Jeep Liberty Diesel
1154155157159160224
  • mngolfermngolfer Member Posts: 18
    Those are similar symptoms we had before the torque converter failed. The engine would rev up a little when coming to a stop. Also felt a clunk when releasing the brake pedal after a stop. When the torque converter failed, we were backing out of the driveway and the engine killed when we put the transmission in Drive. Totally loaded the engine down. We turned the key off and fortunately the engine restarted and we drove directly to the dealer.
  • fustfust Member Posts: 29
    thank-you for your reply, after the torque converter was replaced has the problem disapeered just wondering due to reading other posts indicating this may be normal or the start of complete failure of the torque converter.
  • arvmanarvman Member Posts: 95
    do all you crd owners have the red optima gel cell battery?I've got it and from past experience these are a great battery.Just wondering if different Libby's have different batteries.
  • zachinmizachinmi Member Posts: 228
    Yes, my 2005 CRD Sport has that. I believe they are standard. A friend into the tuner scene was quite impressed - I guess they are expensive and well regarded. All I can say is that it starts reliably.
  • goodcrdgoodcrd Member Posts: 253
    Sorry to bust your bubble. They are having problems with the Optima gel cells. When they replaced mine they put in a "Mopar Gel Cell" and told me tough luck. This is the battery Jeep uses as the replacement. And they wouldn't put a new Optima back in. I called Jeep's Customer Service and they stood by the dealer. My CRD was a 3/05 build date.
  • synlubessynlubes Member Posts: 184
    all the crd liberty get the optima a little smaller than the standard optima with the chrysler decal i sold some of the first optima batterys they built they can be tricky to charge if you completly kill one other than that great batterys
    jeep dealers wer charging over two hundred dollars for the optima should have been one twenty nine ninety five also they are not gels the are filled with electrolyte
    No bubble to burst. Anyway, I have never had battery problems with any car I've owned. I suspect driving/operating style hsa something to do with that.
  • siberiasiberia Member Posts: 520
    I was wondering why cant u just clean the egr valve...On my Lincoln it would stick open and i would take it off clean it then it was fine for another 10k or more
    My EGR "failed" after driving easy for 22,000 miles without periodically or deliberately "blowing its nose." Oddly enough it happened during the third consecutive tank of fuel using Cetane number improver, so I am done with that experiment.
    I had an opportunity to get a close look at the failed valve when it was removed. It looked like a well made unit but also looked unremarkable in complexity. There was a very light coating of soot on the passage way and it was in the closed position. Symptoms preceding the failure were reduced turbo lag, much cleaner exhaust under acceleration and perhaps slightly better mileage. And, it continued to drive very well with three error codes and the engine light on. I regret that I did not remove it, clean it and clear the codes. I might have learned something.
    Observation of inlet air temperature revealed that relatively high inlet air temperature was obtained when driving out of overdrive (3rd) at 2,500 under light load. Driving at high throttle and high load in the same gear produced much lower air inlet temperature. Assuming that air inlet temperature is correlated with egr flow, a lot of exhaust goes through the egr valve in the first case and a lot less exhaust goes through the egr valve in the second case.
    Sorry, Hogwild, I strayed from you original question. Yes I think the egr valve is easily cleanable. The problem I am having is that I am not convinced that the valve failed because of soot. It just wasn't that dirty. In a previous discussion of this topic (Caribou1, it think), it was suggested that perhaps a little more clearance was needed on the moving parts. Next time it fails I intend to find out.
    Nope. It was under warranty and they put in a new gel cell battery made by Orbital with the Mopar stamp on the side. It was black not red. I went around and around with them over it. I was told live with it. And that was from Jeep backing up the dealer. I've worked with gel cells for years. They can be damaged if your charging voltage goes too high or low. And the jeep only had 32,000 miles on it at the time. Mostly highway use of an hour each way to work. Gel cell batteries are more septable to internal shorting then standard batteries.
    Hey siberia,when my e.g.r. got done I saw they had to move a lot of components to get to it.Apparently the tech's have found an easier way now.How much of a pain is it to get to the valve?If there is a clearance issue,shouldn't a handy person be able to take it apart and modify it by a few thou of an inch to improve clearance?I never got to see the valve but it can't be that complicated of a unit.Not too concerned yet,but when warranty is gone it would be a nice thing to be able to do.For anyone else out there,have you heard of anyone putttin a chip in the C.R.D.?I have seen a site selling them but won't do anything until warranty is up and have had some feedback about the chip,cheers...
  • gerbsgerbs Member Posts: 11
    Does anyone know the capacity of the gear lube for the rear axle? I would like to change my own and cannot find it in the owners manual.
  • eebroeebro Member Posts: 80
    arvman,
    I have a decent amount of experience with these Optima batteries from the early 90's installing sound systems in the 10,000+ watt IASCA competition systems. We'd use 15 to 20 of these batteries in parallel separated by isolator circuitry with an Amptron power supply on the outside during sound off.
    There are two types of these gelled lead acid Optima batteries--the yellow top and red top. The yellow top is the deep cycle version rated in amp/hr (typically 75 amp/hr) and it handles full drain/charge cycles like a champ. I'd have to pull up the spec sheets to speak intelligently about the internal plate differences between the red/yellow top versions. (I do know that the deep cycle version is somewhat impervious to anode surface crystalization which would otherwise come from heavy drain cycles. This crystalization is the death knell for any lead-acid battery, especially for those whose acid does not continually wash over the internal surfaces. The gel simply does not have the penetration power of its traditional counterpart.)
    The red top Optima battery, however, is your typical shallow cycle battery albeit all-position because of the gelled sulfuric acid, and it is appropriately rated in CCA. Our team found that if you drained them completely (<4 volts), the battery would NEVER return to full charge of 12.7 volts and would actually randomly walk its way to 11.5, 11, 10.5, etc volts over time until it became an enormous current drain in the power system. We burned out dozens of regulators because of this sustained current draw and the inability of several 210 amp alternators to operate at 100% duty cycle for the duration of a soundoff contest at IASCA. I've probably returned 20 of them under full warranty in my short lifetime.
    In essence, if you drain this battery so that your starter solenoid can't even engage at ignition, be prepared to replace the battery soon or potentially lose the voltage regulator (which in most cases is part of the circuitry in the ECM for the JEEP or OBDC for other, older Chrysler vehicles.)
    Jones
  • faroutfarout Member Posts: 1,609
    arvman: I have checked several web sites and found NONE. I suppose it's because only 11,000 US CRD;s were made. I wonder if any UK web sites might have any, as there are a lot more CRD's over there.
    Farout
    winter2: I am really puzzled. Our CRD does not smoke, and there is no emission of soot, yet. We have 22,400 miles and The ONLY time we have seen any smoke is last winter a couple of times when one of us forgot to wait starting the engine until the red dot went out. As for smell there is a very small trace, but it is not something that is real easy to smell. What do you suppose is the big difference between yours and ours? We have used several brands of fuel and all were very good with the exception of CEMEX, and MFA, and a Stop & Go that had B-20. They very best fuel for mpg's has been the WalMart stations, Murphy diesel, and the last real good mpg was 28 mpg. Frankly we were blown away at this mpg.
    We do blow the nose when we get this jerkyness that lasts for maybe 15 seconds, and they we drop down to 3rd and take it up to 4,000 rpm for a minuet or so, and the jerky feeling gows away. This happens maybe every 2,000 to 3,000 miles. Proberly Philips 66 diesel seems to be pretty good as well.
    Because we do not have smoke or soot, I can see no reason to use additives. The inter-cooler hose still remains oil free anter 11,000 miles fron replacement. However I do use Shell Rotella 5-40w, and it seems to run the same as the Mobile 1 0-40, but at least the Shell Rotella is out here to buy, where the 0-40w was next to impossible to find.
    The only way to tell if you are getting ULSD is to ask, here. There are no tags saying it's the ULSD yet, they have until Oct. 16 to have the right labled diesel. Do you have any ULSD there? Our diesel here is $2.39. That's what it is in about a 70 mile radius from our house.
    Motor Week had their final test results on the 2005 CRD. They averaged 21.7 mpg for 21,000 miles. No problems, but felt the extra price for the CRD, and with the test of the Liberty 3.7 getting in the "high teens" the CRD was ok.
    DCX called the CRD's an "experiment" I call it as it was a sneaky way to get a "test market" where people paid big time to be in it. However, so far we are pleased with the CRD.
    Farout
  • winter2winter2 Member Posts: 1,801
    Farout,
    There is no visible smoke during the day except when I "blow the nose". At night, however, it is a different story. If someone is behind me with their lights on, and I goose the accelerator a bit too much, then you can see the smoke in the lights of the following car.
    As to ULSD, I have learned that on October 16th, ULSD will be available at 80% of the pumps while LSD (S500) will be available at the remaining 20%. S15 will not be mandatory at all pumps for a few years down the road except at CARB rule following states. See the link below for the phase in schedule.
    http://www.eia.doe.gov/pub/oil_gas/petroleum/presentations/2006/ethanol/ethanol0- - - 806_files/frame.html
    Go to slide 26 to see the schedule grid.
    I will continue to use additives for now until I consistently get S15. Once I consistently get S15, I may simply use cetane improver only and see what happens. As to oil, I will stick to the Amsoil products. As good as Shell may be, I have not seen it here at the local Walmart here in Delray Beach. They do have the 0W-40 in good quantity however. Now that Amsoil has a CJ rated 5W-40 available, I will run with it since it has a lower Noack vaporization rate than Shell by several percent.
    To add more salt to the wound, the Optima battery has a serious weakness. If it is discharged beyond a certain point, it will not recharge. This is a serious flaw and several battery shops that once carrier them have dropped them because of this problem and Optima's poor customer service. I am guessing that DCX ran into a similar problem.
    I guess jeep did me a favor. eebro also made a valid explanation of the batteries short coming. The battery put in my CRD is what jeep stood by. It solved the problem and the CRD has been running fine since. I do know that jeep has been having problems with the Optima battery used in the CRD.
    Arvman, the egr valve looks like it might be accessible from below. Maybe, I can answer your questions after it fails again.
    Farout, I have been assuming (perhaps wrongly) that when there is no label at the diesel pump the fuel is ULSD since a warning label is required by law for LSD. I fueled at a station recently that used to have the LSD labels and the labels were gone.
    By my math, the CRD runs a tad over 90 mph in 3rd gear at 4,000 rpm. Are you running that fast for a full minute?! If you just want to blow out the egr valve, run at 2,500 rpm in 3rd at light throttle for a while. At high rpm and heavy load the valve actually closes and maybe that is what is needed. You can close the valve by simply flooring the throttle up hill in 3rd for a few seconds now and then.
    Also, thank you to the battery posters. I had no clue about these batteries. I will use a trickle charger whenever the CRD is not driven for more than a couple of days.
  • playgabeplaygabe Member Posts: 31
    We have had no transmission problems (shudder) with our CRD so far. We use the trans. a lot for breaking as we live on a 3 mile hill. To save on brakes we shift down all the way to the bottom. It's sort of a game with my wife to see if she can use the trans and not the brakes all the way down the hill. I always let the engine idle for a min. when cold b/4 shifting into gear to insure the fluid gets circulated in the trans.
    Around here most stations have the "LSD - not for 2007+ diesel vehicles" stickers, while a few have "ULSD - required for 2007+ diesel vehicles" stickers. I have even been to one truck stop that had the LSD stickers on B20 pumps and ULSD stickers on petrodiesel pumps. If there are no stickers I would guess you are getting ULSD, but I am not sure and perhaps the station is just lazy.
    Well,that is an amazing amount of info,I'm glad I asked.I'll keep an eye on this.Since the battery is quite important to delicate electronics this could explain some issues down the road.I have a good warranty but this info is priceless,thank's a million eebro...
  • zoomy2zoomy2 Member Posts: 50
    I had the new LBJ (recall F23)replaced with my oil change ($98.87, a new cost record) :sick: and the fuel filter ($69.49). :sick: I thought diesels were cheaper to maintain and run, but with this VM puppy it much more then a gasser. Next time I'm going back to gas.
    LBJ changed seem to change the ride and handling. It seems stiffer and more stable while driving on the highway. I can't pin down any other changes, but I make less steering corrections. I didn't feel pulling to the left or right, maybe you don't need to realign after these are changed.
    They also replaced the door moldings as they were peeling away.
    They couldn't duplicate the shutter, but I noticed more when I first started it up at the dealer (after service) with the new fuel filter. I didn't notice it in today's drive to/from work. I did pass a slow car and I didn't feel it when slowing down like normal. I don't think what I felt was a transmission issue. I do use it hard pulling a camping trailer near the CRD's max towing rating. I would think that this would bring out every flaw.
    Do people have this problem with the Hemi powered B2500 & 3500 pickups, I believe they have the same transmission?
  • twocycle2twocycle2 Member Posts: 55
    It's been awhile since I've posted, though I still check in and read as often as I can.....10K miles now....so far, no problems. Mileage seems to hold steady at about 22mpg in mixed driving. I do have a few questions:
    1) What exactly does the EGR valve look like (I know this was addressed in posts months ago, but I'm not sure where)?
    2) As you look at the engine (with the plastic cover off), there is a black plastic device about 3 inches in diameter on the left side of the valve cover....is this the egr valve, and if not, what is it?
    3) Has anybody tried RXP gas additive in their CRD, or any car for that matter? It is common in the DFW area at Kwik Car and O-Riley's. I'm curious what kind of results you got.
    Thx for the info!
    Twocycle2
    The RXP smells like snake oil to me - try a net search for rxp scam (skip the jetski stuff). The Florida DOT study quoted doesn't exist as near as I can tell.
    I've been using redline diesel additive.can't tell much difference,seems when i fuel up at a certain station I get better driveability and mileage,better fuel I guess.
    What your describe is Closed Crankcase Ventilation (CCV). It is a simple flapper valve that guarantees or allows one way flow of crankcase pulses of fumes from the crankcase into the intake ahead of the turbo. Without this vent pressure would build up in the crankcase and push oil past the seals.
    siberia: It must be second gear then? For sure it's at about 50 mph and doing about 4,000rpm. I have yet to do 90 mph in the CRD. Proberly 80 mph. I am glad you brought that math up or who knows what others thought. It must have been a "senior moment" that got me then.
    I called the parts store and the optima battery is $175.
    now that would put a dent in the food budget! If that happens I will look into some other kind of battery that will crank this diesel over and last better, and I hope at half the cost.
    There are no mountains in Missouri mostly little hills, and lots of dips in the road. In fact unless one tows a trailer it might be a little hard to put the CRD under much of a loda.
    Farout
    winter2:Even when we blow the nose there appears to be no smoke. Maybe it's the better fuel they send those who live close to heaven in Missouri?
    I found quarts of 0-40 Mobile today in the parts store, $6.48 each.
    Farout
    Hi, everyone. As you've probably noticed, we have been trying to refine the discussions into more narrowly focussed topics. Our objective is twofold. We want to make it easier for people seeking specific information about their vehicles to find it easily and without having to wade through hundreds or thousands of postings.
    To those ends, we will be shutting down the general make/model discussions and work exclusively with specific issues. This requires us to populate the make/model subsections with relevant, interesting and timely topics. Rather than having the hosts simply create boilerplate topics for each make/model, we feel that you, the owner, the make/model enthusiast and the prospective buyer can best judge what those topics should be.
    You can help by adding a discussion (it's easy!) or suggesting one here.
    To add a discussion, click on the last link in the "You are here" line at the top of this page. That will take you to the topic page for this make/model. Review the list of topics and click on the "Add discussion" link when you've decided what topic you'd like to add. Follow the directions and you're done! Feel free to add more than one. Just avoid duplicating existing topics and try not to make it TOO specific!
    Your help and continued participation in the Forums is greatly appreciated! Thanks.
  • caribou1caribou1 Member Posts: 1,354
    Hi winter2,
    The cetane number is a ratio expressing how easily a diesel fuel self-ignites and burns compared to a set of references:
    - Pure cetane (n-hexadecane) is considered 100%
    - "1-methylnaphthalene" is considered 0% because it burns very slowly in a diesel engine.
    These values quantify the delay of self-ignition in terms of injection timing and also determine the maximum rpm a given diesel engine will be able to achieve because of the time needed to burn the fuel.
    Heated and spin-filtered crude oil can be used on ship engines because of their slow speed (~35% cetane). Smaller diesel engines need shorter combustion times and are limited to roughly 5000 rpm at 51% cetane rating.
    This is the (short) theory about cetane and It seems there is nothing to gain above 51% cetane rating.
    When I asked you how the percentage was expressed, I had in mind the fact that you do get good mileage (better than mine), and that cetane is directly related to efficiency of this engine. In other words why would you have good mileage at a 45% rating and europeans less at 50%?
  • dirtmoverdirtmover Member Posts: 14
    Hi, anyone got any comments or experience with the above oil for the CRD. They are selling the 0W40 and 0W30 as synthetic meeting CI-4 spec. The price, $5.50/l Canadian, is great compared with Rotella or Mobil 1 ($7.5/l-$10/l). I've only seen this oil in WalMart so I'm a touch skeptical.
  • jimhemijimhemi Member Posts: 223
    Same as Mobile. It's a good deal, pick up a few cases before the price goes up.
    Now that you have clarified your question, I will try to answer.
    I think part of why I get better fuel economy is where I live right now, namely Florida. It is still quite warm here in the low to mid eighties. Also, it is quite flat here too and the only hills I encounter are the bridges that cross over other roads and other highways.
    I also feel that part of the fuel economy issue is driving speed. I take my time and generally do not drive faster than sixty-five MPH (105 KPH)and usually I drive closer to 62 MPH (100 KPH)on the highway.
    In my own experimentation, I have found that lower cetane diesel, namely that closer to forty or forty-three yields more noise, more vibration, somewhat slower acceleration, more hesitation when cold and in colder weather and a little less fuel economy. I also get more smoke, especially when I blow the EGR's "nose".
    When I add cetane improvers and detergents with cetane improver that will bring the cetane closer to fifty or fifty-one. I have found that with the higher cetane, the engine is smoother, is quieter, has almost no vibration, hesitation disappears when cold or in colder weather, is more responsive to right foot input and best of all I gain about four percent in fuel economy. Also, there is significantly less smoke when I blow the EGR's nose.
    Does this answer your question?
    I talked with a Shell distributor about the ULSD and the new oils. Here is what he said.
    ULSD has LESS Cetane and is about 43 in most ALL stations, not just Shell. The new ULSD needs a lubercation additive, he suggested PS Cetane booster in the summer and PS anti-gell in the winter. Without sulfer this wil mean the water/fuel filter will need to be changed more often, as sulfer distributed the water in the fuel, not the water will be a larger issue. He said the WalMart fuel, is a pot luck type of fuel, and said I was just lucky to get good fuel, and suggested a major brand now. Also the new ULSD does get lower fuel miles per gallon, in his huge tanker trucks it is noticeable, but not 1%. The tankers get 4-6mpg (if that). Shell has and other brands have run into some big issues with Bio fuel even with the low Bio-5 fuel. Bacteria is a huge issue, and it does cause fuel pump problems, but it does help with lubercation, but he said the trade off is just not worth it in his opinion. The bacteria grows fast and is very risky.
    Now for oil. The old oil CI-4, is being replaced by CJ-4 oil. The Shell Rotella T is what he specificly what he was referring to. The CI-4 oil can be topped off with the CJ-4 oil, but the CJ-4 cannot be topped off with CI-4 oil. By March Shell will stop making CI-4.
    All diesel fuel stations are being sent ULSD as of today, OCT. 16,2006. As the stations buy more fuel the more pure the ULSD will become. All diesel engines put in vehicles until Jan 2007, are able to use the LSD that is currently in tanks. All engine installed in vehicles from Jan. 1,2007 must be the new diesels that can only use the ULSD. Any engine can use the ULSD, that was made before 2007.
    I hope this was helpful and not confusing.
    Farout
  • vtdogvtdog Member Posts: 163
    "Without sulfer this will mean the water/fuel filter will need to be changed more often, as sulfer distributed the water in the fuel, not the water will be a larger issue"
    I don't mean to pick nits, but what the shell guy told you does not make sense from a chemistry standpoint. There is nothing in the sulphur in diesel fuel which would allow the "sulphur to distribute the water". I am not a petrochemist, but just a "regular" organic chemist and have no special insight into diesel chemistry, but sulphur just doesn't do what he says. The sulphur neither acts as a surfactant (detergent), nor as an interface between the oil and water soluable components of the fuel. Depending on the organic sulphur compounds, the sulphur may possibly be somewhat hydroscopic and "take up" some water, but in no fashion should the removal of the sulphur cause a problem with water contamination UNLESS there is something that is done in the removal process that adds water to the final mix.
    If he is contending that the sulphur removal would permit bacteria growth than he is saying that it acts as some kind of bactericide which is possible, but highly unlikely. The sulfur removal may change the ph of the fuel, but I suspect not enough to change bacteria growth rates. Further, some of the bacteria growth may be by sulfur using species which one would think would be greatly reduced if the sulfur is reduced.
    One last thing, on the oil: it is my understanding that by API standards "new" oil has to be back compatible with "old" oil so I don't see why the mixing would be a problem, but I'm not sure of this.
    Winter2,
    I agree you can improve your cetane number with additives, but your basic fuel must have more BTUs than the one we are using. These are two separate issues and we seem to have equivalent experience. This answers my question ;)
    You have one very narrow "ramp" in Miami that climbs into the clouds, much worse than our mountain roads that have at least the rock on one side :shades:
    The following link explains (in french) the mechanism giving presence of bacteria:
    http://www.intertek-cb.com/newsitetest/services/fr/documents/01Bacteries_000.pdf-
    I was not able to find it in english, but here is a brief translation, and sulfer is not addressed:
    When refined, diesel fuel is stored at a warmer temperature than ambient air.
    Condensation occurs when fuel cools down and the free volume of air inside the storage tank shrinks because of the negative temperature variation.
    Micro organisms normally present in humid air penetrate in the vessel and lead to bacteria growth at the interface of the condensed water and the fuel, usually at the bottom of the storage vessel.
    Bacteria are accompanied by fungus and yeasts. A first type of bacteria attacks fuel and oxydises it while a second type of bacteria lives from the waste of the other group.
    This phenomena is self maintained at temperatures near 72 Fahrenheit.
    d'accord
    Caribou,
    I know that fly over. It is quite high and steep and I have travelled on it several times. It is rather unsettling to drive on when it is raining.
    Getting back to the original question, according to some of the refiners I have contacted, there will be less energy per gallon because in the process of removing the sulfur, they are reducing the amount of aromatics found in the fuel. I have seen numbers up to 3% less energy than found in S500 diesel. Aromatics are being reduced by 65% in our diesel fuel while CARB diesel allows only 10% aromatics in their fuel. Aromatic compounds are the biggest source of PAH compounds, a known potent carcinogen. I will be glad to get rid of those.
    I am of the opinion that CARB diesel is very similar to the fuel you buy. It has a cetane of 50 or better, and is very low in aromatic content, thus reducing the BTU content of the fuel.
    According to the EPA schedule, all diesel fuel will be CARB like in the next few years. I wish they would simply make the CARB diesel. By the end of the decade, even home heating oil will be S15. It is now S5000.
  • turbledieselturblediesel Member Posts: 28
    Farout,
    All they replaced was the egr valve, a gasket, and a turbo sensor. It ran worse when I got it back. The 5 star dealer service advisors both said the repair hadn't gone far enough since the cooler wasn't replaced but they "fixed" it with a test drive and said it was fine based on their experience with similar vehicles. Now the turbo doesn't work and the tranny shifts randomly around 55 mph. Passing begs a head-on since it acts differently everytime I try it. Personally I think it's been reprogrammed to make the egr last until warrenty ends and kill the complaining customer. (my check cleared and I don't intend to buy again; I'm useless to jeep)
    17.75 MPG on the highway in 2wd. $3.11 per gallon.
    Is the PCM the computer?
    The oddest part of all this is that I like the thing when it works. It fits my needs. The reality is that it doesn't work now and it's not going to fix itself. Jeep isn't going to fix it and I can't and don't want to anyway... that's why I bought new.
    Glad you're having better luck. You mush have the only non-lemon they built.
    Turblediesel
    If you live in AK don't buy a chrysler/jeep product
    I had big problems with Anchorage Chrysler in 1975. Sounds like they are still operating under the same management.
    Hmmm, I got an '89 Voyager from them in 1988 and they were ok - they didn't even fight me much on replacing the head gasket three times, and the last time I was over the 7/70 warranty by 7,000 miles. When I went back a decade later to shop new vans the sales staff didn't have much of a clue what was on the lot but they weren't as bad as the Honda guys that tag-teamed me when I was trying to buy an Odyssey in '99. I walked out on them.
    The one time I decided to "go see Cal" the staff came running out to my van before I could even find a place to park - so I sped up and got the heck out of there! :D
    My Nissan salesman was great; naturally he left the dealer the day after I picked the new van up. He decided to go sell Jeeps. Which brings us back around to Liberties, right? :shades:
    If the PCM (one of the controlling computers) was disconnected from the battery for more than thirty minutes, then it acts like it had a stroke. I will explain. The programming in the PCM and in the TCM is adaptive. In other words it learns (sort of) your driving style. When battery power is removed fro about 30 minutes then everything it learned is lost. So it is learning all over again. When I bought my Liberty in 2005, it acted strangely. for several hundred miles until it learned my style. When I had to have the computer re-flashed with an update at 683 miles, I had to teach it once again.
    I really feel for you and the problems you are having and I am sure that you are beyond frustrated and angry. I guess I have been quite lucky in that my CRD has been quite trouble free save for the aforementioned computer re-flash and update, a blown hose from the turbo to the after cooler, and now the ball joint recall. Outside of those issues, it has been perfect.
    I have been tag teamed and walked out of a dealer too. I head for the door when the salesperson tells me they need to talk to a manager.
    they are starting to build the 3.ol crd for 2007 it will have 376 pounds of tork at 1600 to 2800 rpm nineteen miles per gallon in town twenty three on the road
    Synlubes: Go to www.jeepsnow.com/modules/news/
    The diesel is for the 2008 Liberty not the 2007. The diesel is to be added later in the year of the 2008.
    Don't get to excited, this diesel for the 2008 Liberty may be just for Europe, not the USA. Remember that 2007 Compass and Patriot will get a diesel this year, but only for Europe. Time will tell, but no diesel engine is shown in the engine schedule that DCX has posted.
    Farout
  • justmecwjustmecw Member Posts: 20
    Can anyone tell me where the EGR is located.
    justmecw: I believe (not positive) it is under the air filter box, or under near there. Hope you are not having trouble.
    Farout
