten mileage! We have the low sulfer fuel now and it seems to make no difference at all.
    My dealer said STAR has turned this over to someone higher up. The tec said my EGR is showing signs while he was driving of a problem, and the trans is not shifting as it should, because it's a slam type of shift, not a firm shift as he says it should be.
    This has me really wondering if DCX was rushing into production at our expense! The customer service people are asking what I want, and I said a CRD that works right!
    Any suggestions, and is anyone having this as well?
    Farout.
    Something else is going on. My mileage as not changed since the re-flash.
  • farmer52farmer52 Member Posts: 61
    I am in Canton, OH. I have seen one other CRD in the Canton area only one time in April. I work on the east side of Cleveland and have never seen another CRD driving to and from the office. I do know of one that was at a dealer in Bedford Heights because I took it for a test drive before I ordered my CRD. I bought mine from Waikem in Massillon. Mine is the second one they have seen. The first one was a 2005 and they dealer traded it soon after taking delivery. They were concerned about the problems with the early ones. They were reluctant to order mine until they checked with some other dealers who said the problems were resolved. I am still thanking the man upstairs for my problem free 03/2006 CRD (3400 miles and counting - 28 mpg highway). :)
  • siberiasiberia Member Posts: 520
    Farout, when my CRD was new it slam shifted pretty bad in the lower gears and slip shifted pretty bad into top gear. After a while the slam shifting turned into harsh shifts and the top gear shifts were less slippery. Now, the shifts seem to be about right (maybe could be a little more firm) with a top gear shift that is about as firm as it can be given the speed difference between the engine and the vehicle. It almost seemed like the transmission was adapting over time. I know...this falls into the strange but true category.
    I recently attended a Ford/Dodge diesel clinic at Woodhouse in Blair NE and the following information was presented:
    Ford requires a cetane rating of 42. Due to engine drivability and performance issues, fuel samples from various stations were submitted to Ford’s fuel testing facility. Samples returned results of 38 cetane. Woodhouse now recommends a cetane booster when they previously recommended no additives other than anti gel in very cold weather. They asserted only 1 to 1.5 MPG increase in fuel economy, cleaner EGR valve, less soot and an overall cleaner engine – also that cetane booster has more effect on low grade fuel than high grade fuel – may not get any increase on high grade fuel.
    A retired oil industry engineer was available at the clinic. He made a brief presentation and statements that go against buying fuel at big truck stops. First off all, he disputed the 38 cetane rating. He said that there are only 3 suppliers of diesel for the area (Coop, BP and Iforget) and everyone gets their fuel out of the same pipeline and the fuel is “commingled.” He also said that cetane is controlled by the suppliers and that there may be a small loss of cetane in transit but that is allowed for by entering a slightly higher cetane at the origin(s).
    After a brief back and forth between the Ford guy that sends in the samples and the engineer, the engineer acknowledged that there are some other producers that make a lower grade product that sometimes sell fuel for use by power companies in diesel generators and it sometimes (wrongly) ends up at truck stops because large diesel engines are more “tolerant” of low grade diesel fuel. He also acknowledged that lower grade heating oil sometimes ends up in the system. And, they make a lot of money selling lower grade diesel as good fuel. The lower grade fuel is apparently trucked to the locations and “commingled” with good fuel. Some areas in NE have only one choice of fuel to sell at all the local stations.
    The Dodge (CRD) diesel tech said that they are having really good luck with their CRDs out there. The service manager said that there was one CRD that had and engine problem that was traced to fuel quality and solved by using cetane booster. Woodhouse recommended buying fuel from a variety of locations and keeping track of mileage asserting that fuel quality can make a difference of 5 mpg – stick with the place that gives you the best mileage (duh!). Keep in mind that fuel is pretty much the same for an area except for companies that are blending in inferior product. This has a ring of truth, since we just went through a very mild winter here and it stands to reason there may have been some extra heating oil all refined up with no place to go.
    With regard to 0w40 Mobil 1 and the CRD owner’s manual that says that 5w40 may be used, the service manager said that DCX diesel engineers say that only Mobil 1 synthetic 0w40 is good enough and the owner’s manual is wrong. The contact at DCX was “shocked” that 5w40 was in the owner’s manual saying that only 0w40 Mobil 1 synthetic is okay because of the additive package in the oil.
    On the red antifreeze, no other antifreeze should ever be mixed with it because antifreezes with a different base can cause a precipitant that can clog up the cooling system. If you have a problem on the road and need repairs to the cooling system you are better off adding straight water until you can be sure you have the right product. Some oil change places are real helpful and top off all your fluids. Do not let them top off you cooling system, or any fluids, unless you are sure they have the right product.
    With regard to draining the filter at every oil change, if you are not finding water in the fuel that is fine, but if there is water and you don’t drain it the water leads to rust and corrosion inside the filter that can lead to other problems. They showed an example of a corroded rusty insert that failed to maintain seal and contaminated a fuel system – expensive repair.
    TSBs should not be done unless the related issue exists.
    There was a lot of discussion about “tow haul mode” and “over drive off” that the big diesel pickup truck guys seemed to think was pretty complicated. The new diesel pickups are very “smart” and tow best in tow haul mode with cruise on. The only thing that seemed to apply to the CRD is that it is better to be over drive off when the transmission is doing a lot of “hunting”.
    Here is an interesting table that correlates transmission oil life with oil temperature:
    175 degrees 100k miles
    195 degrees 50k miles
    212 degrees 25k miles
    235 degrees 12k miles
    255 degrees 6.25k miles
    275 degrees 3k miles
    295 degrees 1.5k miles
    315 degrees 750 miles
    335 degrees 325 miles
    375 degrees 80 miles
    390 degrees 40 miles
    415 degrees less than 30 minutes
    Never let the engine idle more than 5 minutes. It is a waste of fuel and small diesel engines (Cummins, PowerStroke, CRD and Sprinter) are not as tolerant of this as over the road truck engines. When cold, a two minute maximum warm-up followed by easy driving is best.
    Driving easy for the first 500 miles is for braking in the differential and nothing else.
    Nothing new really on turbo cool down. Worst case scenario is to pull a trailer at high speed on the interstate on a hot day, fly into a rest stop, shut off the engine and run into the bathroom. One guy said, “Suppose some guy didn’t know about this and did this a few times, how much damage did he do?” Laughter all around.
    I am making no personal assertions about any of this. I am just relating the information for your perusal. However, Woodhouse claims to be the largest diesel pickup truck dealer in the US. They gave away some samples of cetane booster so I will give it a try and see what happens. I opened a bottle and smelled it. I looks like diesel and smells like diesel / WD40.
    siberia ?: What you have said is exactally what the main CRD tec's at Yark and Steve White Jeep dealers said. They both said, as well as my dealer tec, that 0-40 is what is best for this engine. However when I e-mailed V M Motori and asked what oil to use they said 5-40 when less than 10 C and 10-40 in temps above 18 F. So why the huge difference? Why does V M Motori say one thing and DCX something else?
    I admit I am having very serious doubts about this CRD engine. Maybe they way they are set up in Europe is so much less complex and works so much better. I know 19 mpg sucks!
    The dealer is ordering a ECU that has not been updated and starting over from scratch as they feel this last tsb made things much worse! At first the tsb seemed to help, then it went down hill rather rapidly. It cost me $46.50 to go 360 miles today, I am just so irritated, and I am not sure or what to be irritated at.
    Farout
    I think we are getting worked up over nothing on this oil issue. Remember, the oil is 40 when at operating temps, and 0 or 5 when cold, which doesn't stay that way for very long with the engine heater. I don't see that it makes that much difference. What makes the most difference is overfilling it with a mis-punched dipstick.
  • zachinmizachinmi Member Posts: 228
    If Bluetec is the design that requires an onboard urea tank, I don't see any americans buying one. I thought that was the only option for diesels in 2007 until I visited the Cummins website where they have brochures on their 2007 engines and emissions technology, and they at least can meet the requirements with cooled EGR and a particulate filter. I imagine the Ford and Chevy diesel pickup engines will be similar. I believe the urea based filter is driven by european economics where fuel is especially pricey and urea relatively cheap. I would hazard to guess that europeans are also more likely to tolerate frequent trips to the dealer for routine maintenance, but I lack personal knowledge on that.
    I personally think that the 2007 emissions standards are excessive, especially with current oil prices and the huge fuel savings the US could get from converting even 10% of our personal vehicles to diesel. I would encourage anyone to lobby Congress on this issue (I realize the EPA wrote the regs, but I don't see the EPA changing unless ordered to do so by Congress).
    Greatly appreciate the long post. However I am puzzled by the techs remarking that only 0W40 should be used in the CRD, given that it seems to cause problems with blowby for many posters here, and that it has the dated CF additive standard while the 5W40 has the current CI standard. They didn't discuss this at all did they?
    Bvcrd, I am not worked up or trying to get anyone worked up. I just posted what was said. My next oil change is going to be 5W40. I just think I drive too easy for it to make that much difference.
    The oil level thing does have my attention. My first oil change I measured the oil and my recollection is that it was about half way between the marks. So, I thought the manual was wrong (or I measured wrong) and I filled it up. I wish I had paid more attention to this. I am a little annoyed that over filling may have put oil into my intercooler. I will measure the oil next time and go with that level, as you suggested.
    I am a little conflicted on the oil quality thing. I don't want to pay $6.50 a quart for oil if $4 oil is good enough.
    siberia ?: If what DCX says is so very important, and yet the Owners Manual clearly states that 5-40w may be used, then there is no reason not to use 5-40. The question I have what's the difference between shell Rotella syn. 5-40w and Mobil 1 5-40w? As person who does not have a degree as an oil engineer, I don't see why DCX can say that Shell can't be used. They can not stipulate brand, that is simply un-Americian! What connection does DCX have with Mobil, doesn't seem like there is a very cozy relationship between the two? I saw Rotella in the quart went up from $3.92 to over $4.50 in two weeks. My last oil change at the dealer was $92. and that is outrageous! I darn near passed out when the bill was given to me. That's not going to happen again as long as I own this CRD.
    My dip stick is right on the mark. And may I say leaves a real nice set of ring lines on my fingers thanks to this really odd dipstick. What's wrong with the old type of dip sticks?
    Farout
    zachinmi: I could be wrong and correct me if I am, but I think urea would be high in acid and would rust out any metal rather prematurely would it not? I can't see the Bluetec as a big seller in a Jeep. But I never thought the Big Hummer would still be a good seller either. I also can't understand why people buy these Hemi engines either. I wonder why so many people still think Toyota's are mainly made in Japan with quality workers, when most Toyota's are made in the US. Why are Us cars makers going to Canada, Mexico, and other countries for cars to be made. Why does so many foreign car companies build their cars in the US when labor is cheaper in their country? These are some things about marketing vehicles that baffle most people who wonder why the power of suggestion works on the American public.
    Farout
  • nescosmonescosmo Member Posts: 453
    Farout...My saga start when they (dealer) change the oil for the first time. When later on they change my EGR I told then that my crd was not acting up no loss of power, and mileage was good. only smoke when I step on it. well they change my EGR, Glowplugs and gave me all the tsb on the book. Ever since it drive just like a car. The reason that we are like we are is that we don't let the thing run it course, we just don't let it do it adjustment. complain,complain and the dealer love it; it is more money for their pocket. I was reading in the VW forum and they said that the shudder was cause by fuel related problems, not by tranny problems. their engine have more problems that the vm engine all together and they do not complain as much as we do, so if the dealer replace your ECU good luck if your mileage is bad use cetane buster. Vm engine is a good engine. VW have to replace timing belt at 40k we have to replace it at 100k, they have to replace high pressure fuel pump at 2 yrs and with it water pump and else related parts, we don't, so even we are a testing ground on the crd I think that we have one of the best diesel vehicle ever made, time will tell.
  • caribou1caribou1 Member Posts: 1,354
    Siberia, your post gives a clear view of the situation.
    Over here most diesel vehicles have had the common rail system since 8 to 10 years.
    Our truck fuel is the same we use in passenger cars. We commonly have to press a button to change the pumping speed for filling larger tanks and that's it.
    Oil viscosity to local understanding is related to climate. In northen countries we will use 0-W40, and going south 15-W40 will be more common.
    Antifreeze mixing has always been an issue. Since the day engines were made using aluminium, radiators evolved from brass+copper to plastic+aluminium, and there has been special attention given to stay away from galvanic/voltaic corrosion.
    People have had diesel engines for 35 years here because gasoline was ~40% more expensive than diesel. I never met a person complaining about the behaviour of gasolene engines. It's always been money (tax) related. Today with oil depletion coming up, the perspective is changing and the need of a diesel versus a gas engine is no longer clearly motivated except for towing or pulling things.
    There is still the ongoing discussion about egr valves. We are supposed to have cleaner fuel with higher cetane, but these valves still need cleaning when using the ULSD :sick:
    Local scrapyards are full of turbo-diesel engines in good shape. I think one has to work really hard with his turbo to damage it.
    I agree!!
    I think the answer to that question is not much. When I looked up the specs a year ago, the specs on Rotella syn were only slightly less than Mobil 1. The idea that the CRD engine is so fragile that oil that is slightly less in quality will damage the engine is to me ridiculous. However, I am not an oil engineer either.
    siberia, I forgot to mention in my previous post that over here most dealerships use different oil brands. This depends of commercial agreements for the whole range of lubricants one can find in a garage.
    The CRD engine is just "a very good one" within it's generation. In my owner's manual it is clearly written or equivalent concerning lubricants.
    Concerning the local second hand market, there are more CRDs on the road than on display. I doubt people would accept going to the dealership every month to keep the thing on the road. I've only seen happy owners who wave the hand as we cross on the road :shades:
    I think DCX and Mobil 1 are in bed, and under the covers together. Is Mobil 1 hurting so badly, that they need DCX to mandate useage of their oil exclusivly to stay in business?
    The owners manual gives you a bunch of recommendations. By law, no automobile manufacturer can force you to use one brand of oil over another. They are simply making a recommendation.
    Look under SEMA and the MF act.
    Frankly, I would not touch either of those oils. They are over treated petroleum products with double digit vaporization rates and tons of viscosity improvers and other garbage thrown into them to make them work. I view their base stocks to be barely adequate to do the job.
    About 150 miles ago I changed my oil to Amsoil 15W-40. The CRD starts and runs just fine and in fact is a bit quieter and smoother running. This oil specs out closely to the Mobil 1 5W-40 oil but has half the vaporization rate of the Mobil and has a vaporization rate that is one-third less than Shell Rotella 5W-40.
  • synlubessynlubes Member Posts: 184
    i have been selling synthetic oil for over twenty five years i run amsoil 5-30 series 3000 heavy duty diesel oil love it better protection than any 15-40 0-40 5-40 out there
    Synlube,
    I sent the specs for the Series 3000 5W-30 to VM Motori and they shot it down. They stated that it did not have the high temp protection offered by the 40 weight in warm or hot weather.
    I am using the Amsoil 15W-40 full synthetic in my CRD. It specs closely to Mobil 1 5W-40. CRD runs fine.
    How much cost is your Amsoil? I don't figure the smoothness. If the engine is adequately lubricated, how can it be smoother? If the engine is shuddering so much, it would burn itself up from friction.
    I am 56 years old and I've been driving car since a was 16 years old every car I bought was used and never, never oil was an issue, just drop 10w-30 and there we go. I think that all of this is a money making business and we are trap because we are afraid to do the wrong thing. they know that we are stupid about this, they know that we look at all the angles, that's why they are sucessfull.
    How come you started driving at 16? I was at 14 in Kansas. Anyway, I think the 30w would thin out too much for a CRD and the turbo would cook (coke) the lesser oil.
    The oil, one gallon and three quarts, plus the Amsoil SDF-34 filter cost about $52 (including discount and tax).
    How can the engine be smoother? Better quality lubricant. I do not have a shuddering issue with this engine or trans.
    That urea tank gets refilled every 10 - 12K. I do not see that as a problem or inconvience.
    Nor do I with the Shell. If it were running so rough as to cause shuddering, I feel it would be noticed in the temp gauge. Bearings working rough, other friction related parts going south. The shuddering that a few have experienced is NOT oil related. I change mine every 5000 miles regardless of what the manual says or the tree huggers. It costs me $30 which I am happy to pay for piece of mind in knowing that this engine will last well over 200,000 miles.
    Caribou1, you answered my question before I could ask it concerning how it works you side. :)
    Y'all, check this out!
    link title
    I have been to the Mobil site before and not found a recommendation for the CRD. Now they are recommending Mobil 1 5w40 for a 2005-06 2.8 diesel. Wouldn't you think the recommendation would be 0w40? I tried different options on the search such as below 0 or above 0. Then it shut me off for maximum number of searches. I could only get 5w40. :surprise: :confuse: :D
    Nope!
    You could be right, I don't know. The sad thing is that, if true, DCX is making a lot of good hard working diesel techs part of the scam, hopefully unknowingly.
    I just did it and they said 5w30 was for my crd. Boy are they lame.
    My stealership only has 1 diesel tech and he is a good one. He runs Shell Rotella in his rig.
    The CF rating used in the EU is probably appropriate. They are running ULSD over there with a cetane of 51 or better.
    Domestically, our diesel fuel sucks. It is moderately high in sulphur, and has a cetane of barely 40. CI-4+ rated oil makes more sense here.
    Once ULSD has been in place for several months, then CF rated oil might be okay. Let us see what happens to the cetane rating once ULSD is in place.
    Mobil-Exxon is so big that they do not need to be in bed with anyone. Mobil 1 is heavily advertised so people know about it.
    It is probably easy for Mobil-Exxon to meet the automakers needs so that is why they use them.
    From India? Frankly, it comes from the White House and Capital Hill. :surprise:
    I do not know if the urea solution is synthetic or from biological sources. If it is synthetic, it is probably cleaner and more uniform.
    Sorry Winter2, I deleted my post because I didn't know if it would be understood as a joke. I put it back so you post doesn't look odd.
    Is the urea refined or biological? Does it come from India?
    Should be cheap, no? :)
    Good comeback!
    Then why not put Shell in the owner's manual?
