To diagnose if this is the case, go out and jiggle the license plate holder a little, and see if there are some gaps between the holder and bumper where contact could be occurring. Then wedge some cloth strips in these gaps in-between the holder and the bumper to ensure that the holder cannot vibrate, then drive the car and see if the sound is gone or reduced. Tear up an old T shirt or wash cloth to get some pieces of cloth. If this fixes the problem, have the dealer replace or tighten the license plate holder.
Hope this helps.
Does anyone know anything about automatic door lock? I have a 2008 tsx automatic with navi. Whenever I start the car, and start driving, the doors doesn't lock automatically. I have to manually lock the doors, since they were in the unlock position? Hope I am making any sense.
Yesterday I found that someone has scratch paint off of my rear bumper. I need to know if this is something that I can fix myself, or if I will need to take it into a body shop and have it repaired.
I was told that because it's on the bumper that I need a "felx agent" or the paint will start to crack. Please advise.
Thanks in advance.
If this were my car, I would not fix it myself. I would take it to a dealer or a very reputable shop that would do this. Get many quotes first.
New to this forum.
I have a TSX, 2004, 72K miles. The dealership recommended a Fuel Injector Cleaning. yes, it is more sluggish now (despite using premium gas) but..there is a HUGE difference in price if the dealer does it ($200) or a place like Valvoline. I'm assuming the Acura dealer does a thorough cleaning of the injectors??
Is it worth it??
All the fuel injector cleaner you ever need is already in the gasoline you've been burning since you bought your TSX.
Seems that dealers are trying to make more money in the slow economy on precisely these types of services. You may not need it.
* Helps restore lost engine performance caused by deposits left by lower quality gasolines
* Helps keep emissions low
* Unsurpassed ability to clean vital engine parts such as dirty fuel injectors and intake valves
You can get it here...
http://www.chevron.com/products/ourfuels/prodserv/fuels/gasoline.aspx
I JUST replaced my breaks at 70K miles. I was impressed at how long they lasted. I also just replaced tires, although those should have been replaced a little sooner.
I am going to go ahead and get the throttle body cleaning and fuel injector cleaning. it's cost is about $208, but I have $50 coupon, so I'm going to do it, it's been a little sluggish, so I hope this helps.
Thanks for your response!!
The other things that comes to mind, is to try another dealer and ask to speak to the sales mgr. If they don't know, they are in big trouble. And since you are on Edmunds, did u check under the true cost to own function? Under model info. That is probably the most unbiased report.
Good luck!
- replace valve cover gasket
- adjust valve clearance
- switch to synthetic oil
- change automatic transmission fluid
- change coolant.
- change brake fluid.
I have been following maintenance manual so far. It does not mention replacing valve cover gasket. It says "adjust valve clearance only if noisy". Any thoughts on that?
I have been changing oil and filter every 10k. Used regular mineral oil, as per owner's manual. Oil stayed clean and was not burnt till the end of 10k. Mechanic recommends switching to synthetic. Of course, it costs more.
- any thoughts on that?
I took the car in to the dealership two months ago and they swapped out the Nav unit. The next day it was fine, the day after that it started acting up again. I decided to wait a while to see if the problem persisted, and sure enough it has not improved. I took it back to the dealer today and they could not duplicate the issue and recommended waiting until it "got worse" before bringing it in again.
Does anyone have any thoughts on what could be causing this?
Other than this minor issue, I really like the car! I just hope that I didn't end up with a :lemon: of a display. Please help. Thanks!
Don't be so fast to blame the mechanic. Similar thing happened to me.
I did indeed have a bent rim, but it was on the rear axle. The shaking was not noticeable on the steering wheel. There was a bit of shimming before the tire change, but I wrote it off to the tires being out of balance towards the end of their life. After the tire change, the bent rim (by accident) ended up on the front axle. Of course the vibration was very pronounced. Your choices are:
- move the rim to the back and not rotate tires. In the future, you will have to replace tires two at a time
- take the wheel to a specialty repair shop to see if it can be straightened.
The recommendation to synthetic is just that - a recommendation. You don't need it unless you think the synthetic will somehow help the car. It won't.
see how easy it is. I'm sure you had a bent rim before you came for tire replacement, it was installed in rear and now it's in front.
some one said it probable is the motor????? does any one know how to fix this - or how much it would cost to be fixe - I have a 2004 1/2 TSX with 50k miles - on it
and this is really bugging me...
:mad:
Rick in Northwest Burbs of Chicago
Has anyone had their oxygen sensor replaced under the extended emissions warranty?
sooooooooooo I tightened the cap and it was good to go...r :confuse:
and then checked the gas cap.... it must be on tight.....and the light went off...
not sure if it that simple for you however .... you may want to check...it
RL
in Bartlett .IL
