-Andrew L
"And GM is now offering loyalty rebates of $3-4,000 on the NEW Malibu." The way Im reading the rebates, the basic rebate+loyal will bring you to 3 or 4 thousand dollars. I dont think the loyalty rebate alone is that high.
Ford should not only be paying attention to the Malibu, but to basically every market factor possible. The company has MANY cars to introduce over the next year, and most, if not all, of the introductions need to be executed well for Billy's "less market share but higher profits" mentality to work.
~alpha
MODERATOR /ADMINISTRATOR
Review your vehicle
Ahem...
Someone previously mentioned the 4 cylinder offerings, which is mainly what was missing from the Taurus line. Granted, you had bragging rights over offering standard V6 engines specially in the late 80's, early 90's whereas the imports such as Camry Accord were late to offer V6's.
And even so, you still have consumer's who would rather have the fuel efficiency of an I4, over a V6. Granted, the Vulcan 3.0L V6 in the Taurus isn't a model of efficieny in any manner, and it's more powerful Duratec 3.0L does same fuel estimates.
This time around, (sedan formally known as Futura till we publically get a name announced) will be fitted with a standard 2.3L I-4 and address the consumer's who are looking for a bigger car than the Focus, but with decent better fuel efficiency. Approx. 82-85% of Camry's/Accord's are sold in 4 cylinder versions.
And unlike the Vulcan, the Duratec23 I-4 is quite sophisticated and very advanced compared to other I-4's in it's class, and will sound much better during accelerations.
Will it be as reliable as those other 4's? That matters more than most anything else in this class of car...
TNX
Paul
TNX
Paul
Something Parry Jones every now and then my hippocampus sparks!!!
Officer.
Is he still around and hopefully part of the Futura?
Paul
Paul
Since this "yet un-named vehicle" rides upon that platform, it'll have the DNA to have it as such. BUT (big but here), while Mazda6 can tailor a car to be a bit more specific (niche like), they can maximize and offend some customer's. This "Yet un-named sedan" needs to reach please a wider base of buyer's, so you will find variations depending upon trim levels.
Example: The 4 Cylinder will definately ride a bit softer. The V6 will be tuned appropiately, and the ST270 version will be tuned "european like".
And it's that formula that will be very important to get JUST right. But if the platform is good, then your 70% there into achieving great handling characteristics.
Platforms play a major part in the formula to a good driving/handling vehicle. Second aspect is the suspension tuning. Case in Point... We are well aware of how well the Lincoln LS drives..even better in V8 trim. Uses same platform as the Tbird, YET, the Tbird was fitted with softer shocks. Read reviews on the Tbird, and you will find how much softer it handles...how it's a "Boulevard cruiser". And not a vehicle you want to toss into curves, like the LS.
http://www.findarticles.com/p/articles/mi_m3012/is_7_181/ai_76855- - 621/pg_2
The ST 270 tuning will that be similiar to the former SVT Contour?
Paul
But a lot of cars through the generations mirror certain aspects of eachother...its what consumers want...look back at each decade and notice how similar cars were...cars of the 80's...camrys...toyotas...volkswagons...etc...same small boxy cars...
i think that there is nothing wrong with having similar styling...i believe it was Bill Gates who said...
"Do it second, do it better."
I'll take the Futura over the Caddy :-)
http://www.detnews.com/2004/autosinsider/0407/19/a01-216055.htm
Moderator's can now change the forum's title to Fusion.
And Toyota's prepping its 3.5L 270+ hp V6 for the Avalon, with expectation that it will show up in the Camry eventually...
~alpha
Compare Futura/Fusion with the Camry. The Camry will not likely get the 270 hp engine. Toyota never aimed at high powered vehicles, but rather fuel-efficient vehicles.
I suppose that remains to be seen too. I would agree that I dont think the Camry in this generation will get that engine. But going forward, for the next generation (which debuts for the 2007 Model Year, only what? one year after the Fusion..), it seems to make little sense that Toyota would produce 3 or 4 engines in the same plant for the same vehicles, when it would probably fairly easily produce only 2. (TMMK, the 2.4L, the 3.0L, the 3.3L, and the 3.5L. The 3.0L is already on its way out, used only in the Camry now, and the 3.3L is allegedly an interim engine, from what I've read....)
The Fusion name is FAR better than any others I've read here, and I am personally excited about Ford's resurgance, though I think the Five Hundred/Montego have a tough battle ahead. Im looking forward to driving the Fusion and Freestyle though.
ANT- when is the co. going to axe the uncompetitive, unsuccessful, Freestar/Monterrey? $5000 is a lot of incentive to be putting in the cargo bay.
~alpha
~alpha
FWIW, I use an 04 Monterey in my business, and now have 8,000 trouble free and defect free miles on it. My runner loves it. The ONLY issue we have had is a blown tire - not the car's fault (and no, it didn't roll over, thank you very much!). So, although the van is not class leading in most areas, it's built really well, and would be quite the value for one to buy. Highly underrated vehicle, IMO. We're very pleased with it.
I think its excellent that you've had a good experience, but according to the press (I admit I dont drive minivans), the vehicle does not seem underrated, and nor does it really have that great a value equation where resale is factored in. On the corporate level, I wonder if Ford is making any money. Id bet yes, simply because they set the MSRP in the stratosphere, in my estimation, precisely because they knew theyd need HUGE incentives to get the beast out the door. Ford, under Billy's control, strikes me as finance and marketing/marketplace savvy, if nothing else.
~alpha
I don't understand this up-scale up-scale of every car out there? Is it the only method manufacturers can make money or is it the American consumers vanity?
Personally I've gotten to the point Phooey on what a vehicle symbolizes, it has to have driving dynamics and fit my tightening budget. I guess practicality is not part of automotive marketing strategy? I'd love to have and could appreciate screaming acceleration, but it's just not being a good steward of the earth.
Maybe I'm experiencing some sort of culture shock, since a very large percentage of us WW II baby-boomer earnings potential has been cut short by early retirements, we don't count anymore? Just exactly what segment is controlling the the market?
Paul
Larger than a Ford Focus sedan and smaller than the Five Hundred, the new Fusion will be aimed squarely at the heart of the mid-size car market. Ford fusion will be joined by an all-new, upscale, mid size car from Mercury and the all-new, all wheel-drive Lincoln Zephyr.
Source: PR Newswire
Review your vehicle
Interesting tidbit: FordMoCo sells the most wagons of any other manufacturer... Certainly not something they will leave behind....
The real question is... japanese competitors already have 240/250 hp engines (accord/altima) but they also have xenon headlamps and DVD navigation with voice recognition.
Will the fusion have any of these features? BTW the 2005 Pontiac GP will have a navigation system.
SVT is moving into a bit more hardcore territory...
Review your vehicle
Paul
Is the new "CAN" protocol going into all Fords. Got to get ready for troubleshooting.
A friend related a recent article in Wall Street that the Government has been pushing automakers to release maintenance/troubleshooting info such as DTC codes (when your CEL light lights) and hopefully not be so secretive about troubleshooting. For those of us with the passion to do it ourselves and the ability. Besides there are too many out there causing more pollution and safety issues because of this NSA like secrecy. Then these young folk developed an attitude and come up with own methods to get around what the engineers thought was fool proof. Sure it's going to happen no matter what, but look how bad some of these disgruntle guru's computer viruses have become. can. I'm not sure the reason for the release of info we didn't get to finish the conversation.
It sure would make it a whole lot easier for those of us car buffs who do care and understand how much more affordable vehicle ownership is when maintained properly in the first place.
One big simple glaring issue 100,000 mile spark-plugs Ha Ha Ha. The OBD II points that out even if the vehicle seems to be running fine. Had 18,000 on factory single platinum's, info from the web site and an old laptop with OBD II software installed. I and others tried ever spark-plug out there and wouldn't you know it the ignition system should have had double-platinum's. I gain 3 mpg around town driving know!! No more hint of rotten egg from the cats that the dealer was told by Ford the PCM needed re-calibrated?
This particular car buff web site I participate has helped Ford & Visteon engineers get the real story. We've been told at certain dealerships the mechanics have made very good use are heads-up's thus saving the consumer wasted hours while the service department calls up Detroit.
All part of the high-tech world and the bottom line engineering brings to the market. Same designing that went into the Contour/Mystique. It amazes how good they turned out. Good that is, if your in the know what's really wrong or a certain strange maintenance schedule to keep the tranny happy.
Paul
It's amazing what you can do just so you can afford to things besides throwing money at a vehicle! I was trained well by a WW II/depression survior!!!
Tnx
Paul
I still say it's a miracle vehicles perform as well as they do. If if wasn't for individuals busting their tails, management wouldn't be able to pull half the miracles they thought they have!!!!
Paul
