Well, now that you mention it...
Mine: 1995 318ti Club Sport-2020 C43-2021 Sahara 4xe-1996 Speed Triple Challenge Cup Replica
Wife's: 2015 X1 xDrive28i
BMW 3-Series Run Flat Tires
2500 messages in that discussion..
The real changes will take place in 2012 with a whole new chassis. And rumor has it that a diesel will make it to the US along with a hardtop convertible, but those are just rumors and thus their veracity is in question.
Also, I think they've dropped one of the exterior paint choices. Again, not a big concern.
Specifically, I am interested in the 1-series convertible, if it makes a difference.
Also, are there any significant changes from the 2012 to 2013 1-series models?
Either the 1 is dead or no one who visits Edmunds cares much about them.
Let's see who joins in with the answer to your question.
2013 BMW 135is Priced From $44,145
In any case, I love mine. Bought an '08 about 14 months ago with 42k miles. I'm now at 55k. I autocrossed it once and I've done 4 track days and have my 5th-6th coming up in about a month.
I don't know if you are considering new or used, but on the used side, I have yet to come upon another car that offers comparable performance, comfort, and reliability for comparable money.
The Sandman :sick: :shades:
2023 Hyundai Kona Limited AWD (wife) / 2015 Golf TSI (me) / 2019 Chevrolet Cruze Premier RS (daughter #1) / 2020 Hyundai Accent SE (daughter #2) / 2023 Subaru Impreza Base (son)
The doors are a bit on the heavy side, but my 6-year-old can reach out from his seat and close it, so probably not as bad as you think. They seem to have these detents where you can set the door as you open it. So, when pulling shut, you only need effort to get past the detent and then it just about closes itself.
Upkeep cost is relative, of course. With sportscar brakes and tires, yes, they cost more than those on a less capable car. Oil change? Yeah, as pricey as any BMW when using 7 qts of the required Castrol Syntec.
Right now, the new car has been put on indefinite hold and we'll just fix the a/c once it dies. We talked last night about trying to go to 200k which is very doable I suspect. She doesn't abuse it and I maintain it as best I can so now the plan is to wait till 2015 models come out and then purchase. Plan B has officially been put into place!
Why yes, yes I am.
I finally got around to selling my LS last winter -- drove it over 128K miles, including a trip to Alaska the summer of '07.
Replaced it with an Acura TSX the spring of '08 and am driving it to this day.
Well put. There are a number of Ford apologists who will go on at length about why it ended up as it did, but it was a major failure, other than the car itself. I prefer a company that gradually works out the bugs, year after year, until there are none (or nearly none) left.
Therefore, I own a Honda which has given me exactly zero issues in 75K miles, plus which it has a really nice manual transmission which I enjoy. The only problem is that the wrong pair of wheels are being driven.
Which brings me to BMW, which (at least up until now, but not for much longer) always drives the rear wheels. My issue with them has to do with their penchant for electronic crap I don't want, plus run-flat tires and a general attitude that says: "bring it to the dealer for everything." When the battery goes dead (a common occurrence here in the desert), it's necessary to flatbed the car to the dealer for a replacement. Get real. I've replaced most of the batteries that have needed it on a weekend by taking the old one to Auto Zone to have them pronounce it dead, then bringing the replacement back to car. No big deal. Then there's that dipstick thing, which wouldn't have been so bad if the electronic sensor worked, which it didn't at the beginning. BMW has essentially sold out to the masses who want to own the badge and have told the enthusiasts who like to work on their own cars and keep them simple to not let the door hit them on the way out.
Hope you enjoy your car. I am mine.
thank you
Franco
My preocupation was on the performance (traction, gear box, transmition). I think the difference is too small between both, that should not be a problem.
thank you again.
Franco
what you mean "the rubber wears down"?
Not really all that much (not like on the Flintstones...), but that's why you rotate your tires to make them wear even (unless you have directional tires).
The size of the tire is only part of the traction equation, of course. If you are talking about the stock runflats, they would break away easy even if they were 300 wide. haha.
After 85K miles my 1 series has started to give me trouble with backfire so I decided it was time to replace the spark plugs and coils. The dealer replaced one coil for $300 and when I started having the problem again, I decided it was time to change them all. OMG! Talk about a car designed to discourage you from working on it! To take the engine cover off there are four bolts, only two are accessible. To get to the back two bolts I had to remove the air filter housing, two attached wiring runs and trays and the main tray that runs across the car near the windshield. Changing the coils and plugs was EASY... but getting access to the area... WOW!
Your car may be a little too old, but the newer BMWs have to be taken to the dealer to have the battery replaced -- something to do with synchronizing the battery with the ECU. This is just the most recent of the 5 or 6 things that make me never want to own a BMW made after about 2005. Where I live batteries fail regularly, and replacing one is a 45-minute exercise involving a trip to the local Auto Zone and a quick R & R of the offending unit.
BMW is most of the way to a hermetically sealed engine compartment that is "not user serviceable."
Either the BMW 1 series has lost all favor. . .or Edmunds forums have.
Hard to choose.
2015 Subaru Outback 3.6R / 2014 MINI Countryman S ALL4
This particular vehicle was leased, then bought, by one owner in Orange County, NY, and has 18,000 miles since the in-service date of 04/2011. It is a CPO vehicle from a BMW dealer in Metrowest.
I'm looking at a 2012 M Sport Coupe; it would probably be in my driveway tonight if it had a manual instead of the DCT. I'm not sure I can live without a clutch in the long term.
The Sandman
