Toyota Sienna 2004+
I visited my dealer today where they upgraded the transmission software to supposedly eliminate the problem of the "jerking" at low speeds when turning a corner. From my invoice it states: Updated ECM and transmission per TSB TC007-03 TC3001 .8 T1 26 T2 99 89661-09101. I drove back in heavy rain and some snow so I have not really had much of a chance to determine if it eliminated the problem or not but thought I would pass this on for any interested.
I would have it done and see.
how does an ECM know you're cornering?
please tell me this tsb would improve the performance of engine and transmission regardless of driver on the straight or in a curve.
something isn't adding up if not.
However I don't think the VSC was responsible for the issue, in my limited view it was more the base programming of the transmission shift points relative to vehicle speed.
I now have the complete repair manual with all of the wiring diagrams. This, like most vehicles now, is one complex machine with an amazing amount of interconnection between systems that are controllled by by several ECUs that talk to a main ECU by way of a multiplexed communication system.
So the tranny ECU knows what the vehicle speed is, plus the engine speed, plus the throttle opening. Meanwhile the VSC ECU knows all the tranny knows plus the steering wheel angular direction, the G force of the turning produced, the relative rotation of each wheel and it then can adjust the engine speed, braking for each wheel, and adjust all these parameters several times a second. Yeah they are connected.
But to reiterate, I don't think the VSC system is at the root of the problem, it is the programming of the tranny relative to speed and throttle position. It keeps the tranny in too high a gear going around the corner and then takes a while to shift down into the right gear for the acceleration the driver is calling for with their right foot.
And how does it respond to individual driving habit? Varying the speed of up or down shifting? Sensitivity of throttle?
Anti-rollover stuff.
Yes it does all of those things to respond and likely others.
We all have different habits, I for example tend to accelerate pretty moderately to 3500 rpm in most of my cars before shifting using only part throttle. I suspect my techniques drive others nuts as I tend to be looking way down the road at the next light, where others accelerate all the way to the light. I tend to get all my braking done before the corner so I can accelerate around the corner, allowing me to modulate the line around the corner by either gettng into the gas or letting off (to go wider or tighten the line respectively). My wifes habits are different but similar as I taught her to drive standard (the only kind of car we have had in the last 21 years), but she does drive differently. As our Sienna will be almost always driven by her, when I drive it will be trying to learn my habits so during that transition from driver to driver, it will likely not drive the way we would like or expect.
We live in a locale with few hills, don't have to really accerate hard except for the rare occaisions where we don't have alot of room on an entrance ramp (rarely, or when we go to Chicago). It will be loping along at 25 for much of the time it is running as we only have the 1 speed limit in our city. When we go to Vermont each year, there is a 13 hour drive across flat Canadian land followed by the extreme hilliness of Vermont (large throttle openings) and then the coastal plain of New Hampshire. All will have different effects on the manner the vehicle will behave and learn.
There are other adaptive systems in modern cars too, specifically the fuel injection system, over time makes corrections in its running parameters as it wears, leaks develop and so on. It uses temperature, vacuum, oxygen sensors (2 now of days), throttle position, and so on to adjust the engine.
VSC MAY prevent a downshift simultaneous with WOT and a hard turn if there is insufficient traction as shown by wheel spin sensed by a ABS sensor on one wheel relative to the others. It may also reduce throttle, reduce ignition timing, reduce fuel injected, apply a brake or some other strategy depending on speed and or severity of wheel spin.
I think I want to get off this technology parade NOW!
Your only real choice is to start buying older cars. My Fiats are nice and easy to work on. No start? OK, got gas? check Got spark? nope, change points and condenser and wallah running car. Try that with something built since 1990.
so there was this: "upgraded the transmission software to supposedly eliminate the problem of the "jerking" at low speeds when turning a corner"
really all i was thinking was hey - this van *MUST* exhibit jerking at low speed when NOT turning a corner as well. otherwise, something is not right.
didn't mean to drop back to the VSC discussion - but it's none-the-less good to hear someone without VSC software also experienced the jerking in the turns. whew!
understood...people tend to drive corners differently than others.
all the hype about "adaptive" expert systems technology which "learns" per the drivers inputs... if it was really "smart" - that situation with the "jerking" would be handled (eventually).
no need for the human to re-assert authority and command a reflash.
but seriously, looks like someone fundamentally mis-parameterized the prototypical driving envelope for a portion of the population.
things that make you go hmmmm.
maybe the technology should be training up (not its own parametric tables), but rather the humans and their driving technique...
the future of driving...soon we will have no choice.
LOL.
You could certainly get them aftermarket, but since the Sienna is so new, you might have to go with the OEM parts anyway. Plus the hassle of getting it done. Much easier to deal with a problem if Toyota or the dealer screws up before you buy the van, instead of an aftermarket shop once you own it.
Sorry, I just could not resist. But seriously, it doesn't sound normal to me and most likely will show up as a real problem over time. You can at least keep reporting the problem every time you go in for service. Be sure and keep those receipts and it will give you the necessary paper trail if/when the underlying problem shows its ugly head.
1) Any time you accelerate quickly from a slow speed there is a really long lag probably close to half a second. Its really annoying.
2) The other behavior happens when you accelerate to merge on a highway then coast and then accelerate again to pass in fairly rapid succession. There is a lag of almost 1 second before a hard shift happens and you have power again.
I have only driven one sample so it may not be significant but it was annoying. The Nissan and Honda vans dont this because I try the same thing with all of them and take them through the same loop. I'm driving the XLE Leather at Lou Fusz Toyota later this week or weekend. They actually bought one just to have as a test driver so its there full time.
Other than that its a really nice van.
I suspected that the noise was coming from something that was dragging and that it periodically slam up under the body of the van. A visual inspection did not spot anything of this sort. Anyone else have a similar experience?
Use of snow chains ONLY on the front can potentially be very hazardous so the issue at the rear must be very seriosu for Toyota to recommend this extreme.
Although a good thing to point out by your mechanic, in this case it doesn't apply.
sarniasting mentioned in message #1238 that he had seen a TSB listed "on another board" describing a 2004 transmission issue. What other message boards are out there for us??
The rims from a RAV4, Highlander, or the Camry will all work. The RAV4 rims are a slightly different offset, but not enough to be an issue.
I bought my OEM steel rims and caps from a fellow Sienna owner who changed to Camry rims.
If you look at the member agreement we all accepted, it lays this out in very clear legalese : )
As this site needs to pay for the bandwidth it uses, it is sponsored by companies that pay for the ad space, like the Tire Rack as seen in the lower left corner.
The best I can say is do a search, but even that may get my post deleted and me banished, which I would rather not have happen.
Please tell me I didn't ruin the engine or transmission or shorten it's life! The car seems fine, but I am really worried now, especially since this was during the breaking-in period, the first 768 miles I put on it.
The good news is that I took it out, re-set the trip meter and DRIVING IN THE CORRECT GEAR I am now getting 28.5 mpg on the highway instead of 22.
Thanks to this forum, I realized what I had been doing wrong!
hatcher8, you might check in our Technical Service Bulletins discussion. If you ask your question in that topic, there are some technicians who usually drop in and post the TSB.
kirstie_h
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I like the new Sienna the best, but I am concerned about the seat comfort on long trips - especially after reading the long term test on Edmunds. We are looking at the XLE model with the 8 way power seat.
I would appreciate any comments about the comfort and support of the front seats that any of you can provide.
Recaro seats (there may be others) are _nice_. I don't own them but on a few occasions have driven in cars with them. They make a range of seats, some specifically designed for people w/ back problems (including FDA approved seats).
The nice thing is, if you "grow attached" to the seats, you can move them to future cars. They come with some mounting hardware for installing in a variety of cars.
I would suspect that this would be far superior to any standard seat (short of Porsche or something like that - I believe they already use Recaro seats).
(Article follows): To this we added Package #19. As you've likely noticed, Sienna option packages can be confusing because there are lots of them and they're all numbered — making it difficult to differentiate between them. In any case, this large package set us up with 17-inch wheels; leather upholstery; a rear DVD entertainment system (with two pairs of wireless headphones); a DVD-based navigation system; second- and third-row side sunshades; a moonroof; and seat-mounted side airbags for the front occupants and side curtain airbags for all three rows. The price of this package is an incredible $7,040, but the total MSRP was still only $36,605 — less than the MSRP of our not-as-well equipped '01 Grand Caravan ES. Oddly enough, though, our well-equipped van still has rear drum brakes. Rear disc brakes are available on the Sienna XLE, along with stability control, but none of the packages that contain these items are available with Package #19.
Many thanks!
If you get the factory DVD system, can you listen to it through the rear audio system without the headphones, or are the headphones required to hear the movie sound? Thanks.
