-June 2024 Special Lease Deals-
Subaru XT Turbo Forester
-juice
The clutch is still a pain, but we have gotten use to each other. I can always shift smoothly if I'm wearing my old tennis shoes with the worn out soles.
I do have a couple of intermittent interior rattles that I am just ignoring.
Had my first scary incident where the ABS disengaged brakes briefly while vigorously stopping. This only happened about once a year in my previous Forester.
Overall a great car.
Ken
-juice
Ed
Ken,
Your worst tankful, with no Interstate driving, is better than my best tankful with about 80% Interstate. That disparity remains a total mystery to me.
It is easy for me to see why you're far happier with your XT than I am with mine. And yet, mine doesn't appear to be uniquely awful. Quite a few other XT 5MT drivers are reporting about the same numbers as I'm getting.
Very strange. It's almost as if there are two distinct groups of XTs - the good ones, and the bad ones. You got one from the former group, and I wound up with the latter.
I'm not well informed on aviation matters, but don't most or all aviation piston engines require dual spark plugs per cylinder? There are many conversion cylinder heads (for VW, Corvair, and Porsche engines) that convert them to dual ignition for aircraft use. But I don't know whether that's an actual requirement, or just a good idea.
In any event, the same attributes that I cited for a marine conversion would certainly make the XT/STi engine appealing for flyboys - compact dimensions, light weight, and very high power output per pound.
On the other hand, keeping propeller tip speeds in the acceptable subsonic range would require either de-tuning the engine to operate at substantially lower RPMs, or else a reduction gear to cut the output shaft RPM by about 1/2 to 2/3.
You still complaining about too-short gearing? Ha Ha
-juice
Some things never change...<sigh>
I'm a bit discouraged with the reports of rattles. The XT I test drove seemed well screwed together, with only excess tire noise intruding. I could hear the engine, but I actually like that (or even more of it, like the WRX's growl). Did the rattling XT's rattle right off the dealer's lot, or did they develop the rattles after a few miles?
You're right on with the torque addiction--the 5 speed was sweeeeet!
Here's my list:
1) drivers door - buzz comes and goes
2) rear tire area - seems to go away when I'm carrying something so I suspect its the foam material rubbing with no weight on it - makes a kind of squeak
3) plastic "flexing" sound roughly in center of dash - hard to describe but kind of a snapping / popping sound - really obnoxious, arrived with lower ambient temperatures i. e. below 50 deg.
4) what sounds like a harness buzz behind the drivers knee panel
It's already been at the dealers for the first two, neither of which the dealer could replicate
(big surprise).
Probably one of the best drive trains around for the price, but I would just as soon not have to crank up the tunes to compensate for poor build quality. The engine may be rocket science, but there's no excuse for these kind of squeaks/rattles/snapping/buzzing problems in a vehicle at this price point.
Especially when I know Subaru can get it right judging by the absolute quiet in my wife's OBW with 10.5 k on it.
Larry
Granted its where they add the options, if you catch them in time, but if you wonder about their installation quality I had the turbo gauge installed at my dealer - only took three trips to get it fixed so that it was aligned properly and didn't blow out the instrument light fuse.
Seems that the port installed options are better installed in general than the ones I've had done at the dealer - another example is the Subaru factory alarm option, commonly done at the dealers - on my 03 the module was just tossed in loose behind the dash, and not properly anchored - that would have required an extra 5 minutes and time is money after all. Also, unless there's two different kits, my 03 done at the dealer's never got the add-on horn that mounts on the strut tower. My XT done in RI does have it.
jack - by some chance you didn't get the security system did you? That module made exactly the noise you're describing - and the position is about right.
Larry
If I want to conserve fuel what should I do?
How about a smooth and quick acceleration?
Is boost dictated purely by RPM or does it also affected by the way you press the throttle (gradually or suddenly)?
I didn't order the security upgrade. The buzz seems to be higher than anything located down under the dash. I think it's coming from the passenger airbag cannister.
Boost has much more to do with throttle than with RPM. You can be cruising on the freeway at 3,000 to 3,500 RPM with just enough throttle to maintain speed, and the boost will be negative (below zero on the gauge). Nudge the throttle and the boost soars. Same goes for puttering at 2,000 RPM - light throttle, negative boost. Heavy throttle, the boost climbs.
At moderate speeds (20-45MPH) you'll be able to monitor the boost by listening for the rising or falling pitch of the turbo whine as you add or reduce throttle. At higher speeds (or if your radio is on) you won't be able to hear the turbo over the other sounds.
There is a $250 rebate on 2004 forestor, even in New England, but it's a dealer-only thing, it's up to them to give it to u or not. We are not supposed to know about it.
Break-in: thx for gr8 break-in tips, how long is it gonna take? I just can't wait to floor it.
extended warranty: $1380 Believe it, it's fully refundable when expired and not used. Sales rep mentioned at least 10 times when trying to sell me. It worked.
Make sure you remember to apply for that refund in a timely manner if you don't wind up using the extended warranty. No salesperson is going to be calling you ten times then to remind you :-)
Views on break-in vary widely. My XT was never floored, not even once, prior to reaching 2,000 miles. I never exceeded 3,000 RPMs during the first 1000 miles, and never exceeded 3,500 RPM during the second thousand.
If there's any consolation, most of the other cars I'm considering have their reports of rattles or other annoyances as well. And fuel mileage is surprisingly poor across the board for any "interesting" cars--worth the added cost for the super torque though!
Thanks for describing the rattles so well. Sounds like they can be fixed when found.
-juice
Subaru Community
I probably get better milage than most because of my unique driving conditions, dry thin air, most travel at 45 mph, and only having to stop about once per mile while in-town. Either that or there is something wrong with my calculator or my favorite gas pump.
Ken
You can also check out subaruwrxparts.com which sells Added Security too, I purchased my subaru 17in wheels from them as well as various other things. They don't show any zero deductible warranties on their website but I'll bet if you called them they will give you a price.
ANXIOUS TO HEAR YOUR COMMENTS AFTER PICKING UP YOUR XT ...
Larry
Mark
-Dave
Most dealers will sell a warranty online for the 40% off figure, as long as it's the 7/100 or close to it.
Having looked at subaru-warranty.com, the lack of information on the vendor (as opposed to the warranty itself) is something I find very interesting. Send in an application and we'll get back to you.
If I were Subaru, I'd be all over them--especially since they're using the logo.
I have gotten some excitement by flooring the gas pedal in 1st gear while turing left at intersections. I don't do that anymore in the XT.
I did drive to work this week on icy roads for the first time, no problem.
The torque, at least in the 5-speed, is not a problem as long as you use your head and don't get to excited with the gas pedal.
Ken
Got my new baby (I also have a 2 year old son) on Friday and LOVE IT! The ride is so smooth and it has taken real discipline on our part not to just gun it...You can tell the engine just wants to go. No rattles so far...
I just went to take a joy ride in it and my husband has it again! He loves it too.
This is our first Subaru and I am very impressed.
Thanks for all the comments on the board. You all helped me so much to be an educated consumer.
Just a recap: I got a 2004 XT AT Platinum Silver. I skipped the extended warranty stuff. My dealership has been great (unbelievable to say, given our past experiences with the haggle-haggle), and the finance guy did not even try to hard sell the warranty stuff when I told him I was not interested.
We are thrilled. No if my husband would get back, I want to take my baby for a drive!
Natalie.
I found some papers I had been writing on when researching the price of my ext warranty.The prices subaru-warranty are listing are identical to subaruwarranty.
While I haven't gone through the subaru-warranty.com website and filled out stuff, their MO seems the same as the subaruwarranty.com. If SOA is after them its no wonder they don't identify who they are.
I see no danger in sending them contact info and VIN number only and seeing if they are "genuine" by contacting you with genuine Subaru application materials.
I floored mine once in 1st, and will probably never do it again, straight line or otherwise. Thanks (!) to the gearing, you're at (or past) the redline in an eyeblink. It did nothing to change my opinion of the 4.44 gearing.
Ain't it the truth! Twice I've hit the rev limiter doing that and now never again. No wheel spin, just [b]LAUNCH![/b]
It's a real eye opener to say the least.
The Subaru boxer is laid out longitudinally rather than horizontally. Horizontal position allows the engine to be installed in the car sideways therefore saving room but doing so means the crankshaft and transmission aren't perfectly centered and unequal length driveshafts have to be used. This means one shaft gets more torque than the other thus causing torque steer.
Subaru eliminates this by using the compact boxer configuration in a longitudinal configuration. The engine itself is already harmonically balanced which helps with torque steer and vibration but the real advantage lies in the transmission sitting immediately behind it allowing equal length drive shafts. AWD also helps by distributing power to all four wheels. It's really quite simple but remarkably smooth in execution. I can't really think of a downside to it and surprised more manufacturers don't use this sort of configuration. Certainly saves on parts and manufacturing costs while providing all-around benefits. The H6 is even smoother and a wonderful engine its own right. Pity only Porsche and Subaru use this type of configuration.
P.S. I REALLY wish they would post some kind of instructions on how to add tags here. Seems standard HTML doesn't work and I didn't find anything on how to do it in the, "Town Hall Help" section. Grrrr
These past few posts talking about the instant-on power of the Forester XT in first gear are making me salivate. When I test drove the WRX I was counting the seconds before the car actually got up and moved. Don't want to have to aggressively launch to make a good 0-30 sprint!
-B
After speaking with a gentleman at Curry when I bought my warranty from them he indicated that it was just "too much of a hassle" to maintain the site. I'll bet SOA and the other dealers hassled him plenty. - BTW - he never said, or implied that - that's my own conclusion. He was great to deal with, gave me the best price I found anywhere, and regarding warranty authenticity its SOA that's billing my credit card, and mysubaru.com shows my warranty as gold.
Larry
Miamixt where did you get your info about this Minnehoma Auto company. I suppose they may be the reinsurers but Added Security is run by Subaru and dealers show Added Security vehicles on their computers automatically when they put your VIN in. Its not like some aftermarket system they have to call up about.
I sent a request to subaru-warranty on line, we'll see what response I get.
We don't permit a lot of html stuff in the posts, but the usual html formatting works for the stuff that is allowed (bold, italic, small, etc.)
<B>bold</B> for example.
Lots of tutorials use brackets ([) instead of angles (<) in their examples so the example won't be converted to html format. So just substitute [ for < when you run across those.
http://accessory.subaru.co.jp/forester/3d/index.html
Bob G
Natalie: I guess you had a REALLY Happy Halloween! Congrats!
-juice
